Results 1 to 4 of 4
Thread: delay of nanosecond Teensy ?
    Apr 2019
    5
    is it so possible to make a delay of nanosecond between a low and high state with a teensy 3.6 seen that its frequency 180 MHZ ?
    Jul 2020
    557
    I don't think the pin drivers can go that fast even if given a 500MHz signal... Typical external CMOS pins have rise- and fall- times of a few ns.
    For faster you need impedance matched LVDS or similar - this is into the microwave frequency domain, everything needs to be a transmission
    line.
    Apr 2019
    5
    experimentally with the microsecond delay function I can go down to 7 microseconds after remaining constant!
    23,423
    Here's a thread about fast I/O on Teensy 3.6 which might help. In particular, look for the info about disabling slew rate limiting (which normally you would want, as it greatly reduces high frequency noise & other undesirable effects).
    https://forum.pjrc.com/threads/41874...l=1#post132347
    And here is similar info for Teensy 4
    https://forum.pjrc.com/threads/57185...l=1#post212236
