Weird signal problems using cheap oscilloscope to look at OctoWS2811 adaptor
Hello!
I built a PCB which uses WS2812b LEDs and the Teensy 4.0 and I was having some small signal issues with LEDs randomly flashing random colors every once in a while.
To investigate I used a cheap Oscilloscope I have to measure the signal, and got this crazy result in the photo. I then checked it directly on the Octo Adaptor and got the same result. Do you think this is a problem of to inferior an oscilloscope? What is going on here? Thank you!
You haven't said what the 'scope actually is - so how can we tell?
You don't have a x10 probe, which means the 'scope may interfere with logic signals through the capacitance and signal reflections.
it is a DSO138
200kHz analog bandwidth, possibly with some aliasing - not idea for looking at a high speed logic signal I'm afraid.
For signal integrity of a logic signal something more like 100 to 200MHz bandwidth is good, as reflections down
a few metres of cable happen in timescales of nanoseconds.
What happens if you change the time per division?
It looks like you are getting some aliasing of the signal, as MarkT suggested.
