Wolfson WM8960 DAC
Saibot
I fiddled around with a Wolfson WM8960 DAC until I got it sort of working with a Teensy 3.6 and 4.1 as Audio USB to i2s output passthrough for playing music from a (windows) pc
The code that I mangled use 16 bit and 48kHz - it is from Cirrus Logic for use with an STM32
I need to get it down to 44.1kHz but I cannot figure out a relatively simple setting for the R4 (04h) register Clocking
It seems as if I have to switch froma MCLK derived sustem clock to one that use the PLL?
Am I correct in this?
Any pointers will be appreciated (page 69 in the data sheet for Reg04 Clocking attached next post)
Also code use 25MHz/512 but from schematic use a 24MHz crustal
Therefore need divide by 544(.22) can I use integer PLL page 81 instead of fractional 24bit divide?
Fraction is 0.0018382
Is it accurate enough?
Wolfson docs
https://www.cirrus.com/products/wm8960/
Waveshare DAC
https://www.waveshare.com/wm8960-audio-hat.htm
I attach my code which plays - although it sometimes need a few tries
// i2c_scanner
// http://playground.arduino.cc/Main/I2cScanner
//       WM8960-DAC      Teensy 4      Teensy 3.6       Audioboard 3
//  1,2  VCC      Red    3V3 *         3V3
//  3,4  GND    Brown    GND *         GND (not AGnd)
//  5,6  SDA     Gray    18 SDA0 *     18 SDA0         18 SDA
//  7,8  SCL   Orange    19 SCL0 *     19 SCL0         19 SCL
//  9,10 CLK     Blue    21 BCLK1 *     9 BCK           9 BCLK
// 11,12 WS     White    20 LRCLK1 *  23 LRCK          23 LRCLK   I2S Frame clock input
// 13    RXSDA   Green    7 OUT1A *    22 TX           22 TX      I2S Data output
// 14    TXSDA    Blue                  22 TX            13 RX      I2S Data input
// 15    RXMCLK                                                   I2S System Clock(Sending)
// 16    TXMCLK                                                    I2SSystem Clock(Receive)
// WM8960_ADDRESS = 0x1a
// MCLK signal transmitted (TX MCLK RX) MCLK signal transmitted
// * = usb audio working
//                                                      11 MCLK
//                                                       7 MOSI
//                                                      12 MISO
//                                                      14 SCLK
//                                                    6,10 CS
// See this post for other type of pcm5102 board
// https://forum.pjrc.com/threads/53069-Teensy-with-PCM5102a-Module-via-I2S
// PCM5102A Teensy 3.6
// VCC   = Vin
// 3.3v  = NC
// GND   = GND
// FLT   = GND
// SCL   = GND (also works connected to 11 /MCL)
// BCK   = BCK (9)
// DIN   = TX (22)
// LCK   = LCRLK (23)
// FMT   = GND
// XMT   = 3.3V (HIGH)
// Set Tools -> USB Audio
int led = LED_BUILTIN;
#define WM8960_ADDRESS  0x1A
//register values
static uint16_t WM8960_REG_VAL[56] =
  0x0097, 0x0097, 0x0000, 0x0000, 0x0000, 0x0008, 0x0000, 0x000A,
  0x01C0, 0x0000, 0x00FF, 0x00FF, 0x0000, 0x0000, 0x0000, 0x0000,
  0x0000, 0x007B, 0x0100, 0x0032, 0x0000, 0x00C3, 0x00C3, 0x01C0,
  0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
  0x0100, 0x0100, 0x0050, 0x0050, 0x0050, 0x0050, 0x0000, 0x0000,
  0x0000, 0x0000, 0x0040, 0x0000, 0x0000, 0x0050, 0x0050, 0x0000,
  0x0000, 0x0037, 0x004D, 0x0080, 0x0008, 0x0031, 0x0026, 0x00ED
AudioInputUSB            usb1;           //xy=121,162
AudioOutputI2S           i2s1;           //xy=559,166
AudioConnection          patchCord1(usb1, 0, i2s1, 0);
AudioConnection          patchCord2(usb1, 1, i2s1, 1);
 int delay1 = 10;
 int delay2 = 500;
// i2c master first send an address frame for searching slave and setting communication mode.
// High 7 bits = address, followed a control bit and finally the response signal
// Slave device receives the response signal, it will return a response to master device.
// Then master device could begin to send data to slave device, which is 8 bits and the high 7 bits are
// address and the lowest one is response signal. MSB first.
// Registers of WM8960 are 9-bit. Thus, when we send data to it,
// should split data to two bytes and add the ID of register to recognized before
// transmitting. The ID of register flagged by 7-bit.
// Byte0 = bit7 to bit1 = device address, bit0 = read/write
// Byte1 = bit7 to bit1 = register number 0-57, bit0 = MSB bit8 of register value
// Byte2 =                                                 bit7-bit0 register value
// WM89060 Write RegisterNumber = Value
uint8_t WM8960_Write_Reg(uint8_t reg, uint16_t dat)
  uint8_t res,I2C_Data[2];
  I2C_Data[0] = (reg<<1)|((uint8_t)((dat>>8)&0x0001));  //RegAddr
  I2C_Data[1] = (uint8_t)(dat&0x00FF);                  //RegValue
  //digitalWrite(led, HIGH);                              // briefly flash the LED
  Wire.beginTransmission(WM8960_ADDRESS);  // transmit to device lsb=0 => write
  //Wire.write(I2C_Data[0]);                  // buffer 1 byte reg1 in b7-b1
  //Wire.write(I2C_Data[1]);                  // buffer 1 byte lsb of val1
  Wire.write(I2C_Data, 2);                    // buffer 1 byte lsb of val1
  res = Wire.endTransmission();               // transmit buffer and then stop
  if(res == 0) { WM8960_REG_VAL[reg] = dat;
                 //digitalWrite(led, LOW);
  return res;
// WM89060 Inititialise
uint8_t WM89060_Init(void)  {
  uint8_t res;
  // Reset Device 0x0f, 0x0000
  // #define WM8960_RESET    0xf
  // reg<<1 register now in bit7-bit1
  // msb=b8 (ninth bit) of val now in bit0
  // uint8_t  reg1 = ((reg << 1) |(uint8_t)((val >> 8) & 1))
  // val = lsb b7-b0 val and with val msb b15-b18 all = 0
  res = WM8960_Write_Reg(0x0f, 0x0000);
  //if (res == 0) Serial.println("WM8960 reset completed"); else return res;
  delay(delay1);
  // Set Power Source
  // #define WM8960_POWER1  0x19
  // #define WM8960_POWER2  0x1a
  // #define WM8960_ADDCTL3 0x1b **************
  // #define WM8960_POWER3  0x2f
  res =  WM8960_Write_Reg(0x19, 1<<8 | 1<<7 | 1<<6);
  delayMicroseconds(delay2);
  res += WM8960_Write_Reg(0x1A, 1<<8 | 1<<7 | 1<<6 | 1<<5 | 1<<4 | 1<<3);
  res += WM8960_Write_Reg(0x2F, 1<<3 | 1<<2);
  //if (res == 0) Serial.println("WM8960 power 1,2,3 completed"); else return res;
  delay(delay1);
  // Configure clock
  // MCLK->div1->SYSCLK->DAC/ADC sample Freq = 25MHz(MCLK)/2*256 = 48.8kHz
  res = WM8960_Write_Reg(0x04, 0x0000);
  //if (res == 0) Serial.println("WM8960 Configure clock"); else return res;
  delay(delay1);
  // Configure ADC/DAC
  res = WM8960_Write_Reg(0x05, 0x0000);
  //if (res == 0) Serial.println("WM8960 Configure ADC/DAC"); else return res;
  delay(delay1);
  // Configure audio interface
  // I2S format 16 bits word length
  res = WM8960_Write_Reg(0x07, 0x0002);
  //if (res == 0) Serial.println("WM8960 Configure audio interface"); else return res;
  delay(delay1);
  // Configure HP_L and HP_R OUTPUTS
  res =  WM8960_Write_Reg(0x02, 0x006F | 0x0100);  //LOUT1 Volume Set
  res += WM8960_Write_Reg(0x03, 0x006F | 0x0100);  //ROUT1 Volume Set
  //if (res == 0) Serial.println("WM8960 Configure HP_L and HP_R OUTPUTS"); else return res;
  delay(delay1);
  // Configure SPK_RP and SPK_RN
  res =  WM8960_Write_Reg(0x28, 0x007F | 0x0100); //Left Speaker Volume
  res += WM8960_Write_Reg(0x29, 0x007F | 0x0100); //Right Speaker Volume
  //if (res == 0) Serial.println("WM8960 Configure SPK_RP and SPK_RN"); else return res;
  delay(delay1);
  // Enable the OUTPUTS
  res = WM8960_Write_Reg(0x31, 0x00F7); //Enable Class D Speaker Outputs
  //if (res == 0) Serial.println("WM8960 Enable Class D Speaker Outputs"); else return res;
  delay(delay1);
  // Configure DAC volume
  res =  WM8960_Write_Reg(0x0a, 0x00FF | 0x0100);
  res += WM8960_Write_Reg(0x0b, 0x00FF | 0x0100);
  //if (res == 0) Serial.println("WM8960 Configure DAC volume"); else return res;
  delay(delay1);
  // 3D
  // WM8960_Write_Reg(0x10, 0x001F);
  // Configure MIXER
  res =  WM8960_Write_Reg(0x22, 1<<8 | 1<<7);
  res += WM8960_Write_Reg(0x25, 1<<8 | 1<<7);
  //if (res == 0) Serial.println("WM8960 Configure MIXER"); else return res;
  delay(delay1);
  // Jack Detect
  res =  WM8960_Write_Reg(0x18, 1<<6 | 0<<5);
  res += WM8960_Write_Reg(0x17, 0x01C3);
  res += WM8960_Write_Reg(0x30, 0x0009); //0x000D,0x0005
  //if (res == 0) Serial.println("WM8960 Jack Detect"); else return res;
  delay(delay1);
  return 0;
// Setup
  uint8_t res;
  pinMode(led, OUTPUT);
  AudioMemory(12);
  // uncomment these to use alternate pins
  //Wire.setSCL(16);
  //Wire.setSDA(17);
  Wire.begin();           // join i2c bus (address optional for master)
  //Serial.begin(9600);
  //while (!Serial);        // Leonardo: wait for serial monitor
  //Serial.println(F("\nI2C Scanner"));
  res = WM89060_Init();
  //if (res != 0) Serial.println(res);
// Main
  delay(100);           // wait 5 seconds for next scan
ok sorry formula is on page 60 PLLK = int (2^24 (R-PLLN)) and examples in table 44
44,10kHz
f2 = 4 x 2 x 11.2896Hz = 90.3168MHz
R = 90.316 / 12 = 7.5264
PLLN = int R = 7
k = int ( 2^24 x (7.5264 – 7)) = 8831526
So why do these changes not work?
// Configure clock
  // MCLK->div1->SYSCLK->DAC/ADC sample Freq = 24MHz(MCLK)/2*256 = 46.875kHz
  res = WM8960_Write_Reg(0x04, 0x0001); // Select PLL
  delay(delay1);
  // Configure PLL 1  0011 0111 = 37h
  res = WM8960_Write_Reg(0x34, 0x0037); // Select PLL 1
  delay(delay1);
  // Configure PLL 2  bit 8 reserved 7-0 data
  res = WM8960_Write_Reg(0x35, 0x0086); // Select PLL 2
  delay(delay1);
  // Configure PLL 3
  res = WM8960_Write_Reg(0x36, 0x00C2); // Select PLL 3
  delay(delay1);
  // Configure PLL 4
  res = WM8960_Write_Reg(0x37, 0x0026); // Select PLL 4
  delay(delay1);
@Saibot
Funny I have a couple of those sitting around somewhere but never did anything with them. You are making me want to pull them out. Interesting to see what your final code looks like to play a file :)
@Saibot
Yes I started with the Raspberry Pi hat versions:
Oops this is link for first post general DAC
https://www.waveshare.com/wm8960-audio-board.htm
And they sounded very good with h/phones
Could not find any Arduino code and the Linux drivers are complicated
But anyway it is Friday night and time for a Red Heart and Coke Zero..
Found the bug must be switched on
PLL R26 (1Ah)
Power
management (2)
0 PLLEN 0 PLL Enable
0 = PLL off
1 = PLL on
  // 1111 1100 b0 =1 PLL on
  res += WM8960_Write_Reg(0x1A, 1<<8 | 1<<7 | 1<<6 | 1<<5 | 1<<4 | 1<<3 | 1);
All done
Final code and Teensy 4.0 also tested
// GPL3 license Aug 2020
// Based on Wolfson WM8960 STM32 demo code from Waveshare
// Demo code BSD license from STMicroelectronics
//       WM8960-DAC      Teensy 4.1    Teensy 3.6       Audioboard 3
// 14    TXSDA    Blue                 13 RX           13 RX      I2S Data input
//                                                      11 MCLK
//                                                       7 MOSI
//                                                      12 MISO
//                                                      14 SCLK
//                                                    6,10 CS
//register values
 int delay1 = 10;
 int delay2 = 500;
  return res;
  uint8_t res;
  delay(delay1);
  // Set Power Source
  delay(delay1);
  // Configure clock
  // MCLK->PLL->SYSCLK->DAC/ADC sample Freq = 24MHz/544.217 = 44.100kHz
  // See calculation pages 60 and table 44 in manual
  // f2 = 4 x 2 x 11.2896Hz = 90.3168MHz
  // R = 90.316 / 12 = 7.5264
  // PLLN = int R = 7
  // k = int ( 2^24 x (7.5264 – 7)) = 8831526
  // N = 7
  // Fractional 24bit value = 86C226h
  delay(delay1);
  //                 00010 0111   27h
  res = WM8960_Write_Reg(0x34, 0x0027); // Select PLL 1
  delay(delay1);
  delay(delay1);
  // Configure PLL 3
  delay(delay1);
  // Configure PLL 4
  delay(delay1);
  delay(delay1);
  delay(delay1);
  delay(delay1);
  delay(delay1);
  delay(delay1);
  delay(delay1);
  // 3D
  // Configure MIXER
  delay(delay1);
  // Jack Detect
  delay(delay1);
  return 0;
// Setup
  uint8_t res;
  AudioMemory(12);
// Main
The WM8960 is a 24bit codec, I would like to connect the pi hat to the Teensy4.0 replacing the Audioshield codec; the FW for convolution uses the AudioShield and works with 16bit resolution...is there a solution working at 24bits ?
Thanks and best regards
