Results 1 to 7 of 7
Thread: Audio Effect Delay Pops & Clicks when changing tap times
    Aug 2015
    Scotland
    142
    Hi
    I'm using the AudioEffectDelay with a Teensy4 and AudioBoard.
    When I change tap times I get pops and clicks. I'm changing a few tap time together (like changing between different presets if that makes sense).
    Question is whether this is as expected and if so are there any approaches to minimise the noise?
    I've attached some simple code that switches between two sets of tap delay times (it expects some audio input through the audioboard).
    Any advice appreciated, Cheers Paul
    #include <SerialFlash.h>
    AudioInputI2S i2s1;       // xy=206,94
    AudioMixer4 mixer1;       // xy=523,76
    AudioEffectDelay delay1;  // xy=538,236
    AudioMixer4 mixer2;       // xy=766,197
    AudioOutputI2S i2s2;      // xy=1099,196
    AudioConnection patchCord1(i2s1, 0, mixer1, 0);
    AudioConnection patchCord2(i2s1, 1, mixer1, 1);
    AudioConnection patchCord3(mixer1, delay1);
    AudioConnection patchCord4(mixer1, 0, mixer2, 2);
    AudioConnection patchCord5(delay1, 0, mixer2, 0);
    AudioConnection patchCord6(delay1, 1, mixer2, 1);
    AudioConnection patchCord7(delay1, 2, mixer1, 2);
    AudioConnection patchCord8(mixer2, 0, i2s2, 0);
    AudioConnection patchCord9(mixer2, 0, i2s2, 1);
    AudioControlSGTL5000 codec;  // xy=377,390
    void setup(void) {
      AudioMemory(150 * (128 / AUDIO_BLOCK_SAMPLES));
      codec.enable();
      codec.volume(0.5);
      mixer1.gain(0, 0.7);
      mixer1.gain(1, 0.7);
      mixer1.gain(2, 0.5);
      mixer1.gain(3, 0.0);
    void loop(void) {
      Serial.println("Delay 1");
      delay1.delay(0, 50);
      delay1.delay(1, 75);
      delay1.delay(2, 400);
      delay(2000);
      Serial.println("Delay 2");
      delay1.delay(0, 150);
      delay1.delay(1, 250);
      delay(2000);
    Jul 2020
    581
    Quote Originally Posted by houtson View Post
    Hi
    Yes, its completely expected as you are making discontinuous changes to a signal on the fly.
    One approach often used is to switch on a zero-crossing, but the Audio lib processes in blocks so there's no
    easy way to do this, and it won't work for several taps at once as the zero crossings happen at different
    times.
    Using linear interpolation between old and new taps might work, so you'd need two sets of taps, and fade between them in
    a few ms.
    Aug 2015
    Scotland
    142
    Hi Mark,
    I thought that might the be the expected behaviour, thanks for confirming and your suggestion - I'll have a go at your second suggestion (cross fading two sets of taps)
    cheers, Paul
    Aug 2015
    Scotland
    142
    Thanks again MarkT for the ideas, I made a new delay object to get round the clicks and pops when you change delay times dynamically.
    It seems to work well letting me adjust multiple taps. It's not the most efficient code but works for my situation.
    A few details:
    - the new object works sample by sample rather than by block, fading between old and new delay times per tap to avoid clicks and pops
    - it's less efficient than the standard block based effect but easier to work with
    - it doesn't use the AudioMemory for the delay line, you need to pass it a basic array. this means it won't re-size if you don't use the full delay
    - it's multi-tap with 10 independent taps
    - when you want to change delay time you call delayfade(uint8_t channel, float milliseconds, float transition_time); transition time is the time to fade in millis.
    - it's a good basis for other tape delay type effects
    if anyone is looking for something similar let me know and I'll post the code and an example
    cheers, Paul
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    151
    I'd be interested in trying this, thanks in advance for your effort
    Aug 2015
    Scotland
    142
    Hi ETMoody3
    I've pasted below:
    - example file (just like the first one in this post that changes a few taps over and over)
    - effect_tapedelay10tap.h which is the header file for the effect object
    - effect_tapedelay10tap.cpp which is the main file for the effect object
    I'm not a coder so any suggestions welcome - it uses a bit of float math for the fade which I'm sure could be optimised for integers. I've been using a Teensy 4.
    Hopefully straight forward, any feedback or questions welcome.
    Cheers Paul
    example.ino
    #include "effect_tapedelay10tap.h"
    AudioEffectTapeDelay10tap delay1;  // xy=538,236
    #define DELAY_MAX_LEN 22050  // buffer for samples @44100 samples per second, 22050 = 0.5s
    int16_t sample_delay_line[DELAY_MAX_LEN] = {};
    void setup(void) {
      codec.enable();
      codec.volume(0.5);
      // initialise the delayline
      delay1.begin(sample_delay_line, DELAY_MAX_LEN);
    void loop(void) {
      delay1.delayfade(0, 6, 3.0);  // (tap_number 0-9, millis of delay, milliseconds to tranistion from old to new time)
      delay1.delayfade(1, 12, 3.0);
      delay1.delayfade(2, 18, 3.0);
      delay(2000);
      delay1.delayfade(0, 150, 3.0);
      delay1.delayfade(1, 250, 3.0);
      delay1.delayfade(2, 350, 3.0);
      delay(2000);
    /* Audio Library for Teensy 3.X
     * Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
     * Development of this audio library was funded by PJRC.COM, LLC by sales of
     * Teensy and Audio Adaptor boards.  Please support PJRC's efforts to develop
     * open source software by purchasing Teensy or other PJRC products.
     * THE SOFTWARE.
     * Modified to extend to 10 taps PMF 16-03-2020
     * Modified for single samples delay line (rather than blocks) and tape delay like behaviour PMF 02-09-2020
     * added delayfade to fade between old and new delay time PMF 04-09-2020
    #ifndef effect_tapedelay10tap_h_
    #define effect_tapedelay10tap_h_
    #include "Arduino.h"
    #include "AudioStream.h"
    #define DELAY_NUM_TAPS 10  // max numer of taps / channels
    class AudioEffectTapeDelay10tap : public AudioStream {
     public:
      AudioEffectTapeDelay10tap(void) : AudioStream(1, inputQueueArray) {}
      // initialise the delay line
      void begin(int16_t *delay_line, uint32_t max_delay_length);
      // activate a tap and/or change time with a fade between old and new time (no clicks), transition time in millis
      uint32_t delayfade(uint8_t channel, float milliseconds, float transition_time);
      // disable a tap
      void disable(uint8_t channel);
      // main update routine
      virtual void update(void);
     private:
      uint32_t delay_samples[DELAY_NUM_TAPS];          // actual # of sample delay for each channel
      uint32_t desired_delay_samples[DELAY_NUM_TAPS];  // desired # of sample delay for each channel
      int16_t fade_length_samples[DELAY_NUM_TAPS];     // how long to fade in samples
      int16_t fade_count[DELAY_NUM_TAPS];              // count down for fades
      uint32_t max_delay_length_samples;               // lenght of the delay line in samples
      uint32_t write_index;                            // write head position
      uint16_t activemask;                             // which taps/channels are active
      int16_t *sample_delay_line;                      // pointer to delay line
     * THE SOFTWARE.
    #include <Arduino.h>
    void AudioEffectTapeDelay10tap::begin(int16_t *delay_line, uint32_t max_delay_length) {
      sample_delay_line = delay_line;
      max_delay_length_samples = max_delay_length - 1;
      write_index = 0;
    uint32_t AudioEffectTapeDelay10tap::delayfade(uint8_t channel, float milliseconds, float transition_time) {
      if (channel >= DELAY_NUM_TAPS) return 0;
      if (milliseconds < 0.0) {
        milliseconds = 0.0;
      if (transition_time < 0.0) transition_time = 0.0;
      uint32_t delay_length_samples = (milliseconds * (AUDIO_SAMPLE_RATE_EXACT / 1000.0)) + 0.5;
      if (delay_length_samples > max_delay_length_samples) delay_length_samples = max_delay_length_samples;
      fade_length_samples[channel] = fade_count[channel] = (transition_time * (AUDIO_SAMPLE_RATE_EXACT / 1000.0)) + 0.5;
      // enable disabled channel
      if (!(activemask & (1 << channel))) {
        desired_delay_samples[channel] = delay_samples[channel] = delay_length_samples;
        fade_count[channel] = 0;
        activemask |= (1 << channel);
        desired_delay_samples[channel] = delay_length_samples;
      return delay_samples[channel];
    void AudioEffectTapeDelay10tap::disable(uint8_t channel) {
      if (channel >= DELAY_NUM_TAPS) return;
      // disable this channel
      activemask &= ~(1 << channel);
    void AudioEffectTapeDelay10tap::update(void) {
      audio_block_t *input, *output;
      int16_t *input_data_pointer, *output_data_pointer;
      uint32_t read_index, desired_read_index, start_index;
      uint8_t channel;
      float fade_multiplier;
      if (sample_delay_line == NULL) return;
      // grab a copy of the write_index starting poisition
      start_index = write_index;
      // write incoming block of samples to buffer
      input = receiveReadOnly();
      if (input) {
        input_data_pointer = input->data;
        for (int i = 0; i < AUDIO_BLOCK_SAMPLES; i++) {
          sample_delay_line[write_index++] = *input_data_pointer++;
          if (write_index >= max_delay_length_samples) write_index = 0;
        release(input);
      // process each tap and write out delayed samples
      for (channel = 0; channel < DELAY_NUM_TAPS; channel++) {
        // check if channel is active
        if (!(activemask & (1 << channel))) continue;
        output = allocate();
        if (!output) continue;
        output_data_pointer = output->data;
        // position the read head for this channel / tap
        read_index = ((start_index - delay_samples[channel] + max_delay_length_samples) % max_delay_length_samples);
        // if fading between current delay to desired , position desired read head
        if (fade_count[channel] > 0) desired_read_index = ((start_index - desired_delay_samples[channel] + max_delay_length_samples) % max_delay_length_samples);
          // if fading, cross mix in fade_length_samples steps
          if (fade_count[channel] > 0) {
            // calculate a multipier for the fade
            fade_multiplier = (float)fade_count[channel] / fade_length_samples[channel];
            // read the two points from the delay line, crossfade and send to the output block
            *output_data_pointer++ =
                (int16_t)(sample_delay_line[read_index] * fade_multiplier) + (int16_t)(sample_delay_line[desired_read_index] * (1 - fade_multiplier));
            fade_count[channel]--;
            if (fade_count[channel] == 0) {
              delay_samples[channel] = desired_delay_samples[channel];
              read_index = desired_read_index;
            // increment and wrap around the desired_read_index
            desired_read_index++;
            if (desired_read_index >= max_delay_length_samples) desired_read_index = 0;
            // read delay line and send sample to the output block
            *output_data_pointer++ = sample_delay_line[read_index];
          // increment and wrap around the main read index
          read_index++;
          if (read_index >= max_delay_length_samples) read_index = 0;
        transmit(output, channel);
        release(output);
    Mar 2014
    New Ulm, Mn
    151
    Nice.
    I just put the delay array in external PSRAM on a Teensy4.1.
    EXTMEM int16_t sample_delay_line[DELAY_MAX_LEN] = {};
    Useful.
    Thank you
