Results 1 to 12 of 12
Thread: MIDI device stops working when connected through hub (using USBHost_t36 library)
    My MG-300 guitar processor works fine when connected directly to the USB host port of a Teensy 3.6. But stops responding after a couple of messages when it is connected through a hub.
    This hub works fine when I connect the MG-300 to a mac or PC. Also this hub works fine with the USB host port when I connect other devices.
    Here is my test sketch:
    #include <USBHost_t36.h>
    #define NUMBER_OF_USB_HOST_MIDI_PORTS 8
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    USBHub hub3(myusb);
    USBHub hub4(myusb);
    MIDIDevice_BigBuffer usbhMIDI01(myusb); // With bigbuffer, newer Roland devices are working properly!
    MIDIDevice_BigBuffer usbhMIDI02(myusb);
    MIDIDevice_BigBuffer usbhMIDI03(myusb);
    MIDIDevice_BigBuffer usbhMIDI04(myusb);
    MIDIDevice_BigBuffer usbhMIDI05(myusb);
    MIDIDevice_BigBuffer usbhMIDI06(myusb);
    MIDIDevice_BigBuffer usbhMIDI07(myusb);
    MIDIDevice_BigBuffer usbhMIDI08(myusb);
    MIDIDevice_BigBuffer * usbhMIDI[NUMBER_OF_USB_HOST_MIDI_PORTS] = {
      &usbhMIDI01, &usbhMIDI02, &usbhMIDI03, &usbhMIDI04, &usbhMIDI05, &usbhMIDI06, &usbhMIDI07, &usbhMIDI08
    const uint32_t TIME = 500; // time between identity request messages
    uint32_t timer = millis() + TIME;
    uint8_t PC = 0;
      myusb.begin();
      myusb.Task();
      if (millis() > timer) {
        send_alternative_PC_message(PC);
        if (PC++ > 9) PC = 0;
    void send_alternative_PC_message(uint8_t program) {
      for (uint8_t p = 0; p < NUMBER_OF_USB_HOST_MIDI_PORTS; p++) {
        usbhMIDI[p]->sendControlChange(60, program, 0);
      Serial.println("Sending CC#60 " + String(program));
    So this code sends MIDI CC messages to which the MG-300 changes patch.
    When the MG-300 is connected through a hub, the program will hang and the serial monitor will stop showing data:
    Sending CC#60 0
    Sending CC#60 1
    Sending CC#60 2
    Sending CC#60 3
    Sending CC#60 4
    This is what the debugging in the USBHost_library shows by uncommenting #define USBHOST_PRINT_DEBUG:
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 5
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 1FFFC000
    periodictable = 1FFFC000
    Sending CC#60 0
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 09 00 01 40 E3 05 08 06 98 32 00 01 00 01
        VendorID = 05E3, ProductID = 0608, Version = 3298
        Class/Subclass/Protocol = 9(Hub) / 0 / 1(Single-TT)
        Number of Configurations = 1
    enumeration:
    enumeration:
    Product: USB2.0 Hub
    enumeration:
    Config data length = 25
    enumeration:
    Configuration Descriptor:
      09 02 19 00 01 01 00 E0 32
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 01 09 00 00 00
        Interface = 0
        Number of endpoints = 1
        Class/Subclass/Protocol = 9(Hub) / 0 / 0
      07 05 81 03 01 00 0C
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 1
        Polling Interval = 12
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF6860
    found possible interface, altsetting=0
    number of interfaces found = 1
    USBHub control callback
    09 29 04 E0 00 32 64 00 FF 00 00 00 00 00 00 00
    Hub ports = 4
    power turned on to all ports
    device addr = 1
    new_Pipe
    allocate_interrupt_pipe_bandwidth
      ep interval = 12
      interval = 256
     best_bandwidth = 2, at offset = 0
    pipe cap1 = F0012101
    HUB Callback (member)
    status = 4
    getstatus, port = 2
    01 01 01 00
    New Port Status
      status=10101  port=2
      state=0
      Device is present:
      Has Power
    Port Status Cleared, port=2
    timer event (19999 us): Debounce Timer, this = 1FFF6860, timer = 1FFF6B78
    ports in use bitmask = 4
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=2
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=3
      Device is present:
      Has Power
    timer event (20000 us): Debounce Timer, this = 1FFF6860, timer = 1FFF6B78
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=4
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=5
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    unhandled setup, message = 40323
    ports in use bitmask = 0
    status = 4
    getstatus, port = 2
    03 05 10 00
    New Port Status
      status=100503  port=2
      state=7
      Device is present:
      Enabled, speed = 480 Mbit/sec
      Has Power
    unhandled setup, message = 140123
    timer event (25000 us): Hello, I'm resettimer, this = 1FFF6860, timer = 1FFF6B94
    port_doing_reset = 2
    PORT_RECOVERY
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 EF 02 01 40 C9 1F 60 82 00 01 01 02 03 01
        VendorID = 1FC9, ProductID = 8260, Version = 0100
        Class/Subclass/Protocol = 239 / 2 / 1
    enumeration:
    enumeration:
    Manufacturer: NUX
    enumeration:
    Product: NUX MG-300 AUDIO
    enumeration:
    Serial Number: 2008101346
    enumeration:
    Config data length = 318
    enumeration:
      09 02 3E 01 04 01 00 C0 01
        NumInterfaces = 4
      08 0B 00 03 01 00 20 00
        Interface Association = 0 through 2
        Class / Subclass / Protocol = 1 / 0 / 0
      09 04 00 00 00 01 01 20 00
        Interface = 0
        Number of endpoints = 0
        Class/Subclass/Protocol = 1 / 1 / 32
      09 24 01 00 02 08 65 00 00
      08 24 0A 29 03 07 00 00
      08 24 0B 28 01 29 03 00
      11 24 02 02 01 01 00 28 02 00 00 00 00 00 00 00 00
      12 24 06 0A 02 0F 00 00 00 0F 00 00 00 0F 00 00 00 00
      0C 24 03 14 01 03 00 0A 28 00 00 00
      11 24 02 01 01 02 00 28 02 00 00 00 00 00 00 00 00
      0C 24 03 16 01 01 00 02 28 00 00 00
      09 04 01 00 00 01 02 20 00
        Interface = 1
        Class/Subclass/Protocol = 1 / 2 / 32
      09 04 01 01 02 01 02 20 00
        Interface = 1
        Number of endpoints = 2
      10 24 01 02 00 01 01 00 00 00 02 00 00 00 00 00
      06 24 02 01 04 18
      07 05 01 05 58 02 04
        Endpoint = 1 OUT
        Type = Isochronous
        Max Size = 600
        Polling Interval = 4
      08 25 01 00 00 00 00 00
      07 05 81 11 04 00 04
        Endpoint = 1 IN
        Type = Isochronous
        Max Size = 4
      09 04 02 00 00 01 02 20 00
        Interface = 2
      09 04 02 01 01 01 02 20 00
        Interface = 2
      10 24 01 16 00 01 01 00 00 00 02 00 00 00 00 00
      06 24 02 01 04 18
      07 05 82 05 58 02 04
        Endpoint = 2 IN
        Type = Isochronous
        Max Size = 600
      09 04 03 00 02 01 03 00 04
        Interface = 3
        Class/Subclass/Protocol = 1 / 3 / 0
      07 24 01 00 01 41 00
      06 24 02 01 01 00
      06 24 02 02 02 00
      09 24 03 01 03 01 02 01 00
      09 24 03 02 04 01 01 01 00
      09 05 04 02 00 01 00 00 00
        Endpoint = 4 OUT
        Type = Bulk
        Max Size = 256
        Polling Interval = 0
      05 25 01 01 01
      09 05 83 02 00 01 00 00 00
        Endpoint = 3 IN
        Type = Bulk
        Max Size = 256
      05 25 01 01 03
    enumeration:
    USBHub claim_device this=1FFF6C20
    USBHub claim_device this=1FFF6FE0
    USBHub claim_device this=1FFF5380
    Descriptor 11 = IAD
    Descriptor 4 = INTERFACE
    MIDIDevice claim this=1FFF73C0
    len = 301
      Interface is unknown (might be Yahama)
    type: 36, len: 9
        MIDI Header (ignored)
    type: 36, len: 8
        Unknown MIDI CS_INTERFACE descriptor!
    MIDIDevice claim this=1FFF84E0
    len = 301
    type: 36, len: 9
    type: 36, len: 8
    MIDIDevice claim this=1FFF9600
    len = 301
    type: 36, len: 9
    type: 36, len: 8
    MIDIDevice claim this=1FFFA720
    len = 301
    type: 36, len: 9
    type: 36, len: 8
    MIDIDevice claim this=1FFF5740
    len = 301
    type: 36, len: 9
    type: 36, len: 8
    MIDIDevice claim this=1FFF2020
    len = 301
    type: 36, len: 9
    type: 36, len: 8
    MIDIDevice claim this=1FFF3140
    len = 301
    type: 36, len: 9
    type: 36, len: 8
    MIDIDevice claim this=1FFF4260
    len = 301
    type: 36, len: 9
    type: 36, len: 8
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    len = 191
    type: 4, len: 9
    This interface is not MIDI
    len = 191
    type: 4, len: 9
    len = 191
    type: 4, len: 9
    len = 191
    type: 4, len: 9
    len = 191
    type: 4, len: 9
    len = 191
    type: 4, len: 9
    len = 191
    type: 4, len: 9
    len = 191
    type: 4, len: 9
    len = 182
    type: 36, len: 16
    type: 36, len: 6
        MIDI IN Jack (ignored)
    type: 5, len: 7
    len = 182
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 182
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 182
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 182
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 182
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 182
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 182
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 5 = ENDPOINT
    Descriptor 37 =  ???
    len = 129
    type: 4, len: 9
    len = 129
    type: 4, len: 9
    len = 129
    type: 4, len: 9
    len = 129
    type: 4, len: 9
    len = 129
    type: 4, len: 9
    len = 129
    type: 4, len: 9
    len = 129
    type: 4, len: 9
    len = 129
    type: 4, len: 9
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    len = 120
    type: 36, len: 16
    type: 36, len: 6
    type: 5, len: 7
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    len = 74
      Interface is MIDI
    type: 36, len: 7
    type: 36, len: 6
    type: 36, len: 6
    type: 36, len: 9
        MIDI OUT Jack (ignored)
    type: 36, len: 9
    type: 5, len: 9
        MIDI Endpoint: 4
          tx_size = 256
    type: 37, len: 5
        MIDI Endpoint Jack Association (ignored)
    type: 5, len: 9
        MIDI Endpoint: 83
          rx_size = 256
    type: 37, len: 5
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    Descriptor 37 =  ???
    Sending CC#60 1
    MIDIDevice transmit complete
      MIDI Data: 0B BF 3C 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    MIDIDevice Receive
      MIDI Data: 0B B0 49 00
    avail = 398
    queue another receive packet
    Sending CC#60 2
      MIDI Data: 0B BF 3C 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Sending CC#60 3
    Sending CC#60 4
    Who can help me?
    I added the following lines to the top of void MIDIDeviceBase::write_packed(uint32_t data) in midi.cpp of the USBHost_t36 library:
    println"("tx1_count: ", tx1_count);
    println"("tx2_count: ", tx2_count);(
    When the library send data succesfull, both tx1_count and tx2_count are 0. After that first one and then the other go to a value of 64. After that the code hangs here, as none of the buffers are made available.
    What should cause the buffers to be cleared? It looks like MIDIDeviceBase::tx_data() should be called. But where from? The search brought me to ehci.cpp, but there are too many pointers there. My guess is that USBHost::followup_Transfer() should be called, but where is this called?
    My guess is it has to do with void USBHost::isr(). As all data stops in the monitor, it looks like the interrupt somehow no longer is called. Now what could cause this?
    I have been trying to decipher the USBHost library for days. But it is very complicated. What would be a good strategy to find out where the data gets stuck? It looks like it is starting to send a message, but it is never actually being sent. Who can explain how this actually works? i am completely in the dark here...
    22,637
    Quote Originally Posted by sixeight View Post
    Uncomment this line in USBHost_t36.h
    //#define USBHOST_PRINT_DEBUG
    I guess that would be me.
    Last time a particular hub didn't work, I wrote this detailed blog article about the troubleshooting process and ultimately discovering the bug deep within the EHCI pipe configuration code.
    https://www.pjrc.com/usb-hub-bug-hun...ssons-learned/
    Before we discuss details, I'd like to ask you to give us photos and whatever info you have about this hub, especially where to buy the exact same model (if it's still for sale). The idea is to help me or anyone else who might try to reproduce the problem to find this particular hub, so please try to get photos which capture the model number or any unique markings or other info if the hub is a "generic no-name" style. The debug info using USBHOST_PRINT_DEBUG will also give plenty of info about the hub.
    Also, can you confirm whether it does indeed work with a different hub? If all hubs fail the same way, that's a very different scenario than just 1 particular hub.
    Hi Paul,
    To explain a bit more clearly: I have tried several hubs. Belkin, D-Link and some cheap thing from China. They all work fine with the USBHost_t36 library with all sorts of MIDI devices, apart from this NUX MG-300. This NUX device is giving me a trouble, even though it does work when I connect the NUX to a Mac, PC or Raspberry Pi using any of the hubs.
    To sum it up:
    MG-300 connected directly to Teensy 3.6 port: works.
    MG-300 connected via hub to Teensy 3.6 port: does not work
    Other MIDI devices connected directly to Teensy 3.6 port: work.
    Other MIDI devices connected via hub to Teensy 3.6 port: work.
    Already to have a working sysex connection with the MG-300, I had to change the library. I found sysex messages are sent with just three bytes in one full USB stream in the USBHost_t36 library. But MIDI allows several messages to be sent, filling up the buffer size that is in the MIDI descriptor. The NUX only started working with sysex, once I started sending bytes after one another. Here you can find my fork of the USBHost library - which is a bit messy now: https://github.com/sixeight7/USBHost_t36
    But I wrote the test sketch above, which does not use sysex and went back to the original library. To make sure i was not breaking stuff through my modifications.
    If you read my first post, you can see I already uncommented USB_HOST_DEBUG and included the serial monitor log. I just cannot discover any errors here.
    I would be grateful if you could help me.
    More information about my Teensy projects: https://www.vguitarforums.com/smf/index.php?board=277.0
    22,637
    Just to make sure I understand this...
    Seems like you're using MG-300 fails the same way when connected with any of the 3 hubs you mentioned? This is a very important point to know. If any of the hubs are different, that's a very different sort of problem than if they all do the same wrong thing.
    The MG-300 fails with all hubs.
    Two Midi messages are sent and then the USBHost library hangs in the loop that is in write_packed(). Tx1 count and tx2_count are not cleared. That is as far as I got.
    22,637
    Ok. Here's one more "easy" thing to try, before the very difficult work of diving into the details.
    Uncomment this line in ehci.cpp.
            //USBHS_PORTSC1 |= USBHS_PORTSC_PFSC; // force 12 Mbit/sec
    Does it also fail when the library can't run at 480 Mbit speed?
    Tried that, but it does not make a difference. It still works without a hub and fails with the hub.
    Here is the serial monitor after one successful and then one unsuccessful MIDI message. I uncommented all //print and //println statements I could find in ehci.h. And I added two print statements to midi.c:
    	if (!txpipe) return;
    	uint32_t tx_max = tx_size / 4;
        while (1) {
    	uint32_t tx1 = tx1_count;
    	uint32_t tx2 = tx2_count;
            print("tx1_count: ", tx1_count);
            println(", tx2_count: ", tx2_count);
    	if (tx1 < tx_max && (tx2 == 0 || tx2 >= tx_max)) {
    		// use tx_buffer1
            ...etc
    Sending CC#60 2
    ISR: 4C089
     USB Interrupt
     Frame List Rollover
     SOF
     Periodic Sched En
     Async Sched En
     USB Async
    Async Followup
    Transfer Followup List 1FFF4A80 to 1FFFD540
        forward:
        1FFF4A80 IN 256
        1FFFD540 OUT 0
        backward:
        1FFFD540 OUT 0
        1FFF4A80 IN 256
      Followup 1FFF4A80    token=1008180
      Followup 1FFFD540    token=80008001
    tx_callback
        completed
    Transfer Followup List 1FFF4A80 to 1FFF4A80
        forward:
        1FFF4A80 IN 256
        backward:
        1FFF4A80 IN 256
    tx1_count: 0, tx2_count: 0
    new_Data_Transfer
    Transfer Followup List 1FFFD500 to 1FFFD500
        forward:
        1FFFD500 OUT 0
        backward:
        1FFFD500 OUT 0
    Sending CC#60 3
    tx1_count: 64, tx2_count: 0
    new_Data_Transfer
    Transfer Followup List 1FFFD540 to 1FFFD540
        forward:
        1FFFD540 OUT 0
        backward:
        1FFFD540 OUT 0
    Sending CC#60 4
    tx1_count: 64, tx2_count: 64
    ...etc. Now we are stuck in a loop in midi.h - MIDIDeviceBase::write_packed(uint32_t data)
    But I cannot find the "Transfer Followup List " print statement in the code. Where is this generated?
    22,637
    The "Transfer Followup List" is inside print.cpp at line 55. It's rarely used, but you can find at least 1 usage commented out at line 333 in ehci.cpp.
    It does look like some of the data is being sent and then it stops when the hub is connected. Is there anyway to do a crude jumpstart? I can set a timer inside write_packed that can detect when it is taking too long for the buffers to become available. But most of ehci.h is a complete mystery to me. I found some of the documentation on the subject, but it really is beyond me.
    Paul, do you have any suggestions on how to proceed?
