Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 77
Thread: Teensy Loader slow to start up
  1. #51
    9,215
    Installing fresh Ubuntu on my PI now to see what happens. Using 20.04 LTS instead. Looked like 20.10 support ends april 2021. Using the Raspberry Pi imager then will do the updates.
    And before you ask why fresh - forgot my password and can't get back in ....
    Did you try: ubuntu
  2. #52
    7,210
    Of course
    But just remembered the password when I was setting up with the new version Getting the updates now.
  3. #53
    7,210
    Tried new build on RPI4 running Ubuntu 64 bit ARM,
    And the teensy app works
    Tried the Simple USB keyboard example, where I added simple wait up to 5 seconds for serial, and commented out the Keyboard prints, and it built properly and programmed, but again after that could not open Serial terminal, nor automatically program again... Same issue I have seen on Ubuntu x86 64 on 18.04 and 20.04
    Attachment 23768
    Can confirm that the app works with 20.04.02LTS.
    Tried the same sketch as @KurtE and when I selected Serial+Keyboard... did get out on the Serial monitor.
Name:	Screenshot from 2021-02-20 09-33-02.png
  4. #54
    Feb 2021
    12
    Great to see the problem is solved. Tested good on Ubuntu 16.04 LTS.
  5. #55
    9,215
    @mjs513 - Did you get output if you choose USB type: Keyboard
    This should output using SEREMU
    I just updated one of my 20.04 x86 (64 bit Ubuntu) and the teensy program works, but the SEREMU does not want to either reboot the teensy to program it or for the Serial Monitor to to talk to it
    In this case data shown in Arduino IDE (Unable to open /dev/hidraw6)
    Will investigate some more... Maybe a udev rules issue?
    EDIT: I am guessing that might be it:
    kurt@kurt-XPS-8300:~$ ls -l /dev/hi*
    crw------- 1 root root 241, 0 Feb 20 06:27 /dev/hidraw0
    crw------- 1 root root 241, 1 Feb 20 06:27 /dev/hidraw1
    crw------- 1 root root 241, 2 Feb 20 06:27 /dev/hidraw2
    crw------- 1 root root 241, 3 Feb 20 06:27 /dev/hidraw3
    crw------- 1 root root 241, 4 Feb 20 06:27 /dev/hidraw4
    crw------- 1 root root 241, 5 Feb 20 06:42 /dev/hidraw5
    crw------- 1 root root 241, 6 Feb 20 06:42 /dev/hidraw6
    crw------- 1 root root 241, 7 Feb 20 06:42 /dev/hidraw7
  6. #56
    7,210
    @KurtE
    Not to the serial monitor.
    Either output to textEditor or directly into the IDE window - depending which I had selected (active). But I did get output even when I had keyboard printing.
    Have to go finish shoveling then going to play(test) later.
  7. #57
    9,215
    Thanks,
    Note: on my 20.04 x86, looking at udev rules associated with hidraw I see:
    kurt@kurt-XPS-8300:/etc/udev/rules.d$ grep -i hidraw *
    98-openocd.rules:SUBSYSTEM!="usb|tty|hidraw", GOTO="openocd_rules_end"
    kurt@kurt-XPS-8300:/etc/udev/rules.d$ cat 98-openocd.rules
    # Adding Arduino M0/M0 Pro, Primo UDEV Rules for CMSIS-DAP port
    ACTION!="add|change", GOTO="openocd_rules_end"
    #Please keep this list sorted by VID:PID
    #CMSIS-DAP compatible adapters
    ATTRS{product}=="*CMSIS-DAP*", MODE="664", GROUP="plugdev"
    LABEL="openocd_rules_end"
    Looking around net I see: https://unix.stackexchange.com/quest...missions/85459
    So tried:
    kurt@kurt-XPS-8300:/etc/udev/rules.d$ cat 99-hidraw-permissions.rules
    KERNEL=="hidraw*", SUBSYSTEM=="hidraw", MODE="0664", GROUP="plugdev"
    Now Teensy with keyboard as USB type programs and Serial monitor works
    Not sure what is best way to define this and/or where@!
  8. #58
    7,210
    @KurtE
    getting an error when I try to execute your first line:
    ubuntu@ubuntu:~$ /etc/udev/rules.d$ cat 99-hidraw-permissions.rules
    bash: /etc/udev/rules.d$: No such file or directory
    EDIT: never mind figured it out as I am remembering how to use Linux
  9. #59
    7,210
    Thanks,
    So tried:
    ok - as shown didn;t really work for me - but then I really have no idea with Linux so just used gedit to create the file. Restarted and it now works with serial monitor as you said.
    Maybe Paul can add it to list of UDEV rules to be downloaded from the Teensyduino download page?
  10. #60
    9,215
    Good,
    It also might have worked if you had made sure Arduino was not running and the teensy was not plugged in. Then when you plug in the teensy the rule should fire...
    Was going to upload the file here, but it does not like .rules files
    I added the .txt extension to it.
    Should be able to download it and remove the .txt and then sudo cp it to /etc/udev/rules.d directory
    Also @Paul maybe should instead add it to the 49-teensy.rules file.
    Question, does you install script that checks for rules file simply check it exists or does it also check if the contents are different?
    Will now go back to my other notebook with 20.04.02 and see if everything works
    Edit: notebook that I installed Ubuntu 20.04.02 from ISO disk yesterday is working fine with the new build
    Also updated with the udev rules file I mentioned here and building for USB Type of Keyboard works now. Both the reboot code as well as the Serial monitor
    EDIT 2: Updated notebook other install 18.04 and it also works
    Attached Files Attached Files
  11. #61
    7,210
    Morning again - can't sleep so catching up
    As for restarting. I did close and reopen the IDE but didn't disconnect the Teensy which was probably the issue - didn't even cross my mind to unplug it.
    Probably a better approach to just add it to the rules file but for folks that have already downloaded the rules file and just keeps updating TD may not realize they need to update unless a warning is posted as well that the file has changed and please update.
    ok - remember I just get by with Linux so where do I find that?
    Great that you got it checked out the laptop and with18.04
  12. #62
    24,471
    Yes, I agree.
    But so far, I can't reproduce the problem on my Linux desktop.
    The /dev/hidraw devices are being created with open permissions.
    Maybe this is coming from some other udev rule file I installed long ago?
    Later today I'm going to dig up some USB cables and hubs so I can more easily plug into my Raspberry Pi 4 and Jetson Nano. Those 2 boards have had very little use, so they should be a much better test than my heavily used desktop machine.
  13. #63
    9,215
    Yes, I agree.
    Sounds good,
    For the fun of it you might try a simple on your machine like: grep hidraw /etc/udev/rules.d/*
  14. #64
    24,471
    Well, after much removing and restoring files, I finally tracked it down to this line (meant for some Arduino.org boards):
    SUBSYSTEMS=="usb", ATTRS{idVendor}=="05e3", ATTRS{idProduct}=="*", MODE:="0666"
    I have no idea why this is causing /dev/hidraw devices from Teensy which uses vendor ID 16C0 to get read/write premissions.
    With this removed, I'm able to reproduce the problem. Looking into how the best improve the default udev rules.
  15. #65
    24,471
    Today I went down the deep rabbit hole of Linux udev rules.
    To make serial raw mode configure work well on Raspberry Pi, I had to rename the file from 49-teensy.rules to 00-teensy.rules.
    https://www.pjrc.com/teensy/00-teensy.rules
    Hopefully this resolves all the issues. Please let me know if you give it a try?
  16. #66
    7,210
    Ok - just tried it on a RPI4 and its now working.
Name:	Screenshot from 2021-02-21 19-10-28.png
    Guess the order matters - 00 versus 49. Forgot to document but think you added an extra rule as well to the file.
  17. #67
    24,471
    Did you run 32 bits or 64 bits on your Raspberry Pi? So far, I've only tested 32 bits.
    Yup, added the hidraw rule. The usb subsystem rule also applies. But it looks like the more complex wildcard syntax is buggy on some distros. I switched to the simpler but less precise way.
  18. #68
    7,210
    Should have mentioned. Running Ubuntu 20.04.02LTS 64 bit on the PI4. Don't really have any other Linux systems. Probably can did out a RPI3 and see what I have on it and give it a try if you think its worth it?
  19. #69
    24,471
    Probably not worthwhile. I tested 32 bits on Raspberry Pi 4.
    Unless Kurt turns up any more issues, I'm going to cross ARM64 troubles off my bug list.
  20. #70
    7,210
    Hopefully no more issues. Hope that list is getting shorter but have a feeling it’s getting longer.
  21. #71
    9,215
    It appeared to work on my RPI4 with 64 bit... looked good when I did ls -l /dev/hidr*
    Plus I told it to program the keyboard one which the reboot worked and so did the terminal monitor.
    (Now back to my main machine - Windows 10)
  22. #72
    24,471
    Feels good to finally get these many lingering Linux issues fixed.
  23. #73
    Feb 2021
    12
    I've encountered a problem while trying to update my Asus Laptop running Linux Mint 19.2 Cinnamon. On the Software download page the udev rules have been updated to 00-teensy.rules but the Teensyduino installer is checking for 49-teensy.rules. Is there a step that I'm missing or does the download page need an update? Had a copy of the 49-teensy.rules on my Desktop so was able to finish install on the Laptop.
  24. #74
    8,612
    Quote Originally Posted by MikeH View Post
    The Teensyduino installer is older than the new rules, that's all.
  25. #75
    24,471
    You can also click the button to skip the udev rules check.
