Results 1 to 4 of 4
Thread: Teensy 4.0 Pin Current Capability
    Dec 2015
    177
    Hi all,
    I can't seem to find a reliable answer for the current capability (source/sink) of the I/O pins on the Teensy 4.0.
    I thought that info would be in here:
    https://www.pjrc.com/teensy/IMXRT1060CEC_rev0_1.pdf in table 22 (page 34), but no luck.
    There's a table on the PJRC site, but I know updating it is a much lower priority job than all the programming and designing, so it's a bit out of date.
    I'm sure I'm missing this somewhere simple, I just can't for the life of me figure out where.
    Thank you!
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    330
    You need to get the latest IMXRT1060 datasheet from the NXP website.
    See the updated table 22 for output currents.
    Paul
    Dec 2015
    177
    Ah, thank you very much Paul!
    So based on this I'm seeing 4ma? Am I reading that right?
    Thank you!
    Apr 2015
    Netherlands
    330
    Yes, that's what I read as well when the Drive Strength (DSE) setting is '111'. But I have no idea what the actual DSE setting is or how/where it can be set.
    I think it's defined in C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\co re_pins.h [line 434] but I'm not sure. Perhaps Paul Stoffregen knows?
    Paul
