Results 1 to 12 of 12
Thread: HWSERIAL port #define definition doesn't work
    Ok here's a head scratcher...
    Teensy 3.2 connected to a computer using onboard USB serial, and FTDI USB to RS232 to a max232 connected to serial1 (pins 0 and 1).
    Why doesn't this example code work:
    // set this to the hardware serial port you wish to use
    #define HWSERIAL Serial1
            HWSERIAL.begin(9600);
            int incomingByte;
    	if (Serial.available() > 0) {
    		incomingByte = Serial.read();
    		Serial.print("USB received: ");
    		Serial.println(incomingByte, DEC);
                    HWSERIAL.print("USB received:");
                    HWSERIAL.println(incomingByte, DEC);
    	if (HWSERIAL.available() > 0) {
    		incomingByte = HWSERIAL.read();
    		Serial.print("UART received: ");
                    HWSERIAL.print("UART received:");
    While the version below does work when I removed the #define HWSERIAL Serial1 and explicitly used Serial1 instead of the HWSERIAL????
    The version that doesn't work is copied directly from the https://www.pjrc.com/teensy/td_uart.html page. The only part that works is the USB received on the Arduino Monitor.
    	Serial1.begin(9600);
            int incomingByte;
    		Serial1.print("USB received:");
    		Serial1.println(incomingByte, DEC);
    	if (Serial1.available() > 0) {
    		incomingByte = Serial1.read();
    		Serial1.print("UART received:");
    Is there a different way to define HWSERIAL that will work?
    Senior Member brtaylor's Avatar
    Mar 2016
    Portland, OR
    580
    Quote Originally Posted by Fluxanode View Post
            int incomingByte;
            int incomingByte;
    I use this all the time in my code:
    static constexpr HardwareSerial &GNSS_UART = Serial3;
    So then "HardwareSerial" can be used instead of Serial3?
    Mar 2016
    Portland, OR
    580
    So then HardwareSerial can be used instead of Serial3?
    When I use this:
    It creates a reference to Serial3 called GNSS_UART. So I can use GNSS_UART in my code instead of Serial3. The advantage of this approach is that it maintains type safety, unlike a define, and doesn't take up resources, since it's a reference. I typically have a header file of references like this for all of the hardware definitions for a project. Makes it pretty quick to port to a different hardware platform if, for example, the serial port changes number.
    I'm not sure why your define isn't working...
    7,671
    Note: I use the #define all of the time, and I have not had an issue. The only case that I have seen is if you have some other place that defines it differently.
    So you might simply try a different #define. Example sometimes I will have XBeeSerial or DBGSerial or DXLSerial defined
    Kurt, I don't think so. I just copied and pasted form the web page. Would having another Arduino sketch window open cause problems?
    7,671
    No should make no difference. You might double check and try it again to see if there was not something slightly off?
    1,454
    What exactly do you mean by doesn't work?
    That code (with the #define) runs fine for me on a T3.2 and a T4.0 (on Win 10 with Arduino 1.8.13 and TD 1.53).
    Pete
    Basically just that. It's as if the serial1 port isn't there.
    KurtE:
    Ok i cleared everything and started fresh, now it works. Strange. The first time around all I did to fix was change HWSERIAL Serial1
    Thanks everyone for the help.
    22,752
    Any chance you're using an old pre-10 version of Windows?
    Windows 7 has a really confusing driver bug which could explain why it didn't work one time, but then magically started working the next.
    Thanks Paul, maybe Windows 10 also. It was really weird, it wouldn't work all day but after sleeping on it and completely starting fresh with a clean file, bingo it works...
