Results 1 to 2 of 2
Thread: Toggle output port with register
    Sep 2014
    Paris
    19
    Hi all,
    I'm looking for a way to toggle output port directly with the GPIOx_PTOR register as it's specified page 1336:
    https://www.pjrc.com/teensy/K20P64M72SF1RM.pdf
    My problem is to match the teensy3.2 pin with the register. If I want toggle pin 13 (embedded led), what is the register value that I have to set ? GPIOA, B, C, D, E ?
    In advance many thanks. Bruno
    15,110
    Support has recently been added for :: digitalToggleFast()
    That code is in :: hardware\teensy\avr\cores\teensy3\core_pins.h:
    for pin13 the code uses this when the pin number supplied is a CONSTANT compile time value:
    static inline void digitalToggleFast(uint8_t pin)
    	if (__builtin_constant_p(pin)) {
    		else if (pin == 13) {
    			CORE_PIN13_PORTTOGGLE = CORE_PIN13_BITMASK;
