Results 1 to 7 of 7
Thread: Teensy 4.0 Shield ??
    I want to use an Arduino UNO shield with my Teensy 4.0. I see there is a shield that fits Teensy 3.1 & 3.2, but I need one for the Teensy 4.0.
    Does anyone make one for the Teensy 4.0?
    3,930
    Unfortunately the seller is on vacation until the end of September:
    I bought the revision 1 board and I found the micro SD card was unusable. The revision 2 board evidently fixes those problems. But I must admit, I haven't done anything with mine since buying it. The teensy 4.1 came out with built-in SD card also reduced one of the reasons I bought it.
    The PJRC site says, "Teensy 4.0 is the same size and shape as Teensy 3.1, and retains compatibility with most of the pin functions on Teensy 3.2"
    So I ordered the SparlkFun shield for the 3.1. I'll let you know if it works or not.
    Jul 2020
    570
    Remember 5V is death to the Teensy 4, its 3.3V only. The 3.1 and 3.2 are 5V tolerant so a shield adapter won't put
    those at risk from a 5V shield, but the T4 will die in this situation without level-shifting on the adaptor.
    3,930
    I put this page on the unofficial wiki about Teensy compatibility:
    3,930
    IIRC, newer Arduino shields should be able to run with either 3.3v or 5v power. The Teensy would run the shield at 3.3v. Older shields are 5v only, and you probably want to use just the Teensy 3.2 and 3.5 processors with those old shields.
    This is great information. Looking at all the options available at the moment, it appears the Teensy 3.3 which is 5V tolerant is my best option. Thank you!
