Results 1 to 4 of 4
Thread: Usable Baud Rates for Teensy-LC
    Sep 2020
    1
    I have make code to check error rate of baud rates in teensy-LC.
    #include <stdio.h>
    #include <stdlib.h>
    #define __MKL26Z64__	/* teensy-LC */
    //#define __MK20DX256__	/* teensy 3.1 & 3.2 */
    #if defined(__MKL26Z64__)
    #define KINETISL
    #define F_CPU 48000000
    #define F_PLL 96000000
    #define F_BUS 24000000
    #elif defined(__MK20DX256__)
    #define KINETISK
    #define F_CPU 96000000
    #define F_BUS 48000000
    #if defined(KINETISK)
    #define BAUD2DIV(baud)  (((F_CPU * 2) + ((baud) >> 1)) / (baud))
    #define ACTUIAL(count)   (F_CPU / 16 / (count/32))
    #elif defined(KINETISL)
    #define BAUD2DIV(baud)  (((F_PLL / 2 / 16) + ((baud) >> 1)) / (baud))
    #define ACTUIAL(count)   (F_PLL / 2 / 16 / count)
    int main()
    	int baud[] = {115200, 230400, 250000, 460800, 500000, 921600, 1000000, 2000000, 4608000};
    	printf("<F_CPU : %d>\n", F_CPU);
    	for(int i=0;i<(sizeof(baud)/sizeof(int));i++){
    		int count = BAUD2DIV(baud[i]);
    		if (count < 32) count = 32;
    		if (count == 0) count = 1;
    		int actual = ACTUIAL(count);
    		float err = ((float)(actual - baud[i]) / (float)baud[i]) * (float)100.0;
    		printf("baud: %d, count: %d, actual: %d, error: %.2f\n", baud[i], count, actual, err);
    	return 0;
    <output>
    <F_CPU : 48000000>
    baud: 115200, count: 26, actual: 115384, error: 0.16
    baud: 230400, count: 13, actual: 230769, error: 0.16
    baud: 250000, count: 12, actual: 250000, error: 0.00
    baud: 460800, count: 7, actual: 428571, error: -6.99
    baud: 500000, count: 6, actual: 500000, error: 0.00
    baud: 921600, count: 3, actual: 1000000, error: 8.51
    baud: 1000000, count: 3, actual: 1000000, error: 0.00
    baud: 2000000, count: 2, actual: 1500000, error: -25.00
    baud: 4608000, count: 1, actual: 3000000, error: -34.90
    But, I got difficult result than PJRC site. (https://www.pjrc.com/teensy/td_uart.html)
    ex) 230400bps error rate
    my code : 0.16%
    PJRC site : -6.99%
    Is there a problem with my code?
    2,593
    Your LC numbers look correct for Serial1 (UART0). You can also verify error by setting Serial1 baud rate and then examining the count in UART0_BDH and UART0_BDL.
      while (!Serial);
      int baud = 230400;
      Serial1.begin(baud);
      Serial.println(UART0_BDH, HEX);
      Serial.println(UART0_BDL);
      int count = (UART0_BDH & 0x1F) << 8 | UART0_BDL;
      int actual = F_PLL / 16 / 2 / count;
      Serial.println(count);
      Serial.println(actual);
      float err = 100.*(actual - baud) / (float)baud;
      Serial.println(err);
    output is
    13
    13
    230769
    0.16
    or in perl
    #! /usr/bin/perl
    $clock = 96000000;
    while (<>) {
            $baud = $_ + 0;
            $count = int((($clock / 32) + int($baud / 2)) / $baud);
            $count = 1 if $count < 1;
            $count = 8191 if $count > 8191;
            $actual = int($clock / 32 / ($count)); # Teensy LC
            $error = ($actual - $baud) / $baud;
            $percent = sprintf("%+.2f", $error * 100);
            print "$baud\t$percent%\n";
    7,899
    I wonder if the table is maybe wrong, or if it is worst case....
    That is Serial2 and Serial3 use a different Clock and different formulas depending on clock speed:
    #if F_CPU <= 2000000
    #define BAUD2DIV(baud)  (((F_PLL / 16 ) + ((baud) >> 1)) / (baud))
    #elif F_CPU <= 16000000
    #define BAUD2DIV(baud)  (((F_PLL / (F_PLL / 1000000)) + ((baud) >> 1)) / (baud))
    #else
    #define BAUD2DIV2(baud) (((F_BUS / 16) + ((baud) >> 1)) / (baud))
    #define BAUD2DIV3(baud) (((F_BUS / 16) + ((baud) >> 1)) / (baud))
    I have not tried them to see what it does on Serial2 and 3 which use F_BUS instead of F_PLL or also how running at 48mhz versus 24mhz effects this.
    2,593
    Yes, the column heading for LC says Serial1-3, so table probably reports worst case. LC Serial2 and Serial3 use F_BUS. Here's perl script for UART1 and UART2 (Serial2 and Serial3)
    #! /usr/bin/perl
    $clock = 24000000;
    while (<>) {
            $baud = $_ + 0;
            $count = int((($clock / 16) + int($baud / 2)) / $baud);
            $actual = int($clock / 16 / ($count)); # Teensy LC
            print "$baud\t$actual\t$percent%\n";
    230400 214285 -6.99%
    Serial2 (UART1) sketch
      while (!Serial);
      int baud = 230400;
      Serial2.begin(baud);
      Serial.println(UART1_BDH, HEX);
      Serial.println(UART1_BDL);
      int count = (UART1_BDH & 0x1F) << 8 | UART1_BDL;
      int actual = F_BUS / 16  / count;
    void loop() { }
