Results 1 to 6 of 6
Thread: TDM Output
    TDM Output
    Hey.
    I am trying the read TDM output from my Teensy 4.1. But it doesnt look like its working as it suppose.
    i have taken a picture from my oscilloscope. I know the signal is a "bit" noisy
    I was expecting to see something in the middle between the periods, because i did connect my "playsdWav" too 8 and 9, as it can be seen on my code.
    My oscilloscope is on Pin 7 and Pin 20.
    #include <SerialFlash.h>
    AudioPlaySdWav           playSdWav1;     //xy=301,501
    AudioOutputTDM           tdm1;           //xy=511,580
    AudioConnection          patchCord1(playSdWav1, 0, tdm1, 8);
    AudioConnection          patchCord2(playSdWav1, 1, tdm1, 9);
    // GUItool: end automatically generated code/
    int ledPin= 13;
      pinMode(LED_BUILTIN, OUTPUT); //Quality of life to see when setup begins and ends
      pinMode(ledPin,OUTPUT);
      Serial.print("Programmet er nu startet");
      Serial.begin(9600);//Sætter intern baudrate mellem SD kort og SPI
      if (playSdWav1.isPlaying() == false) {
        playSdWav1.play("YEARS.wav");
        Serial.println("Playing track.");
        delay(10); // wait for library to parse WAV info
          digitalWrite(ledPin, HIGH);
          digitalWrite(ledPin,LOW);
    23,432
    You're missing AudioMemory().
    The audio library can't actually do anything unless you give it memory to use. Open any of the examples under File > Examples > Audio to see the syntax.
    Here are the sort of waveforms you should see when it works.
    Hey Paul.
    I did put the AudioMemory function and i did put AudioMemoryUsageMax/AudioMemoryUsage and did print it on the monitor it just said 0.
    I have uploaded my scope measurements. Maybe its in my software the problem is?
    I am quite new to all this, so i hope its okay that i ask some newbie questions. Thank you very much.
ID:	21683   Click image for larger version.
    23,432
    Another quick look... SD.begin() is also missing, so it can't actually access the SD card.
    23,432
    Here is a much simpler test program which doesn't depend on the SD card working and having a readable file.
    AudioSynthWaveformSine   sine1;          //xy=181,170
    AudioSynthWaveformSine   sine2;          //xy=182,239
    AudioSynthWaveformSine   sine3;          //xy=185,303
    AudioOutputTDM           tdm1;           //xy=389,259
    AudioConnection          patchCord1(sine1, 0, tdm1, 0);
    AudioConnection          patchCord2(sine2, 0, tdm1, 4);
    AudioConnection          patchCord3(sine3, 0, tdm1, 6);
      AudioMemory(40);
      sine1.amplitude(0.95);
      sine2.amplitude(0.95);
      sine3.amplitude(0.95);
      sine1.frequency(220);   // A3
      sine2.frequency(587.3); // D5
      sine3.frequency(0.25);  // very slow
    I'm running it here on a Teensy 4.1. These are the waveforms on pins 20, 7, 21:
    Hopefully this known good, zero dependency test program and this capture of its actual waveforms can help you get past this first difficult part where nothing seems to work?
      AudioMemory(40);
    Thank you very much Paul!
    It did work with your test code, now i atleast know where to start with fixing my own test setup!!! Thanks again!!!
