TDM Output
Tengrii
Hey.
I am trying the read TDM output from my Teensy 4.1. But it doesnt look like its working as it suppose.
i have taken a picture from my oscilloscope. I know the signal is a "bit" noisy :D
I was expecting to see something in the middle between the periods, because i did connect my "playsdWav" too 8 and 9, as it can be seen on my code.
My oscilloscope is on Pin 7 and Pin 20.
AudioPlaySdWav           playSdWav1;     //xy=301,501
AudioOutputTDM           tdm1;           //xy=511,580
AudioConnection          patchCord1(playSdWav1, 0, tdm1, 8);
AudioConnection          patchCord2(playSdWav1, 1, tdm1, 9);
// GUItool: end automatically generated code/
int ledPin= 13;
  pinMode(LED_BUILTIN, OUTPUT); //Quality of life to see when setup begins and ends
  pinMode(ledPin,OUTPUT);
  Serial.print("Programmet er nu startet");
  Serial.begin(9600);//Sætter intern baudrate mellem SD kort og SPI
  if (playSdWav1.isPlaying() == false) {
    playSdWav1.play("YEARS.wav");
    Serial.println("Playing track.");
    delay(10); // wait for library to parse WAV info
      digitalWrite(ledPin, HIGH);
      digitalWrite(ledPin,LOW);
You're missing AudioMemory().
The audio library can't actually do anything unless you give it memory to use. Open any of the examples under File > Examples > Audio to see the syntax.
Here are the sort of waveforms you should see when it works.
Hey Paul.
I did put the AudioMemory function and i did put AudioMemoryUsageMax/AudioMemoryUsage and did print it on the monitor it just said 0.
I have uploaded my scope measurements. Maybe its in my software the problem is?
I am quite new to all this, so i hope its okay that i ask some newbie questions. Thank you very much.
Here is a much simpler test program which doesn't depend on the SD card working and having a readable file.
AudioSynthWaveformSine   sine1;          //xy=181,170
AudioSynthWaveformSine   sine2;          //xy=182,239
AudioSynthWaveformSine   sine3;          //xy=185,303
AudioOutputTDM           tdm1;           //xy=389,259
AudioConnection          patchCord1(sine1, 0, tdm1, 0);
AudioConnection          patchCord2(sine2, 0, tdm1, 4);
AudioConnection          patchCord3(sine3, 0, tdm1, 6);
  AudioMemory(40);
  sine1.amplitude(0.95);
  sine2.amplitude(0.95);
  sine3.amplitude(0.95);
  sine1.frequency(220);   // A3
  sine2.frequency(587.3); // D5
  sine3.frequency(0.25);  // very slow
I'm running it here on a Teensy 4.1. These are the waveforms on pins 20, 7, 21:
Hopefully this known good, zero dependency test program and this capture of its actual waveforms can help you get past this first difficult part where nothing seems to work?
  AudioMemory(40);
Thank you very much Paul!
It did work with your test code, now i atleast know where to start with fixing my own test setup!!! Thanks again!!! :D
