Results 1 to 4 of 4
Thread: Wire library
    May 2017
    106
    Wire library
    @Paul Stoffregen
    I saw Arduino updated Wire lib with "Wire class now supports timeout".
    Any chance to get this functionality on teensy (especially teensy2.0) also?
    I have a project on wich this could be usefull.
    Thank you for your efforts for teensy
    May 2017
    106
    Bump
    An answer would be nice.
    8,514
    If it were me, I would probably try seeing how hard it would be to merge in their changes and then try issuing a Pull Request back to library: https://github.com/PaulStoffregen/Wire
    And/Or add an Issue against the library as a reminder.
    Not sure how much work it would be to integrate it against the three sets of code (AVR, TLX/3.x, and T4.x).
    It is interesting that they released it for AVR, but I don't think their ARM versions have it nor have they updated the Wire library online documentation.
    May 2017
    106
    Thank you for your answer.
    I think merge and pull request might be above my skill level.
    Just for AVR core (T2) would be good enough for my needs.
    Maybe Paul can give his opinion in this topic.
    Best regards
