Results 1 to 11 of 11
Thread: Strange GPIO Port Behaviour
    Jun 2019
    14
    Strange GPIO Port Behaviour (Teensy 3.6)
    Hi all.
    I am working on some code that reads a 16 bit address using 16 of the GPIO pins. I want these reads to be fast and as close to atomic as possible, therefore I am using the GPIO ports directly. However, when I read the address bits from the ports I get different results than if I use digitalReadFast for each pin and shift the bits.
    Using this great post as a guide https://forum.pjrc.com/threads/17532...PIO_PDIR-_PDOR along with the code documentation in core_pins.h I have chosen GPIO port C for the first 12 bits of the address and port B for the highest 4 bits. This is nice because the bits for the ranges I mention are contiguous, and makes read/write code fairly simple.
    Here is how I am testing this (currently only testing first 12 bits from port C):
    // A0 - A11 maps to GPIO port C (bits 0 - 11) . A12 - A15 maps to GPIO port B (bits 0 - 3)
    #define A0  15
    #define A1  22
    #define A2  23
    #define A3  9
    #define A4  10
    #define A5  13
    #define A6  11
    #define A7  12
    #define A8  28
    #define A9  27
    #define A10 29
    #define A11 30
    #define A12 16
    #define A13 17
    #define A14 19
    #define A15 18
    static inline void setAddressMode(uint8_t mode)
      pinMode(A0, mode);
      pinMode(A1, mode);
      // ... do this for all the pins
    // traditional address access
    static inline uint16_t getAddr()
      uint16_t addr = 0;
      addr |= (digitalReadFast(A0));
      addr |= (digitalReadFast(A1) << 1);
      addr |= (digitalReadFast(A2) << 2);
      addr |= (digitalReadFast(A3) << 3);
      addr |= (digitalReadFast(A4) << 4);
      addr |= (digitalReadFast(A5) << 5);
      addr |= (digitalReadFast(A6) << 6);
      addr |= (digitalReadFast(A7) << 7);
      addr |= (digitalReadFast(A8) << 8);
      addr |= (digitalReadFast(A9) << 9);
      addr |= (digitalReadFast(A10) << 10);
      addr |= (digitalReadFast(A11) << 11);
      //addr |= (digitalReadFast(A12) << 12);
      //addr |= (digitalReadFast(A13) << 13);
      //addr |= (digitalReadFast(A14) << 14);
      //addr |= (digitalReadFast(A15) << 15);
      return addr;
      setAddressMode(INPUT);  // set A0 - A15 to INPUT
      Serial.begin(250000);
      while (1)
        // currently just testing the lower 12 bits from the c register
        uint32_t cPortInput = GPIOC_PDIR;
        uint16_t addr = getAddr();
        Serial.println(addr, BIN);
        Serial.println(cPortInput , BIN);
        Serial.println("x");
      Serial.end();
    With the above code, I get the following output:
    100001101
    1101
    x
    100011110
    11110
    x
    I am really not sure how this can be. A8 is clearly high active when using the traditional method, but it is low when reading the C port register directly. I would expect the cPortInput to match addr exactly in this test condition.
    Would love to hear thoughts and suggestions.
    Thanks.
    8,204
    Might help to know what Teensy you are trying this on?
    Jun 2019
    14
    Sorry that's my bad, tagged the page but forgot to put it in the title (updated).
    Testing on a 3.6.
    8,204
    If that is really the code you are running, I wonder about:
      pinMode(A0, mode);
      pinMode(A1, mode);
    Did you do it for all the pins?
    Jun 2019
    14
      pinMode(A0, mode);
      pinMode(A1, mode);
    Yep, all pins. Code omitted for brevity. I've triple checked that code and I know its all good. The fact that getAddr works as intended is proof of that.
    I just don't get what I am seeing when I print the register directly.
    The Arduino style pin names A0- map to Teensy ports in strange ways. From the schematic they appear spread across all of the GPIO ports. Certainly not all on GPIOC.
    Jun 2019
    14
    Thanks for the reply, but I am fully aware of this. If you look at my code you can see that I am using all pins from the c register, apart from the last 4 bit, but I am not testing those in this code.
    23,470
    Quote Originally Posted by Jay8ee View Post
    Please do not omit code.
    In trying to make reading your code easier, you're erecting a huge barrier for any of us to *run* your code.
    Aug 2013
    Gothenburg, Sweden
    344
    Teensy 3.2 and 3.6 have different mappings for PTC8. According to the schematics at https://www.pjrc.com/teensy/schematic.html
    On 3.2 PTC8 is indeed Arduino pin 28
    On 3.6 PTC8 is mapped to Arduino pin number 35, and pin 28 is connected to PTA16
    8,204
    The problem is your data pin numbers are WRONG...
    This one works...
    #define A0  15  // C0
    #define A1  22  // c1
    #define A2  23  //c2
    #define A3  9   // C3
    #define A4  10  // C4
    #define A5  13  // C5
    #define A6  11  //C6
    #define A7  12  // C7
    #define A8  35  // C8 28 A16
    #define A9  36  // C9   27 A15
    #define A10 37  // C10  29
    #define A11 38  // C11 30
    #define A12 16
    #define A13 17
    #define A14 19
    #define A15 18
      pinMode(A0, mode);
      pinMode(A1, mode);
      pinMode(A2, mode);
      pinMode(A3, mode);
      pinMode(A4, mode);
      pinMode(A5, mode);
      pinMode(A6, mode);
      pinMode(A7, mode);
      pinMode(A8, mode);
      pinMode(A9, mode);
      pinMode(A10, mode);
      pinMode(A11, mode);
      uint16_t addr = 0;
      return addr;
      setAddressMode(INPUT_PULLDOWN);  // set A0 - A15 to INPUT
      while (1)
      Serial.end();
    Note: I used INPUT_PULLDOWN as I did not have anything attached to pins, so did not want them floating...
    Here is off one of my Excel document pages:
    Jun 2019
    14
    Thanks, working as expected with those changes.
    Also, that excel is great. Thanks for sharing.
Tags for this Thread
