Serial monitor issues on Windows 10 - port conflict
lubry
New member
Apologies if you know all about this, I couldn't find anything much on the forum myself but I'm a fairly new Teensy and Windows user, albeit with lots of Mac and Arduino experience.
I was having issues getting the serial monitor to work (I know about selecting the port after the code runs) and tracked it down to an issue evident in Device Manager. It seemed that there were two devices trying to use the same port, the Teensy and something called 'Intel Active Management Technology'.
To solve this, within Device Manager you can get the properties of the Teensy (showing as 'USB Serial Device') go to 'Port Settings' and 'Advanced' where you can change the COM port number to something not in use. Once I had done this my serial monitor was printing as it should (sort of... its slow compared to a normal Arduino?)
Thanks Paul, my mistake re the speed...
Thanks Kurt, that's a good tip. I had loads of ports tied up, several for each device I have connected that needed uninstalling.
Is this Windows fault, trying to allocate two devices to the same COM port?
