Results 1 to 5 of 5
Thread: Teensy freeze when stream from Serial port [ ubuntu18.04 teensy3.6 teensyduino1.53]
    I use Teensy 3.6 on Arduino 1.8.13, Teensyduino 1.53, Ubuntu 18.04 when I stream data from Serial port Teensy freeze
    mycode.ino
    #include <DHT.h>
    #define DHTPIN 24
    #define DHTTYPE DHT22 // DHT 22 (AM2302)
    DHT dht(DHTPIN, DHTTYPE);
    dht.begin();
    float h = dht.readHumidity();
    float t = dht.readTemperature();
    Serial.println(t);
    Serial.println(h);
    output
    49-teensy.rules
    # UDEV Rules for Teensy boards, http://www.pjrc.com/teensy/
    # The latest version of this file may be found at:
    # http://www.pjrc.com/teensy/49-teensy.rules
    # This file must be placed at:
    # /etc/udev/rules.d/49-teensy.rules (preferred location)
    # or
    # /lib/udev/rules.d/49-teensy.rules (req'd on some broken systems)
    # To install, type this command in a terminal:
    # sudo cp 49-teensy.rules /etc/udev/rules.d/49-teensy.rules
    # After this file is installed, physically unplug and reconnect Teensy.
    ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789B]?", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
    ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789A]?", ENV{MTP_NO_PROBE}="1"
    SUBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789ABCD]?", MODE:="0666"
    KERNEL=="ttyACM*", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789B]?", MODE:="0666"
    # If you share your linux system with other users, or just don't like the
    # idea of write permission for everybody, you can replace MODE:="0666" with
    # OWNER:="yourusername" to create the device owned by you, or with
    # GROUP:="somegroupname" and mange access using standard unix groups.
    # ModemManager tends to interfere with USB Serial devices like Teensy.
    # Problems manifest as the Arduino Serial Monitor missing some incoming
    # data, and "Unable to open /dev/ttyACM0 for reboot request" when
    # uploading. If you experience these problems, disable or remove
    # ModemManager from your system. If you must use a modem, perhaps
    # try disabling the "MM_FILTER_RULE_TTY_ACM_INTERFACE" ModemManager
    # rule. Changing ModemManager's filter policy from "strict" to "default"
    # may also help. But if you don't use a modem, completely removing
    # the troublesome ModemManager is the most effective solution.
    hope somone help me , Thank you
    12,406
    With delay(1000) that is not pushing much out USB so it shouldn't cause trouble there.
    In setup() add :: pinMode(LED_BUILTIN, OUTPUT);
    > Also add to make sure USB is online before the first print:: while (!Serial && millis() < 5000) ;
    and in loop() do : digitalToggleFast( LED_BUILTIN );
    That will blink the LED showing the Teensy still running or not with a blink on/off each second.
    #include <DHT.h>
    #define DHTPIN 24
    dht.begin();
    Serial.println(t);
    Serial.println(h);
    blink still running
    but when i use Sonarmax MB1242 blink not working
    // Basic Master
    // This creates a simple I2C Master device which when triggered will send/receive a text
    // string to/from a Slave device.  It is intended to pair with a Slave device running the
    // basic_slave sketch.
    // Pull pin12 input low to send.
    // Pull pin11 input low to receive.
    /* Code for Arduino Uno R3
    Assumes the sensor is using the default address
    Sensor Connections:
    Pin 7 to GND
    Pin 6 to 5V
    Pin 5 to SCL
    Pin 4 to SDA
    Requires pull-ups for SCL and SDA connected to 5V to work reliably
    #include <i2c_t3.h>
    // Memory
    #define MEM_LEN 256
    //The Arduino Wire library uses the 7-bit version of the address, so the code example uses 0x70 instead of the 8-bit 0xE0
    #define SensorAddress byte(0x71)
    #define NewSensorAddress byte(0x73)
    //The sensors ranging command has a value of 0x51
    #define RangeCommand byte(0x51)
    //These are the two commands that need to be sent in sequence to change the sensor address
    #define ChangeAddressCommand1 byte(0xAA)
    #define ChangeAddressCommand2 byte(0xA5)
    char databuf[MEM_LEN];
    int count = 0;
        pinMode(LED_BUILTIN,OUTPUT);    // LED
        digitalWrite(LED_BUILTIN,LOW);  // LED off
        // Setup for Master mode, pins 37/38, external pullups, 100kHz, 200ms default timeout
        Wire1.begin(I2C_MASTER, 0x00, I2C_PINS_37_38, I2C_PULLUP_EXT, 100000);
        Wire1.setDefaultTimeout(200000); // 200ms
        // Data init
        memset(databuf, 0, sizeof(databuf));
        count = 0;
    {digitalToggleFast( LED_BUILTIN );
          digitalWrite(LED_BUILTIN,HIGH);   // LED on
          if (count==0){
            changeAddress(SensorAddress, NewSensorAddress, true);     //if is the 7 bit version
            Serial.print("Change address done ");
            count=1;
            Serial.println(count);
          else{
              takeRangeReading();               //Tell the sensor to perform a ranging cycle
           // Check if error occured
            if(Wire1.getError())
                Serial.print("FAIL\n");
            else{
                delay(100);                       //Wait for sensor to finish
                word range = requestRange();       //Get the range from the sensor
                Serial.print("Range: "); Serial.println(range);  //Print to the user
    //Commands the sensor to take a range reading
    void takeRangeReading(){
      Wire1.beginTransmission(NewSensorAddress);    //Start addressing
      Wire1.write(RangeCommand);       //send range command
      Wire1.endTransmission();        //Stop and do something else now
    //Returns the last range that the sensor determined in its last ranging cycle in centimeters. Returns 0 if there is no communication.
    word requestRange(){
      Wire1.requestFrom(NewSensorAddress, byte(2));
         if(Wire1.available()>= 2){ //Sensor responded with the two bytes
                byte  HighByte = Wire1.read();       //Read the high byte back
                byte  LowByte = Wire1.read();       //Read the low byte back
                word  range = word(HighByte, LowByte);   //Make a 16-bit word out of the two bytes for the range
                return range;
         else{
                //range = 0x00;
                return 0;                               //Else nothing was received, return 0
    /* Commands a sensor at oldAddress to change its address to newAddress
    oldAddress must be the 7-bit form of the address that is used by Wire
    7BitHuh determines whether newAddress is given as the new 7 bit version or the 8 bit version of the address
    If true, if is the 7 bit version, if false, it is the 8 bit version
    void changeAddress(byte oldAddress, byte newAddress, boolean SevenBitHuh){
      Wire1.beginTransmission(oldAddress);      //Begin addressing
      Wire1.write(ChangeAddressCommand1);    //Send first change address command
      Wire1.write(ChangeAddressCommand2);    //Send second change address command
      byte temp;
      if(SevenBitHuh){ temp = newAddress << 1; }    //The new address must be written to the sensor
      else             { temp = newAddress;         }    //in the 8bit form, so this handles automatic shifting
      Wire1.write(temp);          //Send the new address to change to
    7,679
    Sorry, I have not fully studied your code. But again it might help to understand more of what the problem is.
    That is all we know so far is it freezes. The question is when? Does it run for awhile or freezes real soon?
    Also the changes for LED are not likely to much for you:
    You run the togglefast and then right after set it high and set it low at the end. Should probably use one method (toggle only at start, or HIGH/LOW)...
    My guess is it has more to do with Device and I2C than the Serial output.
    Again may help to know which sensor you are using. My guess is it is hanging in the reading of it...
    I know at one point I was playing with an SHT-31 sensor and at times it would hang the program...
    Also would help to know how it is hooked up.... What wires do you have connected to it? What voltage are you giving it? Do you have Pull Up resistors?
    Again not much to go on yet.
    If it were me, and I did not have a logic analyzer (which I do), I would probably instrument the code some to get an idea of where it may be hanging???
    Maybe change loop to something like:
      Serial.print(count,DEC); Serial.flush();
      if (count == 0) {
        count = 1;
        Serial.flush(); // make sure it goes out before anything else...
      else {
        Serial.print("("); Serial.flush();
        if (Wire1.getError())
          Serial.print("FAIL\n"); Serial.flush();
        else {
          Serial.print(")"); Serial.flush();
    So you should see Output Serial port like:
    0(Ch...
    1()Range: <the range>
    The use of Serial.flush() in places tells system to send what is currently in the buffer now and not wait for timeout or buffer full. This helps debug as sometimes there will be pending stuff in the Serial buffer, system crashes and you don't see what it actually last output.
    Good Luck
