Results 1 to 2 of 2
Thread: GPS and LoRa modules not working together
    Sep 2020
    2
    Hi everyone,
    I’ve been working on a project that uses a u-blox GPS NEO6MV2 with a NiceRF 2AD66 LoRa device which uses a SX1276 chip. Using the GPS and the LoRa separately they work just fine with the example programs of their libraries (LoRa from sandeepmistry, TinyGPS and TInyGPS++ from mikalhart), even though the GPS had trouble finding a fix sometimes. However, when I used both at the same time, to transmit the gps coordinates, it simply did not work(The GPS could not find location or the LoRa could not send the GPS coordinates). I tried using a Teensy 4.0 and an Arduino Nano as microcontrollers. Does anyone have ideas for a solution?
    Code used with both at the same time:
    #include <LoRa.h>
    #include <TinyGPS++.h>
    #include <SoftwareSerial.h>
       This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
       It requires the use of SoftwareSerial, and assumes that you have a
       4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
    boolean once = true;
    float LAT = 0, LNG = 0;
    long wtime = 0;
    static const int RXPin = 4, TXPin = 3;
    static const uint32_t GPSBaud = 9600;
    // The TinyGPS++ object
    TinyGPSPlus gps;
    // The serial connection to the GPS device
    SoftwareSerial ss(RXPin, TXPin);
    int counter = 0;
      ss.begin(GPSBaud);
      Serial.println(F("DeviceExample.ino"));
      Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
      Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
      Serial.println(F("by Mikal Hart"));
      Serial.println("LoRa Sender");
      if (!LoRa.begin(915E6)) {
        Serial.println("Starting LoRa failed!");
        while (1);
    /*------------------------------Coleta de dados do GPS------------------------*/
      while (ss.available() > 0)
        if (gps.encode(ss.read()))
      if (millis() > 5000 && gps.charsProcessed() < 10)
        Serial.println(F("No GPS detected: check wiring."));
        while(true);
    /*------------------------------Verificação de dados do GPS------------------------*/
    //Quantidade de satélites:
    Serial.print(gps.satellites.value());
    //LATITUDE+LONGITUDE
      if (gps.location.isValid())
        LAT = (gps.location.lat(), 6);
        Serial.print(F(","));
        LNG = (gps.location.lng(), 6);
        if(once == true){
        wtime = millis();
        once = false;
        Serial.print(wtime);
        Serial.println(F("INVALID LOCATION"));
    //DATA
      Serial.print(F("  Date/Time: "));
      if (gps.date.isValid())
        Serial.print(gps.date.month());
        Serial.print(F("/"));
        Serial.print(gps.date.day());
        Serial.print(gps.date.year());
        Serial.print(F("INVALID DATA"));
    //TIME
        Serial.print(F(" "));
      if (gps.time.isValid())
        if (gps.time.hour() < 10) Serial.print(F("0"));
        Serial.print(gps.time.hour());
        Serial.print(F(":"));
        if (gps.time.minute() < 10) Serial.print(F("0"));
        Serial.print(gps.time.minute());
        if (gps.time.second() < 10) Serial.print(F("0"));
        Serial.print(gps.time.second());
        Serial.print(F("."));
        if (gps.time.centisecond() < 10) Serial.print(F("0"));
        Serial.print(gps.time.centisecond());
        Serial.print(F("INVALID TIME"));
      LoRa.beginPacket();
      LoRa.print("Packet number: ");
      LoRa.print(counter);
      LoRa.print(gps.satellites.value());
        LoRa.print(LAT);
        LoRa.print(LNG);
      LoRa.endPacket();
      counter++;
    2,593
    i had a similar problem with GPS and Teensy 4.1 with ethernet. GPS would work ok until Ethernet was activated. I had to use another GPS (NEO-8MU) with active external antenna on a long cable. GPS was on the window sill. I also had an MBED MCU (NUCLEO_F446RE) where GPS wouldn't work with internal antenna. With active external GPS antenna, the GPS would lock on just fine.
