Results 1 to 16 of 16
Thread: Teensy 4.0 analogRead bug
    Hallo friends
    I'm starting with Teensy 4.0 and I have a little problem.
    I want to control the frequency of a waveform with a potentiometer on analog input A0. The potentiometer is connected to the 3.3V supply voltage and GND. The internal reference voltage for the ADC is 3.3V
    The problem: There is a jump at one point in the frequency sweep. The jump in the ADC value can also be seen on the serial plotter. I used a different analog input. It's the same problem. I also tested different ADC resolutions. Without success.
    My hardware
    ADC digital input values
    PHP Code:
    #include <Audio.h>
    #include <Wire.h>
    #include <SPI.h>
    #include <SD.h>
    #include <SerialFlash.h>
    // GUItool: begin automatically generated code
    AudioSynthWaveform       waveform1;      //xy=1123,493
    AudioOutputI2S           i2s1;           //xy=1304,494
    AudioConnection          patchCord1(waveform10i2s10);
    AudioConnection          patchCord2(waveform10i2s11);
    AudioControlSGTL5000     sgtl5000_1;     //xy=1252,563
    // GUItool: end automatically generated code
    void setup() {
    Serial.begin(38400);
    AudioMemory(20);
    sgtl5000_1.enable();
    sgtl5000_1.volume(0.65);
    waveform1.amplitude(0.5);
    int val_1;
    void loop() {
    val_1 analogRead(A0);
    waveform1.frequency(val_1);
    Serial.println(val_1);
    delay(10);
    Greetings Rolf
    May 2015
    USA
    649
    I'd check with volt and ohm meters.
    12,412
    That is perhaps the hysteresis break over point. It has been discussed before in other post(s)
    What version of TeensyDuino is installed? 1.53 is the current.
    Not sure if that was fixed on the analog setup is subsequent releases? If using the latest and still seeing the same result - perhaps prior notes will help.
    12,412
    See this post Teensyduino-1-49-Beta-4
    more notes on page 2 of that thread
    12,412
    Also not sure of using AnalogRead with audio system?
    Jul 2020
    406
    And what value potentiometer are you using?
    Hallo
    I have installed Arduino 1.8.13 and Teensyduino 1.53. I have change resistor from 50K to 10K. Its same Problem.
    The adc resolution ist 10Bit. I will set Oscillator parameters with an poti in my teensy programm.
    reading ADC
    https://youtu.be/PPT20mn968U
    Greetings Rolf
    I do not understand.
    What is the problem with reading an ADC register
    The ADC value (10bit resolution) is Interruption from 492 to 656. The following values from 656 up to 4095 are ok.
    12,412
    That is not the hysteresis point which is at midrange - was just guessing not reading the plotted data values correctly.
    If the same code is done without Audio Library in use in a simple sample does that work?
    Thanks for your help. I will test this
    Here the test without audio interface. I read only ADC input (10Bit). Its same problem.
    code
      analogReadResolution(10);
      analogReadAveraging(20);
      //ADC_CONVERSION_SPEED(VERY_LOW_SPEED);
      // adc->setAveraging(16); // set number of averages
      // adc->setResolution(12); // set bits of resolution
      // adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_LOW_SPEED); // change the conversion speed
      // adc->setSamplingSpeed(ADC_SAMPLING_SPEED::MED_SPEED); // change the sampling speed
    int adc_value;
      adc_value = analogRead(A0);
       Serial.println(adc_value);
        delay(20);
    22,767
    Try adding pinMode(14, INPUT_DISABLE) at the beginning of your program. Does that help at all?
    Do you have an example for me Thanks
    12,412
    That was linked/noted in post #4 above ...
    Yes. It works. Thanks a lot
      pinMode(14, INPUT_DISABLE);
    int adc_value;
        delay(20);
