Results 26 to 50 of 75
Thread: Reading data from CAN bus volkswagen
  1. #26
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    911
    Glad to hear your CAN analyzer has been revived.
    Now I guess it's time to connect the analyzer solo to the OBD port of your Civic and see if you can make sense of what it's happening on the CAN bus.
    Success,
    Paul
  2. #27
    Jul 2022
    17
    I just connected the analyzer to my car to see which data is transmitted and try to interact sending the command and check if there is an answer and which one, but I was not lucky. Too much data on the bus so program gets collapsed and I am not able to see anything. My idea was to use the analyzer as if it was the teensy, sending and receiveing messages to discard a hardware problem. I will keep trying to find what's happening as I am quite sure the arduino code is correct.
    Thank you
  3. #28
    Apr 2015
    Netherlands
    911
    Yeah, I've seen the CAN analyzer program crash as well with too much CAN activity. The program can keep up though when you apply frame-ID filtering.
    Another option is to use the Teensy as a CAN bus monitor. Here is the program I used for showing all CAN data:
    #include <FlexCAN.h>  // TI SN65HVD230 CAN-bus transceiver module: CTX pin 3, CRX pin 4
    static CAN_message_t msg;
    static CAN_filter_t allPassFilter;
      pinMode(LED_BUILTIN, OUTPUT);
      while (!Serial) ;       // wait for serial monitor
      allPassFilter.flags.extended = 0;  // 1 for extended/29 bit IDs
      Can0.begin(500000, allPassFilter); // init CAN bus @ 500kbps
      Serial.println("CAN initialized and listening");
      if (Can0.read(msg)) {
        Serial.printf("0x%08X", msg.id); Serial.print(" ");
        Serial.printf("0x%04X", msg.timestamp); Serial.print(" ");
        Serial.printf("%010u", micros()); Serial.print(" ");
        Serial.printf("0x%02X", msg.flags); Serial.print(" ");
        Serial.printf("0x%02X", msg.len); Serial.print(" ");
        for (byte i = 0; i < sizeof(msg.buf); i++) {
          Serial.printf("0x%02X", msg.buf[i]); Serial.print(" ");
        Serial.println("");
        Can0.write(msg);
    Paul
  4. #29
    Jul 2022
    17
    Thanks Paul, I was trying it and I was able to read all the car data (or at least a lot of data). I also modified the code to request for the engine coolant temps (pid-0x05) but no nswer to it. I was reading a lot and found that on some cars I need to remove the 120ohm resistance on the can transreceiver, I did it but same result. No idea what's happening :S
    Thank you
  5. #30
    Apr 2015
    Netherlands
    911
    Did you see any recognizable CAN data?
    Could it be that your 95 Honda Civic has more than one CAN bus? Where do you actually monitor that CAN data, on the OBD2 connector?
    Paul
  6. #31
    Jul 2022
    17
    I thought about that but I was not able to find any other obd2 port, actually this is where we connect diagnostic machine. It's honda civic 2015 and the obd2 port I am connecting to is just between the steering wheel and pedals.
    Sandra
  7. #32
    Apr 2015
    Netherlands
    911
    So that diagnostic machine you are talking about is able to read out diagnostic data and/or the engine cooling temp?
    If you have that diagnostic machine available you could hook up the Teensy in parallel and scan the CAN bus to see what the diagnostic machine sends out and what is returned by the car.
    Paul
  8. #33
    Jul 2022
    17
    Well this is what I would like to do, but I am still checking if I can buy an OBD2 splitter to be able to connect teensy on one port and diagnostic machine on the other to check which are the messages between them.
  9. #34
    Apr 2015
    Netherlands
    911
    Looked a bit further into the OBD stuff.
    According to this forum your Honda Civic 95 should be the 5th Generation Civic [1992-1995].
    Found a 90 MB service manual and searched for the OBD wiring. As far as I can tell this 5th generation does not have a 16-pin OBD2 interface but a 3-pin OBD1 interface, like this:
    Just checking: is your car really a 5th generation? Does it have an OBD1 or an OBD2 interface?
    Another question: did you perhaps check Honda Civic fora for question related to the OBD issues you see?
    Paul
  10. #35
    Jul 2022
    17
    I'm sure it's an OBD2 port and not OBD1 port, is Honda Civic 2015, not 95, so it's 9th generation. I was not able to find anything on Honda forum, but I just registered so as soon as I can enable my user I will ask if somebody knows something.
  11. #36
    Apr 2015
    Netherlands
    911
    Not sure why I thought you mentioned 95? (I'm getting old I guess...) Anyway, 2015 is definitely OBD2 and that makes live much easier.
    Hope the Civic fora return something useful.
    About the OBD2 splitter you talked about; I assume you're looking for a kind of Y-cable? What about purchasing a short OBD2 extension cable and peel out the CAN-bus signals and GND from that cable and connect the analyzer to them?
    Paul
  12. #37
    Jul 2022
    17
    Maybe I was wrong some time and posted 95 instead of 2015, don't know :S
    I already posted on Honda forum, hopefully I can get a good answer.
    Regarding the splitter yes, I mean an Y-cable but already done, I got a "virgin" OBD2 connector at home, so I welded some wires to the corresponging pins to be able to connect the teensy and the diagnostic machine but I didn't get was expected. I was checking ECT as well, and the temperature was 24, but I a not able to see the corresponding messages on the bus, I just put the results on excel and done a deep search but I am not able to find anything similar to the code I am writting.
    Here some of the messages (I cannot post all of them as there are too much for 2minutes but just some):
    0x0000013C 0xF75C 0019963373 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xF7D3 0019963615 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xF8CD 0019964032 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0xF999 0019964425 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xFA63 0019964822 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xFC80 0019965992 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x0000018E 0x0297 0019969026 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x0349 0019969438 0x00 0x06 0x00 0x73 0xFF 0xFE 0x07 0x1F 0x00 0x00
    0x00000158 0x09C9 0019972809 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x0A45 0019973059 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x0ABB 0019973305 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x101D 0019976036 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0x1093 0019976283 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x110E 0019976530 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x12F1 0019977479 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x1363 0019977728 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x13DF 0019977976 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x15C5 0019978936 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4C 0x0A
    0x00000156 0x1729 0019979617 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x29 0x00 0x00
    0x0000018E 0x178F 0019979865 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x1900 0019980588 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0x1976 0019980835 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x0000013C 0x1DFB 0019983143 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x1E72 0019983395 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x1F66 0019983879 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x205F 0019984303 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x2131 0019984699 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x238A 0019985988 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000156 0x2A53 0019989434 0x00 0x06 0x00 0x73 0xFF 0xFE 0x07 0x3D 0x00 0x00
    0x0000018E 0x2ABA 0019989681 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x30BD 0019992762 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x3139 0019993008 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x31AF 0019993253 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x3719 0019996008 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x378E 0019996254 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x3808 0019996500 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x39E9 0019997439 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x3A5A 0019997687 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x3AD6 0019997936 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000305 0x3CB9 0019998875 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x23 0x00
    0x00000156 0x3E21 0019999580 0x00 0x06 0x00 0x73 0xFF 0xFE 0x07 0x00 0x00 0x00
    0x0000018E 0x3E88 0019999825 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x3ED2 0020000076 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x0000021E 0x3FFA 0020000542 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x000001D8 0x40E0 0020000934 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x419B 0020001320 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0x423A 0020001710 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000295 0x4304 0020002047 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000309 0x43D0 0020002533 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x39
    0x00000158 0x44A0 0020002951 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x451D 0020003199 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x4594 0020003443 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x468E 0020003863 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0x475B 0020004249 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x47A5 0020004492 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000372 0x49D7 0020005505 0x00 0x02 0x00 0x39 0x00 0x00 0x00 0x00 0x00 0x00
    0x0000038C 0x4A19 0020005751 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x1B 0x00 0x00
    0x00000374 0x4A7F 0020005998 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000091 0x4AF0 0020006247 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000377 0x4BA8 0020006542 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x3E
    0x00000378 0x4C8F 0020007006 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xFC
    0x00000386 0x4D7D 0020007482 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x33
    0x000003A1 0x4FC3 0020008572 0x00 0x04 0x00 0x0C 0x00 0x0E 0x00 0x00 0x00 0x00
    0x00000156 0x515E 0020009437 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x15 0x00 0x00
    0x0000018E 0x51C4 0020009685 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x0000013C 0x5889 0020013138 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x00000158 0x58FF 0020013384 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000017C 0x597B 0020013638 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x5E15 0020015978 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x5E8B 0020016223 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x5F06 0020016471 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x60E9 0020017413 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x6159 0020017664 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x61D5 0020017911 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x63B7 0020018868 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4D 0x09
    0x00000156 0x652C 0020019577 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x29 0x00 0x00
    0x0000018E 0x6592 0020019822 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x671C 0020020605 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0x6793 0020020852 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x6B5E 0020022797 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x6BDB 0020023045 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x6C52 0020023287 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x6E3E 0020024195 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x6E94 0020024444 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x71AB 0020026010 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x7868 0020029433 0x00 0x06 0x00 0x72 0xFF 0xF9 0x07 0x33 0x00 0x00
    0x0000018E 0x78CD 0020029676 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x7EDA 0020032777 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x7F56 0020033025 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x7FCC 0020033270 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x8537 0020036022 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x85AC 0020036265 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x8626 0020036511 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x8807 0020037456 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x8878 0020037704 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x88F4 0020037950 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x8BEF 0020039433 0x00 0x06 0x00 0x73 0x00 0x0A 0x07 0x01 0x00 0x00
    0x0000018E 0x8C55 0020039681 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x8CA3 0020039930 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x11
    0x0000021E 0x8DC9 0020040397 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x1F 0x00
    0x000001D8 0x8EAE 0020040791 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x8F69 0020041176 0x00 0x04 0x36 0x00 0x00 0x19 0x00 0x00 0x00 0x00
    0x00000294 0x9008 0020041562 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x11
    0x00000295 0x90D1 0020041899 0x00 0x04 0x00 0x00 0x00 0x17 0x00 0x00 0x00 0x00
    0x00000158 0x9296 0020042890 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x9313 0020043140 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x938A 0020043384 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x9578 0020044285 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0x95CD 0020044533 0x00 0x03 0x00 0x00 0x2A 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0x961A 0020044786 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x98A6 0020045979 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0x9F74 0020049428 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x13 0x00 0x00
    0x0000018E 0x9FD9 0020049674 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xA6A5 0020053159 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xA721 0020053405 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xA797 0020053650 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x0000037C 0xAADF 0020055319 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x2C
    0x00000320 0xAB58 0020055568 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x2D
    0x00000323 0xABD4 0020055813 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2E
    0x00000091 0xAC50 0020056064 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0xACC6 0020056307 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0xAD41 0020056555 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0xADBA 0020056799 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0xAE2C 0020057049 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xAEA8 0020057294 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0xAF24 0020057543 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4E 0x08
    0x00000324 0xB018 0020057992 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0xAD
    0x00000328 0xB10C 0020058491 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x63
    0x0000018E 0xB277 0020059115 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x00000156 0xB33C 0020059565 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x24 0x00 0x00
    0x000001A6 0xB48D 0020060271 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0xB5FB 0020060925 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x000003D7 0xB927 0020062635 0x00 0x08 0xB0 0x00 0x00 0x00 0x00 0x00 0x00 0x33
    0x0000013C 0xBA29 0020063148 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0xBAA0 0020063399 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0xBB94 0020063882 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xBC8D 0020064306 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0xBD5F 0020064702 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xBFC0 0020066011 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000156 0xC67F 0020069434 0x00 0x06 0x00 0x72 0xFF 0xF6 0x07 0x36 0x00 0x00
    0x0000018E 0xC6E6 0020069678 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xCCEA 0020072763 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xCD66 0020073014 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xCDDC 0020073259 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xD338 0020075979 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0xD3AD 0020076224 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0xD427 0020076471 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0xD608 0020077411 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0xD679 0020077658 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xD6F5 0020077907 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0xDA04 0020079428 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x09 0x00 0x00
    0x0000018E 0xDA69 0020079674 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xDBA8 0020080303 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x0000021E 0xDC28 0020080549 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x2E 0x00
    0x000001D8 0xDC96 0020080793 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xDE13 0020081473 0x00 0x04 0x36 0x00 0x00 0x28 0x00 0x00 0x00 0x00
    0x00000294 0xDE6C 0020081721 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x20
    0x00000295 0xDF37 0020082063 0x00 0x04 0x00 0x00 0x00 0x26 0x00 0x00 0x00 0x00
    0x00000158 0xE0B2 0020082900 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xE12F 0020083148 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xE1A6 0020083390 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xE394 0020084300 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x00000039 0xE3EA 0020084549 0x00 0x03 0x00 0x00 0x39 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xE437 0020084798 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xE6BC 0020085981 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0xED8F 0020089440 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x1B 0x00 0x00
    0x0000018E 0xEDF5 0020089685 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xF4B9 0020093154 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xF535 0020093403 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xF5AB 0020093646 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0xFA4A 0020095995 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0xFAC0 0020096240 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0xFB3B 0020096488 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0xFD1E 0020097430 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0xFD8E 0020097679 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xFE0A 0020097925 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0xFFEC 0020098885 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4F 0x07
    0x00000305 0x0064 0020099135 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000156 0x015A 0020099580 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x28 0x00 0x00
    0x0000018E 0x01C0 0020099828 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x0282 0020100208 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0x048F 0020101174 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000309 0x04DC 0020101421 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C
    0x0000038C 0x0558 0020101671 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x2A 0x00 0x00
    0x00000372 0x0687 0020102158 0x00 0x02 0x00 0x0C 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x072F 0020102594 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x05 0x00
    0x0000013C 0x07E3 0020102962 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x085A 0020103216 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x08D7 0020103463 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x09CA 0020103871 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x0A9D 0020104271 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000377 0x0C77 0020105313 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x01
    0x00000091 0x0DF5 0020106068 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000378 0x0E6A 0020106313 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xCF
    0x00000386 0x0F5A 0020106795 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x06
    0x00000405 0x104C 0020107275 0x00 0x08 0x81 0x00 0xA4 0x01 0x00 0x00 0x00 0x25
    0x00000428 0x113F 0020107747 0x00 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x28 0x00
    0x0000042D 0x1229 0020108210 0x00 0x07 0xFF 0xFF 0xFF 0xFF 0xFF 0xFC 0x22 0x00
    0x00000510 0x130B 0020108689 0x00 0x08 0x5D 0x75 0x00 0x00 0x00 0x00 0x00 0x04
    0x00000156 0x14FA 0020109633 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x38 0x00 0x00
    0x0000018E 0x1560 0020109878 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x1B0F 0020112794 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x1B8B 0020113045 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x1C01 0020113290 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x2149 0020115968 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x21BE 0020116213 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x2238 0020116461 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x2419 0020117401 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x248A 0020117649 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x2506 0020117899 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x2819 0020119430 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x0C 0x00 0x00
    0x0000018E 0x287F 0020119679 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001D8 0x2A79 0020120593 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x2B15 0020120993 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x12
    0x0000021E 0x2BD8 0020121366 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x3D 0x00
    0x00000221 0x2CBE 0020121767 0x00 0x04 0x36 0x00 0x00 0x37 0x00 0x00 0x00 0x00
    0x00000294 0x2D7F 0020122230 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x3F
    0x00000295 0x2E49 0020122566 0x00 0x04 0x00 0x00 0x00 0x35 0x00 0x00 0x00 0x00
    0x0000013C 0x2F16 0020123043 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x2F8D 0020123291 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x3081 0020123781 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x317B 0020124204 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0x324D 0020124604 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0x32EF 0020124922 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x34E0 0020126006 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0x3BA0 0020129432 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x15 0x00 0x00
    0x0000018E 0x3C06 0020129680 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x42CD 0020133149 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x4349 0020133397 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x43BF 0020133640 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x4869 0020136012 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0x48DF 0020136256 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x495A 0020136504 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x4B3D 0020137451 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x4BAF 0020137699 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x4C2B 0020137949 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x4E11 0020138914 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x50 0x06
    0x00000156 0x4F86 0020139623 0x00 0x06 0x00 0x72 0xFF 0xF6 0x07 0x27 0x00 0x00
    0x0000018E 0x4FEC 0020139867 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x5176 0020140647 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0x51EC 0020140893 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x559C 0020142788 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x5619 0020143036 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x5690 0020143280 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x587C 0020144184 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x58D2 0020144430 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x5BE7 0020145997 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x0000018E 0x61FB 0020149027 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x62A9 0020149426 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x31 0x00 0x00
    0x00000158 0x6912 0020152754 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x698E 0020153002 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x6A04 0020153247 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x0000037C 0x6CE9 0020154713 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x3B
    0x00000320 0x6D62 0020154960 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x3C
    0x00000323 0x6DDD 0020155210 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3D
    0x00000324 0x6E59 0020155458 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0xBC
    0x00000328 0x6F4E 0020155944 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x72
    0x00000091 0x6FC9 0020156191 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x703E 0020156434 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x70B8 0020156680 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x7131 0020156926 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x71A2 0020157172 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x721E 0020157420 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0x765C 0020159518 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x04 0x00 0x00
    0x0000018E 0x76C2 0020159763 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x7788 0020160152 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x000001D8 0x79A1 0020161143 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x0000021E 0x79ED 0020161392 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x0000040C 0x7A5C 0020161637 0x00 0x08 0x00 0x00 0x00 0x00 0x04 0x00 0x00 0x13
    0x00000221 0x7B97 0020162158 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0x7CBD 0020162822 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000454 0x7D34 0020163069 0x00 0x06 0x10 0xEF 0x01 0x0D 0x20 0x1C 0x00 0x00
    0x0000013C 0x7D98 0020163315 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x7E0F 0020163556 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x7E8C 0020163805 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x7F09 0020164060 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0x7F5F 0020164303 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x8020 0020164550 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000295 0x80E4 0020164880 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000091 0x8384 0020166290 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000465 0x844F 0020166705 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x17
    0x00000156 0x89B3 0020169427 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x13 0x00 0x00
    0x0000018E 0x8A18 0020169672 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x90E0 0020173144 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x915C 0020173391 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x91D2 0020173636 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x9616 0020175803 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x968C 0020176052 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x9707 0020176297 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x98EA 0020177243 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x995A 0020177491 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x99D6 0020177737 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x9BB8 0020178695 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x51 0x05
    0x00000156 0x9D3A 0020179426 0x00 0x06 0x00 0x72 0xFF 0xF9 0x07 0x24 0x00 0x00
    0x0000018E 0x9D9F 0020179669 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001D8 0x9FB2 0020180642 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x9FFF 0020180890 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA1 0x00 0x00 0x01
    0x00000158 0xA3B9 0020182803 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0xA436 0020183051 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0xA4AD 0020183292 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xA699 0020184200 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0xA6EF 0020184446 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xA9F5 0020185981 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0xB0BE 0020189427 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0xB124 0020189675 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xB71E 0020192734 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xB79A 0020192981 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xB810 0020193227 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xBD73 0020195966 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0xBDE8 0020196212 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0xBE62 0020196457 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0xC043 0020197400 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0xC0B4 0020197648 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xC130 0020197895 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000305 0xC315 0020198836 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x05 0x00
    0x00000156 0xC47F 0020199546 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x0C 0x00 0x00
    0x0000018E 0xC4E5 0020199795 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xC52F 0020200044 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA0 0x00 0x00 0x11
    0x0000021E 0xC655 0020200502 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x1F 0x00
    0x000001D8 0xC73A 0020200893 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xC7F5 0020201278 0x00 0x04 0x36 0x00 0x00 0x19 0x00 0x00 0x00 0x00
    0x00000294 0xC894 0020201667 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x11
    0x00000295 0xC95D 0020202006 0x00 0x04 0x00 0x00 0x00 0x17 0x00 0x00 0x00 0x00
    0x00000309 0xCA28 0020202491 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1B
    0x00000372 0xCAF9 0020202793 0x00 0x02 0x00 0x1B 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xCBB8 0020203291 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xCC35 0020203540 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xCCAC 0020203782 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xCDA6 0020204198 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0xCE72 0020204592 0x00 0x03 0x00 0x00 0x2A 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xCF3C 0020204996 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000374 0xD0B5 0020205822 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x14 0x00
    0x00000091 0xD126 0020206070 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000377 0xD19C 0020206313 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x10
    0x00000378 0xD371 0020207240 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xDE
    0x0000038C 0xD3E8 0020207480 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x39 0x00 0x00
    0x00000386 0xD44F 0020207727 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x15
    0x000003A1 0xD621 0020208546 0x00 0x04 0x00 0x0C 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000156 0xD7C9 0020209428 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x13 0x00 0x00
    0x0000018E 0xD82E 0020209676 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000401 0xD9CC 0020210481 0x00 0x07 0x00 0x00 0x00 0x01 0x00 0x00 0x02 0x00
    0x00000158 0xDE49 0020212804 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xDEC5 0020213053 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xDF3B 0020213299 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0xE48E 0020216003 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0xE504 0020216249 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0xE57F 0020216495 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0xE762 0020217442 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0xE7D4 0020217688 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xE850 0020217941 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0xEA36 0020218900 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x52 0x04
    0x00000156 0xEBB4 0020219630 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x22 0x00 0x00
    0x0000018E 0xEC1A 0020219874 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xED9D 0020220644 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA1 0x00 0x00 0x2F
    0x000001D8 0xEE13 0020220890 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xF1C8 0020222789 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0xF245 0020223040 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0xF2BC 0020223282 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xF4A8 0020224187 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0xF4FE 0020224433 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xF813 0020226004 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0xFED4 0020229427 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0xFF3A 0020229672 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x053F 0020232758 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x05BB 0020233009 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x0631 0020233255 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x0B99 0020235999 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x0C0E 0020236244 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x0C88 0020236493 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x0E69 0020237429 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x0EDA 0020237678 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x0F56 0020237928 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x0000018E 0x11B8 0020239047 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x1258 0020239424 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x0A 0x00 0x00
    0x000001A6 0x1336 0020239904 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA0 0x00 0x00 0x3F
    0x0000021E 0x1414 0020240331 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x2E 0x00
    0x00000221 0x14FA 0020240735 0x00 0x04 0x36 0x00 0x00 0x28 0x00 0x00 0x00 0x00
    0x000001D8 0x154D 0020240978 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000294 0x16A6 0020241662 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x20
    0x00000295 0x1726 0020241908 0x00 0x04 0x00 0x00 0x00 0x26 0x00 0x00 0x00 0x00
    0x0000013C 0x1983 0020243127 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x19FA 0020243379 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x1AEE 0020243868 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x1BE8 0020244294 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x00000039 0x1C3E 0020244542 0x00 0x03 0x00 0x00 0x39 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0x1DAB 0020245168 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x1F11 0020245972 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0x25E5 0020249441 0x00 0x06 0x00 0x73 0xFF 0xFB 0x07 0x12 0x00 0x00
    0x0000018E 0x264B 0020249689 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x2C52 0020252774 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x2CCE 0020253026 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x2D44 0020253268 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x0000037C 0x30B9 0020255026 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x0E
    0x00000320 0x3133 0020255276 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x0F
    0x00000323 0x31B0 0020255524 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000324 0x322C 0020255773 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0x8F
    0x00000091 0x32A6 0020256016 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0x331C 0020256262 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x3397 0020256509 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x3410 0020256754 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x3480 0020257001 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x34FC 0020257246 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x3577 0020257495 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x53 0x03
    0x00000328 0x366B 0020257945 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x45
    0x00000156 0x39C0 0020259609 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x22 0x00 0x00
    0x0000018E 0x3A25 0020259856 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x3ADF 0020260223 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA0 0x00 0x00 0x02
    0x000001D8 0x3C4F 0020260872 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x000003D7 0x3F03 0020262344 0x00 0x08 0xB0 0x00 0x00 0x00 0x00 0x00 0x00 0x42
    0x0000013C 0x4004 0020262856 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x407B 0020263104 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x40F8 0020263352 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x41EB 0020263764 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x42BE 0020264166 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x461B 0020265969 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x4CE9 0020269426 0x00 0x06 0x00 0x73 0xFF 0xFB 0x07 0x30 0x00 0x00
    0x0000018E 0x4D50 0020269669 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x5357 0020272763 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x53D3 0020273011 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x5449 0020273257 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x59B1 0020276005 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x5A26 0020276249 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x5AA0 0020276497 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x5C81 0020277433 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x5CF2 0020277683 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x5D6E 0020277933 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x606E 0020279424 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x01 0x00 0x00
    0x0000018E 0x60D5 0020279669 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x61B7 0020280117 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x11
    0x0000021E 0x6277 0020280485 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x3D 0x00
    0x000001D8 0x635C 0020280873 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x6417 0020281259 0x00 0x04 0x36 0x00 0x00 0x37 0x00 0x00 0x00 0x00
    0x00000294 0x64B5 0020281653 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x3F
    0x00000295 0x657F 0020281985 0x00 0x04 0x00 0x00 0x00 0x35 0x00 0x00 0x00 0x00
    0x00000158 0x6761 0020283031 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x67DE 0020283279 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x6855 0020283520 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x00000039 0x6A43 0020284409 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001DC 0x6A90 0020284656 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x000001ED 0x6AE5 0020284907 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x6D3B 0020286013 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0x73F3 0020289424 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x10 0x00 0x00
    0x0000018E 0x745A 0020289667 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x7A65 0020292771 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x7AE1 0020293020 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x7B57 0020293266 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x80B1 0020295984 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x8127 0020296232 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x81A2 0020296481 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x8385 0020297421 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x83F7 0020297671 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x8473 0020297920 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x8659 0020298884 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x54 0x02
    0x00000305 0x86D1 0020299130 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x14 0x00
    0x00000156 0x87C9 0020299587 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x27 0x00 0x00
    0x0000018E 0x882F 0020299832 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x88F1 0020300209 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x21
    0x000001D8 0x8AFC 0020301174 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x00000309 0x8B49 0020301422 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2A
    0x0000038C 0x8BC4 0020301669 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x0C 0x00 0x00
    0x00000372 0x8CF2 0020302157 0x00 0x02 0x00 0x2A 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x8D9B 0020302587 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x23 0x00
    0x0000013C 0x8E4F 0020302963 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x8EC6 0020303214 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x8F43 0020303459 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x9036 0020303867 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x9109 0020304268 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000377 0x92E0 0020305299 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x2F
    0x00000091 0x9454 0020306040 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000378 0x94C9 0020306286 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xED
    0x00000386 0x95B9 0020306761 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x24
    0x00000156 0x9AFE 0020309422 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0x9B64 0020309667 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xA165 0020312748 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xA1E1 0020312995 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xA257 0020313240 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xA7B4 0020315962 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0xA829 0020316211 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0xA8A3 0020316460 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0xAA84 0020317396 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0xAAF5 0020317644 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xAB71 0020317893 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0xAE84 0020319422 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x0A 0x00 0x00
    0x0000018E 0xAEEA 0020319668 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xAFCC 0020320112 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x30
    0x0000021E 0xB08C 0020320481 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x000001D8 0xB171 0020320869 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xB22C 0020321258 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0xB2CB 0020321650 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000295 0xB395 0020321986 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000158 0xB569 0020323002 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xB5E6 0020323247 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xB65D 0020323492 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xB84B 0020324401 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0xB8A1 0020324646 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0xB8EB 0020324894 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xBAB6 0020325704 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x0000018E 0xC15D 0020329024 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000156 0xC209 0020329423 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x15 0x00 0x00
    0x00000158 0xC886 0020332790 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xC902 0020333039 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xC978 0020333285 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0xCECC 0020335993 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0xCF42 0020336241 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0xCFBD 0020336489 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0xD1A0 0020337429 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0xD210 0020337677 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xD28C 0020337926 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0xD46E 0020338881 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x55 0x01
    0x00000156 0xD5E7 0020339599 0x00 0x06 0x00 0x73 0xFF 0xFB 0x07 0x21 0x00 0x00
    0x0000018E 0xD64D 0020339842 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xD7CF 0020340612 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0xD847 0020340859 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xDC03 0020342775 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0xDC80 0020343025 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0xDCF7 0020343268 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xDEE3 0020344168 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0xDF39 0020344415 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xE23F 0020345953 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0xE915 0020349426 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x3E 0x00 0x00
    0x0000018E 0xE97D 0020349670 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xF034 0020353113 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xF0B0 0020353361 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xF126 0020353606 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x0000037C 0xF3CA 0020354947 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x1D
    0x00000320 0xF444 0020355200 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x1E
    0x00000323 0xF4C2 0020355451 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F
    0x00000324 0xF53F 0020355700 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0x9E
    0x00000091 0xF636 0020356178 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0xF6AB 0020356424 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0xF725 0020356671 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0xF79E 0020356917 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0xF80F 0020357163 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xF88B 0020357412 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000328 0xF984 0020357886 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x54
    0x00000156 0xFCCD 0020359528 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x04 0x00 0x00
    0x0000018E 0xFD34 0020359773 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xFDFA 0020360161 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x11
    0x0000021E 0xFEEC 0020360630 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x1F 0x00
    0x000001D8 0xFFC2 0020360989 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x0058 0020361303 0x00 0x04 0x36 0x00 0x00 0x19 0x00 0x00 0x00 0x00
    0x00000294 0x0121 0020361778 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x11
    0x00000295 0x0206 0020362165 0x00 0x04 0x00 0x00 0x00 0x17 0x00 0x00 0x00 0x00
    0x00000158 0x0377 0020362988 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x03F4 0020363236 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x046B 0020363481 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x04E8 0020363729 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x000001ED 0x053D 0020363976 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x06CF 0020364604 0x00 0x03 0x00 0x00 0x2A 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x0985 0020366074 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0x101F 0020369422 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x10 0x00 0x00
    0x0000018E 0x1086 0020369666 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x168B 0020372756 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x1707 0020373005 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x177D 0020373251 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x1CCD 0020375948 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x1D43 0020376198 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x1DBE 0020376448 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x1FA1 0020377388 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x2013 0020377637 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x208F 0020377887 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x2275 0020378849 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x56 0x00
    0x00000156 0x23ED 0020379567 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x22 0x00 0x00
    0x0000018E 0x2453 0020379813 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001D8 0x265D 0020380765 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x26AA 0020381011 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x00000158 0x2A1B 0020382779 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x2A98 0020383030 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x2B0F 0020383272 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x2CFB 0020384173 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x2D51 0020384418 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x3059 0020385962 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x372A 0020389419 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0x3790 0020389664 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x3E49 0020393110 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x3EC5 0020393358 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x3F3B 0020393603 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x43E1 0020395963 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x4456 0020396210 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x44D0 0020396457 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x46B1 0020397397 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x4722 0020397645 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x479E 0020397894 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000305 0x4981 0020398836 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x23 0x00
    0x00000156 0x4AE8 0020399532 0x00 0x06 0x00 0x72 0x00 0x05 0x07 0x07 0x00 0x00
    0x0000018E 0x4B4E 0020399778 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x4CD8 0020400563 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x0000021E 0x4D55 0020400809 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x2E 0x00
    0x000001D8 0x4DC3 0020401057 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x4F40 0020401721 0x00 0x04 0x36 0x00 0x00 0x28 0x00 0x00 0x00 0x00
    0x0000038C 0x4F93 0020401969 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x1B 0x00 0x00
    0x00000294 0x4FF9 0020402218 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x20
    0x00000295 0x50C3 0020402499 0x00 0x04 0x00 0x00 0x00 0x26 0x00 0x00 0x00 0x00
    0x00000309 0x518F 0020402983 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x39
    0x0000013C 0x520A 0020403233 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x5281 0020403476 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x52FE 0020403721 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x537B 0020403968 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0x53D1 0020404219 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000372 0x5470 0020404472 0x00 0x02 0x00 0x39 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x54B2 0020404716 0x00 0x03 0x00 0x00 0x39 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x557A 0020404973 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000377 0x5662 0020405445 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x3E
    0x00000378 0x5755 0020405934 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xFC
    0x00000091 0x57CD 0020406176 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000386 0x58C0 0020406667 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x33
    0x000003A1 0x5D1C 0020408820 0x00 0x04 0x00 0x0C 0x00 0x2C 0x00 0x00 0x00 0x00
    0x00000156 0x5E4B 0020409466 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x18 0x00 0x00
    0x0000018E 0x5EB0 0020409710 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000405 0x5EFA 0020409959 0x00 0x08 0x81 0x00 0xA4 0x01 0x00 0x00 0x00 0x34
    0x00000428 0x6022 0020410437 0x00 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x37 0x00
    0x0000042D 0x610F 0020410902 0x00 0x07 0xFF 0xFF 0xFF 0xFF 0xFF 0xFC 0x31 0x00
    0x00000158 0x649D 0020412751 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x6519 0020413001 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x658F 0020413246 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x6AE4 0020415951 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x6B5A 0020416201 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x6BD5 0020416446 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x6DB8 0020417389 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x6E28 0020417637 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x6EA4 0020417887 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x7086 0020418842 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x57 0xFF
    0x0000018E 0x7111 0020419089 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x71F4 0020419537 0x00 0x06 0x00 0x72 0xFF 0xF6 0x07 0x27 0x00 0x00
    0x000001D8 0x747C 0020420786 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x7515 0020421171 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x02
    0x00000158 0x7827 0020422759 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x78A4 0020423009 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x791B 0020423251 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x7B07 0020424154 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x7B5D 0020424400 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x7E6D 0020425960 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x853E 0020429418 0x00 0x06 0x00 0x73 0x00 0x0A 0x07 0x3E 0x00 0x00
    0x0000018E 0x85A4 0020429663 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x8C5C 0020433107 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x8CD8 0020433355 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x8D4E 0020433600 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x91F1 0020435950 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x9266 0020436196 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x92E0 0020436444 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x94C1 0020437383 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x9532 0020437631 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x95AE 0020437882 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x98C5 0020439422 0x00 0x06 0x00 0x72 0xFF 0xF9 0x07 0x06 0x00 0x00
    0x0000018E 0x992B 0020439669 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x9AB5 0020440446 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x12
    0x0000021E 0x9B32 0020440692 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x3D 0x00
    0x000001D8 0x9BA2 0020440936 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x9D20 0020441612 0x00 0x04 0x36 0x00 0x00 0x37 0x00 0x00 0x00 0x00
    0x00000294 0x9E4D 0020442290 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x3F
    0x00000295 0x9ECB 0020442537 0x00 0x04 0x00 0x00 0x00 0x35 0x00 0x00 0x00 0x00
    0x0000013C 0x9FB8 0020443016 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0xA02F 0020443264 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0xA123 0020443754 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xA21D 0020444174 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0xA2EF 0020444577 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xA391 0020444895 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xA585 0020445985 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0xAC49 0020449422 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x10 0x00 0x00
    0x0000018E 0xACB0 0020449668 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xB2B0 0020452740 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xB32C 0020452991 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xB3A2 0020453235 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x0000037C 0xB753 0020455108 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x2C
    0x00000320 0xB7CC 0020455358 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x2D
    0x00000323 0xB848 0020455608 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2E
    0x00000324 0xB8C4 0020455853 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0xAD
    0x00000091 0xB93C 0020456101 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0xB9B2 0020456345 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0xBA2D 0020456592 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0xBAA6 0020456839 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0xBB18 0020457086 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xBB94 0020457332 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0xBC10 0020457580 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x58 0xFE
    0x00000328 0xBD04 0020458032 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x63
    0x00000156 0xBFDE 0020459446 0x00 0x06 0x00 0x72 0x00 0x05 0x07 0x25 0x00 0x00
    0x0000018E 0xC043 0020459692 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xC178 0020460301 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0xC2E6 0020460952 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x000003D7 0xC599 0020462428 0x00 0x08 0xB0 0x00 0x00 0x00 0x00 0x00 0x00 0x15
    0x0000040C 0xC614 0020462676 0x00 0x08 0x01 0x53 0x48 0x48 0x46 0x4B 0x33 0x26
    0x00000454 0xC688 0020462917 0x00 0x06 0x10 0xEF 0x01 0x0D 0x20 0x2B 0x00 0x00
    0x0000013C 0xC6EA 0020463165 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0xC761 0020463405 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0xC7DE 0020463654 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xC85A 0020463906 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0xC8B0 0020464153 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000465 0xCC5B 0020465887 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x26
    0x00000091 0xCCD5 0020466139 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000156 0xD354 0020469418 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x33 0x00 0x00
    0x0000018E 0xD3B9 0020469663 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xDA70 0020473106 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xDAEC 0020473352 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xDB62 0020473596 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xE001 0020475940 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0xE076 0020476189 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0xE0F0 0020476434 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0xE2D1 0020477374 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0xE342 0020477621 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xE3BE 0020477871 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0xE6D8 0020479416 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x04 0x00 0x00
    0x0000018E 0xE73E 0020479661 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xE901 0020480553 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x30
    0x0000021E 0xE97D 0020480799 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x000001D8 0xE9EC 0020481050 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xEB69 0020481718 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0xEC98 0020482398 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000295 0xED16 0020482643 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000158 0xED7C 0020482893 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xEDF9 0020483142 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xEE70 0020483385 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xEEED 0020483630 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0xEF43 0020483882 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0xF0D6 0020484487 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xF38C 0020485960 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0xFA5E 0020489420 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x19 0x00 0x00
    0x0000018E 0xFAC5 0020489665 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x00C0 0020492732 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x013C 0020492984 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x01B2 0020493229 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x070F 0020495949 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x0785 0020496197 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x0800 0020496446 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x09E3 0020497387 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x0A53 0020497635 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x0ACF 0020497886 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x0CB1 0020498838 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x59 0xFD
    0x00000305 0x0D28 0020499085 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000156 0x0E23 0020499546 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x29 0x00 0x00
    0x0000018E 0x0E89 0020499794 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x0F4A 0020500170 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0x1157 0020501134 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000309 0x11A4 0020501384 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C
    0x0000038C 0x1220 0020501634 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x2A 0x00 0x00
    0x00000372 0x134F 0020502121 0x00 0x02 0x00 0x0C 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x13F7 0020502555 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x05 0x00
    0x00000377 0x14AB 0020502922 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x01
    0x0000013C 0x1522 0020503172 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x1599 0020503416 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x1616 0020503662 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x1692 0020503909 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x16E8 0020504157 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000378 0x1A2D 0020505746 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xCF
    0x00000091 0x1AA4 0020505989 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000386 0x1B19 0020506236 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x06
    0x0000018E 0x20BE 0020509024 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x2168 0020509420 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x3E 0x00 0x00
    0x00000401 0x236B 0020510469 0x00 0x07 0x00 0x00 0x00 0x01 0x00 0x00 0x11 0x00
    0x00000158 0x27CD 0020512738 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x2849 0020512986 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x28BF 0020513232 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x2E1C 0020515954 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x2E91 0020516202 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x2F0B 0020516451 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x30EC 0020517385 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x315D 0020517638 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x31D9 0020517884 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x34ED 0020519414 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x09 0x00 0x00
    0x0000018E 0x3552 0020519660 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x36D3 0020520423 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x12
    Sandra
  13. #38
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    911
    What you saw on the CAN bus are all messages that the different modules in your car [e.g. PCM, BCM, TPM etc etc] are exchanging.
    It may wel be that one of the messages was the reporting of the ECT (maybe once a minute). However that could be a Honda-specific message, not necessarily in OBD2 format...
    I just realized that a lot of scanners are using the K-line interface of the OBD2 port, not the CANH/CANL interface. K-line is a lower-speed, lower-cost interface, aimed at diagnostic tools.
    I have a VAG VCDS scanner which can use both CAN bus and K-line interface for diagnostics. But the scanner I have for my BMW motorbike is K-line only.
    So be aware of that when monitoring to see what the your scanner is actually doing.
    Paul
    PS: you may want to insert long dumps in forum messages using CODE tags [use the # button] to avoid scrolling down a lot of pages, like so:
    0x0000013C 0xF75C 0019963373 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xF7D3 0019963615 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xF8CD 0019964032 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0xF999 0019964425 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xFA63 0019964822 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xFC80 0019965992 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x0000018E 0x0297 0019969026 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x0349 0019969438 0x00 0x06 0x00 0x73 0xFF 0xFE 0x07 0x1F 0x00 0x00
    0x00000158 0x09C9 0019972809 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x0A45 0019973059 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x0ABB 0019973305 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x101D 0019976036 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0x1093 0019976283 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x110E 0019976530 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x12F1 0019977479 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x1363 0019977728 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x13DF 0019977976 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x15C5 0019978936 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4C 0x0A
    0x00000156 0x1729 0019979617 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x29 0x00 0x00
    0x0000018E 0x178F 0019979865 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x1900 0019980588 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0x1976 0019980835 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x0000013C 0x1DFB 0019983143 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x1E72 0019983395 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x1F66 0019983879 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x205F 0019984303 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x2131 0019984699 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x238A 0019985988 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000156 0x2A53 0019989434 0x00 0x06 0x00 0x73 0xFF 0xFE 0x07 0x3D 0x00 0x00
    0x0000018E 0x2ABA 0019989681 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x30BD 0019992762 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x3139 0019993008 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x31AF 0019993253 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x3719 0019996008 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x378E 0019996254 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x3808 0019996500 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x39E9 0019997439 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x3A5A 0019997687 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x3AD6 0019997936 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000305 0x3CB9 0019998875 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x23 0x00
    0x00000156 0x3E21 0019999580 0x00 0x06 0x00 0x73 0xFF 0xFE 0x07 0x00 0x00 0x00
    0x0000018E 0x3E88 0019999825 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x3ED2 0020000076 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x0000021E 0x3FFA 0020000542 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x000001D8 0x40E0 0020000934 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x419B 0020001320 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0x423A 0020001710 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000295 0x4304 0020002047 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000309 0x43D0 0020002533 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x39
    0x00000158 0x44A0 0020002951 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x451D 0020003199 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x4594 0020003443 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x468E 0020003863 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0x475B 0020004249 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x47A5 0020004492 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000372 0x49D7 0020005505 0x00 0x02 0x00 0x39 0x00 0x00 0x00 0x00 0x00 0x00
    0x0000038C 0x4A19 0020005751 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x1B 0x00 0x00
    0x00000374 0x4A7F 0020005998 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000091 0x4AF0 0020006247 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000377 0x4BA8 0020006542 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x3E
    0x00000378 0x4C8F 0020007006 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xFC
    0x00000386 0x4D7D 0020007482 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x33
    0x000003A1 0x4FC3 0020008572 0x00 0x04 0x00 0x0C 0x00 0x0E 0x00 0x00 0x00 0x00
    0x00000156 0x515E 0020009437 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x15 0x00 0x00
    0x0000018E 0x51C4 0020009685 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x0000013C 0x5889 0020013138 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x00000158 0x58FF 0020013384 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000017C 0x597B 0020013638 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x5E15 0020015978 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x5E8B 0020016223 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x5F06 0020016471 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x60E9 0020017413 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x6159 0020017664 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x61D5 0020017911 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x63B7 0020018868 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4D 0x09
    0x00000156 0x652C 0020019577 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x29 0x00 0x00
    0x0000018E 0x6592 0020019822 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x671C 0020020605 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0x6793 0020020852 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x6B5E 0020022797 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x6BDB 0020023045 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x6C52 0020023287 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x6E3E 0020024195 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x6E94 0020024444 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x71AB 0020026010 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x7868 0020029433 0x00 0x06 0x00 0x72 0xFF 0xF9 0x07 0x33 0x00 0x00
    0x0000018E 0x78CD 0020029676 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x7EDA 0020032777 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x7F56 0020033025 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x7FCC 0020033270 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x8537 0020036022 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x85AC 0020036265 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x8626 0020036511 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x8807 0020037456 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x8878 0020037704 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x88F4 0020037950 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x8BEF 0020039433 0x00 0x06 0x00 0x73 0x00 0x0A 0x07 0x01 0x00 0x00
    0x0000018E 0x8C55 0020039681 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x8CA3 0020039930 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x11
    0x0000021E 0x8DC9 0020040397 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x1F 0x00
    0x000001D8 0x8EAE 0020040791 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x8F69 0020041176 0x00 0x04 0x36 0x00 0x00 0x19 0x00 0x00 0x00 0x00
    0x00000294 0x9008 0020041562 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x11
    0x00000295 0x90D1 0020041899 0x00 0x04 0x00 0x00 0x00 0x17 0x00 0x00 0x00 0x00
    0x00000158 0x9296 0020042890 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x9313 0020043140 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x938A 0020043384 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x9578 0020044285 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0x95CD 0020044533 0x00 0x03 0x00 0x00 0x2A 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0x961A 0020044786 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x98A6 0020045979 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0x9F74 0020049428 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x13 0x00 0x00
    0x0000018E 0x9FD9 0020049674 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xA6A5 0020053159 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xA721 0020053405 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xA797 0020053650 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x0000037C 0xAADF 0020055319 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x2C
    0x00000320 0xAB58 0020055568 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x2D
    0x00000323 0xABD4 0020055813 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2E
    0x00000091 0xAC50 0020056064 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0xACC6 0020056307 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0xAD41 0020056555 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0xADBA 0020056799 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0xAE2C 0020057049 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xAEA8 0020057294 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0xAF24 0020057543 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4E 0x08
    0x00000324 0xB018 0020057992 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0xAD
    0x00000328 0xB10C 0020058491 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x63
    0x0000018E 0xB277 0020059115 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x00000156 0xB33C 0020059565 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x24 0x00 0x00
    0x000001A6 0xB48D 0020060271 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0xB5FB 0020060925 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x000003D7 0xB927 0020062635 0x00 0x08 0xB0 0x00 0x00 0x00 0x00 0x00 0x00 0x33
    0x0000013C 0xBA29 0020063148 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0xBAA0 0020063399 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0xBB94 0020063882 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xBC8D 0020064306 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0xBD5F 0020064702 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xBFC0 0020066011 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000156 0xC67F 0020069434 0x00 0x06 0x00 0x72 0xFF 0xF6 0x07 0x36 0x00 0x00
    0x0000018E 0xC6E6 0020069678 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xCCEA 0020072763 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xCD66 0020073014 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xCDDC 0020073259 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xD338 0020075979 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0xD3AD 0020076224 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0xD427 0020076471 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0xD608 0020077411 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0xD679 0020077658 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xD6F5 0020077907 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0xDA04 0020079428 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x09 0x00 0x00
    0x0000018E 0xDA69 0020079674 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xDBA8 0020080303 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x0000021E 0xDC28 0020080549 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x2E 0x00
    0x000001D8 0xDC96 0020080793 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xDE13 0020081473 0x00 0x04 0x36 0x00 0x00 0x28 0x00 0x00 0x00 0x00
    0x00000294 0xDE6C 0020081721 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x20
    0x00000295 0xDF37 0020082063 0x00 0x04 0x00 0x00 0x00 0x26 0x00 0x00 0x00 0x00
    0x00000158 0xE0B2 0020082900 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xE12F 0020083148 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xE1A6 0020083390 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xE394 0020084300 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x00000039 0xE3EA 0020084549 0x00 0x03 0x00 0x00 0x39 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xE437 0020084798 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xE6BC 0020085981 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0xED8F 0020089440 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x1B 0x00 0x00
    0x0000018E 0xEDF5 0020089685 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xF4B9 0020093154 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xF535 0020093403 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xF5AB 0020093646 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0xFA4A 0020095995 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0xFAC0 0020096240 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0xFB3B 0020096488 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0xFD1E 0020097430 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0xFD8E 0020097679 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xFE0A 0020097925 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0xFFEC 0020098885 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x4F 0x07
    0x00000305 0x0064 0020099135 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000156 0x015A 0020099580 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x28 0x00 0x00
    0x0000018E 0x01C0 0020099828 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x0282 0020100208 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0x048F 0020101174 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000309 0x04DC 0020101421 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C
    0x0000038C 0x0558 0020101671 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x2A 0x00 0x00
    0x00000372 0x0687 0020102158 0x00 0x02 0x00 0x0C 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x072F 0020102594 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x05 0x00
    0x0000013C 0x07E3 0020102962 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x085A 0020103216 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x08D7 0020103463 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x09CA 0020103871 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x0A9D 0020104271 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000377 0x0C77 0020105313 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x01
    0x00000091 0x0DF5 0020106068 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000378 0x0E6A 0020106313 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xCF
    0x00000386 0x0F5A 0020106795 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x06
    0x00000405 0x104C 0020107275 0x00 0x08 0x81 0x00 0xA4 0x01 0x00 0x00 0x00 0x25
    0x00000428 0x113F 0020107747 0x00 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x28 0x00
    0x0000042D 0x1229 0020108210 0x00 0x07 0xFF 0xFF 0xFF 0xFF 0xFF 0xFC 0x22 0x00
    0x00000510 0x130B 0020108689 0x00 0x08 0x5D 0x75 0x00 0x00 0x00 0x00 0x00 0x04
    0x00000156 0x14FA 0020109633 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x38 0x00 0x00
    0x0000018E 0x1560 0020109878 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x1B0F 0020112794 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x1B8B 0020113045 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x1C01 0020113290 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x2149 0020115968 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x21BE 0020116213 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x2238 0020116461 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x2419 0020117401 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x248A 0020117649 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x2506 0020117899 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x2819 0020119430 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x0C 0x00 0x00
    0x0000018E 0x287F 0020119679 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001D8 0x2A79 0020120593 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x2B15 0020120993 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x12
    0x0000021E 0x2BD8 0020121366 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x3D 0x00
    0x00000221 0x2CBE 0020121767 0x00 0x04 0x36 0x00 0x00 0x37 0x00 0x00 0x00 0x00
    0x00000294 0x2D7F 0020122230 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x3F
    0x00000295 0x2E49 0020122566 0x00 0x04 0x00 0x00 0x00 0x35 0x00 0x00 0x00 0x00
    0x0000013C 0x2F16 0020123043 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x2F8D 0020123291 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x3081 0020123781 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x317B 0020124204 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0x324D 0020124604 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0x32EF 0020124922 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x34E0 0020126006 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0x3BA0 0020129432 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x15 0x00 0x00
    0x0000018E 0x3C06 0020129680 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x42CD 0020133149 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x4349 0020133397 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x43BF 0020133640 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x4869 0020136012 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0x48DF 0020136256 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x495A 0020136504 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x4B3D 0020137451 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x4BAF 0020137699 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x4C2B 0020137949 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x4E11 0020138914 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x50 0x06
    0x00000156 0x4F86 0020139623 0x00 0x06 0x00 0x72 0xFF 0xF6 0x07 0x27 0x00 0x00
    0x0000018E 0x4FEC 0020139867 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x5176 0020140647 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0x51EC 0020140893 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x559C 0020142788 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x5619 0020143036 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x5690 0020143280 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x587C 0020144184 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x58D2 0020144430 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x5BE7 0020145997 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x0000018E 0x61FB 0020149027 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x62A9 0020149426 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x31 0x00 0x00
    0x00000158 0x6912 0020152754 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x698E 0020153002 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x6A04 0020153247 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x0000037C 0x6CE9 0020154713 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x3B
    0x00000320 0x6D62 0020154960 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x3C
    0x00000323 0x6DDD 0020155210 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3D
    0x00000324 0x6E59 0020155458 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0xBC
    0x00000328 0x6F4E 0020155944 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x72
    0x00000091 0x6FC9 0020156191 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x703E 0020156434 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x70B8 0020156680 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x7131 0020156926 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x71A2 0020157172 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x721E 0020157420 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0x765C 0020159518 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x04 0x00 0x00
    0x0000018E 0x76C2 0020159763 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x7788 0020160152 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x000001D8 0x79A1 0020161143 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x0000021E 0x79ED 0020161392 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x0000040C 0x7A5C 0020161637 0x00 0x08 0x00 0x00 0x00 0x00 0x04 0x00 0x00 0x13
    0x00000221 0x7B97 0020162158 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0x7CBD 0020162822 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000454 0x7D34 0020163069 0x00 0x06 0x10 0xEF 0x01 0x0D 0x20 0x1C 0x00 0x00
    0x0000013C 0x7D98 0020163315 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x7E0F 0020163556 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x7E8C 0020163805 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x7F09 0020164060 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0x7F5F 0020164303 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x8020 0020164550 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000295 0x80E4 0020164880 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000091 0x8384 0020166290 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000465 0x844F 0020166705 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x17
    0x00000156 0x89B3 0020169427 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x13 0x00 0x00
    0x0000018E 0x8A18 0020169672 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x90E0 0020173144 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x915C 0020173391 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x91D2 0020173636 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x9616 0020175803 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x968C 0020176052 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x9707 0020176297 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x98EA 0020177243 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x995A 0020177491 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x99D6 0020177737 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x9BB8 0020178695 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x51 0x05
    0x00000156 0x9D3A 0020179426 0x00 0x06 0x00 0x72 0xFF 0xF9 0x07 0x24 0x00 0x00
    0x0000018E 0x9D9F 0020179669 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001D8 0x9FB2 0020180642 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x9FFF 0020180890 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA1 0x00 0x00 0x01
    0x00000158 0xA3B9 0020182803 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0xA436 0020183051 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0xA4AD 0020183292 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xA699 0020184200 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0xA6EF 0020184446 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xA9F5 0020185981 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0xB0BE 0020189427 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0xB124 0020189675 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xB71E 0020192734 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xB79A 0020192981 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xB810 0020193227 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xBD73 0020195966 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0xBDE8 0020196212 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0xBE62 0020196457 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0xC043 0020197400 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0xC0B4 0020197648 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xC130 0020197895 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000305 0xC315 0020198836 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x05 0x00
    0x00000156 0xC47F 0020199546 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x0C 0x00 0x00
    0x0000018E 0xC4E5 0020199795 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xC52F 0020200044 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA0 0x00 0x00 0x11
    0x0000021E 0xC655 0020200502 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x1F 0x00
    0x000001D8 0xC73A 0020200893 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xC7F5 0020201278 0x00 0x04 0x36 0x00 0x00 0x19 0x00 0x00 0x00 0x00
    0x00000294 0xC894 0020201667 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x11
    0x00000295 0xC95D 0020202006 0x00 0x04 0x00 0x00 0x00 0x17 0x00 0x00 0x00 0x00
    0x00000309 0xCA28 0020202491 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1B
    0x00000372 0xCAF9 0020202793 0x00 0x02 0x00 0x1B 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xCBB8 0020203291 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xCC35 0020203540 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xCCAC 0020203782 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xCDA6 0020204198 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0xCE72 0020204592 0x00 0x03 0x00 0x00 0x2A 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xCF3C 0020204996 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000374 0xD0B5 0020205822 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x14 0x00
    0x00000091 0xD126 0020206070 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000377 0xD19C 0020206313 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x10
    0x00000378 0xD371 0020207240 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xDE
    0x0000038C 0xD3E8 0020207480 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x39 0x00 0x00
    0x00000386 0xD44F 0020207727 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x15
    0x000003A1 0xD621 0020208546 0x00 0x04 0x00 0x0C 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000156 0xD7C9 0020209428 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x13 0x00 0x00
    0x0000018E 0xD82E 0020209676 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000401 0xD9CC 0020210481 0x00 0x07 0x00 0x00 0x00 0x01 0x00 0x00 0x02 0x00
    0x00000158 0xDE49 0020212804 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xDEC5 0020213053 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xDF3B 0020213299 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0xE48E 0020216003 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0xE504 0020216249 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0xE57F 0020216495 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0xE762 0020217442 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0xE7D4 0020217688 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xE850 0020217941 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0xEA36 0020218900 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x52 0x04
    0x00000156 0xEBB4 0020219630 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x22 0x00 0x00
    0x0000018E 0xEC1A 0020219874 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xED9D 0020220644 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA1 0x00 0x00 0x2F
    0x000001D8 0xEE13 0020220890 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xF1C8 0020222789 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0xF245 0020223040 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0xF2BC 0020223282 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xF4A8 0020224187 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0xF4FE 0020224433 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xF813 0020226004 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0xFED4 0020229427 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0xFF3A 0020229672 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x053F 0020232758 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x05BB 0020233009 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x0631 0020233255 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x0B99 0020235999 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x0C0E 0020236244 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x0C88 0020236493 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x0E69 0020237429 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x0EDA 0020237678 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x0F56 0020237928 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x0000018E 0x11B8 0020239047 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x1258 0020239424 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x0A 0x00 0x00
    0x000001A6 0x1336 0020239904 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA0 0x00 0x00 0x3F
    0x0000021E 0x1414 0020240331 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x2E 0x00
    0x00000221 0x14FA 0020240735 0x00 0x04 0x36 0x00 0x00 0x28 0x00 0x00 0x00 0x00
    0x000001D8 0x154D 0020240978 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000294 0x16A6 0020241662 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x20
    0x00000295 0x1726 0020241908 0x00 0x04 0x00 0x00 0x00 0x26 0x00 0x00 0x00 0x00
    0x0000013C 0x1983 0020243127 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x19FA 0020243379 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x1AEE 0020243868 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x1BE8 0020244294 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x00000039 0x1C3E 0020244542 0x00 0x03 0x00 0x00 0x39 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0x1DAB 0020245168 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x1F11 0020245972 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0x25E5 0020249441 0x00 0x06 0x00 0x73 0xFF 0xFB 0x07 0x12 0x00 0x00
    0x0000018E 0x264B 0020249689 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x2C52 0020252774 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x2CCE 0020253026 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x2D44 0020253268 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x0000037C 0x30B9 0020255026 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x0E
    0x00000320 0x3133 0020255276 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x0F
    0x00000323 0x31B0 0020255524 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000324 0x322C 0020255773 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0x8F
    0x00000091 0x32A6 0020256016 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0x331C 0020256262 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x3397 0020256509 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x3410 0020256754 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x3480 0020257001 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x34FC 0020257246 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x3577 0020257495 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x53 0x03
    0x00000328 0x366B 0020257945 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x45
    0x00000156 0x39C0 0020259609 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x22 0x00 0x00
    0x0000018E 0x3A25 0020259856 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x3ADF 0020260223 0x00 0x08 0x04 0x0C 0xC0 0x1E 0xA0 0x00 0x00 0x02
    0x000001D8 0x3C4F 0020260872 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x000003D7 0x3F03 0020262344 0x00 0x08 0xB0 0x00 0x00 0x00 0x00 0x00 0x00 0x42
    0x0000013C 0x4004 0020262856 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x407B 0020263104 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x40F8 0020263352 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x41EB 0020263764 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x42BE 0020264166 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x461B 0020265969 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x4CE9 0020269426 0x00 0x06 0x00 0x73 0xFF 0xFB 0x07 0x30 0x00 0x00
    0x0000018E 0x4D50 0020269669 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x5357 0020272763 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x53D3 0020273011 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x5449 0020273257 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x59B1 0020276005 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x5A26 0020276249 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x5AA0 0020276497 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x5C81 0020277433 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x5CF2 0020277683 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x5D6E 0020277933 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x606E 0020279424 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x01 0x00 0x00
    0x0000018E 0x60D5 0020279669 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x61B7 0020280117 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x11
    0x0000021E 0x6277 0020280485 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x3D 0x00
    0x000001D8 0x635C 0020280873 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x6417 0020281259 0x00 0x04 0x36 0x00 0x00 0x37 0x00 0x00 0x00 0x00
    0x00000294 0x64B5 0020281653 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x3F
    0x00000295 0x657F 0020281985 0x00 0x04 0x00 0x00 0x00 0x35 0x00 0x00 0x00 0x00
    0x00000158 0x6761 0020283031 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x67DE 0020283279 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x6855 0020283520 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x00000039 0x6A43 0020284409 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001DC 0x6A90 0020284656 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x000001ED 0x6AE5 0020284907 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x6D3B 0020286013 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0x73F3 0020289424 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x10 0x00 0x00
    0x0000018E 0x745A 0020289667 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x7A65 0020292771 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x7AE1 0020293020 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x7B57 0020293266 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x80B1 0020295984 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x8127 0020296232 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x81A2 0020296481 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x8385 0020297421 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x83F7 0020297671 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x8473 0020297920 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x8659 0020298884 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x54 0x02
    0x00000305 0x86D1 0020299130 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x14 0x00
    0x00000156 0x87C9 0020299587 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x27 0x00 0x00
    0x0000018E 0x882F 0020299832 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x88F1 0020300209 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x21
    0x000001D8 0x8AFC 0020301174 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x00000309 0x8B49 0020301422 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2A
    0x0000038C 0x8BC4 0020301669 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x0C 0x00 0x00
    0x00000372 0x8CF2 0020302157 0x00 0x02 0x00 0x2A 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x8D9B 0020302587 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x23 0x00
    0x0000013C 0x8E4F 0020302963 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x8EC6 0020303214 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x8F43 0020303459 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x9036 0020303867 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x9109 0020304268 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000377 0x92E0 0020305299 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x2F
    0x00000091 0x9454 0020306040 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000378 0x94C9 0020306286 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xED
    0x00000386 0x95B9 0020306761 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x24
    0x00000156 0x9AFE 0020309422 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0x9B64 0020309667 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xA165 0020312748 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xA1E1 0020312995 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xA257 0020313240 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xA7B4 0020315962 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0xA829 0020316211 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0xA8A3 0020316460 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0xAA84 0020317396 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0xAAF5 0020317644 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xAB71 0020317893 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0xAE84 0020319422 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x0A 0x00 0x00
    0x0000018E 0xAEEA 0020319668 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xAFCC 0020320112 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x30
    0x0000021E 0xB08C 0020320481 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x000001D8 0xB171 0020320869 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xB22C 0020321258 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0xB2CB 0020321650 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000295 0xB395 0020321986 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000158 0xB569 0020323002 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xB5E6 0020323247 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xB65D 0020323492 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xB84B 0020324401 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0xB8A1 0020324646 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0xB8EB 0020324894 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xBAB6 0020325704 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x0000018E 0xC15D 0020329024 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000156 0xC209 0020329423 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x15 0x00 0x00
    0x00000158 0xC886 0020332790 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xC902 0020333039 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xC978 0020333285 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0xCECC 0020335993 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0xCF42 0020336241 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0xCFBD 0020336489 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0xD1A0 0020337429 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0xD210 0020337677 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xD28C 0020337926 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0xD46E 0020338881 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x55 0x01
    0x00000156 0xD5E7 0020339599 0x00 0x06 0x00 0x73 0xFF 0xFB 0x07 0x21 0x00 0x00
    0x0000018E 0xD64D 0020339842 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xD7CF 0020340612 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0xD847 0020340859 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xDC03 0020342775 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0xDC80 0020343025 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0xDCF7 0020343268 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xDEE3 0020344168 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0xDF39 0020344415 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xE23F 0020345953 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0xE915 0020349426 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x3E 0x00 0x00
    0x0000018E 0xE97D 0020349670 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xF034 0020353113 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xF0B0 0020353361 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xF126 0020353606 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x0000037C 0xF3CA 0020354947 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x1D
    0x00000320 0xF444 0020355200 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x1E
    0x00000323 0xF4C2 0020355451 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F
    0x00000324 0xF53F 0020355700 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0x9E
    0x00000091 0xF636 0020356178 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0xF6AB 0020356424 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0xF725 0020356671 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0xF79E 0020356917 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0xF80F 0020357163 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xF88B 0020357412 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000328 0xF984 0020357886 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x54
    0x00000156 0xFCCD 0020359528 0x00 0x06 0x00 0x73 0x00 0x07 0x07 0x04 0x00 0x00
    0x0000018E 0xFD34 0020359773 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xFDFA 0020360161 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x11
    0x0000021E 0xFEEC 0020360630 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x1F 0x00
    0x000001D8 0xFFC2 0020360989 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x0058 0020361303 0x00 0x04 0x36 0x00 0x00 0x19 0x00 0x00 0x00 0x00
    0x00000294 0x0121 0020361778 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x11
    0x00000295 0x0206 0020362165 0x00 0x04 0x00 0x00 0x00 0x17 0x00 0x00 0x00 0x00
    0x00000158 0x0377 0020362988 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0x03F4 0020363236 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0x046B 0020363481 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x04E8 0020363729 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x000001ED 0x053D 0020363976 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x06CF 0020364604 0x00 0x03 0x00 0x00 0x2A 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x0985 0020366074 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0x101F 0020369422 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x10 0x00 0x00
    0x0000018E 0x1086 0020369666 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x168B 0020372756 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x1707 0020373005 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x177D 0020373251 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x1CCD 0020375948 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x1D43 0020376198 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0x1DBE 0020376448 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0x1FA1 0020377388 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0x2013 0020377637 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x208F 0020377887 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0x2275 0020378849 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x56 0x00
    0x00000156 0x23ED 0020379567 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x22 0x00 0x00
    0x0000018E 0x2453 0020379813 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001D8 0x265D 0020380765 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x26AA 0020381011 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x00000158 0x2A1B 0020382779 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x2A98 0020383030 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x2B0F 0020383272 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x2CFB 0020384173 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0x2D51 0020384418 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x3059 0020385962 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x372A 0020389419 0x00 0x06 0x00 0x72 0x00 0x00 0x07 0x39 0x00 0x00
    0x0000018E 0x3790 0020389664 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x3E49 0020393110 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x3EC5 0020393358 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x3F3B 0020393603 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x43E1 0020395963 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x22
    0x000001A4 0x4456 0020396210 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0x44D0 0020396457 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0x46B1 0020397397 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0x4722 0020397645 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x479E 0020397894 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000305 0x4981 0020398836 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x23 0x00
    0x00000156 0x4AE8 0020399532 0x00 0x06 0x00 0x72 0x00 0x05 0x07 0x07 0x00 0x00
    0x0000018E 0x4B4E 0020399778 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x4CD8 0020400563 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x3F
    0x0000021E 0x4D55 0020400809 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x2E 0x00
    0x000001D8 0x4DC3 0020401057 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x4F40 0020401721 0x00 0x04 0x36 0x00 0x00 0x28 0x00 0x00 0x00 0x00
    0x0000038C 0x4F93 0020401969 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x1B 0x00 0x00
    0x00000294 0x4FF9 0020402218 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x20
    0x00000295 0x50C3 0020402499 0x00 0x04 0x00 0x00 0x00 0x26 0x00 0x00 0x00 0x00
    0x00000309 0x518F 0020402983 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x39
    0x0000013C 0x520A 0020403233 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0x5281 0020403476 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0x52FE 0020403721 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0x537B 0020403968 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0x53D1 0020404219 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000372 0x5470 0020404472 0x00 0x02 0x00 0x39 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000039 0x54B2 0020404716 0x00 0x03 0x00 0x00 0x39 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x557A 0020404973 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000377 0x5662 0020405445 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x3E
    0x00000378 0x5755 0020405934 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xFC
    0x00000091 0x57CD 0020406176 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000386 0x58C0 0020406667 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x33
    0x000003A1 0x5D1C 0020408820 0x00 0x04 0x00 0x0C 0x00 0x2C 0x00 0x00 0x00 0x00
    0x00000156 0x5E4B 0020409466 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x18 0x00 0x00
    0x0000018E 0x5EB0 0020409710 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000405 0x5EFA 0020409959 0x00 0x08 0x81 0x00 0xA4 0x01 0x00 0x00 0x00 0x34
    0x00000428 0x6022 0020410437 0x00 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x37 0x00
    0x0000042D 0x610F 0020410902 0x00 0x07 0xFF 0xFF 0xFF 0xFF 0xFF 0xFC 0x31 0x00
    0x00000158 0x649D 0020412751 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x6519 0020413001 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x658F 0020413246 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x6AE4 0020415951 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x6B5A 0020416201 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x6BD5 0020416446 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x6DB8 0020417389 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x6E28 0020417637 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x6EA4 0020417887 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x7086 0020418842 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x57 0xFF
    0x0000018E 0x7111 0020419089 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x71F4 0020419537 0x00 0x06 0x00 0x72 0xFF 0xF6 0x07 0x27 0x00 0x00
    0x000001D8 0x747C 0020420786 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x7515 0020421171 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x02
    0x00000158 0x7827 0020422759 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000013C 0x78A4 0020423009 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x0000017C 0x791B 0020423251 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x7B07 0020424154 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x7B5D 0020424400 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000091 0x7E6D 0020425960 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000156 0x853E 0020429418 0x00 0x06 0x00 0x73 0x00 0x0A 0x07 0x3E 0x00 0x00
    0x0000018E 0x85A4 0020429663 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x8C5C 0020433107 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x8CD8 0020433355 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x8D4E 0020433600 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x91F1 0020435950 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x9266 0020436196 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x92E0 0020436444 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x94C1 0020437383 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x9532 0020437631 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x95AE 0020437882 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x98C5 0020439422 0x00 0x06 0x00 0x72 0xFF 0xF9 0x07 0x06 0x00 0x00
    0x0000018E 0x992B 0020439669 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x9AB5 0020440446 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x12
    0x0000021E 0x9B32 0020440692 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x3D 0x00
    0x000001D8 0x9BA2 0020440936 0x00 0x03 0x00 0x00 0x3F 0x00 0x00 0x00 0x00 0x00
    0x00000221 0x9D20 0020441612 0x00 0x04 0x36 0x00 0x00 0x37 0x00 0x00 0x00 0x00
    0x00000294 0x9E4D 0020442290 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x3F
    0x00000295 0x9ECB 0020442537 0x00 0x04 0x00 0x00 0x00 0x35 0x00 0x00 0x00 0x00
    0x0000013C 0x9FB8 0020443016 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x00000158 0xA02F 0020443264 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000017C 0xA123 0020443754 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xA21D 0020444174 0x00 0x04 0x00 0x00 0x00 0x1D 0x00 0x00 0x00 0x00
    0x00000039 0xA2EF 0020444577 0x00 0x03 0x00 0x00 0x0C 0x00 0x00 0x00 0x00 0x00
    0x000001ED 0xA391 0020444895 0x00 0x03 0x01 0xFF 0x1C 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xA585 0020445985 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x35
    0x00000156 0xAC49 0020449422 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x10 0x00 0x00
    0x0000018E 0xACB0 0020449668 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xB2B0 0020452740 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0xB32C 0020452991 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0xB3A2 0020453235 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x0000037C 0xB753 0020455108 0x00 0x08 0x00 0x00 0x00 0x26 0x00 0x80 0x40 0x2C
    0x00000320 0xB7CC 0020455358 0x00 0x08 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x2D
    0x00000323 0xB848 0020455608 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2E
    0x00000324 0xB8C4 0020455853 0x00 0x08 0x40 0x46 0x00 0x00 0x00 0x00 0x0A 0xAD
    0x00000091 0xB93C 0020456101 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x08
    0x000001A4 0xB9B2 0020456345 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x0D
    0x000001AA 0xBA2D 0020456592 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x03
    0x000001B0 0xBAA6 0020456839 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x01 0x00
    0x000001D0 0xBB18 0020457086 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xBB94 0020457332 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0F
    0x00000255 0xBC10 0020457580 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x58 0xFE
    0x00000328 0xBD04 0020458032 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x63
    0x00000156 0xBFDE 0020459446 0x00 0x06 0x00 0x72 0x00 0x05 0x07 0x25 0x00 0x00
    0x0000018E 0xC043 0020459692 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xC178 0020460301 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA1 0x00 0x00 0x20
    0x000001D8 0xC2E6 0020460952 0x00 0x03 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
    0x000003D7 0xC599 0020462428 0x00 0x08 0xB0 0x00 0x00 0x00 0x00 0x00 0x00 0x15
    0x0000040C 0xC614 0020462676 0x00 0x08 0x01 0x53 0x48 0x48 0x46 0x4B 0x33 0x26
    0x00000454 0xC688 0020462917 0x00 0x06 0x10 0xEF 0x01 0x0D 0x20 0x2B 0x00 0x00
    0x0000013C 0xC6EA 0020463165 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0xC761 0020463405 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0xC7DE 0020463654 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0xC85A 0020463906 0x00 0x04 0x00 0x00 0x00 0x2C 0x00 0x00 0x00 0x00
    0x000001ED 0xC8B0 0020464153 0x00 0x03 0x01 0xFF 0x2B 0x00 0x00 0x00 0x00 0x00
    0x00000465 0xCC5B 0020465887 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x26
    0x00000091 0xCCD5 0020466139 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x17
    0x00000156 0xD354 0020469418 0x00 0x06 0x00 0x73 0x00 0x05 0x07 0x33 0x00 0x00
    0x0000018E 0xD3B9 0020469663 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000158 0xDA70 0020473106 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0xDAEC 0020473352 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0xDB62 0020473596 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0xE001 0020475940 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0xE076 0020476189 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x1C
    0x000001AA 0xE0F0 0020476434 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x12
    0x000001B0 0xE2D1 0020477374 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x10 0x00
    0x000001D0 0xE342 0020477621 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0xE3BE 0020477871 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1E
    0x00000156 0xE6D8 0020479416 0x00 0x06 0x00 0x72 0xFF 0xFB 0x07 0x04 0x00 0x00
    0x0000018E 0xE73E 0020479661 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0xE901 0020480553 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x30
    0x0000021E 0xE97D 0020480799 0x00 0x07 0x00 0x00 0x37 0x41 0x02 0x06 0x00 0x00
    0x000001D8 0xE9EC 0020481050 0x00 0x03 0x00 0x00 0x11 0x00 0x00 0x00 0x00 0x00
    0x00000221 0xEB69 0020481718 0x00 0x04 0x36 0x00 0x00 0x0A 0x00 0x00 0x00 0x00
    0x00000294 0xEC98 0020482398 0x00 0x08 0x00 0x16 0x01 0x02 0x58 0xA6 0x00 0x02
    0x00000295 0xED16 0020482643 0x00 0x04 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00
    0x00000158 0xED7C 0020482893 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x37
    0x0000013C 0xEDF9 0020483142 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x3A
    0x0000017C 0xEE70 0020483385 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x30
    0x000001DC 0xEEED 0020483630 0x00 0x04 0x00 0x00 0x00 0x3B 0x00 0x00 0x00 0x00
    0x000001ED 0xEF43 0020483882 0x00 0x03 0x01 0xFF 0x3A 0x00 0x00 0x00 0x00 0x00
    0x00000039 0xF0D6 0020484487 0x00 0x03 0x00 0x00 0x1B 0x00 0x00 0x00 0x00 0x00
    0x00000091 0xF38C 0020485960 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x31
    0x00000156 0xFA5E 0020489420 0x00 0x06 0x00 0x72 0x00 0x02 0x07 0x19 0x00 0x00
    0x0000018E 0xFAC5 0020489665 0x00 0x03 0x08 0x00 0x72 0x00 0x00 0x00 0x00 0x00
    0x00000158 0x00C0 0020492732 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x0000013C 0x013C 0020492984 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x0D
    0x0000017C 0x01B2 0020493229 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x03
    0x00000091 0x070F 0020495949 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x04
    0x000001A4 0x0785 0020496197 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x2B
    0x000001AA 0x0800 0020496446 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x21
    0x000001B0 0x09E3 0020497387 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x2F 0x00
    0x000001D0 0x0A53 0020497635 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x0ACF 0020497886 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x2D
    0x00000255 0x0CB1 0020498838 0x00 0x08 0x00 0x00 0x00 0x00 0x55 0x55 0x59 0xFD
    0x00000305 0x0D28 0020499085 0x00 0x07 0x8E 0x14 0x00 0x00 0x00 0x00 0x32 0x00
    0x00000156 0x0E23 0020499546 0x00 0x06 0x00 0x73 0x00 0x00 0x07 0x29 0x00 0x00
    0x0000018E 0x0E89 0020499794 0x00 0x03 0x08 0x00 0x45 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x0F4A 0020500170 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x03
    0x000001D8 0x1157 0020501134 0x00 0x03 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00
    0x00000309 0x11A4 0020501384 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C
    0x0000038C 0x1220 0020501634 0x00 0x06 0x00 0x00 0x78 0x7F 0x00 0x2A 0x00 0x00
    0x00000372 0x134F 0020502121 0x00 0x02 0x00 0x0C 0x00 0x00 0x00 0x00 0x00 0x00
    0x00000374 0x13F7 0020502555 0x00 0x07 0x41 0x00 0x00 0x00 0x00 0x00 0x05 0x00
    0x00000377 0x14AB 0020502922 0x00 0x08 0x02 0x68 0x31 0x34 0x18 0x00 0x02 0x01
    0x0000013C 0x1522 0020503172 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x1C
    0x00000158 0x1599 0020503416 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x19
    0x0000017C 0x1616 0020503662 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x12
    0x000001DC 0x1692 0020503909 0x00 0x04 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00
    0x000001ED 0x16E8 0020504157 0x00 0x03 0x01 0xFF 0x0D 0x00 0x00 0x00 0x00 0x00
    0x00000378 0x1A2D 0020505746 0x00 0x08 0x7F 0xFF 0xFE 0xFF 0x1C 0xA7 0xFF 0xCF
    0x00000091 0x1AA4 0020505989 0x00 0x08 0x80 0x21 0x88 0x0E 0x01 0x00 0x00 0x13
    0x00000386 0x1B19 0020506236 0x00 0x08 0xFF 0xE0 0x00 0x05 0x00 0x00 0x00 0x06
    0x0000018E 0x20BE 0020509024 0x00 0x03 0x08 0x00 0x54 0x00 0x00 0x00 0x00 0x00
    0x00000156 0x2168 0020509420 0x00 0x06 0x00 0x72 0xFF 0xFE 0x07 0x3E 0x00 0x00
    0x00000401 0x236B 0020510469 0x00 0x07 0x00 0x00 0x00 0x01 0x00 0x00 0x11 0x00
    0x00000158 0x27CD 0020512738 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x28
    0x0000013C 0x2849 0020512986 0x00 0x08 0xFF 0x94 0xFF 0x94 0x00 0x40 0x01 0x2B
    0x0000017C 0x28BF 0020513232 0x00 0x08 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x21
    0x00000091 0x2E1C 0020515954 0x00 0x08 0x80 0x21 0x88 0x0A 0x01 0x00 0x00 0x26
    0x000001A4 0x2E91 0020516202 0x00 0x08 0x00 0x66 0x00 0x00 0x00 0x00 0x00 0x3A
    0x000001AA 0x2F0B 0020516451 0x00 0x08 0x7F 0xFF 0x00 0x00 0x00 0x00 0x66 0x30
    0x000001B0 0x30EC 0020517385 0x00 0x07 0x80 0x03 0x00 0x00 0x00 0x00 0x3E 0x00
    0x000001D0 0x315D 0020517638 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0A
    0x000001EA 0x31D9 0020517884 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3C
    0x00000156 0x34ED 0020519414 0x00 0x06 0x00 0x73 0x00 0x02 0x07 0x09 0x00 0x00
    0x0000018E 0x3552 0020519660 0x00 0x03 0x08 0x00 0x63 0x00 0x00 0x00 0x00 0x00
    0x000001A6 0x36D3 0020520423 0x00 0x08 0x04 0x0C 0xC0 0x1D 0xA0 0x00 0x00 0x12
  14. #39
    Apr 2020
    DFW area in Texas
    512
    Sandra / PaulS:
    Sandra, not intending to hijack your thread, but I have recently started trying to read CAN bus data from the OBDII connector on my 2020 Honda Civic. So far, I have been unable to see any CAN data on pins 6/14 using my Teensy 4.0 + transceiver CAN setup, the Seeed Studio CAN analyzer, nor my Rigol MSO2202A with CAN decoding (actually, I checked every pin on the OBDII connector with my Rigol, with no CAN data detected on any of them). My T4.0 setup & my Rigol can successfully see & print CAN packets sent by the analyzer.
    My quick question is thus: did you have to do anything special (engine on, short a pin, send a CAN packet, activate any controls, etc.) to see the CAN data reported in P#37 ??
    Thanks for any helpful hints & looking forward to reading about your progress !!
    Mark J Culross
    KD5RXT
    P.S. PaulS, thanks for your help. Up to now, I have been silently monitoring this thread with hopes to do the same as Sandra, & I appreciate your insights & helpful hints (e.g. your recommendation for the Seeed Studios CAN analyzer & supporting software in P#11, as well as the CAN transceiver in P#13).
  15. #40
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    911
    Quote Originally Posted by kd5rxt-mark View Post
    KeyOn-EngineOff should be enough to see CAN data or connect a scanner.
    With KeyOn-EngineOn there is usually more CAN data to be observed since all modules will be active.
    Did you see this video about a Honda Civic 2005 OBD2 problem?
    Paul
  16. #41
    Apr 2015
    Netherlands
    911
    CAN Bus fault finding tips and hints: part 1 and part 2.
    Paul
  17. #42
    Apr 2020
    DFW area in Texas
    512
    Paul:
    Thanks !! I should have mentioned that the car is not showing any problems . . . I built the T4.0 CAN setup just to tinker around & become more familiar with CAN. I also built my T4.0 CAN setup with both male & female connectors to provide an all-pin pass-thru configuration, allowing me to connect external equipment (e.e. the Actron) to the OBDII connector & monitor passively with my T4.0 setup. I can read/reset status on my Civic using my very old Actron CP9145, so I know that the OBDII connector is at least working in that regard. This Actron unit was updated (again, some years ago) with a CAN update, but I have no idea if it is actually using CAN when talking to my 2020 Honda Civic. I do plan to connect this scanner to the OBDII port & monitor 6/14 with my Rigol while reading status with the scanner to see if I can see CAN data of any kind on the scope (in analog mode, then in CAN decode mode).
    Thanks again for your help.
    Mark J Culross
    KD5RXT
  18. #43
    Apr 2020
    DFW area in Texas
    512
    Here is my CAN test setup:
    The two purple wires are flying leads connected to CAN-H/CAN-L on the transceiver, which allows me to connect the transceiver to any of the OBDII pins. The three interwoven purple wires from the analyzer go to a 5-pin header (ground on the middle pin 3, then CAN-H on 2 & 4, CAN-L on 1 & 5, which keeps me from having to worry about plugging in the 3 wires "backward/wrong").
    Mark J Culross
    KD5RXT
  19. #44
    Apr 2020
    DFW area in Texas
    512
    Paul:
    I have successfully demonstrated that my T4.0 CAN setup reads data from pins 6/14, but only by connecting in parallel with an OBD Diagnostic Interface. I haven't figured out what magic the diagnostic interface performs to get the CAN data to flow, but whatever it is, my T4.0 CAN setup cannot currently show the same success by itself.
    Here's the sketch that I'm currently running. It is an amalgam (with slight modifications) of several of the flexCAN_T4 examples, combined with valuable info gleaned from your posts where you were assisting Sandra. I just added the feature to automatically scan thru the various baudrates, or to sit idly at a specific baudrate (controlled thru a simple command-line interface using the Serial Monitor). It was great at first to have it to scan all of the time (until valid CAN frames are detected), but that started getting in the way when the frames became intermittent (as soon as my timer expired, it would go back to scanning & miss the most important first couple frames . . . the ones I was specifically trying to monitor & analyze). I also added the ability to store the current config in EEPROM for repeated sessions with the same settings (like my 2020 Honda Civic at a known/fixed 500kbaud CAN bus rate). There are a few scattered lines that are remnants from some initial work towards being able to send as well as receive, but they are currently non-functional.
    //  Teensy 4.x CAN bus monitor utility - version 1.0 dated 20220826-2205
    //    - designed & written by Mark J Culross (KD5RXT)
    //    - credit & thanks to PaulS for his very helpful posts on the Teensy forum
    //    - includes the ability to change baudrate on-the-fly (manually or automatically)
    //    - configuration is controlled via the USB serial interface
    //    - all data & status is reported via the USB serial interface
    //  Arduino IDE Configuration (last built with Arduino 1.8.19 + Teensyduino 1.57):
    //     Tools/Board:           "Teensy 4.0"
    //     Tools/USB Type:        "Serial"
    //     Tools/CPU Speed:       "600MHz"
    //     Tools/Optimize:        "Smallest Code"
    //     Tools/Keyboard Layout: "US English"
    //     Tools/Port:            "COMx Serial (Teensy 4.0)"
    const String VERSION0  = "1.0";
    const String VERSION1  = "Teensy CAN bus monitor utility";
    const String VERSION2  = "version " + VERSION0 + " dated 08/26/2022 @2205";
    const String VERSION3  = "designed & written by Mark J Culross (KD5RXT)";
    #include <EEPROM.h>
    #include <FlexCAN_T4.h>
    FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can1;
    //#define DEBUG_HEARTBEAT                 // uncomment to use the onboard LED as a heartbeat indicator
    //#define DEBUG_EEPROM_WRITE              // uncomment to show specifics of EEPROM writes
    //#define DEBUG_EEPROM_READ               // uncomment to show specifics of EEPROM reads
    //#define DISABLE_EEPROM_READ_SETTINGS    // uncomment to not read settings from EEPROM (to simply use program defaults for all settings)
    //#define DISABLE_EEPROM_WRITE_SETTINGS   // uncomment to not write settings to EEPROM
    // The following pins are used in this (Audio) portion of the Teensy 4.x PolySynth project:
    // PIN D0       = (not used)
    // PIN D1       = (not used)
    // PIN D2       = (not used)
    // PIN D3       = (not used)
    // PIN D4       = (not used)
    // PIN D5       = (not used)
    // PIN D6       = (not used)
    // PIN D7       = (not used)
    // PIN D8       = (not used)
    // PIN D9       = (not used)
    // PIN D10      = (not used)
    // PIN D11      = (not used)
    // PIN D12      = (not used)
    // PIN D13      = (not used)
    // PIN D14/A0   = (not used)
    // PIN D15/A1   = (not used)
    // PIN D16/A2   = (not used)
    // PIN D17/A3   = (not used)
    // PIN D18/A4   = (not used)
    // PIN D19/A5   = (not used)
    // PIN D20/A6   = (not used)
    // PIN D21/A7   = (not used)
    // PIN D22/A8   = CAN1 TX
    // PIN D23/A9   = CAN1 RX
    // PIN D24/A10  = (not used)
    // PIN D25/A11  = (not used)
    // PIN D26/A12  = (not used)
    // PIN D27/A13  = (not used)
    // PIN D28      = (not used)
    // PIN D29      = (not used)
    // PIN D30      = (not used)
    // PIN D31      = (not used)
    // PIN D32      = (not used)
    // PIN D33      = (not used)
    // PIN D34      = (not used)
    // PIN D35      = (not used)
    // PIN D36      = (not used)
    // PIN D37      = (not used)
    // PIN D38/A14  = (not used)
    // PIN D39/A15  = (not used)
    // PIN D40/A16  = (not used)
    // PIN D41/A17  = (not used)
    // carriage return
    #define LF 0x0A
    // onboard LED on pin 13
    #define LED_PIN 13
    unsigned long LED_timer;
    #define LED_DURATION_MSEC 5
    // how long to stay on a given baudrate, looking for packets
    unsigned long CAN_baud_change_timer = millis();
    #define CAN_BAUD_CHANGE_INTERVAL_MSEC 500
    unsigned long heartbeat_timer = millis();
    bool heartbeat_toggle = false;
    #define LED_INTENSITY_OFF 0
    #define LED_INTENSITY_ON 64
    // array of CAN baudrates
    const uint32_t CAN_baudrate_list[] = { 5000, 10000, 20000, 25000, 33333, 50000, 100000, 125000, 200000, 250000, 400000, 500000, 800000, 1000000 };
    int CAN_baudrate_size = sizeof(CAN_baudrate_list) / sizeof(uint32_t);
    int CAN_baudrate_index;
    volatile bool CAN_baudrate_fixed = false;
    volatile bool CAN_baudrate_match_found = false;
    // how long to wait for more packets (timing out) before scanning thru the baudrate list
    #define CAN_BAUDRATE_MATCH_TIMEOUT_MSEC 5000
    volatile unsigned long CAN_baudrate_match_timeout = millis();
    #define PID_REQUEST 0x7DF
    #define PID_REPLY 0x7E8
    #define ENGINE_COOLANT_TEMP 0x05
    #define MAX_T4X_EEPROM_SIZE_ALLOWED 4284
    // header: "Teensy CAN Bus Monitor"
    const char EEPROM_HEADER[] = "TCBM";
    typedef enum
       EEPROM_INDEX_HEADER_00 = 0, EEPROM_INDEX_HEADER_01, EEPROM_INDEX_HEADER_02, EEPROM_INDEX_HEADER_03,
       EEPROM_INDEX_CAN_BAUDRATE_FIXED,
       EEPROM_INDEX_CAN_BAUDRATE_INDEX,
       EEPROM_INDEX_CHECKSUM, EEPROM_INDEX_INV_CHECKSUM,
       EEPROM_INDEX_VALUE_COUNT
    }  EEPROM_INDEX;
    #define EEPROM_INDEX_HEADER_FIRST      EEPROM_INDEX_HEADER_00
    #define EEPROM_INDEX_HEADER_LAST       EEPROM_INDEX_HEADER_03
    // function headers
    void canSniff(const CAN_message_t &msg);
    void loop();
    void next_CAN_baudrate(void);
    void previous_CAN_baudrate(void);
    bool readSettings(void);
    void report_current_baudrate(void);
    void saveSettings(void);
    void setup(void);
    void showByteValue(unsigned char byte_value);
    void showIndex(int index);
       Serial.print("MBX: ");
       if (msg.mb < 10)
          Serial.print("0");
       Serial.print(msg.mb);
       Serial.print("  LEN: ");
       Serial.print(msg.len);
       Serial.print("  EXT: ");
       Serial.print(msg.flags.extended);
       Serial.print("  TS: ");
       if (msg.timestamp < 10000)
          Serial.print(" ");
       if (msg.timestamp < 1000)
          Serial.print(" ");
       if (msg.timestamp < 100)
          Serial.print(" ");
       if (msg.timestamp < 10)
          Serial.print(" ");
       Serial.print(msg.timestamp);
       Serial.print("  ID: 0x");
       if (msg.id < 0x10000000)
          Serial.print("0");
       if (msg.id < 0x1000000)
          Serial.print("0");
       if (msg.id < 0x10000)
          Serial.print("0");
       if (msg.id < 0x1000)
          Serial.print("0");
       if (msg.id < 0x100)
          Serial.print("0");
       if (msg.id < 0x10)
          Serial.print("0");
       Serial.print(msg.id, HEX);
       Serial.print("  OVERRUN: ");
       Serial.print(msg.flags.overrun);
       Serial.print("  MSG: ");
       for ( uint8_t i = 0; i < msg.len; i++ ) {
          Serial.print("0x");
          if (msg.buf[i] < 0x10)
             Serial.print("0");
          Serial.print(msg.buf[i], HEX);
          Serial.print(" ");
    //   if (msg.id == 0)
    //      CAN_message_t can_MsgTx;
    //      can_MsgTx.buf[0] = 0xFF;
    //      can_MsgTx.buf[1] = 0xEE;
    //      can_MsgTx.buf[2] = 0xDD;
    //      can_MsgTx.buf[3] = 0xCC;
    //      can_MsgTx.buf[4] = 0xBB;
    //      can_MsgTx.buf[5] = 0xAA;
    //      can_MsgTx.buf[6] = 0x99;
    //      can_MsgTx.buf[7] = 0x88;
    //      can_MsgTx.len = 8;
    //      can_MsgTx.flags.extended = 0;
    //      can_MsgTx.flags.remote = 0;
    //      can_MsgTx.id = PID_REQUEST;
    //      Can1.write(can_MsgTx);
    #ifndef DEBUG_HEARTBEAT
       LED_timer = millis();
       analogWrite(LED_PIN, LED_INTENSITY_ON);
       CAN_baudrate_match_found = true;
    }  // canSniff()
       CAN_message_t msg;
       char inKey;
       if ( Can1.read(msg) ) {
          canSniff(msg);
       if ((LED_timer) && ((millis() - LED_timer) > LED_DURATION_MSEC))
          analogWrite(LED_PIN, LED_INTENSITY_OFF);
          LED_timer = 0;
    #else
       if (millis() - heartbeat_timer > 250)
          heartbeat_toggle = !heartbeat_toggle;
          analogWrite(LED_PIN, heartbeat_toggle);
       // if we're not parked on a baudrate, then see if it's time to hunt
       if (!(CAN_baudrate_fixed))
          // if we're currently successfully receiving CAN packets at this baudrate
          if (CAN_baudrate_match_found)
             if ((millis() - CAN_baudrate_match_timeout) > CAN_BAUDRATE_MATCH_TIMEOUT_MSEC)
                // go back to scanning the baudrate list
             if ((millis() - CAN_baud_change_timer) > CAN_BAUD_CHANGE_INTERVAL_MSEC)
                next_CAN_baudrate();
                report_current_baudrate();
                delay(10 * LED_DURATION_MSEC);
                delay(5 * LED_DURATION_MSEC);
       while (Serial.available() > 0)
          inKey = Serial.read();
          bool report_current = false;
          switch (inKey)
             case LF:
                report_current = true;
             case 'f':
             case 'F':
                CAN_baudrate_fixed = true;
                // save settings to EEPROM
                saveSettings();
             // hunt for a matching baudrate & stop there
             case 'h':
             case 'H':
                saveSettings();
             // next (higher) baudrate
             case 'n':
             case 'N':
                saveSettings();
             // previous (lower) baudrate
             case 'p':
             case 'P':
                previous_CAN_baudrate();
                saveSettings();
          if (report_current)
    }  // loop()
       if (++CAN_baudrate_index >= CAN_baudrate_size)
          CAN_baudrate_index = 0;
       Can1.reset();
       Can1.begin();
       Can1.setBaudRate(CAN_baudrate_list[CAN_baudrate_index]);
    }  // next_CAN_baudrate
       if (--CAN_baudrate_index < 0)
          CAN_baudrate_index = CAN_baudrate_size - 1;
       Can1.reset();
       Can1.begin();
    }  // previous_CAN_baudrate
    // read the current settings from EEPROM
       byte eeprom_value, xor_value, inv_xor_value;
       byte xor_result = 0x4d;  // start with a non-zero value
       bool header_is_good = true;
       bool eeprom_settings_good = false;
       Serial.println("");
       Serial.print("Attempting to read/verify saved settings (");
       Serial.print(EEPROM_INDEX_VALUE_COUNT);
       Serial.print(" values) from EEPROM...");
       for (byte eeprom_index = EEPROM_INDEX_HEADER_FIRST; eeprom_index < EEPROM_INDEX_CHECKSUM; eeprom_index++)
          EEPROM.get((int)(eeprom_index), eeprom_value);
          xor_result = xor_result ^ eeprom_value;
    #ifdef DEBUG_EEPROM_READ
          if (eeprom_index == EEPROM_INDEX_HEADER_FIRST)
             Serial.println("");
          Serial.print("(READ ");
          showIndex((int)(eeprom_index));
          Serial.print(": ");
          showByteValue(eeprom_value);
          Serial.println(")");
          if (eeprom_index <= EEPROM_INDEX_HEADER_LAST)
             if (eeprom_value != EEPROM_HEADER[eeprom_index])
                header_is_good = false;
       // read the checksum & inverse checksum
       EEPROM.get(EEPROM_INDEX_CHECKSUM, xor_value);
       EEPROM.get(EEPROM_INDEX_INV_CHECKSUM, inv_xor_value);
       // if the checksums match & the header values match, then we seem to have valid settings in EEPROM, so read all of the settings
       if ((xor_value == xor_result) &&
             (inv_xor_value == (byte)~xor_result) &&
             (header_is_good))
          Serial.print("verified settings (");
          Serial.println(" values) in EEPROM are valid...");
          Serial.println("");
    #ifndef DISABLE_EEPROM_READ_SETTINGS
          for (byte eeprom_index = EEPROM_INDEX_HEADER_FIRST; eeprom_index <= EEPROM_INDEX_INV_CHECKSUM; eeprom_index++)
             Serial.print(": ");
             switch (eeprom_index)
                case EEPROM_INDEX_HEADER_00:
                case EEPROM_INDEX_HEADER_01:
                case EEPROM_INDEX_HEADER_02:
                case EEPROM_INDEX_HEADER_03:
                   Serial.print(") Header[");
                   Serial.print(eeprom_index / 10);
                   Serial.print(eeprom_index % 10);
                   Serial.print("]                      = ");
                   Serial.println((char)eeprom_value);
                case EEPROM_INDEX_CAN_BAUDRATE_FIXED:
                   if (eeprom_value & 0x01)
                   Serial.print(")    CAN baudrate is fixed        = ");
                      Serial.println("ON");
                      Serial.println("OFF");
                case EEPROM_INDEX_CAN_BAUDRATE_INDEX:
                   CAN_baudrate_index = eeprom_value;
                   Serial.print(")    CAN baudrate index           = ");
                   Serial.println(eeprom_value);
                case EEPROM_INDEX_CHECKSUM:
                   eeprom_value = (char)(xor_result);
                   Serial.print(") Calculated CHECKSUM             = ");
                   showByteValue(xor_result);
                   Serial.println("");
                case EEPROM_INDEX_INV_CHECKSUM:
                   eeprom_value = (char)(~xor_result);
                   Serial.print(") Calculated INVERSE CHECKSUM     = ");
                   showByteValue((byte)~xor_result);
                   Serial.println("");
          eeprom_settings_good = true;
          Serial.println("EEPROM values failed checksum verification...");
          Serial.println("");
          Serial.println("Discarding invalid EEPROM settings & storing/using defaults...");
          Serial.println("");
          if (!header_is_good)
             Serial.println("HEADER mismatch between EEPROM values & expected values...");
             Serial.println("CHECKSUM mismatch between EEPROM values & expected values...");
             showIndex((int)(EEPROM_INDEX_CHECKSUM));
             Serial.print  (") xor_value          = ");
             Serial.println(xor_value);
             Serial.print("(CALC) xor_result             = ");
             Serial.println(xor_result);
             showIndex((int)(EEPROM_INDEX_INV_CHECKSUM));
             Serial.print  (") inv_xor_value      = ");
             Serial.println(inv_xor_value);
             Serial.print("(CALC) inv_xor_result         = ");
             Serial.println((byte)~xor_result);
          Serial.println("");
       return (eeprom_settings_good);
    }  // readSettings()
       Serial.println("");
       Serial.print("CAN baudrate set to: ");
       Serial.print(CAN_baudrate_list[CAN_baudrate_index]);
       if (CAN_baudrate_fixed)
          Serial.println(" (not scanning)");
          Serial.println(" (scanning)");
       Serial.println("");
       Serial.println("CONTROL MENU (send from the serial monitor, terminated with LF or CR/LF):");
       Serial.println("   F: FIXED CAN baudrate (not scanning)");
       Serial.println("   H: HUNT for a matching CAN baudrate (scanning)");
       Serial.println("   N: NEXT (higher) CAN baudrate (not scanning)");
       Serial.println("   P: PREVIOUS (lower) CAN baudrate (not scanning)");
       Serial.println("");
    }  // report_current_baudrate()
    // save the current settings to EEPROM
       byte xor_result = 0x4D;  // start with a non-zero value
       char eeprom_value = 0x00;
       Serial.println("");
       Serial.print("Saving settings (");
       Serial.println(" values) to EEPROM...");
       Serial.println("");
       for (byte eeprom_index = (byte)(EEPROM_INDEX_HEADER_FIRST); eeprom_index <= (byte)(EEPROM_INDEX_INV_CHECKSUM); eeprom_index++)
    #ifdef DEBUG_EEPROM_WRITE
          Serial.print("(WRITE ");
          Serial.print(": ");
                eeprom_value = EEPROM_HEADER[eeprom_index];
                   eeprom_value = 0x01;
                eeprom_value = CAN_baudrate_index;
                Serial.println("");
                Serial.println("");
                Serial.println("");
    #ifndef DISABLE_EEPROM_WRITE_SETTINGS
          EEPROM.update((int)(eeprom_index), (byte)(eeprom_value));
          if (eeprom_index < EEPROM_INDEX_CHECKSUM)
             xor_result = (byte)(xor_result ^ eeprom_value);
    }  // saveSettings()
    void setup(void)
       while (!Serial && (millis() <= 1000));
       Serial.println("=============================================");
       Serial.print("       ");
       Serial.println(VERSION1);
       Serial.print("     ");
       Serial.println(VERSION2);
       Serial.println(VERSION3);
       Serial.println("");
       Serial.println("");
       if (CrashReport) {
          Serial.print(CrashReport);
       // try to read the settings from EEPROM for this index
       if (!readSettings())
          // if the setting in EEPROM for this index are invalid, then set to default values & save
          saveSettings();
       Serial.println("");
       Serial.print("EEPROM USED: ");
       Serial.println(EEPROM_INDEX_VALUE_COUNT);
       Serial.print("EEPROM MAX ALLOWED: ");
       Serial.println(MAX_T4X_EEPROM_SIZE_ALLOWED);
       Serial.println("");
       Can1.begin();
       pinMode(LED_PIN, OUTPUT);
    } // setup()
    // show index of EEPROM reads/writes
       if (byte_value < 100)
          Serial.print("0");
          Serial.print((char)(((byte_value / 100) % 10) + 0x30));
       if (byte_value < 10)
          Serial.print("0");
          Serial.print((char)(((byte_value / 10) % 10) + 0x30));
       Serial.print((char)((byte_value % 10) + 0x30));
    }  // showByteValue()
       if (index < 1000)
          Serial.print("0");
          Serial.print((char)((index / 1000) + 0x30));
       if (index < 100)
          Serial.print("0");
          Serial.print((char)(((index / 100) % 10) + 0x30));
       if (index < 10)
          Serial.print("0");
          Serial.print((char)(((index / 10) % 10) + 0x30));
       Serial.print((char)((index % 10) + 0x30));
    }  // showIndex()
    // EOF PLACEHOLDER
    Thanks again for your assistance, both direct & indirect !!
    Mark J Culross
    KD5RXT
  20. #45
    Apr 2015
    Netherlands
    911
    Hi Mark, thanks for reporting your progress and sharing your code.
    I wouldn't be surprised if the Actron scanner first starts in K-line mode and once it figures out that CAN mode is also possible, it switches over to that faster CAN mode. No sure though if and how that is done actually.
    @Sandra, thinking over your initial CAN approach and in light of what Mark found out above, I wonder if using the K-line interface is not the better option for you. You will be able to get the EngineCoolantTemperature PID over the K-line as well.
    When you google for "arduino OBD2 K-line", you get a lot of hits on working projects, e.g. https://github.com/iwanders/OBD9141.
    Paul
  21. #46
    Apr 2015
    Netherlands
    911
    This looks like a very informative OBD II UART Hookup Guide : https://learn.sparkfun.com/tutorials...okup-guide/all.
    Paul
  22. #47
    Apr 2015
    Netherlands
    911
    Looking further into the OBD9141 project mentioned above [using a Teensy 3.x], there seems to be a mandatory init sequence to wake up the ECU.
    This init sequence uses the K-line interface per ISO9141 spec.
    From OBD9141.cpp, line 355:
    bool OBD9141::init(){
        use_kwp_ = false;
        // this function performs the ISO9141 5-baud 'slow' init.
        this->set_port(false); // disable the port.
        this->kline(true);
        delay(OBD9141_INIT_IDLE_BUS_BEFORE); // no traffic on bus for 3 seconds.
        OBD9141println("Before magic 5 baud.");
        // next, send the startup 5 baud init..
        this->kline(false); delay(200); // start
        this->kline(true); delay(400);  // first two bits
        this->kline(false); delay(400); // second pair
        this->kline(true); delay(400);  // third pair
        this->kline(false); delay(400); // last pair
        this->kline(true); delay(200);  // stop bit
        // this last 200 ms delay could also be put in the setTimeout below.
        // But the spec says we have a stop bit.
        // done, from now on it the bus can be treated ad a 10400 baud serial port.
    Once the init sequence has been perfomed and the ECU is awake, you should be able to talk over the K-line interface or the CAN interface.
    Paul
  23. #48
    Apr 2015
    Netherlands
    911
    Hi Mark, perhaps I found the magic to get the CAN data flowing...
    When reading Adventures in Automotive Networks and Control Units, on page 14 I found this:
    DiagnosticSessionControl
    This establishes a diagnostic session with the ECU and is usually necessary before any other commands can be sent.
    IDH: 07, IDL: E0, Len: 08, Data: 02 10 03 00 00 00 00 00
    After sending that CAN frame, the reply for a successful establishment should be:
    IDH: 07, IDL: E8, Len: 08, Data: 06 50 03 00 32 01 F4 00
    Perhaps worth a try?
    Paul
  24. #49
    Apr 2020
    DFW area in Texas
    512
    Paul
    Paul:
    Thanks for finding that golden nugget of info !! It will be after the Labor Day holiday before I can get back home to test this . . . we're camping for the week (my annual extended relaxation period, which before I retired earlier this year, was to allow me to "forget who I am, ignore what I do for a living for a bit, & most of all, to relax !!" . . . this year, it's just to relax !!).
    I will give that a try & let you know what I find out !!
    Thanks again,
    Mark J Culross
    KD5RXT
  25. #50
    Jul 2022
    17
    Dear PAul and Mark,
    thanks for all your replies, I was again on a busniess trip and no way to connect, now i am on my holidays but I have some time to do some test, so I will read everything and try as much as possible and get back to you with any further information.
    Thank you,
    Sandra
