Results 1 to 3 of 3
Thread: unable to use setSyncProvider for teensy41 in platformIO
    Hello world,
    I recently got myself some sweet teensy41 for a project.
    The main reason was that it has everything on board to build a quick data logger with timestamp.
    Having good experiences in the past with TimeLib I decided to give it a go.
    However, I ran into an issue:
    Gives me the following error:
    src/main.cpp: In function 'void setup()':
    src/main.cpp:6:19: error: 'getTeensy3Time' was not declared in this scope
    *** [.pio/build/teensy41/src/main.cpp.o] Error 1
    I can set the time using setTime just fine, it's just a hassle as I have multiple devices that I need to update every now and then.
    Does setSyncProvider not work for teensy41?
    I am using:
    A teensy41 straight out of the box, only a micro-usb is attached
    VS code
    The latest version of platformIO (updated it today)
    Can someone shed some light on this conundrum?
    Kind regards,
    inimidi
    Aug 2018
    Brisbane, Australia
    30
    What happens if you add this to your source file
    time_t getTeensy3Time() {
    	return Teensy3Clock.get();
    Worked like a charm, can't believe I missed that >.<
    Thanks thebigg~
