I'm hoping to run a slave/master system over a distance of about 200 feet using an RS485 cable and a Teensy 4.0 on either end. I'm very new to this and have a few questions. I need to pass a few different signals from point A (i.e. joystick, a switch, etc.) to control a device in room B. Is there a specific breakout board that I should use to interface between the Teensy and the cable (I've seen several for use with Arduino Uno, but I can't find any information as to whether they are compatible with the Teensy)? I was also looking to use the Arduino Modbus library for communication but I'm also not sure if it works as is or if changes will need to be made to it? Or is there another library that would work better? Any suggestions would be helpful!
