Results 1 to 6 of 6
Thread: Teensy 4.1 USB host ERROR Followup
    Jul 2020
    15
    I have an enumeration issue when I plug a Boss Katana amplifier to the USB host of my Teensy 4.1
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20003000
    periodictable = 20003000
    Ready
    port change: 14001403
        connect
      begin reset
    port change: 14001005
      port enabled
      end recovery
    new_Device: 1.5 Mbit/sec
    new_Pipe
    ERROR Followup
        remove from followup list
        stray halted 200034C0
      qtd: 20003480, token=80080180, next=200034C0
      qtd: 200034C0, token=80008080, next=20003500
      dummy halt: 20003500
    enumeration:
        remain on followup list
    Here's some info from Linux on this device :
    [  167.356085] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
    [  167.488353] usb 1-1.3: New USB device found, idVendor=0582, idProduct=01d8, bcdDevice= 0.00
    [  167.488439] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [  167.488465] usb 1-1.3: Product: KATANA
    [  167.488487] usb 1-1.3: Manufacturer: BOSS
    pi@raspberrypi:~ $ lsusb -v -d 0582:01d8
    Bus 001 Device 005: ID 0582:01d8 Roland Corp.
    Couldn't open device, some information will be missing
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass          255 Vendor Specific Class
      bDeviceSubClass         0
      bDeviceProtocol       255
      bMaxPacketSize0        64
      idVendor           0x0582 Roland Corp.
      idProduct          0x01d8
      bcdDevice            0.00
      iManufacturer           1
      iProduct                2
      iSerial                 0
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x00bc
        bNumInterfaces          4
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0xc0
          Self Powered
        MaxPower                0mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           0
          bInterfaceClass       255 Vendor Specific Class
          bInterfaceSubClass    255 Vendor Specific Subclass
          bInterfaceProtocol      0
          iInterface              0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           0
          bInterfaceProtocol      2
          iInterface              0
          ** UNRECOGNIZED:  06 24 f1 01 00 00
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       1
          bNumEndpoints           1
          iInterface              0
          ** UNRECOGNIZED:  07 24 01 01 00 01 00
          ** UNRECOGNIZED:  0b 24 02 01 04 04 18 01 44 ac 00
          ** UNRECOGNIZED:  06 24 f1 04 16 00
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x0d  EP 13 OUT
            bmAttributes            5
              Transfer Type            Isochronous
              Synch Type               Asynchronous
              Usage Type               Data
            wMaxPacketSize     0x0070  1x 112 bytes
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           0
          bInterfaceProtocol      1
          iInterface              0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       1
          bNumEndpoints           1
          iInterface              0
          ** UNRECOGNIZED:  07 24 01 07 00 01 00
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x8e  EP 14 IN
            bmAttributes           37
              Usage Type               Implicit feedback Data
            bInterval               1
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceSubClass      3
          iInterface              0
          ** UNRECOGNIZED:  06 24 f1 02 03 03
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x03  EP 3 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0200  1x 512 bytes
            bInterval               1
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x84  EP 4 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       1
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            bInterval               4
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x85  EP 5 IN
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval               4
    I know this is not class compliant, I'll be dealing with that later, for now I just want Teensy to enumerate it correctly before I work on a custom driver for it.
    What could be causing this "ERROR Followup", and where should I look to debug this ? Is there more debug print in the library I can enable to get more details on this ?
    7,658
    Looks like everything about this USB device is vendor specific...
    You already turned on the main debug output code.
    But: many of the source files have debug code commented out. As being too verbose...
    If it were me, I would probably go into enumeration.cpp And uncomment the few that are there...
    Likewise in ehci.cpp especially when that file has the print for ERROR Followup.
    Also what sketch are you running? Which USB devices have you added? Reason I ask is if none are added maybe there are not any resources like transfers and the like that can be allocated?
    I would probably go into: USBHost::new_Device and add some more prints to see where it is erroring out?
    And then localize down to what is failing.
    Jul 2020
    15
    Thanks for the advice, I'll give that a go.
    Here's the code I use :
    #include "USBHost_t36.h"
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    MIDIDevice midi1(myusb);
      delay(1500);
      myusb.begin();
      Serial.println("Ready");
      myusb.Task();
      midi1.read();
    I noticed that I get different results with different cables.
    One cable gives me :
    USB2 PLL running
    begin ehci reset reset waited 6
    Ready
    port change: 10001803
        connect
    timer0
      begin reset
    port change: 10001005
      port enabled
    timer0
      end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
      first in async list
    new_Control_Transfer
    setup address 200033B0
    Transfer Followup List 20003540 to 200034C0
        forward:
        20003540 OUT 0
        20003480 IN 8
        200034C0 OUT 0
        backward:
        200034C0 OUT 0
        20003480 IN 8
        20003540 OUT 0
    While 2 other cables give me :
    USB2 PLL running
    Ready
        connect
    timer0
      begin reset
      port enabled
    timer0
      end recovery
    new_Pipe
      first in async list
        forward:
        20003540 OUT 0
        20003480 IN 8
        200034C0 OUT 0
        backward:
        200034C0 OUT 0
        20003480 IN 8
        20003540 OUT 0
    ERROR Followup
      Followup 20003540    token=80259
        completed
    enumeration:
    00 00 00 00 00 00 00 00
    Transfer @ 200034C0
       next:  20003500
       anext: 1
       token: 800080C0
       bufs:  0,1000,2000,3000,4000
    Transfer Followup List 20003500 to 200022E0
        forward:
        20003500 OUT 0
        200022E0 IN 0
        backward:
        200022E0 IN 0
        20003500 OUT 0
      Followup 20003480    token=80080180
      Followup 20003500    token=80280
      Followup 200022E0    token=80008180
    I suspect that the first cable is bad, but let me know what you think.
    I'll add some more debug print in the library and keep you posted.
    7,658
    I am not sure if it would help much, but I do have a sketch I posted about yesterday (with a PR to add to hopefully next release of Teensyduino), that prints out a lot of information about device when plugged in. Mainly for HID devices, but some of the top level stuff might be useful. And would at least see if it enumerates the devices properly...
    You might try running it and see if it at least shows the enumeration being called and if it makes it to enumeration of Interfaces...
    Attached Files Attached Files
    Jul 2020
    15
    Sweet, thanks, unfortunately it doesn't print anything when I plug the device in, so as I suspected I'm not completing enumeration at all. It will be handy later though once I solved the enumeration issue.
    Jul 2020
    15
    Right, I think I found the problem, I'm an idiot. I soldered my usb socket back to front... Good thing I didn't blow up the Teensy nor the Amp .
    I now have enumeration :
    USB2 PLL running
     reset waited 6
    Ready
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 FF 00 FF 40 82 05 D8 01 00 00 01 02 00 01
        VendorID = 0582, ProductID = 01D8, Version = 0000
        Class/Subclass/Protocol = 255 / 0 / 255
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: BOSS
    enumeration:
    Product: KATANA
    enumeration:
    Config data length = 188
    enumeration:
      09 02 BC 00 04 01 00 C0 00
        NumInterfaces = 4
        ConfigurationValue = 1
      09 04 00 00 00 FF FF 00 00
        Interface = 0
        Number of endpoints = 0
        Class/Subclass/Protocol = 255 / 255 / 0
      09 04 01 00 00 FF 02 02 00
        Interface = 1
        Class/Subclass/Protocol = 255 / 2 / 2
      06 24 F1 01 00 00
      09 04 01 01 01 FF 02 02 00
        Interface = 1
        Number of endpoints = 1
      0B 24 02 01 04 04 18 01 44 AC 00
      06 24 F1 04 16 00
      07 05 0D 05 70 00 01
        Endpoint = 13 OUT
        Type = Isochronous
        Max Size = 112
        Polling Interval = 1
      07 25 01 00 00 00 00
      09 04 02 00 00 FF 02 01 00
        Interface = 2
        Class/Subclass/Protocol = 255 / 2 / 1
      09 04 02 01 01 FF 02 01 00
        Interface = 2
      06 24 F1 04 16 00
      07 05 8E 25 70 00 01
        Endpoint = 14 IN
        Type = Isochronous
        Max Size = 112
      09 04 03 00 02 FF 03 00 00
        Interface = 3
        Number of endpoints = 2
        Class/Subclass/Protocol = 255 / 3 / 0
      06 24 F1 02 03 03
      07 05 03 02 00 02 01
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 512
      07 05 84 02 00 02 00
        Endpoint = 4 IN
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      09 04 03 01 02 FF 03 00 00
        Interface = 3
      07 05 03 03 00 02 04
        Endpoint = 3 OUT
        Type = Interrupt
        Max Size = 512
        Polling Interval = 4
      07 05 85 03 00 02 04
        Endpoint = 5 IN
        Type = Interrupt
        Max Size = 512
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=200023A0
    USBHub claim_device this=20002760
    Descriptor 4 = INTERFACE
    MIDIDevice claim this=20001CC0
    len = 179
      Interface is unknown (might be Yahama)
    type: 4, len: 9
    This interface is not MIDI
    len = 170
    type: 36, len: 6
        Unknown MIDI CS_INTERFACE descriptor!
    Descriptor 36 =  ???
    len = 155
    type: 36, len: 7
        MIDI Header (ignored)
    type: 36, len: 11
        MIDI IN Jack (ignored)
    type: 36, len: 6
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 5 = ENDPOINT
    Descriptor 37 =  ???
    len = 108
    type: 4, len: 9
    len = 99
    type: 36, len: 7
    type: 36, len: 11
    type: 36, len: 6
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 37 =  ???
    len = 52
    type: 36, len: 6
        Roland vendor-specific (ignored)
    type: 5, len: 7
        MIDI Endpoint: 3
          tx_size = 512
    type: 5, len: 7
        MIDI Endpoint: 84
          rx_size = 512
    type: 4, len: 9
    Descriptor 36 =  ???
    len = 23
    type: 5, len: 7
        MIDI Endpoint: 3
          tx_size = 512
    type: 5, len: 7
        MIDI Endpoint: 85
          rx_size = 512
    I will now be working on a MIDI driver for this.
