Results 1 to 2 of 2
Thread: Need help making Trellis send MIDI on/off messages
    Aug 2020
    14
    I want to send MIDI on/off messages with the Trellis. According to those on the internet, it's super easy. I'm finding it hard. The code I'm using is the Trellis Test that comes in the Trellis library, with MIDI code copied from another basic Trellis library that doesn't work.
    The Trellis Test code aspect of this sketch still functions as intended, but I get no MIDI reading when using the MIDI Monitor 2 software. Please help. Thanks.
    #include "Adafruit_Trellis.h"
    #include <MIDI.h>
    #define MOMENTARY 0
    #define MODE MOMENTARY
    #define NUMTRELLIS 1
    #define numKeys (NUMTRELLIS * 16)
    #define INTPIN 13
    Adafruit_Trellis matrix0 = Adafruit_Trellis();
    Adafruit_TrellisSet trellis = Adafruit_TrellisSet(&matrix0);
    int velocity = 100;
    int noteON = 144;
    int noteOFF = 128;
        pinMode(INTPIN, INPUT);
      digitalWrite(INTPIN, HIGH);
      delay(30);
      if (MODE == MOMENTARY) {
      if (trellis.readSwitches()) {
          for (int8_t i=0; i<numKeys; i++) {
            if (trellis.justPressed(i)) {
              MIDImessage(noteON, 48+1, velocity);
              trellis.setLED(i);
            if (trellis.justReleased(i)) {
              MIDImessage(noteOFF, 48+i, velocity);
              trellis.clrLED(i);
          trellis.writeDisplay();
    void MIDImessage(int command, int MIDInote, int MIDIvelocity) {
      Serial.write(command);
      Serial.write(MIDInote);
      Serial.write(MIDIvelocity);
    Aug 2019
    Melbourne Australia
    160
    You might try this :-
    #include <MIDI.h>
    // then we need to tell the library which Uart to use
    // So, assuming you have connected Midi I/O circuitry to TX/RX 1
    MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
    #define MOMENTARY 0
    #define INTPIN 13
    int velocity = 100;
    int noteON = 144; //not used
    int noteOFF = 128;//not used
    int channel = 1; // A channel to send on
    //  Then we need to wake the Midi library up
        MIDI.begin(MIDI_CHANNEL_OMNI);
        while (MIDI.read())
         // controllers must call .read() to keep the queue clear even if they are not responding to MIDI
      delay(30);
    //          MIDImessage(noteON, 48+1, velocity);
          MIDI.sendNoteOn(48+i, velocity, channel);
              trellis.setLED(i);
    //          MIDImessage(noteOFF, 48+i, velocity);
          MIDI.sendNoteOff(48+i, velocity, channel);
              trellis.clrLED(i);
    // Not using this part
    //void MIDImessage(int command, int MIDInote, int MIDIvelocity) {
    //  Serial.write(command);
    //  Serial.write(MIDInote);
    // Serial.write(MIDIvelocity);
    I think will work, not tested here.
