Results 1 to 8 of 8
Thread: teensy_loader_cli executable for windows?
    Sep 2018
    17
    Does anyone happen to have a windows executable for teensy_loader_cli, the Teensy Loader Command Line Interface, that is recent enough to work with Teensy 4.1? I am quite unfamiliar with gcc compiling (which is why I like Teensyduino!)
    Many thanks!
    Jul 2020
    174
    Better that this should be provided directly by PJRC. You don't want to run binary code from some random person online. Even if the person is nice (and I suspect most people here are) there is no way of knowing what's going on with another person's computer. All antivirus programs can be bypassed by sufficiently new exploits.
    12,691
    not seeing a posted Windows binary - or as part of TD install.
    This doesn't have T_4.1 support :: pjrc.com/teensy/loader_cli.html
    And it isn't here either: github.com/PaulStoffregen/teensy_loader_cli
    7,909
    I have not tried it yet, but it might be as simple as adding one line to the sources:
    } MCUs[] = {
    	{"at90usb162",   15872,   128},
    	{"atmega32u4",   32256,   128},
    	{"at90usb646",   64512,   256},
    	{"at90usb1286", 130048,   256},
    #if defined(USE_LIBUSB) || defined(USE_APPLE_IOKIT) || defined(USE_WIN32)
    	{"mkl26z64",     63488,   512},
    	{"mk20dx128",   131072,  1024},
    	{"mk20dx256",   262144,  1024},
    	{"mk66fx1m0",  1048576,  1024},
    	{"mk64fx512",   524288,  1024},
    	{"imxrt1062",  2031616,  1024},
    	// Add duplicates that match friendly Teensy Names
    	// Match board names in boards.txt
    	{"TEENSY2",   32256,   128},
    	{"TEENSY2PP", 130048,   256},
    	{"TEENSYLC",     63488,   512},
    	{"TEENSY30",   131072,  1024},
    	{"TEENSY31",   262144,  1024},
    	{"TEENSY35",   524288,  1024},
    	{"TEENSY36",  1048576,  1024},
    	{"TEENSY40",  2031616,  1024},
    	{"TEENSY41",  8126464,  1024},
    	{NULL, 0, 0},
    12,691
    That's what I saw that showed it 'missing' - but the HTML page is lacking too.
    Also haven't seen the 'Pass PC time to Teensy during upload for RTC' exposed for T_4.x so koromix can put it into TyCommander.
    7,909
    Yep - It only adds it in part way... Still don't have any of the information about time, but that is also true for T4...
    Would also be good to update the Readme file and website as well.
    12,691
    Maybe flash uses block size over 1024 and programming fails?
    Indeed - already copied post #3 above about website to the web edit needed thread.
    7,909
    I did a quick and dirty and added the entry and build on RPI and was able to program a T4.1 with a simple fast blink program.
    I also updated Readme file: https://github.com/PaulStoffregen/te...er_cli/pull/61
