Page 2 of 2 FirstFirst 1 2
Results 26 to 33 of 33
Thread: teensy_loader_cli executable for windows?
  1. #26
    10,536
    It probably would build on 2019 as well...
    The RAWHID stuff was done on 2019
  2. #27
    16,013
    It was asking for some specific 1.45 (?) tool pack. Rather than see if an update would grab it (or it could be found) - the Install of VS2022 Enterprise is done - ready for a reboot
  3. #28
    16,013
    Didn't restart yet - opened and build gave this:
    Severity	Code	Description	Project	File	Line	Suppression State
    Error	LNK2019	unresolved external symbol __imp_SetupDiGetDeviceInterfaceDetailW referenced in function open_usb_device	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\hid_Windows.obj	1
    Error	LNK2019	unresolved external symbol __imp_timeGetTime referenced in function teensy_write	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\hid_Windows.obj	1
    Error	LNK2019	unresolved external symbol __imp_SetupDiDestroyDeviceInfoList referenced in function open_usb_device	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\hid_Windows.obj	1
    Error	LNK2019	unresolved external symbol __imp_SetupDiEnumDeviceInterfaces referenced in function open_usb_device	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\hid_Windows.obj	1
    Error	LNK2019	unresolved external symbol __imp_SetupDiGetClassDevsW referenced in function open_usb_device	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\hid_Windows.obj	1
    Error	LNK2019	unresolved external symbol HidD_GetAttributes referenced in function open_usb_device	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\hid_Windows.obj	1
    Error	LNK2019	unresolved external symbol HidD_GetHidGuid referenced in function open_usb_device	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\hid_Windows.obj	1
    Error	LNK1120	7 unresolved externals	Teensy_loader_cli	D:\Tim\downloads\Teensy_loader_cli\x64\Debug\Teensy_loader_cli.exe	1
    >> same after restart of course
  4. #29
    10,536
    Not right now I am building for Debug x86
    I am not sure if x64 can build.
    If you open properties on project:
    Go to linker/Input section
    The Additional Dependencies: hid.lib;setupapi.lib;winmm.lib;%(AdditionalDepende ncies)
  5. #30
    16,013
    Kurt - works to build fine as x86:
    D:\Tim\downloads\Teensy_loader_cli\Debug>Teensy_loader_cli.exe
    Filename must be specified
    Usage: teensy_loader_cli --mcu=<MCU> [-w] [-h] [-n] [-b] [-v] [-f] <file.hex>
            -w : Wait for device to appear
            -r : Use hard reboot if device not online
            -s : Use soft reboot if device not online (Teensy 3.x & 4.x)
            -n : No reboot after programming
            -b : Boot only, do not program
            -v : Verbose output
            -f : Fill memory region holes with 0s
            -d : dump hex file memory ranges
  6. #31
    10,536
    Quick update: I reworked the setup, such that the Visual Studio builds using the same .c file as used in the makefile
    I then added the external stuff into that source file. And it appears to build again.
    I then pushed these changes up to my Fork/Branch: https://github.com/KurtE/teensy_load...ee/experiments
    Will see if this is something I should issue a Pull Request back to Paul or not...
    note: My experiments branch code has two extra options:
    -d (Dumps the address ranges within the hex file)
    -f (Tries to fill in holes between areas within hex file)
    Some of my changes were to make Windows happier, to use things like sscanf_s instead of sscanf but Linux did not like ssconf_s so made all of these use: SSCANF
    which I defined depending on this or not.
  7. #32
    16,013
    @KurtE - I'll give it a go to confirm it builds here and check back.
  8. #33
    16,013
    @KurtE - Teensy_loader_cli.sln works to build setting Debug x86:
            Hello World - Defragster was here!
            -v : Verbose output
    Didn't try an upload - but minor source edit built, and shows in usage output!
    Using Win 11 and up to date MSFT Visual Studio 2022
    If WDK was needed - it was resident from VS 2019 install
