// Note: it is important for the pins to be #defined here to allow the fast reads to work properly as the need to know the pins at compile time
#define PinCamVsync 2 // EMC_04
#define PinCamHref 3 // EMC_05
#define PinCamPpclk 4 // EMC_06
#define PinCamXclk 5 // EMC_08
#define PinCamD0 14 // AD_B1_02
#define PinCamD1 15 // AD_B1_03
#define PinCamD2 17 // AD_B1_06
#define PinCamD3 16 // AD_B1_07
#define PinCamD4 22 // AD_B1_08
#define PinCamD5 23 // AD_B1_09
#define PinCamD6 20 // AD_B1_10
#define PinCamD7 21 // AD_B1_11
#include "Camera.h"
static int const cameraAddress= 0x21; // i2c address of camera's sccb device
static struct { uint8_t reg, val; } const OV7670Registers[] = {
{0x12, 0x80}, // Reset to default values
{0x11, 0x80}, // Set some reserved bit to 1!
{0x3B, 0x0A}, // Banding filter value uses BD50ST 0x9D as value. some reserved stuff + exposure timing can be less than limit on strong light
{0x3A, 0x04}, // output sequense elesection. Doc too lmited to be sure
{0x3A, 0x04},
{0x12, 0x04}, // Output format: rgb
{0x8C, 0x00}, // Disable RGB444
{0x40, 0xD0}, // Set RGB565
{0x17, 0x16}, // Y window start msb (3-11) I think
{0x18, 0x04}, // Y window end msb (3-11)
{0x32, 0x24}, // Y window lsb end= 100b start= 100b
{0x19, 0x02}, // X window start msb (2-10) I think
{0x1A, 0x7A}, // X window end msb (2-10) I think
{0x03, 0x0A}, // X window lsb (10 and 10)
{0x15, 0x02}, // VSync negative
{0x0C, 0x04}, // DCW enable?
{0x3E, 0x1A}, // Divide by 4
{0x1E, 0x27}, // mirror image black sun enabled and more reserved!
{0x72, 0x22}, // Downsample by 4
{0x73, 0xF2}, // Divide by 4
{0x4F, 0x80}, // matrix coef
{0x50, 0x80},
{0x51, 0x00},
{0x52, 0x22},
{0x53, 0x5E},
{0x54, 0x80},
{0x56, 0x40}, // contracts
{0x58, 0x9E}, // matrix
{0x59, 0x88}, // AWB
{0x5A, 0x88},
{0x5B, 0x44},
{0x5C, 0x67},
{0x5D, 0x49},
{0x5E, 0x0E},
{0x69, 0x00}, // gain per channel
{0x6A, 0x40}, // more gain
{0x6B, 0x0A}, // pll reserved stuff!
{0x6C, 0x0A}, // AWB
{0x6D, 0x55},
{0x6E, 0x11},
{0x6F, 0x9F},
{0xB0, 0x84}, // reserved!
{0xFF, 0xFF} // End marker
// Read a single uint8_t from address and return it as a uint8_t
static uint8_t cameraReadRegister(uint8_t address)
Wire.beginTransmission(cameraAddress);
Wire.write(address);
Wire.endTransmission();
Wire.requestFrom(cameraAddress, 1);
uint8_t data = Wire.read();
return data;
// Writes a single uint8_t (data) into address
static int cameraWriteRegister(uint8_t address, uint8_t data)
Wire.write(address); Wire.write(data);
return Wire.endTransmission();
// Reset all OV7670 registers to their default values
static void cameraReset()
cameraWriteRegister(0x12, 0x80); delay(10);
cameraWriteRegister(0x12, 0); delay(10);
// Read and display all of the OV7670 registers
static void cameraReadI2C()
for (int i = 0; i <= 0xC9; i ++)
Serial.print("Register: "); Serial.print(i, HEX); Serial.print(" Value: "); uint8_t reg = cameraReadRegister(i); Serial.println(reg, HEX);
// Slow the frame rate enough for camera code to run with 8 MHz XCLK. Approximately 1.5 frames/second
static void cameraSlowFrameRate()
{ // Clock = external-clock * pll_mull(0,4,6 or 8 on bits 6 and 7) / (2*divider_5_lsb+1)
// Here:
// CLKRC register: Prescaler divide by 31
uint8_t reg = cameraReadRegister(0x11); cameraWriteRegister(0x11, (reg & 0b1000000) | 0b00011110);
// DBLV register: PLL = 6
reg = cameraReadRegister(0x6B); cameraWriteRegister(0x6B, (reg & 0b00111111) | 0b10000000);
static void cameraClock(int mhz) // Assumes pixel clock = 8Mhz
float ratio= mhz/8.0f; // this is what we want to get to... find closest value...
float const pll[3]= { 4.0f, 6.0f, 8.0f };
int bestpll= 0, bestdiv=0; float bestr= 1000.0;
for (int p= 0; p<3; p++)
for (int d=0; d<32; d++)
float r= pll[p]/(2*(d+1)); if (abs(r-ratio)<abs(ratio-bestr)) { bestr= r; bestpll= p+1; bestdiv= d; }
uint8_t reg = cameraReadRegister(0x11); cameraWriteRegister(0x11, (reg & 0b1000000) | bestdiv);
reg = cameraReadRegister(0x6B); cameraWriteRegister(0x6B, (reg & 0b00111111) | (bestpll<<6));
char t[100]; sprintf(t, "camera clock %f with pll=%d and div=%d", 8.0f*bestr, bestpll, bestdiv); Serial.println(t);
static void cameraFrameStartIrq();
static void cameraReadLineIrq();
static inline bool getCamVsync() { return (GPIO4_DR & (1<<4))!=0; } // 2 // EMC_04
static inline bool getCamHref() { return (GPIO4_DR & (1<<5))!=0; } // 3 // EMC_05
static void inline cameraStopLineIrq() { GPIO4_IMR&= ~(1<<5); } // disable irq
static void inline cameraStartLineIrq() { GPIO4_ISR&= ~(1<<5); GPIO4_IMR|= 1<<5; } // clear any previous IRQ and re-enabled
static inline bool getCamPpclk() { return (GPIO4_DR & (1<<6))!=0; } // 4 // EMC_06
void cameraBegin()
// Setup all GPIO pins as inputs
pinMode(PinCamVsync, INPUT); pinMode(PinCamHref, INPUT); pinMode(PinCamPpclk, INPUT);
pinMode(PinCamD0, INPUT); pinMode(PinCamD1, INPUT); pinMode(PinCamD2, INPUT); pinMode(PinCamD3, INPUT); pinMode(PinCamD4, INPUT); pinMode(PinCamD5, INPUT); pinMode(PinCamD6, INPUT); pinMode(PinCamD7, INPUT);
analogWriteFrequency(PinCamXclk, 8000000); analogWrite(PinCamXclk, 127); delay(100); // 9mhz works, but try to reduce to debug timings with logic analyzer
// Configure the camera for operation
Wire.begin();
int i= 0; while (OV7670Registers[i].reg!=0xff) { cameraWriteRegister(OV7670Registers[i].reg, OV7670Registers[i].val), i++; }
cameraWriteRegister(0x3a, 0x14);cameraWriteRegister(0x67, 0xc80);cameraWriteRegister(0x68, 0x80); // B&W mode...
//cameraClock(12);
//cameraWriteRegister(0x11, 0x07); cameraWriteRegister(0x3b, 0x0a);// Night mode1
//cameraWriteRegister(0x11, 0x03); cameraWriteRegister(0x3b, 0x0a);// Night mode2
attachInterrupt(digitalPinToInterrupt(PinCamVsync), cameraFrameStartIrq, RISING);
attachInterrupt(digitalPinToInterrupt(PinCamHref), cameraReadLineIrq, RISING); //cameraStopLineIrq();
static inline uint32_t cameraReadPixel()
uint32_t pword= GPIO6_DR >> 18; // get the port bits. We want bits 18, 19 and 22 to 27
return (pword&3) | ((pword&0x3f0)>>2);
static uint16_t cameraImageTemp[160 * 120]; // QQVGA image buffer in RGB565 format. This is where the IRQ stores the incomming picture
uint16_t cameraImage[160 * 120]; // When an image is complete, it is copied here (note: use switch buffers to avoid mem copy?)
static bool cameraNewFrame= false; // true when cameraImage contains a new image that was never read
static uint32_t cameraPixelPos= 0, cameraLineCount= 0; // Used to know where to store the nex incmming pixel and where we are in the frame receiving...
static uint32_t nextFrameGatherTime= 0; // when next to grab a frame? This is used to limit the framerate
static bool cameraframeError= false; // true if an error was detected
static bool cameraframeDone= true; // true when a frame was fully received. no further reception will be done while ture
// Function called on line sync raising IRQ. Reads an incomming line and stores it in cameraImageTemp
if (cameraframeDone) return; // not actively receiving. Ignore the frame.
// uint32_t linet1= ARM_DWT_CYCCNT;
for (int k=cameraWidth(); --k>=0;) // get a full ine
if (!getCamHref() || !getCamVsync()) { cameraframeError= true; return; } // if premature end detected. note it.
while (!getCamPpclk()); // Wait for clock to go high
uint32_t hByte = cameraReadPixel();
while (getCamPpclk()); // Wait for clock to go back low
uint32_t lByte = cameraReadPixel();
cameraImageTemp[cameraPixelPos++] = (hByte << 8) | lByte; // save data.
if (--cameraLineCount>0) return; // frame not done? ready for next line!
cameraframeDone= true; // stop further reading until requested
cameraNewFrame= true; // note that the frame is complete for the caller
memcpy(cameraImage, cameraImageTemp, sizeof(cameraImageTemp)); // Copy it to main buffer
// Function called on frame sync raising IRQ. schedule a read of the next frame.
// limit frame reading at 5/s
uint32_t now= millis();
if (nextFrameGatherTime>now) return;
nextFrameGatherTime= now+200; // schedule next read in 200ms
// ready for next frame...
cameraPixelPos= 0; cameraLineCount= cameraHeight(); cameraframeError= false; cameraframeDone= false;
// return true if a new frame is available in the cameraImage buffer.
bool cameraRead()
bool r= cameraNewFrame; cameraNewFrame= false; return r;
