I have a project based around a PGA4311, but I don't seem to be able to work out how to get the SPI data to be padded out to the required 8 bits per channel. So when 10000010 is written, the correct number of bits are sent, but when 01111000 is, only 7 bits are sent (for example). I've tried using the data variable as an uint8_t type, but this hasn't done what I expected (which was, that it would be an 8 bit value, regardless of how many bits are stored). I'm sure i'm missing something rather simple, as without doubt this is a fairly common scenario.
My function for writing is:
The output of the above shows that it isn't strictly an SPI issue, as the 7 bit value can be seen in the serial monitor:
void updatePGA(int newVolume){
uint8_t scaledVolume = ((PGA_MAX / VOL_MAX) * newVolume);
Serial.println("New scaled volume:");
Serial.println(scaledVolume);
Serial.println(scaledVolume, BIN);
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
digitalWrite(slaveSelectPinPGA, LOW);
for (int iCh = 0; iCh < 4; iCh++) {
// 4 times, for each channel on the PGA4311
//Serial.println(iCh);
SPI.transfer(scaledVolume);
digitalWrite(slaveSelectPinPGA, HIGH);
SPI.endTransaction();
Serial.println("end updatePGA()");
12:35:18.645 -> New scaled volume:
12:35:18.645 -> 120
12:35:18.645 -> 1111000
12:35:19.672 -> New scaled volume:
12:35:19.672 -> 130
12:35:19.672 -> 10000010
