Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 26 to 50 of 83
Thread: Teensy with 4 or 5 wireless temperature sensors
  1. #26
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    339
    No Data sent in serial ?
    Also if you have no delay in the loop this will run continously ... I would add either a long delay or let the transmissions happend at certain second (based on currentMillis).
    Look at the TX and RX example on https://forum.arduino.cc/index.php?topic=421081
    They use currentMillis as a trigger to send data ever X milliseconds.
  2. #27
    Jun 2015
    285
    hmmm I trie dthe TX exmaple as suggested.
    Still got TX failed msg in Serial.
    But accidently disconnected teh SCK pin from board (aka D13 on Nano) & it suddenly changed to Acknowledge Recieved
  3. #28
    Jun 2018
    Netherlands
    339
    And does the data get transmitted ? Do you see it on the RX side ?
  4. #29
    Jul 2020
    174
    Off the top of my head, you are sending a float into println() and getting "NaN".
    Try using Serial.printf("Sent temperature: %f\n", SENT_temperature). That way, you can eliminate "is println() correctly figuring out what I'm asking?" from what could be happening. I vaguely remember that there are cases where you have to use printf() with a format string because println() will not figure it out.
    The float value probably is "not a number" (which is a supported value for floats), which would indicate that the library either didn't receive anything - or did, but couldn't make sense of it (timing issue, running at the wrong speed, some configuration isn't right, etc.)
  5. #30
    Jun 2015
    285
    OK
    I got really frustrated with all this and took it right back to basics.
    Now my board literally just has the NRF24L01+ connected.
    And I loaded the GETTINGSTART project that comes with NRL24 library - just to see if I could get one of these things to talk to itself.
    BTW - I had to change the include part from:
    #include "RF24.h"
    as it wouldnt compile.
    I also changed teh data being sent to a String.
    #include <nRF24L01.h>
    #include <RF24.h>
    /****************** User Config ***************************/
    /***      Set this radio as radio number 0 or 1         ***/
    bool radioNumber = 0;
    /* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
    RF24 radio(7, 8);
    byte addresses[][6] = {"1Node","2Node"};
    // Used to control whether this node is sending or receiving
    bool role = 1;
      Serial.println(F("RF24/examples/GettingStarted"));
      Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
      radio.begin();
      // Set the PA Level low to prevent power supply related issues since this is a
     // getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
      radio.setPALevel(RF24_PA_LOW);
      // Open a writing and reading pipe on each radio, with opposite addresses
      if(radioNumber){
        radio.openWritingPipe(addresses[1]);
        radio.openReadingPipe(1,addresses[0]);
      }else{
        radio.openWritingPipe(addresses[0]);
        radio.openReadingPipe(1,addresses[1]);
      radio.setDataRate(RF24_2MBPS);
      // Start the radio listening for data
      radio.startListening();
    /****************** Ping Out Role T ***************************/
    if (role == 1)  {
        radio.stopListening();                                    // First, stop listening so we can talk.
        Serial.println(F("----------------------------------------------"));
        Serial.println(F("Now sending Data"));
        unsigned long start_time = micros();
        String Astart_time = "HELP"; // Take the time, and send it.  This will block until complete
         if (!radio.write( &Astart_time, sizeof(Astart_time) ))
           Serial.println(F("Write failed"));
          Serial.println(F("**** Write SUCCEEDED ****"));
        radio.startListening();                                    // Now, continue listening
        unsigned long started_waiting_at = micros();               // Set up a timeout period, get the current microseconds
        boolean timeout = false;                                   // Set up a variable to indicate if a response was received or not
        while ( ! radio.available() ) // While nothing is received
          if (micros() - started_waiting_at > 200000 )    // If waited longer than 200ms, indicate timeout and exit while loop
              timeout = true;
        if ( timeout )
        {                                             // Describe the results
            Serial.println(F("Failed, response timed out."));
        }else
            unsigned long got_time;                                 // Grab the response, compare, and send to debugging spew
            String Agot_time;
            radio.read( &Agot_time, sizeof(got_time) );
            unsigned long end_time = micros();
            // Spew it
            Serial.print(F("Tx: "));
            Serial.println(Astart_time);
            Serial.print(F("Rx: "));
            Serial.println(Agot_time);
            Serial.print(F("Round-trip delay "));
            Serial.print(end_time-start_time);
            Serial.println(F(" micros"));
            Serial.println("");
        // Try again 1s later
    /****************** Pong Back Role R ***************************/
      if ( role == 0 )
        if( radio.available()){                                                   // Variable for the received timestamp
          while (radio.available())
          {                                                             // While there is data ready
            radio.read( &got_time, sizeof(unsigned long) );             // Get the payload
          radio.write( &got_time, sizeof(unsigned long) );              // Send the final one back.
          radio.startListening();                                       // Now, resume listening so we catch the next packets.
          Serial.print(F("Sent response "));
          Serial.println(got_time);
    /****************** Change Roles via Serial Commands ***************************/
      if ( Serial.available() )
        char c = toupper(Serial.read());
        if ( c == 'T' && role == 0 ){
          Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
          role = 1;                  // Become the primary transmitter (ping out)
       }else
        if ( c == 'R' && role == 1 ){
          Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
           role = 0;                // Become the primary receiver (pong back)
    } // Loop
    Still can't get it working.
    I set the code to run in TRANSMIT mode.
    and here's what i get on the Serial:
    PHP Code:
    Now sending Data
    Write failed
    Tx
    HELP
    Rx
    Round-trip delay 95681 micros
    ie nothing Rx'd.
    Then I physically picked the project up by teh wires & noticed the serial chnaged to :
    PHP Code:
    Now sending Data
    TxHELP
    Rx
    Round-trip delay 14847 micros
    ie the Write now succeeds but still nothing is recieved.
    By trial & error I found I can replicate this by literally just lightly touching the SPI wires OR putting my fingers around the whole wire bundle WITHOUT touching then.
    No idea whats going on here - any one ideas pls.
    BTW get the same thing with a Teensy 3.2, 3.6 and a clone Nano.
  6. #31
    Jun 2018
    Netherlands
    339
    For me it is unclear what you are trying to achieve. Are you trying to receive with the same NRF24L01+ that has been sending ?
    Cor
    PS: if you are using the example from https://github.com/nRF24/RF24/blob/m...ingStarted.ino than its ment to be used on two boards one with role=1 and one with role=0.
  7. #32
    Jun 2015
    285
    DOH!!!
    Now dont I just feel stupid (again).
    Maybe thsi RF stuff is just a step too far for me.
    I did think it was strange.
    But I thought the switching was being done in the code - to send as a Tx then switch to recieve as a Rx.
    All teh other examples I seen explicity called out seperate code for teh Tx & Rx.
    Will hook up a 2nd one again & give it another try - thanks.
    BTW any idea on the behaviour I mentioned with wrapping my fingers arund the cables?
  8. #33
    Jun 2018
    Netherlands
    339
    Yes you can switch roles in the code but ... you need to go back in time first to be able to receive the data you just had sent
    Your fingers and cables could be that there is a lot of static around or so. How long are your cables ? I never used cables on these and mounted them on a perfboard very close to the MCU.
  9. #34
    Jun 2018
    Netherlands
    339
    When I work on things that are new to me I tend to remember a quote from a danish mathematician:
    The road to wisdom? — Well, it's plain
    and simple to express:
    Err
    and err
    and err again
    but less
    and less
    and less.
  10. #35
    Jun 2018
    Netherlands
    339
    For the wires check for instance this thread for arduino nano https://forum.arduino.cc/index.php?topic=500708.0
  11. #36
    Jun 2015
    285
    thanks.
    I'm using short cables as still working at breadboard stage.
    wires are 100mm max.
    Got 2 modules running now.
    But still can get data to be recieved
  12. #37
    Jun 2018
    Netherlands
    339
    Have you tried this advice "It is recommended to plce a 10F capacitor across VCC and GND"
    And furthermore, your measured all the connections ? No broken wires/disconnected breadboard points ?
  13. #38
    Jun 2018
    Netherlands
    339
    And finally (for today) this might be helpfull (message #29) https://forum.arduino.cc/index.php?t...559#msg3653559
  14. #39
    Jul 2020
    174
    What is the significance of this?
  15. #40
    Jun 2018
    Netherlands
    339
    Quote Originally Posted by Pilot View Post
    The lines above the code state the logic behind it. When you are testing devices you dont need to use the maximum power, doing so reduces the power needed to send data and thus also reduces (possible) issues due to an unstable power-supply. The other advice (to mount a 10uF close to the nRF24L01 over VCC/GND) is probably related to these type of issues.
    In my setup (as stated before using TI MSP430 chips) I have never had to do this, but using other MCUs things might work different.
  16. #41
    Jun 2015
    285
    Quote Originally Posted by CorBee View Post
    Yes doen this too
  17. #42
    Jun 2018
    Netherlands
    339
    And you also tried the suggestion I made in message #38 ?
  18. #43
    Jun 2015
    285
    I did yes - no luck either.
    I'm currently trying solder Nano & Radio unit onto a small perf board.
    WIll report back what that yeilds.
    Thanks for your continued support & help.
  19. #44
    Jun 2018
    Netherlands
    339
    What was the output of the testconnection.ino ?
  20. #45
    Jun 2015
    285
    This what im now getting with a single project on a perf board:
    13:31:38.454 -> CheckConnection Starting
    13:31:38.454 ->
    13:31:38.454 -> FIRST WITH THE DEFAULT ADDRESSES after power on
    13:31:38.554 -> Note that RF24 does NOT reset when Arduino resets - only when power is removed
    13:31:38.601 -> If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
    13:31:38.702 -> communicating with the nRF24
    13:31:38.755 ->
    13:31:38.755 -> SPI Speedz = 10 Mhz
    13:31:38.755 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    13:31:38.855 -> RX_ADDR_P0-1 = 0xe7e7e7e7e7 0x4141417852
    13:31:38.855 -> RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
    13:31:38.902 -> TX_ADDR = 0xe7e7e7e7e7
    13:31:38.956 -> RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
    13:31:38.956 -> EN_AA = 0x3f
    13:31:39.003 -> EN_RXADDR = 0x02
    13:31:39.003 -> RF_CH = 0x4c
    13:31:39.056 -> RF_SETUP = 0x07
    13:31:39.056 -> CONFIG = 0x0e
    13:31:39.056 -> DYNPD/FEATURE = 0x00 0x00
    13:31:39.103 -> Data Rate = 1MBPS
    13:31:39.103 -> Model = nRF24L01+
    13:31:39.156 -> CRC Length = 16 bits
    13:31:39.156 -> PA Power = PA_MAX
    13:31:39.156 ->
    13:31:39.203 ->
    13:31:39.203 -> AND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1
    13:31:39.257 -> and 250KBPS data rate
    13:31:39.257 ->
    13:31:39.257 -> SPI Speedz = 10 Mhz
    13:31:39.304 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    13:31:39.357 -> RX_ADDR_P0-1 = 0xe7e7e7e7e7 0x4141417852
    13:31:39.404 -> RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
    13:31:39.457 -> TX_ADDR = 0xe7e7e7e7e7
    13:31:39.457 -> RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
    13:31:39.504 -> EN_AA = 0x3f
    13:31:39.558 -> EN_RXADDR = 0x02
    13:31:39.558 -> RF_CH = 0x4c
    13:31:39.558 -> RF_SETUP = 0x27
    13:31:39.605 -> CONFIG = 0x0e
    13:31:39.605 -> DYNPD/FEATURE = 0x00 0x00
    13:31:39.658 -> Data Rate = 250KBPS
    13:31:39.658 -> Model = nRF24L01+
    13:31:39.658 -> CRC Length = 16 bits
    13:31:39.705 -> PA Power = PA_MAX
    13:31:39.705 ->
    13:31:39.705 ->
  21. #46
    Jun 2018
    Netherlands
    339
    You said "no luck", but why do you conclude that ?
  22. #47
    Jun 2015
    285
    Sorry my post wasnt clear - forgot to paste the report in that post.
    So I concluded that becasue originally I was getting this:
    ***** CheckConnection Starting *****
    SPI Speedz	 = 10 Mhz
    STATUS		 = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
    RX_ADDR_P0-1	 = 0x0000000000 0x0000000000
    RX_ADDR_P2-5	 = 0x00 0x00 0x00 0x00
    TX_ADDR		 = 0x0000000000
    RX_PW_P0-6	 = 0x00 0x00 0x00 0x00 0x00 0x00
    EN_AA		 = 0x00
    EN_RXADDR	 = 0x00
    RF_CH		 = 0x00
    RF_SETUP	 = 0x00
    CONFIG		 = 0x00
    Data Rate	 = 1MBPS
    Model		 = nRF24L01
    CRC Length	 = Disabled
    PA Power	 = PA_MIN
    SPI Speedz	 = 10 Mhz
    EN_AA		 = 0x00
    EN_RXADDR	 = 0x00
    RF_CH		 = 0x00
    RF_SETUP	 = 0x00
    CONFIG		 = 0x00
    Data Rate	 = 1MBPS
    Model		 = nRF24L01
    PA Power	 = PA_MIN
  23. #48
    Jun 2018
    Netherlands
    339
    Thats indeed wrong ... getting all 0 means that the arduino is not interacting with the NRF24L01+ ... Have you tested all your NRF24L01+ transceivers with this or only one ?
  24. #49
    Jun 2015
    285
    Several.
    So does the 1st set of report output I posted - with the MCU & RF unit mounted on a Perf Baord look OK?
    ie Post #45
  25. #50
    Jun 2018
    Netherlands
    339
    Yes, that looks as the reports you can see from others. So the perfboard version should work ! Make two and install the pingpong (role) code on them and dont forget to make one of them role=0 and the other role=1, and it seems (see https://learn.sparkfun.com/tutorials...e/arduino-code) you also need to set the radionumber for each to 0 or 1 (they need to be different).
