void AudioSynthWaveformModulatedTS::update(void)
audio_block_t *block, *moddata, *shapedata;
int16_t *bp, *end;
int32_t val1, val2;
int16_t magnitude15;
uint32_t i, ph, index, index2, scale, priorphase;
const uint32_t inc = phase_increment;
moddata = receiveReadOnly(0);
shapedata = receiveReadOnly(1);
if(syncFlag==1){
phase_accumulator = 0;
syncFlag = 0;
// Pre-compute the phase angle for every output sample of this update
ph = phase_accumulator;
priorphase = phasedata[AUDIO_BLOCK_SAMPLES-1];
if (moddata && modulation_type == 0) {
// Frequency Modulation
bp = moddata->data;
for (i=0; i < AUDIO_BLOCK_SAMPLES; i++) {
int32_t n = (*bp++) * modulation_factor; // n is # of octaves to mod
int32_t ipart = n >> 27; // 4 integer bits
n &= 0x7FFFFFF; // 27 fractional bits
#ifdef IMPROVE_EXPONENTIAL_ACCURACY
// exp2 polynomial suggested by Stefan Stenzel on "music-dsp"
// mail list, Wed, 3 Sep 2014 10:08:55 +0200
int32_t x = n << 3;
n = multiply_accumulate_32x32_rshift32_rounded(536870912, x, 1494202713);
int32_t sq = multiply_32x32_rshift32_rounded(x, x);
n = multiply_accumulate_32x32_rshift32_rounded(n, sq, 1934101615);
n = n + (multiply_32x32_rshift32_rounded(sq,
multiply_32x32_rshift32_rounded(x, 1358044250)) << 1);
n = n << 1;
#else
// exp2 algorithm by Laurent de Soras
// https://www.musicdsp.org/en/latest/Other/106-fast-exp2-approximation.html
n = (n + 134217728) << 3;
n = multiply_32x32_rshift32_rounded(n, n);
n = multiply_32x32_rshift32_rounded(n, 715827883) << 3;
n = n + 715827882;
uint32_t scale = n >> (14 - ipart);
uint64_t phstep = (uint64_t)inc * scale;
uint32_t phstep_msw = phstep >> 32;
if (phstep_msw < 0x7FFE) {
ph += phstep >> 16;
ph += 0x7FFE0000;
phasedata[i] = ph;
release(moddata);
} else if (moddata) {
// Phase Modulation
bp = moddata->data;
// more than +/- 180 deg shift by 32 bit overflow of "n"
uint32_t n = (uint16_t)(*bp++) * modulation_factor;
phasedata[i] = ph + n;
ph += inc;
release(moddata);
// No Modulation Input
phasedata[i] = ph;
ph += inc;
phase_accumulator = ph;
//Amplitude is always 1 on TSynth when oscillator is sounding
//magnitude must be set to zero, otherwise digital noise comes through
if(tone_type == WAVEFORM_SILENT){
magnitude = 0;
}else{
magnitude = 65536.0;
// If the amplitude is zero, no output, but phase still increments properly
if (magnitude == 0) {
if (shapedata) release(shapedata);
return;
block = allocate();
if (!block) {
return;
bp = block->data;
// Now generate the output samples using the pre-computed phase angles
switch(tone_type) {
case WAVEFORM_SINE:
ph = phasedata[i];
index = ph >> 24;
val1 = AudioWaveformSine[index];
val2 = AudioWaveformSine[index+1];
scale = (ph >> 8) & 0xFFFF;
val2 *= scale;
val1 *= 0x10000 - scale;
*bp++ = multiply_32x32_rshift32(val1 + val2, magnitude);
case WAVEFORM_ARBITRARY:
if (!arbdata) {
release(block);
return;
// len = 256
ph = phasedata[i];
index = ph >> 24;
index2 = index + 1;
if (index2 >= 256) index2 = 0;
val1 = *(arbdata + index);
val2 = *(arbdata + index2);
val2 *= scale;
case WAVEFORM_PULSE:
if (shapedata) {
magnitude15 = signed_saturate_rshift(magnitude, 16, 1);
uint32_t width = ((shapedata->data[i] + 0x8000) & 0xFFFF) << 16;
if (phasedata[i] < width) {
*bp++ = magnitude15;
*bp++ = -magnitude15;
} // else fall through to orginary square without shape modulation
case WAVEFORM_SQUARE:
if (phasedata[i] & 0x80000000) {
case WAVEFORM_BANDLIMIT_PULSE:
if (shapedata)
int32_t val = band_limit_waveform.generate_pulse (phasedata[i], width, i) ;
*bp++ = (int16_t) ((val * magnitude) >> 16) ;
case WAVEFORM_BANDLIMIT_SQUARE:
for (i = 0 ; i < AUDIO_BLOCK_SAMPLES ; i++)
int32_t val = band_limit_waveform.generate_square (phasedata[i], i) ;
case WAVEFORM_SAWTOOTH:
*bp++ = signed_multiply_32x16t(magnitude, phasedata[i]);
case WAVEFORM_SAWTOOTH_REVERSE:
*bp++ = signed_multiply_32x16t(0xFFFFFFFFu - magnitude, phasedata[i]);
case WAVEFORM_BANDLIMIT_SAWTOOTH:
case WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE:
int16_t val = band_limit_waveform.generate_sawtooth (phasedata[i], i) ;
val = (int16_t) ((val * magnitude) >> 16) ;
*bp++ = tone_type == WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE ? (int16_t) -val : (int16_t) +val ;
case WAVEFORM_TRIANGLE_VARIABLE:
if (shapedata) {
uint32_t width = (shapedata->data[i] + 0x8000) & 0xFFFF;
uint32_t rise = 0xFFFFFFFF / width;
uint32_t fall = 0xFFFFFFFF / (0xFFFF - width);
uint32_t halfwidth = width << 15;
uint32_t n;
ph = phasedata[i];
if (ph < halfwidth) {
n = (ph >> 16) * rise;
*bp++ = ((n >> 16) * magnitude) >> 16;
} else if (ph < 0xFFFFFFFF - halfwidth) {
n = 0x7FFFFFFF - (((ph - halfwidth) >> 16) * fall);
*bp++ = (((int32_t)n >> 16) * magnitude) >> 16;
n = ((ph + halfwidth) >> 16) * rise + 0x80000000;
ph += inc;
} // else fall through to orginary triangle without shape modulation
case WAVEFORM_TRIANGLE:
ph = phasedata[i];
uint32_t phtop = ph >> 30;
if (phtop == 1 || phtop == 2) {
*bp++ = ((0xFFFF - (ph >> 15)) * magnitude) >> 16;
*bp++ = (((int32_t)ph >> 15) * magnitude) >> 16;
case WAVEFORM_SAMPLE_HOLD:
ph = phasedata[i];
if (ph < priorphase) { // does not work for phase modulation
sample = random(magnitude) - (magnitude >> 1);
priorphase = ph;
*bp++ = sample;
if (tone_offset) {
bp = block->data;
end = bp + AUDIO_BLOCK_SAMPLES;
do {
val1 = *bp;
*bp++ = signed_saturate_rshift(val1 + tone_offset, 16, 0);
} while (bp < end);
transmit(block, 0);
release(block);
Oscilloscope scope;
AudioOutputI2S PCM5102A;
AudioSynthWaveformDc constant1Dc; //xy=69.5,437
AudioSynthWaveformDc pitchBend; //xy=128,74
AudioSynthWaveformDc FilterVelo1; //xy=69.5,437
AudioSynthWaveformDc FilterVelo2; //xy=69.5,437
AudioSynthWaveformDc FilterVelo3; //xy=69.5,437
AudioSynthWaveformDc FilterVelo4; //xy=69.5,437
AudioSynthWaveformDc FilterVelo5; //xy=69.5,437
AudioSynthWaveformDc FilterVelo6; //xy=69.5,437
AudioSynthWaveformDc FilterVelo7; //xy=69.5,437
AudioSynthWaveformDc FilterVelo8; //xy=69.5,437
AudioSynthWaveformDc glide1; //xy=124,152
AudioSynthWaveformDc glide2; //xy=124,152
AudioSynthWaveformDc glide3; //xy=124,152
AudioSynthWaveformDc glide4; //xy=124,152
AudioSynthWaveformDc glide5; //xy=124,152
AudioSynthWaveformDc glide6; //xy=124,152
AudioSynthWaveformDc glide7; //xy=124,152
AudioSynthWaveformDc glide8; //xy=124,152
AudioSynthWaveformDc keytracking1; //xy=176,745
AudioSynthWaveformDc keytracking2; //xy=196,745
AudioSynthWaveformDc keytracking3; //xy=216,745
AudioSynthWaveformDc keytracking4; //xy=236,745
AudioSynthWaveformDc keytracking5; //xy=216,745
AudioSynthWaveformDc keytracking6; //xy=236,745
AudioSynthWaveformDc keytracking7; //xy=176,745
AudioSynthWaveformDc keytracking8; //xy=196,745
AudioSynthWaveformDc pwa; //xy=107,256
AudioSynthWaveformDc pwb; //xy=110,301
AudioSynthWaveformModulatedTS waveformMod1b; //xy=503,170
AudioSynthWaveformModulatedTS waveformMod1a; //xy=507,114
AudioSynthWaveformModulatedTS waveformMod2b; //xy=513,550
AudioSynthWaveformModulatedTS waveformMod4a; //xy=519,899
AudioSynthWaveformModulatedTS waveformMod2a; //xy=521,458
AudioSynthWaveformModulatedTS waveformMod4b; //xy=525,940
AudioSynthWaveformModulatedTS waveformMod3a; //xy=532,678
AudioSynthWaveformModulatedTS waveformMod3b; //xy=535,744
AudioSynthWaveformModulatedTS waveformMod5a; //xy=521,458
AudioSynthWaveformModulatedTS waveformMod5b; //xy=525,940
AudioSynthWaveformModulatedTS waveformMod6a; //xy=532,678
AudioSynthWaveformModulatedTS waveformMod6b; //xy=535,744
AudioSynthWaveformModulatedTS waveformMod7b; //xy=503,170
AudioSynthWaveformModulatedTS waveformMod7a; //xy=507,114
AudioSynthWaveformModulatedTS waveformMod8b; //xy=513,550
AudioSynthWaveformModulatedTS waveformMod8a; //xy=519,899
AudioSynthWaveformTS pitchLfo; //xy=122,111
AudioSynthWaveformTS filterLfo; //xy=166,632
AudioSynthWaveformTS pwmLfoA; //xy=92,208
AudioSynthWaveformTS pwmLfoB; //xy=92,208
AudioSynthNoisePink pink; //xy=268,349
AudioSynthNoiseWhite white; //xy=268,359
AudioAnalyzePeak peak;
AudioEffectEnvelope filterEnvelope1; //xy=628,300
AudioEffectEnvelope filterEnvelope2; //xy=640,604
AudioEffectEnvelope filterEnvelope3; //xy=636,857
AudioEffectEnvelope filterEnvelope4; //xy=617,1107
AudioEffectEnvelope filterEnvelope5; //xy=638,300
AudioEffectEnvelope filterEnvelope6; //xy=629,1107
AudioEffectEnvelope filterEnvelope7; //xy=629,1107
AudioEffectEnvelope filterEnvelope8; //xy=638,300
AudioEffectEnvelope ampEnvelope1; //xy=1327,211
AudioEffectEnvelope ampEnvelope2; //xy=1315,503
AudioEffectEnvelope ampEnvelope3; //xy=1315,823
AudioEffectEnvelope ampEnvelope4; //xy=1321,1045
AudioEffectEnvelope ampEnvelope5; //xy=1321,1045
AudioEffectEnvelope ampEnvelope6; //xy=1327,211
AudioEffectEnvelope ampEnvelope7; //xy=1315,503
AudioEffectEnvelope ampEnvelope8; //xy=1315,823
AudioEffectWaveshaper waveshaper1; //xy=638,301
AudioEffectWaveshaper waveshaper2; //xy=638,302
AudioEffectWaveshaper waveshaper3; //xy=638,303
AudioEffectWaveshaper waveshaper4; //xy=638,304
AudioEffectWaveshaper waveshaper5; //xy=638,305
AudioEffectWaveshaper waveshaper6; //xy=638,306
AudioEffectWaveshaper waveshaper7; //xy=638,307
AudioEffectWaveshaper waveshaper8; //xy=638,308
AudioEffectWaveshaper waveshaper9; //xy=638,308
AudioEffectDigitalCombine oscFX1; //xy=663,223
AudioEffectDigitalCombine oscFX2; //xy=684,542
AudioEffectDigitalCombine oscFX4; //xy=686,1046
AudioEffectDigitalCombine oscFX3; //xy=687,803
AudioEffectDigitalCombine oscFX5; //xy=686,1046
AudioEffectDigitalCombine oscFX6; //xy=687,803
AudioEffectDigitalCombine oscFX7; //xy=663,223
AudioEffectDigitalCombine oscFX8; //xy=684,542
AudioEffectEnsemble ensemble; //xy=1800,600
AudioFilterStateVariable filter1; //xy=1000,210
AudioFilterStateVariable filter2; //xy=994,498
AudioFilterStateVariable filter3; //xy=1002,822
AudioFilterStateVariable filter4; //xy=1022,1047
AudioFilterStateVariable filter5; //xy=1002,822
AudioFilterStateVariable filter6; //xy=1022,1047
AudioFilterStateVariable filter7; //xy=994,498
AudioFilterStateVariable filter8; //xy=1000,210
AudioFilterStateVariable dcOffsetFilter; //xy=1564,580
AudioMixer4 oscGlobalModMixer; //xy=296,95
AudioMixer4 noiseMixer; //xy=288,369
AudioMixer4 pwMixer1a; //xy=281,169
AudioMixer4 pwMixer1b; //xy=287,272
AudioMixer4 pwMixer2a; //xy=323.75,472.75
AudioMixer4 pwMixer2b; //xy=323.75,553.75
AudioMixer4 pwMixer3a; //xy=353.75,688.75
AudioMixer4 pwMixer3b; //xy=358.75,763.75
AudioMixer4 pwMixer4b; //xy=313.75,954.75
AudioMixer4 pwMixer4a; //xy=314.75,887.75
AudioMixer4 pwMixer5a; //xy=323.75,472.75
AudioMixer4 pwMixer5b; //xy=323.75,553.75
AudioMixer4 pwMixer6a; //xy=353.75,688.75
AudioMixer4 pwMixer6b; //xy=358.75,763.75
AudioMixer4 pwMixer7a; //xy=281,169
AudioMixer4 pwMixer7b; //xy=287,272
AudioMixer4 pwMixer8b; //xy=313.75,954.75
AudioMixer4 pwMixer8a; //xy=314.75,887.75
AudioMixer4 oscModMixer1a; //xy=550,165
AudioMixer4 oscModMixer1b; //xy=550,195
AudioMixer4 oscModMixer2a; //xy=550,205
AudioMixer4 oscModMixer2b; //xy=550,225
AudioMixer4 oscModMixer3a; //xy=550,245
AudioMixer4 oscModMixer3b; //xy=550,265
AudioMixer4 oscModMixer4a; //xy=550,285
AudioMixer4 oscModMixer4b; //xy=550,305
AudioMixer4 oscModMixer5a; //xy=550,245
AudioMixer4 oscModMixer5b; //xy=550,265
AudioMixer4 oscModMixer6a; //xy=550,285
AudioMixer4 oscModMixer6b; //xy=550,305
AudioMixer4 oscModMixer7a; //xy=550,165
AudioMixer4 oscModMixer7b; //xy=550,195
AudioMixer4 oscModMixer8a; //xy=550,205
AudioMixer4 oscModMixer8b; //xy=550,225
AudioMixer4 waveformMixer1; //xy=824,170
AudioMixer4 waveformMixer2; //xy=829,476
AudioMixer4 waveformMixer3; //xy=846,774
AudioMixer4 waveformMixer4; //xy=854,1023
AudioMixer4 waveformMixer5; //xy=846,774
AudioMixer4 waveformMixer6; //xy=854,1023
AudioMixer4 waveformMixer7; //xy=824,170
AudioMixer4 waveformMixer8; //xy=829,476
AudioMixer4 filterModMixer1; //xy=845,292
AudioMixer4 filterModMixer2; //xy=848,637
AudioMixer4 filterModMixer3; //xy=852,937
AudioMixer4 filterModMixer4; //xy=855,1099
AudioMixer4 filterModMixer5; //xy=852,937
AudioMixer4 filterModMixer6; //xy=855,1099
AudioMixer4 filterModMixer7; //xy=845,292
AudioMixer4 filterModMixer8; //xy=848,637
AudioMixer4 filterMixer1; //xy=1151,214
AudioMixer4 filterMixer2; //xy=1144,504
AudioMixer4 filterMixer3; //xy=1144,825
AudioMixer4 filterMixer4; //xy=1155,1050
AudioMixer4 filterMixer5; //xy=1151,214
AudioMixer4 filterMixer6; //xy=1155,1050
AudioMixer4 filterMixer7; //xy=1144,504
AudioMixer4 filterMixer8; //xy=1144,825
AudioMixer4 voiceMixer1; //xy=1524,570
AudioMixer4 voiceMixer2; //xy=1524,570
AudioMixer4 voiceMixer3; //xy=1524,570
AudioMixer4 voiceMixerM; //xy=1544,580
AudioMixer4 volumeMixer; //xy=1544,580
AudioMixer4 effectMixerR; //xy=1848,625
AudioMixer4 effectMixerL; //xy=1857,539
// AudioSynthWaveformDc -------------------------------------------------
AudioConnection patchCord1(constant1Dc, filterEnvelope1);
AudioConnection patchCord2(constant1Dc, filterEnvelope2);
AudioConnection patchCord3(constant1Dc, filterEnvelope3);
AudioConnection patchCord4(constant1Dc, filterEnvelope4);
AudioConnection patchCord5(constant1Dc, filterEnvelope5);
AudioConnection patchCord6(constant1Dc, filterEnvelope6);
AudioConnection patchCord7(constant1Dc, filterEnvelope7);
AudioConnection patchCord8(constant1Dc, filterEnvelope8);
AudioConnection patchCord20(pwa, 0, pwMixer1a, 1);
AudioConnection patchCord21(pwa, 0, pwMixer2a, 1);
AudioConnection patchCord22(pwa, 0, pwMixer3a, 1);
AudioConnection patchCord23(pwa, 0, pwMixer4a, 1);
AudioConnection patchCord24(pwb, 0, pwMixer5a, 1);
AudioConnection patchCord25(pwb, 0, pwMixer6a, 1);
AudioConnection patchCord26(pwb, 0, pwMixer7a, 1);
AudioConnection patchCord27(pwb, 0, pwMixer8a, 1);
AudioConnection patchCord28(pwa, 0, pwMixer1b, 1);
AudioConnection patchCord29(pwb, 0, pwMixer2b, 1);
AudioConnection patchCord30(pwa, 0, pwMixer3b, 1);
AudioConnection patchCord31(pwb, 0, pwMixer4b, 1);
AudioConnection patchCord32(pwa, 0, pwMixer5b, 1);
AudioConnection patchCord33(pwb, 0, pwMixer6b, 1);
AudioConnection patchCord34(pwa, 0, pwMixer7b, 1);
AudioConnection patchCord35(pwb, 0, pwMixer8b, 1);
AudioConnection patchCord40(pitchBend, 0, oscGlobalModMixer, 0);
AudioConnection patchCord50(keytracking1, 0, filterModMixer1, 2);
AudioConnection patchCord51(keytracking2, 0, filterModMixer2, 2);
AudioConnection patchCord52(keytracking3, 0, filterModMixer3, 2);
AudioConnection patchCord53(keytracking4, 0, filterModMixer4, 2);
AudioConnection patchCord54(keytracking5, 0, filterModMixer5, 2);
AudioConnection patchCord55(keytracking6, 0, filterModMixer6, 2);
AudioConnection patchCord56(keytracking7, 0, filterModMixer7, 2);
AudioConnection patchCord57(keytracking8, 0, filterModMixer8, 2);
AudioConnection patchCord70(FilterVelo1, 0, filterModMixer1, 3);
AudioConnection patchCord71(FilterVelo2, 0, filterModMixer2, 3);
AudioConnection patchCord72(FilterVelo3, 0, filterModMixer3, 3);
AudioConnection patchCord73(FilterVelo4, 0, filterModMixer4, 3);
AudioConnection patchCord74(FilterVelo5, 0, filterModMixer5, 3);
AudioConnection patchCord75(FilterVelo6, 0, filterModMixer6, 3);
AudioConnection patchCord76(FilterVelo7, 0, filterModMixer7, 3);
AudioConnection patchCord77(FilterVelo8, 0, filterModMixer8, 3);
AudioConnection patchCord100(glide1, 0, oscModMixer1a, 2);
AudioConnection patchCord101(glide1, 0, oscModMixer1b, 2);
AudioConnection patchCord102(glide2, 0, oscModMixer2a, 2);
AudioConnection patchCord103(glide2, 0, oscModMixer2b, 2);
AudioConnection patchCord104(glide3, 0, oscModMixer3a, 2);
AudioConnection patchCord105(glide3, 0, oscModMixer3b, 2);
AudioConnection patchCord106(glide4, 0, oscModMixer4a, 2);
AudioConnection patchCord107(glide4, 0, oscModMixer4b, 2);
AudioConnection patchCord108(glide5, 0, oscModMixer5a, 2);
AudioConnection patchCord109(glide5, 0, oscModMixer5b, 2);
AudioConnection patchCord110(glide6, 0, oscModMixer6a, 2);
AudioConnection patchCord111(glide6, 0, oscModMixer6b, 2);
AudioConnection patchCord112(glide7, 0, oscModMixer7a, 2);
AudioConnection patchCord113(glide7, 0, oscModMixer7b, 2);
AudioConnection patchCord114(glide8, 0, oscModMixer8a, 2);
AudioConnection patchCord115(glide8, 0, oscModMixer8b, 2);
// AudioSynthWaveformModulatedTS ----------------------------------------
AudioConnection patchCord201(waveformMod1a, 0, waveformMixer1, 0);
AudioConnection patchCord202(waveformMod2a, 0, waveformMixer2, 0);
AudioConnection patchCord203(waveformMod3a, 0, waveformMixer3, 0);
AudioConnection patchCord204(waveformMod4a, 0, waveformMixer4, 0);
AudioConnection patchCord205(waveformMod5a, 0, waveformMixer5, 0);
AudioConnection patchCord206(waveformMod6a, 0, waveformMixer6, 0);
AudioConnection patchCord207(waveformMod7a, 0, waveformMixer7, 0);
AudioConnection patchCord208(waveformMod8a, 0, waveformMixer8, 0);
AudioConnection patchCord209(waveformMod1b, 0, waveformMixer1, 1);
AudioConnection patchCord210(waveformMod2b, 0, waveformMixer2, 1);
AudioConnection patchCord211(waveformMod3b, 0, waveformMixer3, 1);
AudioConnection patchCord212(waveformMod4b, 0, waveformMixer4, 1);
AudioConnection patchCord213(waveformMod5b, 0, waveformMixer5, 1);
AudioConnection patchCord214(waveformMod6b, 0, waveformMixer6, 1);
AudioConnection patchCord215(waveformMod7b, 0, waveformMixer7, 1);
AudioConnection patchCord216(waveformMod8b, 0, waveformMixer8, 1);
AudioConnection patchCord251(waveformMod1a, 0, oscModMixer1b, 3);
AudioConnection patchCord252(waveformMod2a, 0, oscModMixer2b, 3);
AudioConnection patchCord253(waveformMod3a, 0, oscModMixer3b, 3);
AudioConnection patchCord254(waveformMod4a, 0, oscModMixer4b, 3);
AudioConnection patchCord255(waveformMod5a, 0, oscModMixer5b, 3);
AudioConnection patchCord256(waveformMod6a, 0, oscModMixer6b, 3);
AudioConnection patchCord257(waveformMod7a, 0, oscModMixer7b, 3);
AudioConnection patchCord258(waveformMod8a, 0, oscModMixer8b, 3);
AudioConnection patchCord259(waveformMod1b, 0, oscModMixer1a, 3);
AudioConnection patchCord260(waveformMod2b, 0, oscModMixer2a, 3);
AudioConnection patchCord261(waveformMod3b, 0, oscModMixer3a, 3);
AudioConnection patchCord262(waveformMod4b, 0, oscModMixer4a, 3);
AudioConnection patchCord263(waveformMod5b, 0, oscModMixer5a, 3);
AudioConnection patchCord264(waveformMod6b, 0, oscModMixer6a, 3);
AudioConnection patchCord265(waveformMod7b, 0, oscModMixer7a, 3);
AudioConnection patchCord266(waveformMod8b, 0, oscModMixer8a, 3);
AudioConnection patchCord301(waveformMod1a, 0, oscFX1, 0);
AudioConnection patchCord302(waveformMod2a, 0, oscFX2, 0);
AudioConnection patchCord303(waveformMod3a, 0, oscFX3, 0);
AudioConnection patchCord304(waveformMod4a, 0, oscFX4, 0);
AudioConnection patchCord305(waveformMod5a, 0, oscFX5, 0);
AudioConnection patchCord306(waveformMod6a, 0, oscFX6, 0);
AudioConnection patchCord307(waveformMod7a, 0, oscFX7, 0);
AudioConnection patchCord308(waveformMod8a, 0, oscFX8, 0);
AudioConnection patchCord309(waveformMod1b, 0, oscFX1, 1);
AudioConnection patchCord310(waveformMod2b, 0, oscFX2, 1);
AudioConnection patchCord311(waveformMod3b, 0, oscFX3, 1);
AudioConnection patchCord312(waveformMod4b, 0, oscFX4, 1);
AudioConnection patchCord313(waveformMod5b, 0, oscFX5, 1);
AudioConnection patchCord314(waveformMod6b, 0, oscFX6, 1);
AudioConnection patchCord315(waveformMod7b, 0, oscFX7, 1);
AudioConnection patchCord316(waveformMod8b, 0, oscFX8, 1);
// AudioSynthWaveformTS -------------------------------------------------
AudioConnection patchCord351(pwmLfoA, 0, pwMixer1a, 0);
AudioConnection patchCord352(pwmLfoB, 0, pwMixer2a, 0);
AudioConnection patchCord353(pwmLfoA, 0, pwMixer3a, 0);
AudioConnection patchCord354(pwmLfoB, 0, pwMixer4a, 0);
AudioConnection patchCord355(pwmLfoA, 0, pwMixer5a, 0);
AudioConnection patchCord356(pwmLfoB, 0, pwMixer6a, 0);
AudioConnection patchCord357(pwmLfoA, 0, pwMixer7a, 0);
AudioConnection patchCord358(pwmLfoB, 0, pwMixer8a, 0);
AudioConnection patchCord359(pwmLfoA, 0, pwMixer1b, 0);
AudioConnection patchCord360(pwmLfoB, 0, pwMixer2b, 0);
AudioConnection patchCord361(pwmLfoA, 0, pwMixer3b, 0);
AudioConnection patchCord362(pwmLfoB, 0, pwMixer4b, 0);
AudioConnection patchCord363(pwmLfoA, 0, pwMixer5b, 0);
AudioConnection patchCord364(pwmLfoB, 0, pwMixer6b, 0);
AudioConnection patchCord365(pwmLfoA, 0, pwMixer7b, 0);
AudioConnection patchCord366(pwmLfoB, 0, pwMixer8b, 0);
AudioConnection patchCord401(filterLfo, 0, filterModMixer1, 1);
AudioConnection patchCord402(filterLfo, 0, filterModMixer2, 1);
AudioConnection patchCord403(filterLfo, 0, filterModMixer3, 1);
AudioConnection patchCord404(filterLfo, 0, filterModMixer4, 1);
AudioConnection patchCord405(filterLfo, 0, filterModMixer5, 1);
AudioConnection patchCord406(filterLfo, 0, filterModMixer6, 1);
AudioConnection patchCord407(filterLfo, 0, filterModMixer7, 1);
AudioConnection patchCord408(filterLfo, 0, filterModMixer8, 1);
AudioConnection patchCord420(pitchLfo, 0, oscGlobalModMixer, 1);
AudioConnection patchCord421(pink, 0, noiseMixer, 0);
AudioConnection patchCord422(white, 0, noiseMixer, 1);
// AudioEffectEnvelope --------------------------------------------------
AudioConnection patchCord501(filterEnvelope1, 0, oscModMixer1a, 1);
AudioConnection patchCord502(filterEnvelope1, 0, oscModMixer1b, 1);
AudioConnection patchCord503(filterEnvelope2, 0, oscModMixer2a, 1);
AudioConnection patchCord504(filterEnvelope2, 0, oscModMixer2b, 1);
AudioConnection patchCord505(filterEnvelope3, 0, oscModMixer3a, 1);
AudioConnection patchCord506(filterEnvelope3, 0, oscModMixer3b, 1);
AudioConnection patchCord507(filterEnvelope4, 0, oscModMixer4a, 1);
AudioConnection patchCord508(filterEnvelope4, 0, oscModMixer4b, 1);
AudioConnection patchCord509(filterEnvelope5, 0, oscModMixer5a, 1);
AudioConnection patchCord510(filterEnvelope5, 0, oscModMixer5b, 1);
AudioConnection patchCord511(filterEnvelope6, 0, oscModMixer6a, 1);
AudioConnection patchCord512(filterEnvelope6, 0, oscModMixer6b, 1);
AudioConnection patchCord513(filterEnvelope7, 0, oscModMixer7a, 1);
AudioConnection patchCord514(filterEnvelope7, 0, oscModMixer7b, 1);
AudioConnection patchCord515(filterEnvelope8, 0, oscModMixer8a, 1);
AudioConnection patchCord516(filterEnvelope8, 0, oscModMixer8b, 1);
AudioConnection patchCord551(filterEnvelope1, 0, pwMixer1a, 2);
AudioConnection patchCord552(filterEnvelope1, 0, pwMixer1b, 2);
AudioConnection patchCord553(filterEnvelope2, 0, pwMixer2a, 2);
AudioConnection patchCord554(filterEnvelope2, 0, pwMixer2b, 2);
AudioConnection patchCord555(filterEnvelope3, 0, pwMixer3a, 2);
AudioConnection patchCord556(filterEnvelope3, 0, pwMixer3b, 2);
AudioConnection patchCord557(filterEnvelope4, 0, pwMixer4a, 2);
AudioConnection patchCord558(filterEnvelope4, 0, pwMixer4b, 2);
AudioConnection patchCord559(filterEnvelope5, 0, pwMixer5a, 2);
AudioConnection patchCord560(filterEnvelope5, 0, pwMixer5b, 2);
AudioConnection patchCord561(filterEnvelope6, 0, pwMixer6a, 2);
AudioConnection patchCord562(filterEnvelope6, 0, pwMixer6b, 2);
AudioConnection patchCord563(filterEnvelope7, 0, pwMixer7a, 2);
AudioConnection patchCord564(filterEnvelope7, 0, pwMixer7b, 2);
AudioConnection patchCord565(filterEnvelope8, 0, pwMixer8a, 2);
AudioConnection patchCord566(filterEnvelope8, 0, pwMixer8b, 2);
AudioConnection patchCord581(filterEnvelope1, 0, filterModMixer1, 0);
AudioConnection patchCord582(filterEnvelope2, 0, filterModMixer2, 0);
AudioConnection patchCord583(filterEnvelope3, 0, filterModMixer3, 0);
AudioConnection patchCord584(filterEnvelope4, 0, filterModMixer4, 0);
AudioConnection patchCord585(filterEnvelope5, 0, filterModMixer5, 0);
AudioConnection patchCord586(filterEnvelope6, 0, filterModMixer6, 0);
AudioConnection patchCord587(filterEnvelope7, 0, filterModMixer7, 0);
AudioConnection patchCord588(filterEnvelope8, 0, filterModMixer8, 0);
// AudioEffectWaveshaper ------------------------------------------------
AudioConnection patchCord601(ampEnvelope1, waveshaper1);
AudioConnection patchCord602(ampEnvelope2, waveshaper2);
AudioConnection patchCord603(ampEnvelope3, waveshaper3);
AudioConnection patchCord604(ampEnvelope4, waveshaper4);
AudioConnection patchCord605(ampEnvelope5, waveshaper5);
AudioConnection patchCord606(ampEnvelope6, waveshaper6);
AudioConnection patchCord607(ampEnvelope7, waveshaper7);
AudioConnection patchCord608(ampEnvelope8, waveshaper8);
AudioConnection patchCord631(waveshaper1, 0, voiceMixer1, 0);
AudioConnection patchCord632(waveshaper2, 0, voiceMixer1, 1);
AudioConnection patchCord633(waveshaper3, 0, voiceMixer1, 2);
AudioConnection patchCord634(waveshaper4, 0, voiceMixer1, 3);
AudioConnection patchCord635(waveshaper5, 0, voiceMixer2, 0);
AudioConnection patchCord636(waveshaper6, 0, voiceMixer2, 1);
AudioConnection patchCord637(waveshaper7, 0, voiceMixer2, 2);
AudioConnection patchCord638(waveshaper8, 0, voiceMixer2, 3);
// AudioEffectDigitalCombine --------------------------------------------
AudioConnection patchCord651(oscFX1, 0, waveformMixer1, 3);
AudioConnection patchCord652(oscFX2, 0, waveformMixer2, 3);
AudioConnection patchCord653(oscFX4, 0, waveformMixer4, 3);
AudioConnection patchCord654(oscFX3, 0, waveformMixer3, 3);
AudioConnection patchCord655(oscFX5, 0, waveformMixer5, 3);
AudioConnection patchCord656(oscFX6, 0, waveformMixer6, 3);
AudioConnection patchCord657(oscFX7, 0, waveformMixer7, 3);
AudioConnection patchCord658(oscFX8, 0, waveformMixer8, 3);
// AudioFilterStateVariable ---------------------------------------------
AudioConnection patchCord701(filter1, 0, filterMixer1, 0);
AudioConnection patchCord702(filter1, 1, filterMixer1, 1);
AudioConnection patchCord703(filter1, 2, filterMixer1, 2);
AudioConnection patchCord704(filter2, 0, filterMixer2, 0);
AudioConnection patchCord705(filter2, 1, filterMixer2, 1);
AudioConnection patchCord706(filter2, 2, filterMixer2, 2);
AudioConnection patchCord707(filter3, 0, filterMixer3, 0);
AudioConnection patchCord708(filter3, 1, filterMixer3, 1);
AudioConnection patchCord709(filter3, 2, filterMixer3, 2);
AudioConnection patchCord710(filter4, 0, filterMixer4, 0);
AudioConnection patchCord711(filter4, 1, filterMixer4, 1);
AudioConnection patchCord712(filter4, 2, filterMixer4, 2);
AudioConnection patchCord713(filter5, 0, filterMixer5, 0);
AudioConnection patchCord714(filter5, 1, filterMixer5, 1);
AudioConnection patchCord715(filter5, 2, filterMixer5, 2);
AudioConnection patchCord716(filter6, 0, filterMixer6, 0);
AudioConnection patchCord717(filter6, 1, filterMixer6, 1);
AudioConnection patchCord718(filter6, 2, filterMixer6, 2);
AudioConnection patchCord719(filter7, 0, filterMixer7, 0);
AudioConnection patchCord720(filter7, 1, filterMixer7, 1);
AudioConnection patchCord721(filter7, 2, filterMixer7, 2);
AudioConnection patchCord722(filter8, 0, filterMixer8, 0);
AudioConnection patchCord723(filter8, 1, filterMixer8, 1);
AudioConnection patchCord724(filter8, 2, filterMixer8, 2);
AudioConnection patchCord730(dcOffsetFilter, 2, volumeMixer, 0);
AudioConnection patchCord731(dcOffsetFilter, 2, scope, 0);
AudioConnection patchCord732(dcOffsetFilter, 2, peak, 0);
// Mixer ----------------------------------------------------------------
AudioConnection patchCord751(noiseMixer, 0, waveformMixer1, 2);
AudioConnection patchCord752(noiseMixer, 0, waveformMixer2, 2);
AudioConnection patchCord753(noiseMixer, 0, waveformMixer3, 2);
AudioConnection patchCord754(noiseMixer, 0, waveformMixer4, 2);
AudioConnection patchCord755(noiseMixer, 0, waveformMixer5, 2);
AudioConnection patchCord756(noiseMixer, 0, waveformMixer6, 2);
AudioConnection patchCord757(noiseMixer, 0, waveformMixer7, 2);
AudioConnection patchCord758(noiseMixer, 0, waveformMixer8, 2);
AudioConnection patchCord771(pwMixer1a, 0, waveformMod1a, 1);
AudioConnection patchCord772(pwMixer1b, 0, waveformMod1b, 1);
AudioConnection patchCord773(pwMixer3b, 0, waveformMod3b, 1);
AudioConnection patchCord774(pwMixer4b, 0, waveformMod4b, 1);
AudioConnection patchCord775(pwMixer4a, 0, waveformMod4a, 1);
AudioConnection patchCord776(pwMixer2a, 0, waveformMod2a, 1);
AudioConnection patchCord777(pwMixer2b, 0, waveformMod2b, 1);
AudioConnection patchCord778(pwMixer3a, 0, waveformMod3a, 1);
AudioConnection patchCord779(pwMixer5a, 0, waveformMod5a, 1);
AudioConnection patchCord780(pwMixer5b, 0, waveformMod5b, 1);
AudioConnection patchCord781(pwMixer6a, 0, waveformMod6a, 1);
AudioConnection patchCord782(pwMixer6b, 0, waveformMod6b, 1);
AudioConnection patchCord783(pwMixer7a, 0, waveformMod7a, 1);
AudioConnection patchCord784(pwMixer7b, 0, waveformMod7b, 1);
AudioConnection patchCord785(pwMixer8a, 0, waveformMod8a, 1);
AudioConnection patchCord786(pwMixer8b, 0, waveformMod8b, 1);
AudioConnection patchCord801(oscGlobalModMixer, 0, oscModMixer1a, 0);
AudioConnection patchCord802(oscGlobalModMixer, 0, oscModMixer1b, 0);
AudioConnection patchCord803(oscGlobalModMixer, 0, oscModMixer2a, 0);
AudioConnection patchCord804(oscGlobalModMixer, 0, oscModMixer2b, 0);
AudioConnection patchCord805(oscGlobalModMixer, 0, oscModMixer3a, 0);
AudioConnection patchCord806(oscGlobalModMixer, 0, oscModMixer3b, 0);
AudioConnection patchCord807(oscGlobalModMixer, 0, oscModMixer4a, 0);
AudioConnection patchCord808(oscGlobalModMixer, 0, oscModMixer4b, 0);
AudioConnection patchCord809(oscGlobalModMixer, 0, oscModMixer5a, 0);
AudioConnection patchCord810(oscGlobalModMixer, 0, oscModMixer5b, 0);
AudioConnection patchCord811(oscGlobalModMixer, 0, oscModMixer6a, 0);
AudioConnection patchCord812(oscGlobalModMixer, 0, oscModMixer6b, 0);
AudioConnection patchCord813(oscGlobalModMixer, 0, oscModMixer7a, 0);
AudioConnection patchCord814(oscGlobalModMixer, 0, oscModMixer7b, 0);
AudioConnection patchCord815(oscGlobalModMixer, 0, oscModMixer8a, 0);
AudioConnection patchCord816(oscGlobalModMixer, 0, oscModMixer8b, 0);
AudioConnection patchCord831(filterModMixer1, 0, filter1, 1);
AudioConnection patchCord832(filterModMixer2, 0, filter2, 1);
AudioConnection patchCord833(filterModMixer3, 0, filter3, 1);
AudioConnection patchCord834(filterModMixer4, 0, filter4, 1);
AudioConnection patchCord835(filterModMixer5, 0, filter5, 1);
AudioConnection patchCord836(filterModMixer6, 0, filter6, 1);
AudioConnection patchCord837(filterModMixer7, 0, filter7, 1);
AudioConnection patchCord838(filterModMixer8, 0, filter8, 1);
AudioConnection patchCord851(filterMixer1, ampEnvelope1);
AudioConnection patchCord852(filterMixer2, ampEnvelope2);
AudioConnection patchCord853(filterMixer3, ampEnvelope3);
AudioConnection patchCord854(filterMixer4, ampEnvelope4);
AudioConnection patchCord855(filterMixer5, ampEnvelope5);
AudioConnection patchCord856(filterMixer6, ampEnvelope6);
AudioConnection patchCord857(filterMixer7, ampEnvelope7);
AudioConnection patchCord858(filterMixer8, ampEnvelope8);
AudioConnection patchCord871(oscModMixer1a, 0, waveformMod1a, 0);
AudioConnection patchCord872(oscModMixer1b, 0, waveformMod1b, 0);
AudioConnection patchCord873(oscModMixer2a, 0, waveformMod2a, 0);
AudioConnection patchCord874(oscModMixer2b, 0, waveformMod2b, 0);
AudioConnection patchCord875(oscModMixer3a, 0, waveformMod3a, 0);
AudioConnection patchCord876(oscModMixer3b, 0, waveformMod3b, 0);
AudioConnection patchCord877(oscModMixer4a, 0, waveformMod4a, 0);
AudioConnection patchCord878(oscModMixer4b, 0, waveformMod4b, 0);
AudioConnection patchCord879(oscModMixer5a, 0, waveformMod5a, 0);
AudioConnection patchCord880(oscModMixer5b, 0, waveformMod5b, 0);
AudioConnection patchCord881(oscModMixer6a, 0, waveformMod6a, 0);
AudioConnection patchCord882(oscModMixer6b, 0, waveformMod6b, 0);
AudioConnection patchCord883(oscModMixer7a, 0, waveformMod7a, 0);
AudioConnection patchCord884(oscModMixer7b, 0, waveformMod7b, 0);
AudioConnection patchCord885(oscModMixer8a, 0, waveformMod8a, 0);
AudioConnection patchCord886(oscModMixer8b, 0, waveformMod8b, 0);
AudioConnection patchCord901(voiceMixer1, 0, voiceMixerM, 0);
AudioConnection patchCord902(voiceMixer2, 0, voiceMixerM, 1);
AudioConnection patchCord903(voiceMixer3, 0, voiceMixerM, 2);
AudioConnection patchCord921(voiceMixerM, 0, dcOffsetFilter, 0);
AudioConnection patchCord922(dcOffsetFilter, 2, volumeMixer, 0);
AudioConnection patchCord923(dcOffsetFilter, 2, scope, 0);
AudioConnection patchCord924(dcOffsetFilter, 2, peak, 0);
AudioConnection patchCord941(waveformMixer1, 0, filter1, 0);
AudioConnection patchCord942(waveformMixer2, 0, filter2, 0);
AudioConnection patchCord943(waveformMixer3, 0, filter3, 0);
AudioConnection patchCord944(waveformMixer4, 0, filter4, 0);
AudioConnection patchCord945(waveformMixer5, 0, filter5, 0);
AudioConnection patchCord946(waveformMixer6, 0, filter6, 0);
AudioConnection patchCord947(waveformMixer7, 0, filter7, 0);
AudioConnection patchCord948(waveformMixer8, 0, filter8, 0);
AudioConnection patchCord950(voiceMixer1, 0, voiceMixerM, 0);
AudioConnection patchCord951(voiceMixer2, 0, voiceMixerM, 1);
AudioConnection patchCord952(voiceMixer3, 0, voiceMixerM, 2);
AudioConnection patchCord960(voiceMixerM, 0, dcOffsetFilter, 0);
AudioConnection patchCord998(volumeMixer, 0, PCM5102A, 0);
AudioConnection patchCord999(volumeMixer, 0, PCM5102A, 1);
Oscilloscope scope;
AudioConnection patchCord1(constant1Dc, filterEnvelope2);
AudioConnection patchCord2(constant1Dc, filterEnvelope3);
AudioConnection patchCord3(constant1Dc, filterEnvelope4);
AudioConnection patchCord4(constant1Dc, filterEnvelope1);
AudioConnection patchCord5(pwmLfoA, 0, pwMixer1a, 0);
AudioConnection patchCord6(pwmLfoB, 0, pwMixer1b, 0);
AudioConnection patchCord7(pwmLfoA, 0, pwMixer2a, 0);
AudioConnection patchCord8(pwmLfoB, 0, pwMixer2b, 0);
AudioConnection patchCord9(pwmLfoA, 0, pwMixer3a, 0);
AudioConnection patchCord10(pwmLfoB, 0, pwMixer3b, 0);
AudioConnection patchCord11(pwmLfoA, 0, pwMixer4a, 0);
AudioConnection patchCord12(pwmLfoB, 0, pwMixer4b, 0);
AudioConnection patchCord13(pwa, 0, pwMixer1a, 1);
AudioConnection patchCord14(pwa, 0, pwMixer2a, 1);
AudioConnection patchCord15(pwa, 0, pwMixer3a, 1);
AudioConnection patchCord16(pwa, 0, pwMixer4a, 1);
AudioConnection patchCord17(pwb, 0, pwMixer1b, 1);
AudioConnection patchCord18(pwb, 0, pwMixer2b, 1);
AudioConnection patchCord19(pwb, 0, pwMixer3b, 1);
AudioConnection patchCord20(pwb, 0, pwMixer4b, 1);
AudioConnection patchCord21(pitchLfo, 0, oscGlobalModMixer, 1);
AudioConnection patchCord22(glide1, 0, oscModMixer1a, 2);
AudioConnection patchCord23(pitchBend, 0, oscGlobalModMixer, 0);
AudioConnection patchCord24(filterLfo, 0, filterModMixer1, 1);
AudioConnection patchCord25(filterLfo, 0, filterModMixer2, 1);
AudioConnection patchCord26(filterLfo, 0, filterModMixer3, 1);
AudioConnection patchCord27(filterLfo, 0, filterModMixer4, 1);
AudioConnection patchCord28(keytracking1, 0, filterModMixer1, 2);
AudioConnection patchCord29(keytracking2, 0, filterModMixer2, 2);
AudioConnection patchCord30(keytracking3, 0, filterModMixer3, 2);
AudioConnection patchCord31(keytracking4, 0, filterModMixer4, 2);
AudioConnection patchCord32(noiseMixer, 0, waveformMixer1, 2);
AudioConnection patchCord33(noiseMixer, 0, waveformMixer2, 2);
AudioConnection patchCord34(noiseMixer, 0, waveformMixer3, 2);
AudioConnection patchCord35(noiseMixer, 0, waveformMixer4, 2);
AudioConnection patchCord36(pwMixer1a, 0, waveformMod1a, 1);
AudioConnection patchCord37(pwMixer1b, 0, waveformMod1b, 1);
AudioConnection patchCord38(pwMixer3b, 0, waveformMod3b, 1);
AudioConnection patchCord39(oscGlobalModMixer, 0, oscModMixer1a, 0);
AudioConnection patchCord40(oscGlobalModMixer, 0, oscModMixer1b, 0);
AudioConnection patchCord41(oscGlobalModMixer, 0, oscModMixer2a, 0);
AudioConnection patchCord42(oscGlobalModMixer, 0, oscModMixer2b, 0);
AudioConnection patchCord43(oscGlobalModMixer, 0, oscModMixer3a, 0);
AudioConnection patchCord44(oscGlobalModMixer, 0, oscModMixer3b, 0);
AudioConnection patchCord45(oscGlobalModMixer, 0, oscModMixer4a, 0);
AudioConnection patchCord46(oscGlobalModMixer, 0, oscModMixer4b, 0);
AudioConnection patchCord47(pwMixer4b, 0, waveformMod4b, 1);
AudioConnection patchCord48(pwMixer4a, 0, waveformMod4a, 1);
AudioConnection patchCord49(pwMixer2a, 0, waveformMod2a, 1);
AudioConnection patchCord50(pwMixer2b, 0, waveformMod2b, 1);
AudioConnection patchCord51(pwMixer3a, 0, waveformMod3a, 1);
AudioConnection patchCord52(waveformMod1b, 0, waveformMixer1, 1);
AudioConnection patchCord53(waveformMod1b, 0, oscFX1, 1);
AudioConnection patchCord54(waveformMod1a, 0, waveformMixer1, 0);
AudioConnection patchCord55(waveformMod1a, 0, oscFX1, 0);
AudioConnection patchCord56(waveformMod2b, 0, waveformMixer2, 1);
AudioConnection patchCord57(waveformMod2b, 0, oscFX2, 1);
AudioConnection patchCord58(waveformMod4a, 0, waveformMixer4, 0);
AudioConnection patchCord59(waveformMod4a, 0, oscFX4, 0);
AudioConnection patchCord60(waveformMod2a, 0, waveformMixer2, 0);
AudioConnection patchCord61(waveformMod2a, 0, oscFX2, 0);
AudioConnection patchCord62(waveformMod4b, 0, waveformMixer4, 1);
AudioConnection patchCord63(waveformMod4b, 0, oscFX4, 1);
AudioConnection patchCord64(waveformMod3a, 0, oscFX3, 0);
AudioConnection patchCord65(waveformMod3a, 0, waveformMixer3, 0);
AudioConnection patchCord66(waveformMod3b, 0, oscFX3, 1);
AudioConnection patchCord67(waveformMod3b, 0, waveformMixer3, 1);
AudioConnection patchCord68(filterEnvelope4, 0, filterModMixer4, 0);
AudioConnection patchCord69(filterEnvelope4, 0, pwMixer4a, 2);
AudioConnection patchCord70(filterEnvelope4, 0, pwMixer4b, 2);
AudioConnection patchCord71(filterEnvelope1, 0, filterModMixer1, 0);
AudioConnection patchCord72(filterEnvelope1, 0, pwMixer1a, 2);
AudioConnection patchCord73(filterEnvelope1, 0, pwMixer1b, 2);
AudioConnection patchCord74(filterEnvelope3, 0, filterModMixer3, 0);
AudioConnection patchCord75(filterEnvelope3, 0, pwMixer3a, 2);
AudioConnection patchCord76(filterEnvelope3, 0, pwMixer3b, 2);
AudioConnection patchCord77(filterEnvelope2, 0, filterModMixer2, 0);
AudioConnection patchCord78(filterEnvelope2, 0, pwMixer2a, 2);
AudioConnection patchCord79(filterEnvelope2, 0, pwMixer2b, 2);
AudioConnection patchCord80(oscFX1, 0, waveformMixer1, 3);
AudioConnection patchCord81(oscFX2, 0, waveformMixer2, 3);
AudioConnection patchCord82(oscFX4, 0, waveformMixer4, 3);
AudioConnection patchCord83(oscFX3, 0, waveformMixer3, 3);
AudioConnection patchCord86(filterModMixer1, 0, filter1, 1);
AudioConnection patchCord88(filterModMixer2, 0, filter2, 1);
AudioConnection patchCord89(filterModMixer3, 0, filter3, 1);
AudioConnection patchCord91(filterModMixer4, 0, filter4, 1);
AudioConnection patchCord95(filter1, 0, filterMixer1, 0);
AudioConnection patchCord96(filter1, 1, filterMixer1, 1);
AudioConnection patchCord97(filter1, 2, filterMixer1, 2);
AudioConnection patchCord92(filter2, 0, filterMixer2, 0);
AudioConnection patchCord93(filter2, 1, filterMixer2, 1);
AudioConnection patchCord94(filter2, 2, filterMixer2, 2);
AudioConnection patchCord98(filter3, 0, filterMixer3, 0);
AudioConnection patchCord99(filter3, 1, filterMixer3, 1);
AudioConnection patchCord100(filter3, 2, filterMixer3, 2);
AudioConnection patchCord101(filter4, 0, filterMixer4, 0);
AudioConnection patchCord102(filter4, 1, filterMixer4, 1);
AudioConnection patchCord103(filter4, 2, filterMixer4, 2);
AudioConnection patchCord106(filterMixer1, ampEnvelope1);
AudioConnection patchCord104(filterMixer2, ampEnvelope2);
AudioConnection patchCord105(filterMixer3, ampEnvelope3);
AudioConnection patchCord107(filterMixer4, ampEnvelope4);
AudioConnection patchCord121(oscModMixer1a, 0, waveformMod1a, 0);
AudioConnection patchCord122(oscModMixer1b, 0, waveformMod1b, 0);
AudioConnection patchCord123(oscModMixer2a, 0, waveformMod2a, 0);
AudioConnection patchCord124(oscModMixer2b, 0, waveformMod2b, 0);
AudioConnection patchCord125(oscModMixer3a, 0, waveformMod3a, 0);
AudioConnection patchCord126(oscModMixer3b, 0, waveformMod3b, 0);
AudioConnection patchCord127(oscModMixer4a, 0, waveformMod4a, 0);
AudioConnection patchCord128(oscModMixer4b, 0, waveformMod4b, 0);
AudioConnection patchCord129(filterEnvelope1, 0, oscModMixer1a, 1);
AudioConnection patchCord130(filterEnvelope1, 0, oscModMixer1b, 1);
AudioConnection patchCord131(filterEnvelope2, 0, oscModMixer2a, 1);
AudioConnection patchCord132(filterEnvelope2, 0, oscModMixer2b, 1);
AudioConnection patchCord133(filterEnvelope3, 0, oscModMixer3a, 1);
AudioConnection patchCord134(filterEnvelope3, 0, oscModMixer3b, 1);
AudioConnection patchCord135(filterEnvelope4, 0, oscModMixer4a, 1);
AudioConnection patchCord136(filterEnvelope4, 0, oscModMixer4b, 1);
AudioConnection patchCord137(pink, 0, noiseMixer, 0);
AudioConnection patchCord138(white, 0, noiseMixer, 1);
AudioConnection patchCord139(pwmLfoA, 0, pwMixer5a, 0);
AudioConnection patchCord140(pwmLfoB, 0, pwMixer5b, 0);
AudioConnection patchCord141(pwmLfoA, 0, pwMixer6a, 0);
AudioConnection patchCord142(pwmLfoB, 0, pwMixer6b, 0);
AudioConnection patchCord143(pwa, 0, pwMixer5a, 1);
AudioConnection patchCord144(pwb, 0, pwMixer5b, 1);
AudioConnection patchCord145(pwa, 0, pwMixer6a, 1);
AudioConnection patchCord146(pwb, 0, pwMixer6b, 1);
AudioConnection patchCord147(filterLfo, 0, filterModMixer5, 1);
AudioConnection patchCord148(filterLfo, 0, filterModMixer6, 1);
AudioConnection patchCord149(keytracking5, 0, filterModMixer5, 2);
AudioConnection patchCord150(keytracking6, 0, filterModMixer6, 2);
AudioConnection patchCord151(noiseMixer, 0, waveformMixer5, 2);
AudioConnection patchCord152(noiseMixer, 0, waveformMixer6, 2);
AudioConnection patchCord153(oscGlobalModMixer, 0, oscModMixer5a, 0);
AudioConnection patchCord154(oscGlobalModMixer, 0, oscModMixer5b, 0);
AudioConnection patchCord155(oscGlobalModMixer, 0, oscModMixer6a, 0);
AudioConnection patchCord156(oscGlobalModMixer, 0, oscModMixer6b, 0);
AudioConnection patchCord157(oscModMixer5a, 0, waveformMod5a, 0);
AudioConnection patchCord158(oscModMixer5b, 0, waveformMod5b, 0);
AudioConnection patchCord159(oscModMixer6a, 0, waveformMod6a, 0);
AudioConnection patchCord160(oscModMixer6b, 0, waveformMod6b, 0);
AudioConnection patchCord161(filterEnvelope5, 0, oscModMixer5a, 1);
AudioConnection patchCord162(filterEnvelope5, 0, oscModMixer5b, 1);
AudioConnection patchCord163(filterEnvelope6, 0, oscModMixer6a, 1);
AudioConnection patchCord164(filterEnvelope6, 0, oscModMixer6b, 1);
AudioConnection patchCord165(pwMixer5a, 0, waveformMod5a, 1);
AudioConnection patchCord166(pwMixer5b, 0, waveformMod5b, 1);
AudioConnection patchCord167(pwMixer6a, 0, waveformMod6a, 1);
AudioConnection patchCord168(pwMixer6b, 0, waveformMod6b, 1);
AudioConnection patchCord169(waveformMod5a, 0, waveformMixer5, 0);
AudioConnection patchCord170(waveformMod5a, 0, oscFX5, 0);
AudioConnection patchCord171(waveformMod5b, 0, waveformMixer5, 1);
AudioConnection patchCord172(waveformMod5b, 0, oscFX5, 1);
AudioConnection patchCord173(waveformMod6a, 0, waveformMixer6, 0);
AudioConnection patchCord174(waveformMod6a, 0, oscFX6, 0);
AudioConnection patchCord175(waveformMod6b, 0, waveformMixer6, 1);
AudioConnection patchCord176(waveformMod6b, 0, oscFX6, 1);
AudioConnection patchCord177(filterEnvelope5, 0, filterModMixer5, 0);
AudioConnection patchCord178(filterEnvelope5, 0, pwMixer5a, 2);
AudioConnection patchCord179(filterEnvelope5, 0, pwMixer5b, 2);
AudioConnection patchCord180(filterEnvelope6, 0, filterModMixer6, 0);
AudioConnection patchCord181(filterEnvelope6, 0, pwMixer6a, 2);
AudioConnection patchCord182(filterEnvelope6, 0, pwMixer6b, 2);
AudioConnection patchCord183(oscFX5, 0, waveformMixer5, 3);
AudioConnection patchCord184(oscFX6, 0, waveformMixer6, 3);
AudioConnection patchCord186(filterModMixer5, 0, filter5, 1);
AudioConnection patchCord188(filterModMixer6, 0, filter6, 1);
AudioConnection patchCord189(filter5, 1, filterMixer5, 1);
AudioConnection patchCord190(filter5, 2, filterMixer5, 2);
AudioConnection patchCord191(filter6, 1, filterMixer6, 1);
AudioConnection patchCord192(filter6, 2, filterMixer6, 2);
AudioConnection patchCord193(filterMixer5, ampEnvelope5);
AudioConnection patchCord194(filterMixer6, ampEnvelope6);
AudioConnection patchCord197(voiceMixer1, 0, voiceMixerM, 0);
AudioConnection patchCord198(voiceMixer2, 0, voiceMixerM, 1);
AudioConnection patchCord199(constant1Dc, filterEnvelope5);
AudioConnection patchCord200(constant1Dc, filterEnvelope6);
AudioConnection patchCord201(filter5, 0, filterMixer5, 0);
AudioConnection patchCord202(filter6, 0, filterMixer6, 0);
AudioConnection patchCord203(voiceMixerM, 0, dcOffsetFilter, 0);
AudioConnection patchCord204(glide1, 0, oscModMixer1b, 2);
AudioConnection patchCord205(glide2, 0, oscModMixer2a, 2);
AudioConnection patchCord206(glide2, 0, oscModMixer2b, 2);
AudioConnection patchCord207(glide3, 0, oscModMixer3a, 2);
AudioConnection patchCord208(glide3, 0, oscModMixer3b, 2);
AudioConnection patchCord209(glide4, 0, oscModMixer4a, 2);
AudioConnection patchCord210(glide4, 0, oscModMixer4b, 2);
AudioConnection patchCord211(glide5, 0, oscModMixer5a, 2);
AudioConnection patchCord212(glide5, 0, oscModMixer5b, 2);
AudioConnection patchCord213(glide6, 0, oscModMixer6a, 2);
AudioConnection patchCord214(glide6, 0, oscModMixer6b, 2);
AudioConnection patchCord215(voiceMixer3, 0, voiceMixerM, 2);
AudioConnection patchCord222(filterMixer7, ampEnvelope7);
AudioConnection patchCord223(filterMixer8, ampEnvelope8);
AudioConnection patchCord228(constant1Dc, filterEnvelope7);
AudioConnection patchCord229(constant1Dc, filterEnvelope8);
AudioConnection patchCord234(pwmLfoA, 0, pwMixer7a, 0);
AudioConnection patchCord235(pwmLfoB, 0, pwMixer7b, 0);
AudioConnection patchCord236(pwmLfoA, 0, pwMixer8a, 0);
AudioConnection patchCord237(pwmLfoB, 0, pwMixer8b, 0);
AudioConnection patchCord246(pwa, 0, pwMixer7a, 1);
AudioConnection patchCord247(pwb, 0, pwMixer7b, 1);
AudioConnection patchCord248(pwa, 0, pwMixer8a, 1);
AudioConnection patchCord249(pwb, 0, pwMixer8b, 1);
AudioConnection patchCord258(filterLfo, 0, filterModMixer7, 1);
AudioConnection patchCord259(filterLfo, 0, filterModMixer8, 1);
AudioConnection patchCord264(keytracking7, 0, filterModMixer7, 2);
AudioConnection patchCord265(keytracking8, 0, filterModMixer8, 2);
AudioConnection patchCord270(noiseMixer, 0, waveformMixer7, 2);
AudioConnection patchCord271(noiseMixer, 0, waveformMixer8, 2);
AudioConnection patchCord276(pwMixer7a, 0, waveformMod7a, 1);
AudioConnection patchCord277(pwMixer7b, 0, waveformMod7b, 1);
AudioConnection patchCord278(pwMixer8a, 0, waveformMod8a, 1);
AudioConnection patchCord279(pwMixer8b, 0, waveformMod8b, 1);
AudioConnection patchCord288(oscGlobalModMixer, 0, oscModMixer7a, 0);
AudioConnection patchCord289(oscGlobalModMixer, 0, oscModMixer7b, 0);
AudioConnection patchCord290(oscGlobalModMixer, 0, oscModMixer8a, 0);
AudioConnection patchCord291(oscGlobalModMixer, 0, oscModMixer8b, 0);
AudioConnection patchCord300(waveformMod7b, 0, waveformMixer7, 1);
AudioConnection patchCord301(waveformMod7b, 0, oscFX7, 1);
AudioConnection patchCord302(waveformMod7a, 0, waveformMixer7, 0);
AudioConnection patchCord303(waveformMod7a, 0, oscFX7, 0);
AudioConnection patchCord304(waveformMod8b, 0, waveformMixer8, 1);
AudioConnection patchCord305(waveformMod8b, 0, oscFX8, 1);
AudioConnection patchCord308(waveformMod8a, 0, waveformMixer8, 0);
AudioConnection patchCord309(waveformMod8a, 0, oscFX8, 0);
AudioConnection patchCord327(filterEnvelope7, 0, filterModMixer7, 0);
AudioConnection patchCord328(filterEnvelope7, 0, pwMixer7a, 2);
AudioConnection patchCord329(filterEnvelope7, 0, pwMixer7b, 2);
AudioConnection patchCord333(filterEnvelope8, 0, filterModMixer8, 0);
AudioConnection patchCord334(filterEnvelope8, 0, pwMixer8a, 2);
AudioConnection patchCord335(filterEnvelope8, 0, pwMixer8b, 2);
AudioConnection patchCord342(oscFX7, 0, waveformMixer7, 3);
AudioConnection patchCord343(oscFX8, 0, waveformMixer8, 3);
AudioConnection patchCord350(filterModMixer7, 0, filter7, 1);
AudioConnection patchCord352(filterModMixer8, 0, filter8, 1);
AudioConnection patchCord361(filter8, 0, filterMixer8, 0);
AudioConnection patchCord362(filter8, 1, filterMixer8, 1);
AudioConnection patchCord363(filter8, 2, filterMixer8, 2);
AudioConnection patchCord364(filter7, 0, filterMixer7, 0);
AudioConnection patchCord365(filter7, 1, filterMixer7, 1);
AudioConnection patchCord366(filter7, 2, filterMixer7, 2);
AudioConnection patchCord379(oscModMixer7a, 0, waveformMod7a, 0);
AudioConnection patchCord380(oscModMixer7b, 0, waveformMod7b, 0);
AudioConnection patchCord381(oscModMixer8a, 0, waveformMod8a, 0);
AudioConnection patchCord382(oscModMixer8b, 0, waveformMod8b, 0);
AudioConnection patchCord391(filterEnvelope7, 0, oscModMixer7a, 1);
AudioConnection patchCord392(filterEnvelope7, 0, oscModMixer7b, 1);
AudioConnection patchCord393(filterEnvelope8, 0, oscModMixer8a, 1);
AudioConnection patchCord394(filterEnvelope8, 0, oscModMixer8b, 1);
AudioConnection patchCord403(glide7, 0, oscModMixer7a, 2);
AudioConnection patchCord404(glide7, 0, oscModMixer7b, 2);
AudioConnection patchCord405(glide8, 0, oscModMixer8a, 2);
AudioConnection patchCord406(glide8, 0, oscModMixer8b, 2);
AudioConnection patchCord415(dcOffsetFilter, 2, scope, 0);
AudioConnection patchCord416(dcOffsetFilter, 2, peak, 0);
AudioConnection patchCord417(waveformMod1b, 0, oscModMixer1a, 3);
AudioConnection patchCord418(waveformMod2b, 0, oscModMixer2a, 3);
AudioConnection patchCord419(waveformMod3b, 0, oscModMixer3a, 3);
AudioConnection patchCord420(waveformMod4b, 0, oscModMixer4a, 3);
AudioConnection patchCord421(waveformMod5b, 0, oscModMixer5a, 3);
AudioConnection patchCord422(waveformMod6b, 0, oscModMixer6a, 3);
AudioConnection patchCord423(waveformMod7b, 0, oscModMixer7a, 3);
AudioConnection patchCord424(waveformMod8b, 0, oscModMixer8a, 3);
AudioConnection patchCord429(waveformMod1a, 0, oscModMixer1b, 3);
AudioConnection patchCord430(waveformMod2a, 0, oscModMixer2b, 3);
AudioConnection patchCord431(waveformMod3a, 0, oscModMixer3b, 3);
AudioConnection patchCord432(waveformMod4a, 0, oscModMixer4b, 3);
AudioConnection patchCord433(waveformMod5a, 0, oscModMixer5b, 3);
AudioConnection patchCord434(waveformMod6a, 0, oscModMixer6b, 3);
AudioConnection patchCord435(waveformMod7a, 0, oscModMixer7b, 3);
AudioConnection patchCord436(waveformMod8a, 0, oscModMixer8b, 3);
AudioConnection patchCord441(dcOffsetFilter, 2, volumeMixer, 0);
AudioConnection patchCord551(FilterVelo1, 0, filterModMixer1, 3);
AudioConnection patchCord552(FilterVelo2, 0, filterModMixer2, 3);
AudioConnection patchCord553(FilterVelo3, 0, filterModMixer3, 3);
AudioConnection patchCord554(FilterVelo4, 0, filterModMixer4, 3);
AudioConnection patchCord555(FilterVelo5, 0, filterModMixer5, 3);
AudioConnection patchCord556(FilterVelo6, 0, filterModMixer6, 3);
AudioConnection patchCord557(FilterVelo7, 0, filterModMixer7, 3);
AudioConnection patchCord558(FilterVelo8, 0, filterModMixer8, 3);
AudioConnection patchCord809(waveformMixer1, 0, filter1, 0);
AudioConnection patchCord810(waveformMixer2, 0, filter2, 0);
AudioConnection patchCord811(waveformMixer3, 0, filter3, 0);
AudioConnection patchCord812(waveformMixer4, 0, filter4, 0);
AudioConnection patchCord813(waveformMixer5, 0, filter5, 0);
AudioConnection patchCord814(waveformMixer6, 0, filter6, 0);
AudioConnection patchCord815(waveformMixer7, 0, filter7, 0);
AudioConnection patchCord816(waveformMixer8, 0, filter8, 0);
AudioConnection patchCord901(ampEnvelope1, waveshaper1);
AudioConnection patchCord902(ampEnvelope2, waveshaper2);
AudioConnection patchCord903(ampEnvelope3, waveshaper3);
AudioConnection patchCord904(ampEnvelope4, waveshaper4);
AudioConnection patchCord905(ampEnvelope5, waveshaper5);
AudioConnection patchCord906(ampEnvelope6, waveshaper6);
AudioConnection patchCord907(ampEnvelope7, waveshaper7);
AudioConnection patchCord908(ampEnvelope8, waveshaper8);
AudioConnection patchCord909(waveshaper1, 0, voiceMixer1, 0);
AudioConnection patchCord910(waveshaper2, 0, voiceMixer1, 1);
AudioConnection patchCord911(waveshaper3, 0, voiceMixer1, 2);
AudioConnection patchCord912(waveshaper4, 0, voiceMixer1, 3);
AudioConnection patchCord913(waveshaper5, 0, voiceMixer2, 0);
AudioConnection patchCord914(waveshaper6, 0, voiceMixer2, 1);
AudioConnection patchCord915(waveshaper7, 0, voiceMixer2, 2);
AudioConnection patchCord916(waveshaper8, 0, voiceMixer2, 3);
AudioConnection patchCord953(voiceMixerM, 0, dcOffsetFilter, 0);
AudioConnection patchCord954(dcOffsetFilter, 2, volumeMixer, 0);
AudioConnection patchCord955(dcOffsetFilter, 2, scope, 0);
AudioConnection patchCord956(dcOffsetFilter, 2, peak, 0);
Oscilloscope scope;
AudioAmplifier WaveshaperAmp1; //xy=1145,825
AudioAmplifier WaveshaperAmp2; //xy=1145,826
AudioAmplifier WaveshaperAmp3; //xy=1145,827
AudioAmplifier WaveshaperAmp4; //xy=1145,828
AudioAmplifier WaveshaperAmp5; //xy=1145,829
AudioAmplifier WaveshaperAmp6; //xy=1145,830
AudioAmplifier WaveshaperAmp7; //xy=1145,831
AudioAmplifier WaveshaperAmp8; //xy=1145,832
Oscilloscope scope;
AudioConnection patchCord631(ampEnvelope1, 0, voiceMixer1, 0);
AudioConnection patchCord632(ampEnvelope2, 0, voiceMixer1, 1);
AudioConnection patchCord633(ampEnvelope3, 0, voiceMixer1, 2);
AudioConnection patchCord634(ampEnvelope4, 0, voiceMixer1, 3);
AudioConnection patchCord635(ampEnvelope5, 0, voiceMixer2, 0);
AudioConnection patchCord636(ampEnvelope6, 0, voiceMixer2, 1);
AudioConnection patchCord637(ampEnvelope7, 0, voiceMixer2, 2);
AudioConnection patchCord638(ampEnvelope8, 0, voiceMixer2, 3);
// waveshaper
AudioConnection patchCord841(filterMixer1, WaveshaperAmp1);
AudioConnection patchCord842(filterMixer2, WaveshaperAmp2);
AudioConnection patchCord843(filterMixer3, WaveshaperAmp3);
AudioConnection patchCord844(filterMixer4, WaveshaperAmp4);
AudioConnection patchCord845(filterMixer5, WaveshaperAmp5);
AudioConnection patchCord846(filterMixer6, WaveshaperAmp6);
AudioConnection patchCord847(filterMixer7, WaveshaperAmp7);
AudioConnection patchCord848(filterMixer8, WaveshaperAmp8);
AudioConnection patchCord849(WaveshaperAmp1, waveshaper1);
AudioConnection patchCord850(WaveshaperAmp2, waveshaper2);
AudioConnection patchCord851(WaveshaperAmp3, waveshaper3);
AudioConnection patchCord852(WaveshaperAmp4, waveshaper4);
AudioConnection patchCord853(WaveshaperAmp5, waveshaper5);
AudioConnection patchCord854(WaveshaperAmp6, waveshaper6);
AudioConnection patchCord855(WaveshaperAmp7, waveshaper7);
AudioConnection patchCord856(WaveshaperAmp8, waveshaper8);
AudioConnection patchCord857(waveshaper1, ampEnvelope1);
AudioConnection patchCord858(waveshaper2, ampEnvelope2);
AudioConnection patchCord859(waveshaper3, ampEnvelope3);
AudioConnection patchCord860(waveshaper4, ampEnvelope4);
AudioConnection patchCord861(waveshaper5, ampEnvelope5);
AudioConnection patchCord862(waveshaper6, ampEnvelope6);
AudioConnection patchCord863(waveshaper7, ampEnvelope7);
AudioConnection patchCord864(waveshaper8, ampEnvelope8);
