Page 1 of 9 1 2 3 ... LastLast
Results 1 to 25 of 201
Thread: New Teensy 4.1 DIY Synthesizer
    Senior Member Rolfdegen's Avatar
    Sep 2020
    241
    Hi there...
    I am currently developing a new DIY synthesizer based on a
    Teensy 4.0 Boards. The synthesizer will look similar to the small
    Shruthi Synthesizer from Mutable Instruments. Compared to the Shruthi
    this synth will be polyphonic, have a color TFT display
    and other things like a 2Channel 16Bit DA-Converter, digital and
    analog filters. The housing and board format is similar to the
    Shruthi (see picture). That's why for the DIY Project I also created the
    Name "Shruthi 2" selected.
    I replaced the 2.2 inch TFT display with a smaller 1.8 inch
    Display replaced. I think this fits better to the small
    Shruthi format. The 2.2 inch display is a bit overloaded
    looked like. Waveform displays and menu texts also fit like this
    a small color display with a resolution of 128 x 160 pixels
    I put the Teensy 4.0 board on the backside. What is still missing
    is the 16Bit 2Ch. DA-converter PT8211. This is ordered. With the 4
    Potis you control the parameter setting. The encoder is equipped with a
    key function and controls the menu functions. There are 4
    analog inputs for modulation. Midi sockets and 6 keys and 8 LEDs.
    There will be the possibility to use the "Shruthi 2" with or without filter board
    to operate. You then have the possibility to use the digital filters in the
    Teensy to use.
    Display test on Teensy: https://youtu.be/14eL3NDJccw
    Greeting Rolf
    Sep 2020
    241
    Hallo
    I have a problem with the playback of PWM sound and TFT display. I have no PWM sound on pin 10 + 12 when using the display driver.
    The PWM sound works without display driver.
    // Shruthi 2  with Teensy 4.0   (c) 21.09.2020
    #define TFT_SCLK 13  // SCLK
    #define TFT_MOSI 11  // MOSI
    #define TFT_CS    6  // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
    #define TFT_DC    9  //  but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
    #define TFT_RST   8  // RST can use any pin
    #define SD_CS     4  // CS for SD card, can use any pin
    #include <Adafruit_GFX.h>
    #include <ST7735_t3.h>
    #include <SerialFlash.h>
    #define RGB(r,g,b) (b<<11|g<<6|r)
    AudioSynthWaveform       waveform1;      //xy=263,306
    AudioFilterStateVariable filter1;        //xy=459,371
    AudioMixer4              mixer1;         //xy=627,378
    AudioOutputMQS           mqs1;           //xy=850,426
    AudioConnection          patchCord1(waveform1, 0, filter1, 0);
    AudioConnection          patchCord2(filter1, 0, mixer1, 0);
    AudioConnection          patchCord3(filter1, 1, mixer1, 1);
    AudioConnection          patchCord4(filter1, 2, mixer1, 2);
    AudioConnection          patchCord5(mixer1, 0, mqs1, 0);
    ST7735_t3 disp = ST7735_t3(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
      // init 1.8" TFT
      disp.initR(INITR_BLACKTAB);
      disp.fillScreen(ST7735_BLACK);
      disp.setTextColor(ST7735_YELLOW, ST7735_BLACK);
      disp.setRotation(3);
      disp.setTextWrap(false);
      disp.setTextSize(2);
      disp.setCursor(20,40);
      disp.print("SHRUTHI II");
      disp.setTextSize(0);
      disp.setCursor(32,70);
      disp.print("www.tubeohm.com");
      // init PWM audio
      AudioMemory(20);
      analogReadResolution(8);
      analogReadAveraging(16);
      waveform1.begin(WAVEFORM_SAWTOOTH);
      waveform1.amplitude(0.85);
      waveform1.frequency(100);
      filter1.frequency(1000);
      filter1.octaveControl(1.0);   // freqency. Range is 0 to 7
      filter1.resonance(0);       //Q ranges from 0.7 to 5.0.
      mixer1.gain(0, 1);
      mixer1.gain(1, 0);
      mixer1.gain(2, 0);
      mixer1.gain(3, 0);
    Sep 2020
    241
    I think I found a solution. I swapped the Display connections MOSI and SCK to MOSI1 and SCK1 on teensy board.
    Sep 2020
    241
    OK.This is Pin function now:
    #define TFT_SCLK 27 // SCK1
    #define TFT_MOSI 26 // MOSI1
    Sep 2020
    241
    First sound on my Teensy Synth "Shruthi 2"
    Video: https://youtu.be/ffCMaR70G6g
    Aug 2015
    Scotland
    214
    Sounds and looks great, are you using some of the Shruthi codebase or are you using the audio lib? Cheers, Paul
    Jul 2020
    174
    Did you have this board made, or did you fabricate it at home?
    Sep 2020
    241
    I use the Audio Lib and later part of the Shruthi syntheses.
    It's a Phoenix / Shruthi board without filters from tubeohm.com
    Sep 2020
    241
    Its AudioBlock from Shruthi 2
    Sep 2020
    241
    From today we will dance in several voices: cheer:
    Teensy Synth
    Synth block
    The "Shruthi 2" now has 6 voices and plays polyphonically. I think you can expand that to 8 voices, since the processor load including the filter calculation is below 6%.
    There is currently only one oscillator per voice. But later there will be 2 per vote. The oscillator functions are not yet integrated. This is my next step now.
    The sound is still being worked on. There is still a lot to program. Let's do it ;-)
    Video
    https://youtu.be/Oj_5WZgwOww
    My code (in worke)
    // DIY Synth "Shruthi II" with Teensy 4.1 board and 16Bit Stereo DAC
    // (c) Rolf Degen      Version 1.02  15.10.2020
    #include <MIDI.h>
    #define ENCODER_OPTIMIZE_INTERRUPTS
    #include <Encoder.h>
    #define TFT_SCLK 27		// SCLK can also use pin 14
    #define TFT_MOSI 26		// MOSI can also use pin 7
    #define TFT_CS   25		// CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
    #define TFT_DC   24		//  but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
    #define TFT_RST  9		// RST can use any pin
    #define ST7735_BLACK   0x0000
    #define ST7735_GRAY    0x8410
    #define ST7735_WHITE   0xFFFF
    #define ST7735_RED     0xF800
    #define ST7735_ORANGE  0xFA60
    #define ST7735_YELLOW  0xFFE0
    #define ST7735_LIME    0x07FF
    #define ST7735_GREEN   0x07E0
    #define ST7735_CYAN    0x07FF
    #define ST7735_AQUA    0x04FF
    #define ST7735_BLUE    0x001F
    #define ST7735_MAGENTA 0xF81F
    #define ST7735_PINK    0xF8FF
    #define Menu_Osc            0	// Menu pages
    #define Menu_AmpEnv			1
    #define Menu_FilterEnv		2
    #define Menu_Filter			3
    #define LowPass				0
    #define BandPass			1
    #define HighPass			2
    #define pi		3.14159
    #define NO_OF_VOICES        6
    // Global var
    const int ANALOG_PIN8 = A8;
    unsigned long previousTime_cpu = 0;
    unsigned long previousTime_pot = 0;
    unsigned long previousTime_midi = 0;
    unsigned long previousTime_ADC = 0;
    const int interval_cpu = 200;           // poll interval CPU usage
    const int interval_pot = 35;            // poll interval pots and keys
    const int interval_ADC = 15;				// poll ADC
    const int interval_midi = 1;            // poll interval midi data
    const uint8_t channel = 1;
    uint8_t note = 0;
    byte velocity = 0;
    float freq = 0;
    int pitch_bnd = 1;
    float bendf = 0;
    float BendFactor = 1;
    int pot_1 = 0;
    int pot_2 = 0;
    int pot_3 = 0;
    int pot_4 = 0;
    int pot_1_old = 0;
    int pot_2_old = 0;
    int pot_3_old = 0;
    int pot_4_old = 0;
    uint8_t Amp_env_delay = 0;
    uint8_t Amp_env_att = 20;
    uint8_t Amp_env_hold = 0;
    uint8_t Amp_env_dcy = 30;
    uint8_t Amp_env_sus = 40;
    uint8_t Amp_env_rel = 50;
    uint8_t Filter_env_delay = 0;
    uint8_t Filter_env_att = 80;
    uint8_t Filter_env_hold = 0;
    uint8_t Filter_env_dcy = 70;
    uint8_t Filter_env_sus = 70;
    uint8_t Filter_env_rel = 60;
    uint8_t Filter_cut = 64;
    uint8_t Filter_res = 20;
    uint8_t Filter_key = 50;
    uint8_t Filter_typ = 0;
    boolean pot_1_change = false;
    boolean pot_2_change = false;
    boolean pot_3_change = false;
    boolean pot_4_change = false;
    uint8_t Menu_page = 0;
    float pot_div127 = 0.228;		// pot_value divider
    int oldPosition  = -999;
    uint8_t Osc_waveform = 0;
    struct VoiceAndNote {
    	int note;
    	long timeOn;
    	boolean voiceOn;
    	uint8_t lampTimeOn;
    struct VoiceAndNote voices[NO_OF_VOICES] = {
    	{ -1, 0, false, 0},
    	{ -1, 0, false, 0},
    	{ -1, 0, false, 0},
    	{ -1, 0, false, 0},
    	{ -1, 0, false, 0},
    	{ -1, 0, false, 0}
    int voiceToReturn = -1;			// Voices allocation
    long earliestTime = millis();	// Voices allocation
    // Tabels
    // Sine filter curv ------------------------------------------------------
    const byte Filter_curve[385] PROGMEM = {
    	1,      2,      2,      3,      2,      3,      3,      4,
    	5,      4,      7,      5,      9,      7,     10,     11,
    	11,     13,     13,     17,     16,     18,     21,     21,
    	23,     25,     27,     28,     32,     31,     36,     36,
    	39,     41,     43,     46,     48,     51,     53,     55,
    	57,     62,     63,     65,     70,     70,     75,     76,
    	81,     82,     85,     89,     92,     94,     97,    100,
    	104,    107,    109,    112,    116,    119,    122,    124,
    	129,    130,    135,    137,    140,    144,    147,    148,
    	154,    155,    158,    163,    163,    169,    169,    174,
    	177,    178,    182,    185,    187,    191,    192,    195,
    	199,    200,    203,    205,    209,    210,    212,    216,
    	216,    220,    221,    223,    226,    227,    230,    230,
    	233,    235,    235,    239,    238,    241,    242,    243,
    	245,    245,    246,    249,    247,    251,    249,    252,
    	251,    252,    253,    253,    253,    254,    254,    254,
    	253,    255,    254,    253,    253,    254,    252,    253,
    	251,    251,    250,    250,    248,    248,    246,    246,
    	245,    242,    243,    240,    239,    238,    236,    234,
    	233,    231,    230,    226,    226,    224,    221,    219,
    	217,    215,    212,    211,    208,    206,    202,    201,
    	198,    196,    192,    190,    188,    184,    182,    179,
    	177,    173,    170,    168,    164,    162,    158,    156,
    	153,    149,    147,    143,    141,    136,    135,    131,
    	128,    125,    122,    118,    116,    113,    109,    106,
    	104,    101,     96,     95,     92,     88,     85,     83,
    	80,     77,     74,     71,     69,     66,     63,     61,
    	57,     56,     53,     50,     49,     45,     43,     42,
    	38,     37,     35,     32,     31,     29,     26,     26,
    	22,     22,     20,     19,     16,     16,     13,     14,
    	11,     10,     10,      8,      8,      6,      6,      5,
    	4,      5,      2,      3,      2,      2,      2,      3,
    	0,		0,		0,		0,		0,		0,		0,		0,
    	0,
    // Potentiometer Power table
    const int Pot_PowerTab[128] PROGMEM = {
    	0,     0,     1,     2,     3,     4,     5,     6,
    	7,     9,    12,    15,    19,    24,    29,    36,
    	43,    50,    59,    68,    78,    89,   101,   114,
    	128,   143,   159,   176,   194,   214,   234,   256,
    	279,   303,   329,   355,   384,   413,   444,   476,
    	510,   545,   582,   620,   660,   701,   744,   789,
    	835,   882,   932,   983,  1036,  1091,  1147,  1206,
    	1266,  1328,  1392,  1457,  1525,  1595,  1666,  1740,
    	1815,  1893,  1973,  2055,  2138,  2224,  2313,  2403,
    	2495,  2590,  2687,  2786,  2888,  2991,  3097,  3206,
    	3317,  3430,  3545,  3663,  3784,  3907,  4032,  4160,
    	4290,  4423,  4559,  4697,  4837,  4981,  5126,  5275,
    	5426,  5580,  5737,  5896,  6059,  6224,  6391,  6562,
    	6736,  6912,  7091,  7273,  7458,  7646,  7837,  8031,
    	8228,  8428,  8630,  8836,  9045,  9257,  9473,  9691,
    	9912, 10137, 10365, 10596, 10830, 11068, 11800, 11800,
    // Filter Frequency
    // DeepMind 6
    const int FilterFrequency[256] PROGMEM = {
    	50,		51,     52,     54,		55,     56,		58,		59,
    	60,     62,		63,		65,		66,		68,		69,		71,
    	73,		75,		76,		78,		80,		82,		84,		86,
    	88,		90,		92,		94,		97,		99,		101,    104,
    	106,	109,	111,    114,	116,	119,	122,	125,
    	128,	131,	134,	137,	141,	144,	147,	151,
    	154,	158,	162,	166,	170,	174,	178,	182,
    	186,	191,	195,	200,	205,	210,	215,	220,
    	225,	230,	236,	241,	247,	253,	259,	265,
    	271,	278,	284,	291,	298,	305,	313,	320,
    	328,	335,	343,	351,	360,	368,	377,	386,
    	395,	405,	414,	424,	434,	445,	455,	466,
    	477,	488,	500,	512,	524,	537,	549,	562,
    	576,	589,	603,	618,	632,	647,	663,	679,
    	695,	711,	728,	746,	763,	781,	800,	819,
    	838,	858,	879,	900,	921,	943,	965,	988,
    	1012,	1036,	1060,	1086,	1112,	1138,	1165,	1193,
    	1221,	1250,	1280,	1310,	1341,	1373,	1406,	1439,
    	1474,	1509,	1544,	1581,	1619,	1657,	1697,	1737,
    // TSynth
    const static int FilterFrequency[256] = {
    	20,		20,		22,		23,		24,		26,		27,		28,
    	29,		31,		32,		33,		34,		35,		36,		38,
    	39,		40,		41,		43,		44,		46,		47,		49,
    	50,		52,		53,		55,		57,		59,		61,		63,
    	65,		68,		70,		73,		76,		78,		81,		84,
    	87,		91,		94,		98,		102,	106,	110,	114,
    	119,	123,	128,	133,	138,	144,	149,	155,
    	161,	167,	174,	181,	187,	195,	202,	210,
    	218,	226,	234,	243,	252,	261,	271,	281,
    	291,	301,	312,	323,	334,	346,	358,	370,
    	383,	395,	409,	422,	436,	451,	465,	480,
    	496,	512,	528,	544,	561,	578,	596,	614,
    	633,	652,	671,	691,	711,	732,	753,	774,
    	796,	818,	841,	865,	888,	913,	937,	962,
    	988,	1014,	1041,	1068,	1096,	1124,	1152,	1182,
    	1211,	1242,	1272,	1304,	1335,	1368,	1401,	1434,
    	1468,	1503,	1538,	1574,	1610,	1647,	1684,	1722,
    	1761,	1800,	1840,	1881,	1922,	1964,	2006,	2049,
    	2093,	2137,	2182,	2227,	2274,	2320,	2368,	2416,
    	2465,	2515,	2565,	2616,	2668,	2720,	2773,	2827,
    	2881,	2936,	2992,	3049,	3106,	3164,	3223,	3283,
    	3343,	3404,	3466,	3529,	3592,	3656,	3721,	3787,
    	3853,	3921,	3989,	4058,	4127,	4198,	4269,	4341,
    	4414,	4488,	4563,	4638,	4715,	4792,	4870,	4949,
    	5029,	5109,	5191,	5273,	5357,	5441,	5526,	5612,
    	5699,	5787,	5876,	5965,	6056,	6147,	6240,	6333,
    	6427,	6523,	6619,	6716,	6814,	6913,	7013,	7114,
    	7216,	7319,	7424,	7529,	7635,	7742,	7850,	7959,
    	8069,	8180,	8292,	8405,	8519,	8634,	8751,	8868,
    	8986,	9106,	9226,	9348,	9471,	9594,	9719,	9845,
    	9972,	10100,	10230,	10360,	10491,	10624,	10758,	10893,
    	11029,	11166,	11304,	11443,	11584,	11726,	12000,	12000
    // Waveform text
    const char* const Waveform_text[] PROGMEM = {"SINE","SAW ","SQU ","TRI ","VTRI","ARB ","PULS","S&H "};
    // GUItool
    MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
    Encoder myEnc(31, 30);
    ResponsiveAnalogRead analog1(A0, true);
    ResponsiveAnalogRead analog2(A2, true);
    ResponsiveAnalogRead analog3(A3, true);
    ResponsiveAnalogRead analog4(A8, true);
    AudioSynthWaveformDc     dc1;            //xy=393,162
    AudioSynthWaveformDc     dc2;            //xy=387,383
    AudioSynthWaveformDc     dc3;            //xy=385,590
    AudioSynthWaveformDc     dc4;            //xy=382,789
    AudioSynthWaveformDc     dc5;            //xy=380,959
    AudioSynthWaveformDc     dc6;            //xy=376,1152
    AudioSynthWaveform       waveform1;      //xy=399,92
    AudioSynthWaveform       waveform2;      //xy=395,317
    AudioSynthWaveform       waveform3;      //xy=394,528
    AudioSynthWaveform       waveform4;      //xy=393,735
    AudioSynthWaveform       waveform5;      //xy=389,909
    AudioSynthWaveform       waveform6;      //xy=387,1093
    AudioEffectEnvelope      envelope1_0;      //xy=1101,105
    AudioEffectEnvelope      envelope2_0;      //xy=1104,331
    AudioEffectEnvelope      envelope3_0;      //xy=1104,539
    AudioEffectEnvelope      envelope4_0;     //xy=1106,745
    AudioEffectEnvelope      envelope5_0;     //xy=1108,923
    AudioEffectEnvelope      envelope6_0;     //xy=1110,1105
    AudioEffectEnvelope      envelope1_1;      //xy=559,162
    AudioEffectEnvelope      envelope2_1;      //xy=548,382
    AudioEffectEnvelope      envelope3_1;      //xy=539,590
    AudioEffectEnvelope      envelope4_1;      //xy=538,789
    AudioEffectEnvelope      envelope5_1;      //xy=536,959
    AudioEffectEnvelope      envelope6_1;      //xy=537,1152
    AudioFilterStateVariable filter1;        //xy=723,99
    AudioFilterStateVariable filter2;        //xy=718,325
    AudioFilterStateVariable filter3;        //xy=712,533
    AudioFilterStateVariable filter4;        //xy=709,739
    AudioFilterStateVariable filter5;        //xy=711,917
    AudioFilterStateVariable filter6;        //xy=713,1100
    AudioMixer4              mixer1;         //xy=936,105
    AudioMixer4              mixer2;         //xy=931,331
    AudioMixer4              mixer3;         //xy=930,539
    AudioMixer4              mixer4;         //xy=931,745
    AudioMixer4              mixer5;         //xy=931,923
    AudioMixer4              mixer6;         //xy=929,1106
    AudioMixer4              mixer20;         //xy=1351,498
    AudioMixer4              mixer21;         //xy=1351,942
    AudioMixer4              mixer22;         //xy=1560,730
    AudioOutputI2S           i2s1;           //xy=1745,728
    AudioConnection          patchCord1(dc6, envelope6_1);
    AudioConnection          patchCord2(dc5, envelope5_1);
    AudioConnection          patchCord3(dc4, envelope4_1);
    AudioConnection          patchCord4(dc3, envelope3_1);
    AudioConnection          patchCord5(dc2, envelope2_1);
    AudioConnection          patchCord6(waveform6, 0, filter6, 0);
    AudioConnection          patchCord7(waveform5, 0, filter5, 0);
    AudioConnection          patchCord8(dc1, envelope1_1);
    AudioConnection          patchCord9(waveform4, 0, filter4, 0);
    AudioConnection          patchCord10(waveform3, 0, filter3, 0);
    AudioConnection          patchCord11(waveform2, 0, filter2, 0);
    AudioConnection          patchCord12(waveform1, 0, filter1, 0);
    AudioConnection          patchCord13(envelope5_1, 0, filter5, 1);
    AudioConnection          patchCord14(envelope4_1, 0, filter4, 1);
    AudioConnection          patchCord15(envelope3_1, 0, filter3, 1);
    AudioConnection          patchCord16(envelope6_1, 0, filter6, 1);
    AudioConnection          patchCord17(envelope2_1, 0, filter2, 1);
    AudioConnection          patchCord18(envelope1_1, 0, filter1, 1);
    AudioConnection          patchCord19(filter4, 0, mixer4, 0);
    AudioConnection          patchCord20(filter4, 1, mixer4, 1);
    AudioConnection          patchCord21(filter4, 2, mixer4, 2);
    AudioConnection          patchCord22(filter3, 0, mixer3, 0);
    AudioConnection          patchCord23(filter3, 1, mixer3, 1);
    AudioConnection          patchCord24(filter3, 2, mixer3, 2);
    AudioConnection          patchCord25(filter5, 0, mixer5, 0);
    AudioConnection          patchCord26(filter5, 1, mixer5, 1);
    AudioConnection          patchCord27(filter5, 2, mixer5, 2);
    AudioConnection          patchCord28(filter6, 0, mixer6, 0);
    AudioConnection          patchCord29(filter6, 1, mixer6, 1);
    AudioConnection          patchCord30(filter6, 2, mixer6, 2);
    AudioConnection          patchCord31(filter2, 0, mixer2, 0);
    AudioConnection          patchCord32(filter2, 1, mixer2, 1);
    AudioConnection          patchCord33(filter2, 2, mixer2, 2);
    AudioConnection          patchCord34(filter1, 0, mixer1, 0);
    AudioConnection          patchCord35(filter1, 1, mixer1, 1);
    AudioConnection          patchCord36(filter1, 2, mixer1, 2);
    AudioConnection          patchCord37(mixer3, envelope3_0);
    AudioConnection          patchCord38(mixer2, envelope2_0);
    AudioConnection          patchCord39(mixer6, envelope6_0);
    AudioConnection          patchCord40(mixer4, envelope4_0);
    AudioConnection          patchCord41(mixer5, envelope5_0);
    AudioConnection          patchCord42(mixer1, envelope1_0);
    AudioConnection          patchCord43(envelope1_0, 0, mixer20, 0);
    AudioConnection          patchCord44(envelope2_0, 0, mixer20, 1);
    AudioConnection          patchCord45(envelope3_0, 0, mixer20, 2);
    AudioConnection          patchCord46(envelope4_0, 0, mixer20, 3);
    AudioConnection          patchCord47(envelope5_0, 0, mixer21, 0);
    AudioConnection          patchCord48(envelope6_0, 0, mixer21, 1);
    AudioConnection          patchCord49(mixer20, 0, mixer22, 0);
    AudioConnection          patchCord50(mixer21, 0, mixer22, 1);
    AudioConnection          patchCord51(mixer22, 0, i2s1, 0);
    AudioConnection          patchCord52(mixer22, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=1735,625
    // draw Voice Lamps
    void draw_Voice_Lamps(void)
    	disp.drawLine(128, 1, 128, 16, ST7735_GRAY);
    	disp.drawRect(133, 3, 7, 4, ST7735_RED);
    	disp.drawRect(133 + 10, 3, 7, 4, ST7735_RED);
    	disp.drawRect(133 + 10 + 10, 3, 7, 4, ST7735_RED);
    	disp.drawRect(133, 11, 7, 4, ST7735_RED);
    	disp.drawRect(133 + 10, 11, 7, 4, ST7735_RED);
    	disp.drawRect(133 + 10 + 10, 11, 7, 4, ST7735_RED);
    // Oscillator menu
    void Osc_menu (void)
    	disp.drawLine(0, 20, 240, 20, ST7735_YELLOW);
    	disp.setCursor(10, 5);
    	disp.print("OSC");
    	disp.setTextColor(ST7735_WHITE);
    	disp.setCursor(10, 105);
    	disp.print("SHA");
    	disp.setCursor(10 + 40, 105);
    	disp.print("PRM");
    	disp.setCursor(10 + 40 + 40, 105);
    	disp.print("RNG");
    	disp.setCursor(10 + 40 + 40 + 40, 105);
    	disp.print("TUN");
    	// draw pot values --------------------------
    	disp.drawLine(4,116,30,116,ST7735_BLUE);
    	disp.drawLine(4+40,116,30+40,116,ST7735_BLUE);
    	disp.drawLine(4+40+40,116,30+40+40,116,ST7735_BLUE  );
    	disp.drawLine(4+40+40+40,116,30+40+40+40,116,ST773  5_BLUE);
    	// draw voice lamps --------------------------
    	draw_Voice_Lamps();
    	//draw_AMP_envLine();
    	//pot_1 = Amp_env_att;
    	//pot_2 = Amp_env_dcy;
    	//pot_3 = Amp_env_sus;
    	//pot_4 = Amp_env_rel;
    	pot_1_change = true;
    	pot_2_change = true;
    	pot_3_change = true;
    	pot_4_change = true;
    	//set_AMP_envelope();
    	refresh_pot_values();
    // AMP envelope menu
    void AMP_envelope_menu (void)
    	disp.print("AMP ENV");
    	disp.print("ATK");
    	disp.print("DCY");
    	disp.print("SUS");
    	disp.print("REL");
    	draw_Voice_Lamps();
    	draw_AMP_envLine();
    	set_AMP_envelope();
    // FILTER envelope menu
    void Filter_envelope_menu (void)
    	disp.print("FILTER ENV");
    	disp.print("ATK");
    	disp.print("DCY");
    	disp.print("SUS");
    	disp.print("REL");
    	draw_Voice_Lamps();
    	draw_Filter_envLine();
    	pot_1 = Filter_env_att;
    	pot_2 = Filter_env_dcy;
    	pot_3 = Filter_env_sus;
    	pot_4 = Filter_env_rel;
    	set_Filter_envelope();
    // FILTER menu
    void Filter_menu (void)
    	disp.print("FILTER");
    	disp.print("FRQ");
    	disp.print("RES");
    	disp.print("KEY");
    	disp.setCursor(6 + 40 + 40 + 40+4, 105);
    	disp.print("MOD");
    	draw_Voice_Lamps();
    	// draw diagramm line
    	disp.drawLine(19,45,19,45+41,ST7735_GRAY);
    	disp.drawLine(19,45+41,19+115,45+41,ST7735_GRAY);
    	disp.setTextColor(ST7735_GRAY);
    	disp.setCursor(7, 46);
    	disp.print("dB");
    	disp.setCursor(110, 88);
    	disp.print("f/Hz");
    	draw_filter_curves(Filter_typ);
    	pot_1 = Filter_cut;
    	pot_2 = Filter_res;
    	pot_3 = Filter_key;
    	pot_4 = Filter_typ * 42; // pot_4 value
    	set_Filter_typ();
    	set_Filter_values();
    // draw_DCA envelope line
    void draw_AMP_envLine(void)
    	uint8_t xplot1 = Amp_env_att;
    	uint8_t xplot1_decay = Amp_env_dcy;
    	uint8_t yplot2_sustain = Amp_env_sus;
    	uint8_t xplot3_release = Amp_env_rel;
    	static uint8_t xplot1_temp = 10;
    	static uint8_t yplot2_sustain_temp = 40;
    	static uint8_t xplot1_decay_temp = 0;
    	static uint8_t xplot3_release_temp = 0;
    	// Attack line
    	disp.drawLine(10,85,xplot1_temp,40,ST7735_BLACK);	// delete old line
    	xplot1 = 10+(Amp_env_att / 4);
    	disp.drawLine(10,85,xplot1,40,ST7735_RED);		// draw new line
    	// Decay Line
    	xplot1_decay = (Amp_env_dcy / 4);
    	yplot2_sustain = 85 - ((Amp_env_sus * 85)/239);
    	disp.drawLine(xplot1_temp,40,xplot1_temp + xplot1_decay_temp,yplot2_sustain_temp,ST7735_BLACK  );
    	disp.drawLine(xplot1,40,xplot1 + xplot1_decay,yplot2_sustain,ST7735_RED);
    	// Sustain Line
    	disp.drawLine(xplot1_temp + xplot1_decay_temp,yplot2_sustain_temp,90,yplot2_su  stain_temp,ST7735_BLACK);
    	disp.drawLine(xplot1 + xplot1_decay,yplot2_sustain,90,yplot2_sustain,ST77  35_RED);
    	// Relaese line
    	xplot3_release = (90 + ((Amp_env_rel * 25)/127));
    	disp.drawLine(90,yplot2_sustain_temp,xplot3_releas  e_temp,85,ST7735_BLACK);
    	disp.drawLine(90,yplot2_sustain,xplot3_release,85,  ST7735_RED);
    	// draw little rectangle for ADSR points
    	disp.fillRect(xplot1_temp - 2,39,5,5,ST7735_BLACK);
    	disp.fillRect(xplot1 - 2,39,5,5,ST7735_BLUE);
    	disp.fillRect(xplot1_temp + xplot1_decay_temp -2,yplot2_sustain_temp-1,5,5,ST7735_BLACK);
    	disp.fillRect(xplot1 + xplot1_decay -2,yplot2_sustain-1,5,5,ST7735_BLUE);
    	disp.fillRect(88,yplot2_sustain_temp-1,5,5,ST7735_BLACK);
    	disp.fillRect(88,yplot2_sustain-1,5,5,ST7735_BLUE);
    	// draw vertikal point-line for relaese
    	for (uint8_t i = 40; i <= 85; i++){
    		disp.drawPixel(90,i,ST7735_GRAY);
    		i++;
    		i++;
    	// save current lines for delete old lines
    	xplot1_temp = xplot1;
    	yplot2_sustain_temp = yplot2_sustain;
    	xplot1_decay_temp = xplot1_decay;
    	xplot3_release_temp = xplot3_release;
    // draw Filter envelope line
    void draw_Filter_envLine (void)
    	uint8_t xplot1 = Filter_env_att;
    	uint8_t yplot2_sustain = Filter_env_sus;
    	uint8_t xplot1_decay = Filter_env_dcy;
    	uint8_t xplot3_release = Filter_env_rel;
    	// Attack line
    	xplot1 = 10+(Filter_env_att / 4);
    	// Decay Line
    	xplot1_decay = (Filter_env_dcy / 4);
    	yplot2_sustain = 85 - ((Filter_env_sus * 85)/239);
    	// Sustain Line
    	// Relaese line
    	xplot3_release = (90 + ((Filter_env_rel * 25)/127));
    		i++;
    		i++;
    // draw Filter curves on LCD
    void draw_filter_curves (uint8_t filterTyp)
    	// clear old curve
    	disp.fillRect(20,48,114,38,ST7735_BLACK);
    	// draw LowPass Filter curve -----------------------------------------
    	if (filterTyp == LowPass){
    		const uint8_t x_plot = 68;
    		const uint8_t y_plot = 85;
    		uint8_t pot_1_cut = Filter_cut;
    		uint8_t pot_2_res = Filter_res;
    		uint8_t x = 40;
    		uint16_t r = 0;
    		uint8_t y = 0;
    		uint8_t y_ = 0;
    		uint8_t i = 0;
    		uint8_t i_ = 0;
    		uint8_t q_typ = 12;			// Filter Q
    		uint16_t resonance = 0;
    		for (i = 0; i < 48; i++)
    			resonance = (Filter_curve[(i * 8)]);
    			resonance = (((resonance >> 2) * pot_2_res) >> 7);
    			r = (x + r - y) + resonance;
    			y = r / q_typ;
    			disp.drawLine((pot_1_cut / 2) + x_plot - i_,(y_plot - y_ / 2), (pot_1_cut / 2) + x_plot - i, (y_plot - y / 2),ST7735_RED);
    			i_ = i;
    			y_ = y;
    		disp.drawLine(20, (y_plot - y_ / 2), 20 + (pot_1_cut / 2), (y_plot - y_ / 2), ST7735_RED);
    	// draw BandPass Filter curve ----------------------------------------
    	else if (filterTyp == BandPass){
    		const uint8_t x_plot = 20;
    		uint8_t x = 40;
    		uint16_t r = 0;
    		uint8_t y = 0;
    		uint8_t y_ = 0;
    		uint8_t i = 0;
    		uint8_t i_ = 0;
    		for (i = 0; i < 27; i++)
    			y = r / q_typ;
    			disp.drawLine((pot_1_cut / 2) + x_plot + i_,(y_plot - y_ / 2),(pot_1_cut / 2) + x_plot + i,(y_plot - y_ / 2),ST7735_RED);
    			disp.drawLine((pot_1_cut / 2) + x_plot + 49 - i_,(y_plot - y_ / 2),(pot_1_cut / 2) + x_plot + 49 - i,(y_plot - y_ / 2),ST7735_RED);
    			i_ = i;
    			y_ = y;
    	// draw HighPass Filter curve ----------------------------------------
    	else if (filterTyp == HighPass){
    		uint8_t x = 40;
    		uint16_t r = 0;
    		uint8_t y = 0;
    		uint8_t y_ = 0;
    		uint8_t i = 0;
    		uint8_t i_ = 0;
    			y = r / q_typ;
    			disp.drawLine((pot_1_cut / 2) + x_plot + i_,(y_plot - y_ / 2), (pot_1_cut / 2) + x_plot + i, (y_plot - y / 2),ST7735_RED);
    			i_ = i;
    			y_ = y;
    		disp.drawLine(68 + (pot_1 / 2), (y_plot - y_ / 2), 131, (y_plot - y_ / 2), ST7735_RED);
    // set Filter typ
    void set_Filter_typ(void)
    	if (pot_4 <= 39)						// set LowPass
    		mixer1.gain(0, 1.0);	// LP
    		mixer1.gain(1, 0);		// BP
    		mixer1.gain(2, 0);		// HP
    		mixer1.gain(3, 0);		// --
    		mixer2.gain(0, 1.0);	// LP
    		mixer2.gain(1, 0);		// BP
    		mixer2.gain(2, 0);		// HP
    		mixer2.gain(3, 0);		// --
    		mixer3.gain(0, 1.0);	// LP
    		mixer3.gain(1, 0);		// BP
    		mixer3.gain(2, 0);		// HP
    		mixer3.gain(3, 0);		// --
    		mixer4.gain(0, 1.0);	// LP
    		mixer4.gain(1, 0);		// BP
    		mixer4.gain(2, 0);		// HP
    		mixer4.gain(3, 0);		// --
    		mixer5.gain(0, 1.0);	// LP
    		mixer5.gain(1, 0);		// BP
    		mixer5.gain(2, 0);		// HP
    		mixer5.gain(3, 0);		// --
    		mixer6.gain(0, 1.0);	// LP
    		mixer6.gain(1, 0);		// BP
    		mixer6.gain(2, 0);		// HP
    		mixer6.gain(3, 0);		// --
    		disp.fillRect(134, 120, 17, 8, ST7735_BLACK);
    		disp.setCursor(134, 120);
    		disp.print("LP");
    		Filter_typ = LowPass;
    	else if (pot_4 >= 42 && pot_4 <= 79)	// set BandPass
    		mixer1.gain(0, 0);		// LP
    		mixer1.gain(1, 2.0);	// BP
    		mixer2.gain(0, 0);		// LP
    		mixer2.gain(1, 2.0);	// BP
    		mixer3.gain(0, 0);		// LP
    		mixer3.gain(1, 2.0);	// BP
    		mixer4.gain(0, 0);		// LP
    		mixer4.gain(1, 2.0);	// BP
    		mixer5.gain(0, 0);		// LP
    		mixer5.gain(1, 2.0);	// BP
    		mixer6.gain(0, 0);		// LP
    		mixer6.gain(1, 2.0);	// BP
    		disp.print("BP");
    		Filter_typ = BandPass;
    	else if (pot_4 >= 84 && pot_4 <= 127)	// set HighPass
    		mixer1.gain(2, 2.0);	// HP
    		mixer2.gain(2, 2.0);	// HP
    		mixer3.gain(2, 2.0);	// HP
    		mixer4.gain(2, 2.0);	// HP
    		mixer5.gain(2, 2.0);	// HP
    		mixer6.gain(2, 2.0);	// HP
    		disp.print("HP");
    		Filter_typ = HighPass;
    // print CPU usage every 200ms
    void print_CPU_usage (void)
    	disp.fillRect(133, 25, 23, 8, ST7735_BLACK);
    	disp.setCursor(133, 26);
    	disp.print(AudioProcessorUsage());
    // read Potentiometers with averaging calculation
    boolean read_pots (void)
    	boolean pot_change = false;
    	int adc_sum = 0;
    	// read Potentiometer 1
    	for (uint8_t i = 0; i < 16; i++){
    		//analog1.update();				// averaging calculation
    		adc_sum = adc_sum + ((analog1.getValue()) >> 3);
    	pot_1 = adc_sum / 16;
    	if(pot_1_old  != pot_1){
    		pot_1_old = pot_1;
    		pot_change = true;
    	// read Potentiometer 2
    	adc_sum = 0;
    		//analog2.update();
    		adc_sum = adc_sum + ((analog2.getValue()) >> 3);
    	pot_2 = adc_sum / 16;
    	if(pot_2_old  != pot_2){
    		pot_2_old = pot_2;
    		pot_change = true;
    	// read Potentiometer 3
    	adc_sum = 0;
    		//analog3.update();
    		adc_sum = adc_sum + ((analog3.getValue()) >> 3);
    	pot_3 = adc_sum / 16;
    	if(pot_3_old  != pot_3){
    		pot_3_old = pot_3;
    		pot_change = true;
    	// read Potentiometer 4
    	adc_sum = 0;
    		//analog4.update();
    		adc_sum = adc_sum + ((analog4.getValue()) >> 3);
    	pot_4 = adc_sum / 16;
    	if(pot_4_old  != pot_4){
    		pot_4_old = pot_4;
    		pot_change = true;
    	boolean temp_flag = pot_change;
    	pot_change = false;
    	return temp_flag;
    // draw Potentiometer values
    void refresh_pot_values(void)
    	uint8_t pot1_value = 0;
    	uint8_t pot2_value = 0;
    	uint8_t pot3_value = 0;
    	uint8_t pot4_value = 0;
    	if (pot_1_change == true)
    		pot1_value = pot_1;
    		disp.fillRect(4, 114, 32, 4, ST7735_BLACK);
    		disp.drawLine(4,116,32,116,ST7735_BLUE);
    		disp.drawLine(4 + (pot_div127 * pot1_value),114,4 + (pot_div127 * pot1_value),117,ST7735_RED);
    	if (pot_2_change == true)
    		pot2_value = pot_2;
    		disp.fillRect(4+40, 114, 32, 4, ST7735_BLACK);
    		disp.drawLine(4+40,116,32+40,116,ST7735_BLUE);
    		disp.drawLine(4 + 40 + (pot_div127 * pot2_value),114,4 + 40 + (pot_div127 * pot2_value),117,ST7735_RED);
    	if (pot_3_change == true)
    		pot3_value = pot_3;
    		disp.fillRect(4+40+40, 114, 32, 4, ST7735_BLACK);
    		disp.drawLine(4+40+40,116,32+40+40,116,ST7735_BLUE  );
    		disp.drawLine(4 + 40 + 40+(pot_div127 * pot3_value),114,4 + 40 + 40+(pot_div127 * pot3_value),117,ST7735_RED);
    	if (pot_4_change == true)
    		pot4_value = pot_4;
    		disp.fillRect(4+40+40+40, 114, 32, 4, ST7735_BLACK);
    		disp.drawLine(4+40+40+40,116,32+40+40+40,116,ST773  5_BLUE);
    		disp.drawLine(4 + 40+40+40+(pot_div127 * pot4_value),114,4 + 40+40+40+(pot_div127 * pot4_value),117,ST7735_RED);
    // read Encoder
    boolean read_Encoder (void)
    	int newPosition = (myEnc.read() >> 2);
    	if (newPosition != oldPosition) {
    		if (newPosition < 0) {
    			newPosition = 0;
    			oldPosition = 0;
    			myEnc.write(0);
    		else if (newPosition > 9){
    			newPosition = 9;
    			oldPosition = 9;
    			myEnc.write(9 * 4);
    		oldPosition = newPosition;
    		return true;
    	return false;
    // set Voices Lamp off
    void set_Voices_Lamp (void)
    	if (voices[0].lampTimeOn == 1){
    		disp.fillRect(133, 3, 7, 4, ST7735_BLACK);
    		disp.drawRect(133, 3, 7, 4, ST7735_RED);	// Lamp1 off
    		voices[0].lampTimeOn--;
    	else if (voices[0].lampTimeOn > 1){
    	if (voices[1].lampTimeOn == 1){
    		disp.fillRect(133+10, 3, 7, 4, ST7735_BLACK);
    		disp.drawRect(133+10, 3, 7, 4, ST7735_RED);	// Lamp2 off
    		voices[1].lampTimeOn--;
    	else if (voices[1].lampTimeOn > 1){
    	if (voices[2].lampTimeOn == 1){
    		disp.fillRect(133+20, 3, 7, 4, ST7735_BLACK);
    		disp.drawRect(133+20, 3, 7, 4, ST7735_RED);	// Lamp3 off
    		voices[2].lampTimeOn--;
    	else if (voices[2].lampTimeOn > 1){
    	if (voices[3].lampTimeOn == 1){
    		disp.fillRect(133, 11, 7, 4, ST7735_BLACK);
    		disp.drawRect(133, 11, 7, 4, ST7735_RED);	// Lamp4 off
    		voices[3].lampTimeOn--;
    	else if (voices[3].lampTimeOn > 1){
    	if (voices[4].lampTimeOn == 1){
    		disp.fillRect(133+10, 11, 7, 4, ST7735_BLACK);
    		disp.drawRect(133+10, 11, 7, 4, ST7735_RED);	// Lamp5 off
    		voices[4].lampTimeOn--;
    	else if (voices[4].lampTimeOn > 1){
    	if (voices[5].lampTimeOn == 1){
    		disp.fillRect(133+20, 11, 7, 4, ST7735_BLACK);
    		disp.drawRect(133+20, 11, 7, 4, ST7735_RED);	// Lamp6 off
    		voices[5].lampTimeOn--;
    	else if (voices[5].lampTimeOn > 1){
    // get Voice number
    int getVoiceNo(int note)
    	voiceToReturn = -1;      //Initialise
    	earliestTime = millis(); //Initialise to now
    	if (note == -1)
    		//NoteOn() - Get the oldest free voice (recent voices may be still on release stage)
    		for (int i = 0; i < NO_OF_VOICES; i++)
    			if (voices[i].voiceOn == false)
    				if (voices[i].timeOn < earliestTime)
    					earliestTime = voices[i].timeOn;
    					voiceToReturn = i;
    		if (voiceToReturn == -1)
    			//No free voices, need to steal oldest sounding voice
    			earliestTime = millis(); //Reinitialise
    					voiceToReturn = i;
    		return voiceToReturn + 1;
    		//NoteOff() - Get voice number from note
    			if (voices[i].note == note && voices[i].voiceOn)
    				return i + 1;
    	//Shouldn't get here, return voice 1
    	return 1;
    // set Voice on
    void set_Voice_on(uint8_t note)
    	float freq = 440.0 * powf(2.0, (float)(note - 69) * 0.08333333);
    	switch(getVoiceNo(-1))
    		case 1:
    			waveform1.frequency(freq * BendFactor);
    			waveform1.phase(0);
    			envelope1_0.noteOn();
    			envelope1_1.noteOn();
    			voices[0].note = note;
    			voices[0].timeOn = millis();
    			voices[0].voiceOn = true;
    			disp.fillRect(133, 3, 7, 4, ST7735_RED);	// Lamp1 on
    		case 2:
    			waveform2.frequency(freq * BendFactor);
    			waveform2.phase(0);
    			envelope2_0.noteOn();
    			envelope2_1.noteOn();
    			voices[1].note = note;
    			voices[1].timeOn = millis();
    			voices[1].voiceOn = true;
    			disp.fillRect(133+10, 3, 7, 4, ST7735_RED);	// Lamp2 on
    		case 3:
    			waveform3.frequency(freq * BendFactor);
    			waveform3.phase(0);
    			envelope3_0.noteOn();
    			envelope3_1.noteOn();
    			voices[2].note = note;
    			voices[2].timeOn = millis();
    			voices[2].voiceOn = true;
    			disp.fillRect(133+20, 3, 7, 4, ST7735_RED);	// Lamp3 on
    		case 4:
    			waveform4.frequency(freq * BendFactor);
    			waveform4.phase(0);
    			envelope4_0.noteOn();
    			envelope4_1.noteOn();
    			voices[3].note = note;
    			voices[3].timeOn = millis();
    			voices[3].voiceOn = true;
    			disp.fillRect(133, 11, 7, 4, ST7735_RED);	// Lamp4 on
    		case 5:
    			waveform5.frequency(freq * BendFactor);
    			waveform5.phase(0);
    			envelope5_0.noteOn();
    			envelope5_1.noteOn();
    			voices[4].note = note;
    			voices[4].timeOn = millis();
    			voices[4].voiceOn = true;
    			disp.fillRect(133+10, 11, 7, 4, ST7735_RED);	// Lamp5 on
    		case 6:
    			waveform6.frequency(freq * BendFactor);
    			waveform6.phase(0);
    			envelope6_0.noteOn();
    			envelope6_1.noteOn();
    			voices[5].note = note;
    			voices[5].timeOn = millis();
    			voices[5].voiceOn = true;
    			disp.fillRect(133+20, 11, 7, 4, ST7735_RED);	// Lamp6 on
    // set Voices off
    void set_Voice_off(uint8_t note)
    	switch (getVoiceNo(note))
    		case 1:
    			envelope1_0.noteOff();	// AMP
    			envelope1_1.noteOff();	// Filter
    			voices[0].voiceOn = false;
    			voices[0].lampTimeOn = 64;
    		case 2:
    			envelope2_0.noteOff();	// AMP
    			envelope2_1.noteOff();	// Filter
    			voices[1].voiceOn = false;
    			voices[1].lampTimeOn = 64;;
    		case 3:
    			envelope3_0.noteOff();	// AMP
    			envelope3_1.noteOff();	// Filter
    			voices[2].voiceOn = false;
    			voices[2].lampTimeOn = 64;
    		case 4:
    			envelope4_0.noteOff();	// AMP
    			envelope4_1.noteOff();	// Filter
    			voices[3].voiceOn = false;
    			voices[3].lampTimeOn = 64;
    		case 5:
    			envelope5_0.noteOff();	// AMP
    			envelope5_1.noteOff();	// Filter
    			voices[4].voiceOn = false;
    			voices[4].lampTimeOn = 64;
    		case 6:
    			envelope6_0.noteOff();	// AMP
    			envelope6_1.noteOff();	// Filter
    			voices[5].voiceOn = false;
    			voices[5].lampTimeOn = 64;
    // set AllNotesOff
    void set_AllNotesOff(void)
    // Midi handel  (every 1ms)
    void midi_handel (void)
    	if (MIDI.read()) { // look for a message
    		switch (MIDI.getType()) { // get message type
    			// note on ---------------------------------------------------
    			case midi::NoteOn:
    				note = MIDI.getData1();
    				velocity = MIDI.getData2();
    				set_Voice_on(note);
    			// note off --------------------------------------------------
    			case midi::NoteOff:
    				set_Voice_off(note);
    			// Contrl: PitchBend -----------------------------------------
    			case midi::PitchBend:
    			pitch_bnd = (MIDI.getData2() << 7) + MIDI.getData1();
    			pitch_bnd = (pitch_bnd - 8192);
    			bendf = pitch_bnd;
    			bendf = bendf / 8192;
    			bendf = bendf * 2;
    			bendf = bendf / 12;
    			BendFactor = pow(2, bendf);
    			default:
    // set Osc values
    void set_OSC_values(void)
    	uint8_t pot_temp = 0;
    	if (pot_1_change == true){
    		pot_temp = (pot_1 / 18);
    		waveform1.begin(pot_temp);
    		waveform2.begin(pot_temp);
    		waveform3.begin(pot_temp);
    		waveform4.begin(pot_temp);
    		waveform5.begin(pot_temp);
    		waveform6.begin(pot_temp);
    		disp.setCursor(5,40);
    		disp.fillRect(5,39,23,8,ST7735_BLACK);
    		disp.print(Waveform_text[pot_temp]);
    		Osc_waveform = pot_1;
    	if (pot_2_change == true){
    	if (pot_3_change == true){
    	if (pot_4_change == true){
    // print pot_value
    void print_potValue (int pot_temp, uint8_t x, uint8_t y)
    	// sustain only in %
    	if (x == 84) {
    		disp.fillRect(x, y, 30, 8, ST7735_BLACK);
    		uint8_t value = ((float)0.79 * pot_temp);
    		if (value < 10){
    			disp.setCursor(x + 9, y);
    			disp.print(value);
    			disp.print("%");
    		else if (value < 100){
    			disp.setCursor(x + 6, y);
    			disp.print(value);
    			disp.print("%");
    		else if (value >= 100){
    			disp.setCursor(x + 2, y);
    			disp.print(value);
    			disp.print("%");
    	// attack, decay and release
    		int value = pot_temp;
    		if (value < 10) {
    			disp.print(value);
    			disp.print("ms");
    		else if (value < 100) {
    			disp.setCursor(x + 4,y);
    			disp.print(value);
    			disp.print("ms");
    		else if (value < 1000) {
    			disp.setCursor(x, y);
    			disp.print(value);
    			disp.print("ms");
    		else if (value < 10000) {
    			float val_sec = (float)value / 1000;
    			disp.drawFloat(val_sec, 1, x, y);
    			disp.setCursor(x + 24, y);
    			disp.print("s");
    		else if (value >= 10000) {
    			uint8_t val_sec = value / 1000;
    			disp.print(val_sec);
    			disp.print("s");
    // set AMP envelope(1)
    void set_AMP_envelope(void)
    	float pot_temp = 0;
    	// Delay
    		envelope1_0.delay(0);
    		envelope2_0.delay(0);
    		envelope3_0.delay(0);
    		envelope4_0.delay(0);
    		envelope5_0.delay(0);
    		envelope6_0.delay(0);
    	// Attack
    		pot_temp = (Pot_PowerTab[pot_1]);
    		envelope1_0.attack(pot_temp);
    		envelope2_0.attack(pot_temp);
    		envelope3_0.attack(pot_temp);
    		envelope4_0.attack(pot_temp);
    		envelope5_0.attack(pot_temp);
    		envelope6_0.attack(pot_temp);
    		Amp_env_att = pot_1;
    		print_potValue(pot_temp,4,120);
    	// Hold
    		envelope1_0.hold(0);
    		envelope2_0.hold(0);
    		envelope3_0.hold(0);
    		envelope4_0.hold(0);
    		envelope5_0.hold(0);
    		envelope6_0.hold(0);
    	// Decay
    		pot_temp = (Pot_PowerTab[pot_2]);
    		envelope1_0.decay(pot_temp);
    		envelope2_0.decay(pot_temp);
    		envelope3_0.decay(pot_temp);
    		envelope4_0.decay(pot_temp);
    		envelope5_0.decay(pot_temp);
    		envelope6_0.decay(pot_temp);
    		Amp_env_dcy = pot_2;
    		print_potValue(pot_temp, 4+40, 120);
    	// Sustain
    		if (pot_3 <= 2)
    			pot_3 = 0;
    		pot_temp = (0.008 * pot_3);
    		envelope1_0.sustain(pot_temp);
    		envelope2_0.sustain(pot_temp);
    		envelope3_0.sustain(pot_temp);
    		envelope4_0.sustain(pot_temp);
    		envelope5_0.sustain(pot_temp);
    		envelope6_0.sustain(pot_temp);
    		Amp_env_sus = pot_3;
    		print_potValue(pot_3, 4+40+40, 120);
    	// Release
    		pot_temp = (Pot_PowerTab[pot_4]);
    		envelope1_0.release(pot_temp);
    		envelope2_0.release(pot_temp);
    		envelope3_0.release(pot_temp);
    		envelope4_0.release(pot_temp);
    		envelope5_0.release(pot_temp);
    		envelope6_0.release(pot_temp);
    		Amp_env_rel = pot_4;
    		print_potValue(pot_temp, 4+40+40+40, 120);
    // set Filter envelope(2)
    void set_Filter_envelope(void)
    	float pot_temp = 0;
    	// Delay
    		envelope1_1.delay(0);
    		envelope2_1.delay(0);
    		envelope3_1.delay(0);
    		envelope4_1.delay(0);
    		envelope5_1.delay(0);
    		envelope6_1.delay(0);
    	// Attack
    		envelope1_1.attack(pot_temp);
    		envelope2_1.attack(pot_temp);
    		envelope3_1.attack(pot_temp);
    		envelope4_1.attack(pot_temp);
    		envelope5_1.attack(pot_temp);
    		envelope6_1.attack(pot_temp);
    		Filter_env_att = pot_1;
    	// Hold
    		envelope1_1.hold(0);
    		envelope2_1.hold(0);
    		envelope3_1.hold(0);
    		envelope4_1.hold(0);
    		envelope5_1.hold(0);
    		envelope6_1.hold(0);
    	// Decay
    		envelope1_1.decay(pot_temp);
    		envelope2_1.decay(pot_temp);
    		envelope3_1.decay(pot_temp);
    		envelope4_1.decay(pot_temp);
    		envelope5_1.decay(pot_temp);
    		envelope6_1.decay(pot_temp);
    		Filter_env_dcy = pot_2;
    	// Sustain
    		if (pot_3 <= 2)
    			pot_3 = 0;
    		envelope1_1.sustain(pot_temp);
    		envelope2_1.sustain(pot_temp);
    		envelope3_1.sustain(pot_temp);
    		envelope4_1.sustain(pot_temp);
    		envelope5_1.sustain(pot_temp);
    		envelope6_1.sustain(pot_temp);
    		Filter_env_sus = pot_3;
    	// Release
    		envelope1_1.release(pot_temp);
    		envelope2_1.release(pot_temp);
    		envelope3_1.release(pot_temp);
    		envelope4_1.release(pot_temp);
    		envelope5_1.release(pot_temp);
    		envelope6_1.release(pot_temp);
    		Filter_env_rel = pot_4;
    void set_Filter_values(void)
    	float pot_temp = 0;
    	int pot_value = 0;
    	// set frequency
    			analog1.update();
    			pot_value = pot_value + ((analog1.getValue()) >> 2);
    		pot_value = pot_value / 16;
    		pot_temp = (FilterFrequency[pot_value]);
    		filter1.frequency(pot_temp);
    		filter2.frequency(pot_temp);
    		filter3.frequency(pot_temp);
    		filter4.frequency(pot_temp);
    		filter5.frequency(pot_temp);
    		filter6.frequency(pot_temp);
    		Filter_cut = pot_1;
    		disp.fillRect(4, 120, 30, 8, ST7735_BLACK);
    		if (value < 100){
    			disp.setCursor(8, 120);
    			disp.print(value);
    			disp.print("Hz");
    		else if (value < 1000){
    			disp.setCursor(4, 120);
    			disp.print(value);
    			disp.print("Hz");
    		else if (value < 10000){
    			value = value / 1000;
    			disp.setCursor(6, 120);
    			disp.print(value);
    			disp.print("KHz");
    		else if (value < 100000){
    			disp.print(value);
    			disp.print("KHz");
    	// set resonance
    		pot_temp = (0.039 * pot_2);
    		filter1.resonance(pot_temp);
    		filter2.resonance(pot_temp);
    		filter3.resonance(pot_temp);
    		filter4.resonance(pot_temp);
    		filter5.resonance(pot_temp);
    		filter6.resonance(pot_temp);
    		Filter_res = pot_2;
    		disp.fillRect(44, 120, 30, 8, ST7735_BLACK);
    		uint8_t value = ((float)0.79 * pot_2);
    		if (value < 10){
    			disp.setCursor(44 + 9, 120);
    			disp.print(value);
    			disp.print("%");
    			disp.setCursor(44 + 6, 120);
    			disp.print(value);
    			disp.print("%");
    			disp.setCursor(44 + 2, 120);
    			disp.print(value);
    			disp.print("%");
    	// set KeyTracking
    		pot_value = 0;
    			analog3.update();
    			pot_value = pot_value + ((analog3.getValue()) >> 2);
    		pot_temp = (0.055 * pot_3);
    		filter1.octaveControl(pot_temp);
    		filter2.octaveControl(pot_temp);
    		filter3.octaveControl(pot_temp);
    		filter4.octaveControl(pot_temp);
    		filter5.octaveControl(pot_temp);
    		filter6.octaveControl(pot_temp);
    		Filter_key = pot_3;
    		disp.fillRect(84, 120, 30, 8, ST7735_BLACK);
    		int value = (pot_value * 0.785) - 100;
    		if (value == 0){
    			disp.setCursor(84 + 12, 120);
    			disp.print(value);
    		else if (value > -10 && value < 0){
    			disp.setCursor(84 + 8, 120);
    			disp.print(value);
    		else if (value > -100 && value < 0){
    			disp.setCursor(84 + 6, 120);
    			disp.print(value);
    		else if (value > 0 && value < 10){
    			disp.print("+");
    			disp.print(value);
    		else if (value >= 10 && value < 100){
    			disp.print("+");
    			disp.print(value);
    			//disp.print("+");
    	// set Filter Typ
    		set_Filter_typ();
    // init System
    	// init 1.8" TFT ------------------------------------
    	disp.setCursor(20, 40);
    	disp.setCursor(60, 70);
    	disp.print("V 1.02");
    	// init Audio and Waveform -------------------------------------------
    	AudioMemory(48);
    	sgtl5000_1.enable();
    	sgtl5000_1.volume(0.9);
    	sgtl5000_1.audioPostProcessorEnable();
    	sgtl5000_1.enhanceBassEnable();
    	sgtl5000_1.enhanceBass(0.85, 0.85, 0, 2);		// high Bass + HP-Filter
    	waveform1.begin(0);   // SINE
    	waveform2.begin(0);   // SINE
    	waveform3.begin(0);   // SINE
    	waveform4.begin(0);   // SINE
    	waveform5.begin(0);   // SINE
    	waveform6.begin(0);   // SINE
    	waveform1.frequency(440);
    	waveform2.frequency(440);
    	waveform3.frequency(440);
    	waveform4.frequency(440);
    	waveform5.frequency(440);
    	waveform6.frequency(440);
    	waveform1.amplitude(0.5);
    	waveform2.amplitude(0.5);
    	waveform3.amplitude(0.5);
    	waveform4.amplitude(0.5);
    	waveform5.amplitude(0.5);
    	waveform6.amplitude(0.5);
    	// init Envelopes ---------------------------------------------------
    	envelope1_0.attack(0);
    	envelope2_0.attack(0);
    	envelope3_0.attack(0);
    	envelope4_0.attack(0);
    	envelope5_0.attack(0);
    	envelope6_0.attack(0);
    	envelope1_0.decay(5);
    	envelope2_0.decay(5);
    	envelope3_0.decay(5);
    	envelope4_0.decay(5);
    	envelope5_0.decay(5);
    	envelope6_0.decay(5);
    	envelope1_0.sustain(0.7);
    	envelope2_0.sustain(0.7);
    	envelope3_0.sustain(0.7);
    	envelope4_0.sustain(0.7);
    	envelope5_0.sustain(0.7);
    	envelope6_0.sustain(0.7);
    	envelope1_0.release(50);
    	envelope2_0.release(50);
    	envelope3_0.release(50);
    	envelope4_0.release(50);
    	envelope5_0.release(50);
    	envelope6_0.release(50);
    	envelope1_1.attack(0);
    	envelope2_1.attack(0);
    	envelope3_1.attack(0);
    	envelope4_1.attack(0);
    	envelope5_1.attack(0);
    	envelope6_1.attack(0);
    	envelope1_1.decay(5);
    	envelope2_1.decay(5);
    	envelope3_1.decay(5);
    	envelope4_1.decay(5);
    	envelope5_1.decay(5);
    	envelope6_1.decay(5);
    	envelope1_1.sustain(0.7);
    	envelope2_1.sustain(0.7);
    	envelope3_1.sustain(0.7);
    	envelope4_1.sustain(0.7);
    	envelope5_1.sustain(0.7);
    	envelope6_1.sustain(0.7);
    	envelope1_1.release(50);
    	envelope2_1.release(50);
    	envelope3_1.release(50);
    	envelope4_1.release(50);
    	envelope5_1.release(50);
    	envelope6_1.release(50);
    	Amp_env_att = 0;
    	Amp_env_dcy = 30;
    	Amp_env_sus = 95;
    	Amp_env_rel = 30;
    	Filter_env_att = 0;
    	Filter_env_dcy = 30;
    	Filter_env_sus = 95;
    	Filter_env_rel = 30;
    	Filter_cut = 80;
    	Filter_res = 30;
    	Filter_key = 50;
    	Filter_typ = 0;
    	dc1.amplitude(1.0);
    	dc2.amplitude(1.0);
    	dc3.amplitude(1.0);
    	dc4.amplitude(1.0);
    	dc5.amplitude(1.0);
    	dc6.amplitude(1.0);
    	// Mixer 1-6 (Filter) ------------------------------------------------
    	// Mixer AMP ---------------------------------------------------------
    	mixer20.gain(0, 0.85);	// Osc1
    	mixer20.gain(1, 0.85);	// Osc2
    	mixer20.gain(2, 0.85);	// Osc3
    	mixer20.gain(3, 0.85);	// Osc4
    	mixer21.gain(0, 0.85);	// Osc5
    	mixer21.gain(1, 0.85);	// Osc6
    	mixer21.gain(2, 0);		// --
    	mixer21.gain(3, 0);		// --
    	mixer22.gain(0, 0.85);	// Sum1
    	mixer22.gain(1, 0.85);	// Sum2
    	mixer22.gain(2, 0);		// --
    	mixer22.gain(3, 0);		// --
    	// Filter ------------------------------------------------------------
    	filter1.frequency(2000);
    	filter2.frequency(2000);
    	filter3.frequency(2000);
    	filter4.frequency(2000);
    	filter5.frequency(2000);
    	filter6.frequency(2000);
    	filter1.resonance(2.5);
    	filter2.resonance(2.5);
    	filter3.resonance(2.5);
    	filter4.resonance(2.5);
    	filter5.resonance(2.5);
    	filter6.resonance(2.5);
    	filter1.octaveControl(7.0);
    	filter2.octaveControl(7.0);
    	filter3.octaveControl(7.0);
    	filter4.octaveControl(7.0);
    	filter5.octaveControl(7.0);
    	filter6.octaveControl(7.0);
    	//init analog Inputs
    	pinMode(14, INPUT_DISABLE);
    	pinMode(16, INPUT_DISABLE);
    	pinMode(17, INPUT_DISABLE);
    	pinMode(22, INPUT_DISABLE);
    	//analogReadResolution(12);
    	//analogReadAveraging(16);
    	// init Encoder
    	//myEnc.begin(0, 0, 9); // will start at 20 and go from 0 to 40
    	// init Midi and clear Note_buffers
    	MIDI.begin(channel);
    	set_AllNotesOff();
    	// draw first menu site
    	for (uint8_t i = 0; i <= 5; i++)
    		read_pots();
    	Osc_menu();
    // Main loop
    	unsigned long currentMillis = millis();
    	// read Midi datas (every 1ms) --------------------------------------
    	if (currentMillis - previousTime_midi >= interval_midi){
    		midi_handel();
    		set_Voices_Lamp();
    		previousTime_midi = currentMillis;
    	// read ADC (every 15ms) --------------------------------------------
    	if (currentMillis - previousTime_ADC >= interval_ADC){
    		analog1.update();
    		analog2.update();
    		analog3.update();
    		analog4.update();
    		previousTime_ADC = currentMillis;
    	// read Encoder  and Potentiometers (every 25ms) --------------------
    	if (currentMillis - previousTime_pot >= interval_pot){
    		if(read_Encoder() == true){		// Encoder menu site
    			Menu_page = oldPosition;
    			if(Menu_page == Menu_Osc){
    				Osc_menu();
    			else if(Menu_page == Menu_AmpEnv){
    				AMP_envelope_menu();
    			else if(Menu_page == Menu_FilterEnv){
    				Filter_envelope_menu();
    			else if(Menu_page == Menu_Filter){
    				Filter_menu();
    		if (read_pots() == true){
    			if (Menu_page == Menu_Osc){
    				set_OSC_values();
    			else if (Menu_page == Menu_AmpEnv){
    				set_AMP_envelope();
    				draw_AMP_envLine();
    			else if (Menu_page == Menu_FilterEnv){
    			else if (Menu_page == Menu_Filter){
    	// Measurement CPU usage (every 200ms) ------------------------------
    	if (currentMillis - previousTime_cpu >= interval_cpu) {
    		print_CPU_usage();
    		previousTime_cpu = currentMillis;
    // seriell print ----------------------------------------------------------
    Greetings from germany
    Sep 2020
    241
    Hallo friends
    I optimized the potentiometer request in the ADC setup settings.
    This prevents the potentiometer values from jumping accidentally on the menu pages.
    Envelope menu
    //init ADC inputs fom Teensy in Setup function
    	analog1.setActivityThreshold(16);
    	analog2.setActivityThreshold(16);
    	analog3.setActivityThreshold(16);
    	analog4.setActivityThreshold(16);
    	analog1.enableEdgeSnap();
    	analog2.enableEdgeSnap();
    	analog3.enableEdgeSnap();
    	analog4.enableEdgeSnap();
    	if (analog1.hasChanged() == true){
    		pot_1 = ((analog1.getValue())>> 3);
    		pot_change = true;
    	if (analog2.hasChanged() == true){
    		pot_2 = ((analog2.getValue())>> 3);
    		pot_change = true;
    	if (analog3.hasChanged() == true){
    		pot_3 = ((analog3.getValue())>> 3);
    		pot_change = true;
    	if (analog4.hasChanged() == true){
    		pot_4 = ((analog4.getValue())>> 3);
    		pot_change = true;
    	pot_change = false;
    	return temp_flag;
    Greetings from germany. Rolf
    Jul 2020
    174
    That looks really good. I love bare-board stuff like this.
    Sep 2020
    241
    I love the small details, for example a small peak meter at the top.
    Sep 2020
    241
    Hello friends
    Today I implemented the key tracking for the filter. The digital multimode filter has one
    Control input with the designation octaveControl (). This can be used to control the filter corner frequency.
    The signal for the filter envelope and for key tracking is sent to this control input via a mixer
    connected (see SynthBlock). The filter cutoff frequency is set using the frequency () parameter
    and the resonance via the parameter resonance ().
    Filter description
    SynthBlock
    Big pic: https://i.ibb.co/pP9N6Ts/Shruthi2-Synth-Block.jpg
    Greetings Rolf
    Sep 2020
    241
    Hallo
    Here my Audio designe code
    AudioSynthWaveformDc     dc2;            //xy=297,292
    AudioSynthWaveformDc     dc1;            //xy=299,157
    AudioSynthWaveformDc     dc6;            //xy=298,900
    AudioSynthWaveformDc     dc3;            //xy=300,428
    AudioSynthWaveformDc     dc4;            //xy=300,564
    AudioSynthWaveformDc     dc5;            //xy=300,757
    AudioSynthWaveform       waveform2;      //xy=305,252
    AudioSynthWaveform       waveform1;      //xy=307,116
    AudioSynthWaveform       waveform6;      //xy=307,855
    AudioSynthWaveform       waveform4;      //xy=309,521
    AudioSynthWaveform       waveform3;      //xy=310,387
    AudioSynthWaveform       waveform5;      //xy=310,714
    AudioSynthWaveformDc     KeyTrak3;            //xy=438,469
    AudioSynthWaveformDc     KeyTrak4;           //xy=440,607
    AudioSynthWaveformDc     KeyTrak6;           //xy=439,946
    AudioSynthWaveformDc     KeyTrak2;            //xy=443,335
    AudioSynthWaveformDc     KeyTrak5;           //xy=442,803
    AudioSynthWaveformDc     KeyTrak1;            //xy=454,198
    AudioEffectEnvelope      envelope3_1;    //xy=454,428
    AudioEffectEnvelope      envelope2_1;    //xy=457,292
    AudioEffectEnvelope      envelope4_1;    //xy=456,564
    AudioEffectEnvelope      envelope5_1;    //xy=456,757
    AudioEffectEnvelope      envelope6_1;    //xy=459,900
    AudioEffectEnvelope      envelope1_1;    //xy=465,157
    AudioMixer4              mixEnvKey6;        //xy=631,919
    AudioMixer4              mixEnvKey4;        //xy=633,583
    AudioMixer4              mixEnvKey5;        //xy=633,777
    AudioMixer4              mixEnvKey3;         //xy=638,447
    AudioMixer4              mixEnvKey1;         //xy=641,177
    AudioMixer4              mixEnvKey2;         //xy=641,311
    AudioFilterStateVariable filter2;        //xy=806,258
    AudioFilterStateVariable filter1;        //xy=809,120
    AudioFilterStateVariable filter3;        //xy=809,394
    AudioFilterStateVariable filter4;        //xy=809,528
    AudioFilterStateVariable filter6;        //xy=812,863
    AudioFilterStateVariable filter5;        //xy=814,720
    AudioMixer4              mixer2;         //xy=1019,264
    AudioMixer4              mixer1;         //xy=1022,126
    AudioMixer4              mixer3;         //xy=1027,400
    AudioMixer4              mixer6;         //xy=1028,869
    AudioMixer4              mixer4;         //xy=1031,534
    AudioMixer4              mixer5;         //xy=1034,726
    AudioEffectEnvelope      envelope1_0;    //xy=1187,125
    AudioEffectEnvelope      envelope2_0;    //xy=1192,264
    AudioEffectEnvelope      envelope3_0;    //xy=1201,400
    AudioEffectEnvelope      envelope4_0;    //xy=1206,534
    AudioEffectEnvelope      envelope6_0;    //xy=1209,868
    AudioEffectEnvelope      envelope5_0;    //xy=1211,726
    AudioMixer4              mixer20;        //xy=1449,514
    AudioMixer4              mixer21;        //xy=1454,745
    AudioMixer4              mixer22;        //xy=1646,751
    AudioOutputI2S           i2s1;           //xy=1831,749
    AudioAnalyzePeak         peak1;          //xy=1831,798
    AudioConnection          patchCord1(dc2, envelope2_1);
    AudioConnection          patchCord2(dc1, envelope1_1);
    AudioConnection          patchCord3(dc6, envelope6_1);
    AudioConnection          patchCord5(dc4, envelope4_1);
    AudioConnection          patchCord6(dc5, envelope5_1);
    AudioConnection          patchCord7(waveform2, 0, filter2, 0);
    AudioConnection          patchCord8(waveform1, 0, filter1, 0);
    AudioConnection          patchCord9(waveform6, 0, filter6, 0);
    AudioConnection          patchCord10(waveform4, 0, filter4, 0);
    AudioConnection          patchCord11(waveform3, 0, filter3, 0);
    AudioConnection          patchCord12(waveform5, 0, filter5, 0);
    AudioConnection          patchCord13(KeyTrak3, 0, mixEnvKey3, 1);
    AudioConnection          patchCord14(KeyTrak4, 0, mixEnvKey4, 1);
    AudioConnection          patchCord15(KeyTrak6, 0, mixEnvKey6, 1);
    AudioConnection          patchCord16(KeyTrak2, 0, mixEnvKey2, 1);
    AudioConnection          patchCord17(KeyTrak5, 0, mixEnvKey5, 1);
    AudioConnection          patchCord18(KeyTrak1, 0, mixEnvKey1, 1);
    AudioConnection          patchCord19(envelope3_1, 0, mixEnvKey3, 0);
    AudioConnection          patchCord20(envelope2_1, 0, mixEnvKey2, 0);
    AudioConnection          patchCord21(envelope4_1, 0, mixEnvKey4, 0);
    AudioConnection          patchCord22(envelope5_1, 0, mixEnvKey5, 0);
    AudioConnection          patchCord23(envelope6_1, 0, mixEnvKey6, 0);
    AudioConnection          patchCord24(envelope1_1, 0, mixEnvKey1, 0);
    AudioConnection          patchCord25(mixEnvKey6, 0, filter6, 1);
    AudioConnection          patchCord26(mixEnvKey4, 0, filter4, 1);
    AudioConnection          patchCord27(mixEnvKey5, 0, filter5, 1);
    AudioConnection          patchCord28(mixEnvKey3, 0, filter3, 1);
    AudioConnection          patchCord29(mixEnvKey1, 0, filter1, 1);
    AudioConnection          patchCord30(mixEnvKey2, 0, filter2, 1);
    AudioConnection          patchCord37(filter3, 0, mixer3, 0);
    AudioConnection          patchCord38(filter3, 1, mixer3, 1);
    AudioConnection          patchCord39(filter3, 2, mixer3, 2);
    AudioConnection          patchCord40(filter4, 0, mixer4, 0);
    AudioConnection          patchCord41(filter4, 1, mixer4, 1);
    AudioConnection          patchCord42(filter4, 2, mixer4, 2);
    AudioConnection          patchCord43(filter6, 0, mixer6, 0);
    AudioConnection          patchCord44(filter6, 1, mixer6, 1);
    AudioConnection          patchCord45(filter6, 2, mixer6, 2);
    AudioConnection          patchCord46(filter5, 0, mixer5, 0);
    AudioConnection          patchCord47(filter5, 1, mixer5, 1);
    AudioConnection          patchCord48(filter5, 2, mixer5, 2);
    AudioConnection          patchCord49(mixer2, envelope2_0);
    AudioConnection          patchCord50(mixer1, envelope1_0);
    AudioConnection          patchCord51(mixer3, envelope3_0);
    AudioConnection          patchCord52(mixer6, envelope6_0);
    AudioConnection          patchCord53(mixer4, envelope4_0);
    AudioConnection          patchCord54(mixer5, envelope5_0);
    AudioConnection          patchCord55(envelope1_0, 0, mixer20, 0);
    AudioConnection          patchCord56(envelope2_0, 0, mixer20, 1);
    AudioConnection          patchCord57(envelope3_0, 0, mixer20, 2);
    AudioConnection          patchCord58(envelope4_0, 0, mixer20, 3);
    AudioConnection          patchCord59(envelope6_0, 0, mixer21, 1);
    AudioConnection          patchCord60(envelope5_0, 0, mixer21, 0);
    AudioConnection          patchCord61(mixer20, 0, mixer22, 0);
    AudioConnection          patchCord62(mixer21, 0, mixer22, 1);
    AudioConnection          patchCord63(mixer22, 0, i2s1, 0);
    AudioConnection          patchCord64(mixer22, 0, i2s1, 1);
    AudioConnection          patchCord65(mixer22, peak1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=1828,698
    Now I'm working on the wave oscillators and modulation.
    Greetings Rolf
    Sep 2020
    241
    Hallo friends
    I have a little problem with the resonance in the filter. I use an A State Variable (Chamberlin) filter with 12 dB / octave.
    When I set the resonance to maximum level, the filter does not oscillate. I increased the Q value in the filter function from 5 to 15 but it doesn't oscillate.
    Where is the problem
    #ifndef filter_variable_h_
    #define filter_variable_h_
    #include "Arduino.h"
    #include "AudioStream.h"
    class AudioFilterStateVariable: public AudioStream
    public:
    	AudioFilterStateVariable() : AudioStream(2, inputQueueArray) {
    		frequency(1000);
    		octaveControl(1.0); // default values
    		resonance(0.707);
    		state_inputprev = 0;
    		state_lowpass = 0;
    		state_bandpass = 0;
    	void frequency(float freq) {
    		if (freq < 20.0) freq = 20.0;
    		else if (freq > AUDIO_SAMPLE_RATE_EXACT/2.5) freq = AUDIO_SAMPLE_RATE_EXACT/2.5;
    		setting_fcenter = (freq * (3.141592654/(AUDIO_SAMPLE_RATE_EXACT*2.0)))
    			* 2147483647.0;
    		// TODO: should we use an approximation when freq is not a const,
    		// so the sinf() function isn't linked?
    		setting_fmult = sinf(freq * (3.141592654/(AUDIO_SAMPLE_RATE_EXACT*2.0)))
    			* 2147483647.0;
    	void resonance(float q) {
    		if (q < 0.7) q = 0.7;
    		else if (q > 15.0) q = 15;
    		// TODO: allow lower Q when frequency is lower
    		setting_damp = (1.0 / q) * 1073741824.0;
    	void octaveControl(float n) {
    		// filter's corner frequency is Fcenter * 2^(control * N)
    		// where "control" ranges from -1.0 to +1.0
    		// and "N" allows the frequency to change from 0 to 7 octaves
    		if (n < 0.0) n = 0.0;
    		else if (n > 6.9999) n = 6.9999;
    		setting_octavemult = n * 4096.0;
    	virtual void update(void);
    private:
    	void update_fixed(const int16_t *in,
    		int16_t *lp, int16_t *bp, int16_t *hp);
    	void update_variable(const int16_t *in, const int16_t *ctl,
    	int32_t setting_fcenter;
    	int32_t setting_fmult;
    	int32_t setting_octavemult;
    	int32_t setting_damp;
    	int32_t state_inputprev;
    	int32_t state_lowpass;
    	int32_t state_bandpass;
    	audio_block_t *inputQueueArray[2];
    Thanks for help. Greeting from germany. Rolf
    Sep 2020
    241
    OK. It was my fault. It was the wrong filter_variable.h file in the Arduino Lib folder.
    Oct 2020
    8
    Cant wait to see the result and built one for myself!
    Sep 2020
    241
    It will take a little longer. I am currently developing the oscillator page.
    This is my current synth block.
    Greetings Rolf
    Senior Member fdaniels's Avatar
    Oct 2020
    Ostwestfalen, Germany
    117
    Moin Rolf,
    are you considerung using a PT8211?
    Sep 2020
    241
    No. I have tested the PT8211. The SGTL5000 makes a better sound and has Filter and bass boost built-in.
    Oct 2020
    117
    Would you mind borrowing your PT8211 for evaluation purposes ?
    Sep 2020
    241
    No. I have 2 pieces with a breadboard.
  24. #24
    Sep 2020
    241
    First test with 8 Voices.
    The oscilloscope function is not yet perfect and is still being changed.
    It is probably due to the framebuffer for the display.
    Video: https://youtu.be/hQjbzxM8q1A
  25. #25
    Apr 2019
    175
    Hello. Very nice presets. It would be great if you made the code open source, so I can take the oscilloscope code, if and when you improve it. Presets #24 and #58 were designed to be held, by the way, not played staccato.
Tags for this Thread
