Page 8 of 8 FirstFirst ... 6 7 8
Results 176 to 199 of 199
Thread: New Teensy 4.1 DIY Synthesizer
  1. #176
    geiler typ! sequencer looks great in the video!
  2. #177
    Senior Member Rolfdegen's Avatar
    Sep 2020
    227
    Danke. Ich strenge mich an. Thank you. I will give my best
  3. #178
    Sep 2020
    227
    Hi friends..
    We're almost there. My friend Andre now orders the new circuit board and if it works he will order the housing and components for a pilot series.
    For my part, I'm still writing around the operating instructions and programming a few "weird" demo sounds. I'm curious..
  4. #179
    Sep 2020
    227
    Hello there..
    After minor technical difficulties, we are now in the final phase of our development.
    We still had some problems with the FV-1 DSP chip for the effects. But we were able to solve that.
    The procurement of components is still a minor problem. We try it through Chinese distributors.
    The housing construction is ready and will be ordered in the next few weeks. It becomes a transparent one
    and colored housing with support feet (similar to the one in the picture).
    More informatin here: https://www.tubeohm.com/new-developement.html
    I can already reveal a few technical details about the Jeannie ..
    • 8 voices polyphoner DIY Synthesizer
    • ARM Cortex-M7 Prozessor 816MHz mit 1MByte Ram
    • 2 digitale Oszillatoren per voice with PWM controll for Variable Pulse and Variable Triangle Waveform
    • 1 PWM LFO
    • Pitch Envelope für beide Osczillatoren
    • 2 LFOs für Pitch und Filter
    • Osc FX (XOR, XMOD, MOD, AND, OR, FM) with OSC-Mix function
    • 12 Standard Wellenformen (zum Teil bandlimitiert)
    • 500 User Wellenformen
    • Noise Generator (White or Pink)
    • Digitaler 12dB Multimode Filter mit Resonanz und Überblendfunktion (LP/HP/BP)
    • 2 ADSR Envelopes max 12sec für Amplifier und Filter mit positiver und negativer Steuerung
    • Waveshaper mit verschiedenen Kurvenformen
    • Unisono Modes
    • 15 DSP Effekte mit einstellbaren Parametern
    • Farbiges TFT Display mit 128x160 Pixel
    • 16 Step Sequencer
    • SD Karte fürs laden und speichern der Sound Programme max 2048
    • Externer Netzteilanschluss 12 VDC/1A und Netzschalter
      und einiges mehr..
    Sound Demo: https://drive.google.com/file/d/15U35TvE...iew?usp=sharing
    Gruß Rolf
  5. #180
    9,403
    816 MHz.. how hot is it, when inside the houseing? Is there a ventilation?
  6. #181
    Sep 2020
    227
    We tested it with a heat sink on the CPU. The temperatures in the case are below 60 degrees.
  7. #182
    9,403
    In summer, too? (well, a real summer, not this summer here in Germany) Teensy reboots or switches off if the die temperature is too high (but you can set the "panic" temp higher)
    A very very nice project.
  8. #183
    Sep 2020
    227
    I test the temperatures. At 74 degrees the CPU does a reset.
  9. #184
    9,403
    The die temperature is about 90°C, then.
  10. #185
    Sep 2020
    227
  11. #186
    Sep 2020
    227
    Do the same again on Youtube if it doesn't work on Soundcoud. Everyone has.
    In the future I will only upload the sound to Youtube. I am not aware of any other free,
    unlimited and free platform for music.
    https://youtu.be/UMu46sERF3A
    Regards from West germany
  12. #187
    Sep 2020
    227
    Hello dear Synthians
    The new Jeannie Panel Board has arrived from China. Andre has now soldering the board and
    tested. It all works wonderfully. The DIY manual is also almost ready. Now that's all that's missing
    Housing and then we're done.
    Greetings Rolf
  13. #188
    Member DIYLAB's Avatar
    Jun 2020
    64
    Hi Rolf,
    i have no idea about synthesizers, but your GUI is beautiful, i appreciate every pixel ;o)
    Best
    Bruno
  14. #189
    Sep 2020
    227
    Thank you. :Ö
  15. #190
    Sep 2015
    Mechelen, Belgium
    38
    Hello Rolf,
    in #187 you show a picture which says FXDSP Phaser.
    In Green it says DEEPTH, should this not be DEPTH
    Regards, Otto
  16. #191
    Sep 2020
    227
    Thanks for your tip. Of course you are right. It has to be called depth
  17. #192
    Sep 2015
    Mechelen, Belgium
    38
    happy to help.
    Regards, Otto
  18. #193
    Sep 2020
    227
    The backside from Jeannie with the assembled boards.
    Now the case is made and then we're done. The assembly instructions can be downloaded from tubeohm.com. Sales will start soon.
    New Sound Demo: https://youtu.be/MubIuBQYDOw
  19. #194
    Sep 2020
    227
    The case is now ordered. I'm curious..
  20. #195
    Sep 2020
    227
    I changed the filter page a bit. Instead of "AMT" I have "ENV" as
    Parameter designation selected. The red marker for CUT is now also available.
    FilterMix LP / HP (LP red / HP yellow)
    A filter submenu can be reached using the Shift key. Then you can
    Set the filter velocity, key tracking and LFO modulation strength.
    Software changes in the sequencer
    The sequencer record function now records velocity values when playing the notes on the keyboard.
    The volume of the notes corresponds to a color. The lighter the color, the louder the note.
    A poly-mode sequencer is also planned. After all, we have an 8-voice synthesizer.
    A maximum of 4 notes are saved in one step at the same time.
    Greetings Rolf
  21. #196
    Sep 2020
    227
    Hello Paul
    I have a problems with the releaseNoteOn function (5ms) in my polyphonic DIY Synth.
    If the releaseNoteOn phase were the new note will be played (see picture).
    I'm using Teensy 4.1 and the latest Audio Lib. Release Phase is 4.4sec long.
    Play 8 voices is good and Click the 9th note and the following
    Envelope curve
    1. Voices block
    Thanks for help
  22. #197
    Sep 2020
    227
    Hallo everybody
    The new colored cases have arrived. We have three colors: black, blue and yellow.
  23. #198
    Sep 2020
    227
    Small video about the polyphonic sequencer ..
    The sequencer now has a mode function.
    In mode: REC, notes are received from a connected midi keyboard.
    The pitch of the notes can then be edited with pitch or muted with mute.
    In mode: TRP, the sequencer notes can be transposed using a midi keyboard.
    In mode: KEY you can play additional notes via a midi keyboard.
    Youtube: https://youtu.be/-MgLeGGeYow
  24. #199
    Sep 2020
    227
    Hello there..
    My Jeannie has finally found a nice home
    Kits, components and assembly instructions are now available at tubeohm.com.
    Greetings Rolf
Tags for this Thread
