Results 1 to 5 of 5
Thread: Solution for adding support for pre-compiled Libraries
    Senior Member Blackaddr's Avatar
    Mar 2017
    Canada
    270
    Anyone know which of Paul's repos on Github is for the Teensyduino files with regards to the following file. I can't seem to find which one it is and I'd like to make a pull request to get support for precompiled libraries working.
    hardware/teensy/avr/platform.txt
    Arduino IDE added support for precompiled libraries, it was discussed here previously, but there is an easier solution (see below):
    https://forum.pjrc.com/threads/50172...mpiled-library
    I really need to use precompiled libraries for a project so I looked into this, it's actually pretty easy to solve now. I used this very helpful link as a reference:
    https://forum.arduino.cc/index.php?topic=653746.0
    TL;DR
    The following changes must be made to the platform.txt file:
    1) Insert {compiler.libraries.ldflags} in the correct loocation to the recipe.c.combine.pattern, after the {object_files}
    ## Link
    recipe.c.combine.pattern="{compiler.path}{build.toolchain}{build.command.linker}" {build.flags.optimize} {build.flags.ld} {build.flags.ldspecs} {build.flags.cpu} -o "{build.path}/{build.project_name}.elf" {object_files} {compiler.libraries.ldflags} "{build.path}/{archive_file}" "-L{build.path}" {build.flags.libs}
    2) Add 'compiler.libraries.ldflags=' to the platform.txt file, I threw it at the end
    That's it for changes to Teensyduino.
    3) To build your library, you must add the following option to your library.properties file in order to have the compiler output the static library .a file.
    dot_a_linkage=true
    4) Compile the library and go grab the YourLibrary.a file from /tmp/<build otuput>
    5) Package up (zip) your library as follows:
    MyLibrary/library.properties
    MyLibrary/src/<arch>/libYourLibrary.a
    MyLibrary/src/<public header files only>
    5a) remove the dot_a_linkage in your packaged version and replace with the following two lines:
    precompiled=true
    ldflags=-lMyLibrary
    5b) figure our the arch you targeting. For example for Teensy 4.X, its 'imxrt1062'. You need to separately compile and package for each architecture you are targeting.
    5c) notice we have to rename YourLibrary.a to libYourLibrary.a in the package.
    You can do these steps yourself in the meantime. If I can get a pull request to update the platform.txt file in Teensyduino, Steps 1 & 2 would already be done.
    12,340
    Paul deals with platform & boards files behind the scenes AFAIK
    Mar 2017
    Canada
    270
    Thanks, I'll try reaching out to Paul directly then.
    22,649
    Indeed those files aren't on github.
    Mar 2017
    Canada
    270
    Any chance of getting that small addition to the platform.txt file? Similar changes have been made on other Arduino compatible boards to support the precompiled library feature.
