Results 1 to 19 of 19
Thread: Encoders jumping positive
    Jul 2020
    3
    I've got a board with four rotary encoders on it. Two of them work well, but the other two would occasionally jump positive by counts of ~8-16 while being turned in the negative/CCW direction, with the result that progress could not be made turning them CCW. This occurred no matter how fast or slow I turned the encoders.
    Delving into the Encoder library code, I saw that transitions 3, 6, 9, and 12, normally considered invalid, were being counted as +/- 2. I commented out those counts and the problem cleared up entirely.
    I'm guessing that (a) my un-debounced hardware is occasionally presenting invalid data, and (b) the +/- 2 counts are there to support fast-moving encoders that the Teensy isn't quite able to keep up with.
    I almost reported this as an issue on the github repo but accepted the issue form's strong encouragement to come here.
    This seems like a borderline bug. The +/- 2 counts clearly have value to some use cases, but they can ruin the functionality of the library in a basic use case. One solution would be to make the +/- 2 count an optional feature that has to be explicitly enabled. Another helpful feature would be to show a typical debouncing schematic on the Encoder page -- the protoboard photos show the necessary resistors and caps, but they aren't explained.
    In any case, I have a workaround for the moment and will add hardware debounce in my next rev.
    Germany
    1,136
    Any chance I can talk you into testing my encoder library https://github.com/luni64/EncoderTool/wiki?
    • It uses dedicated state machines for encoders with mechanical detents (at 2 or 4 quadrature "edges") which makes it absolutely bounce free without additional hardware.
    • If you need to count every edge, (e.g. for high res encoders without detents) it guarantees that you'll end up with the right count after bouncing. During the bouncing period it can not prevent rapid up/down counts. In this mode it has exactly the same behaviour as the stock encoder library.
    • You can use it in interrupt mode or in polling mode (which often is more than sufficient for mechanical encoders)
    I was looking for really bad encoders to test its debouncing capabilities but didn't find any. So I would be highly interested if it is able to tame your encoders :-)
    Quick start guide: https://github.com/luni64/EncoderToo...ck-start-guide
    Jul 2020
    3
    No promises, but if I get some time to play with it I'll report back.
    Jul 2020
    398
    When I write quadrature encoder code I use the invalid transitions to increment an error count, not
    the position count. Then you can programmatically check for errors if you suspect you are not
    sampling the encoder often enough.
    Oct 2020
    Ostwestfalen, Germany
    10
    @luni - any chances your EncoderTool willl be available for TeensyLC? I have severe bouncing Problems over here..... many thanks in advance independent if you will make it available or not ;-)
    Germany
    1,136
    Sure, I'm currently traveling but I can have a look later this week. I'm not aware of anything not compatible to T-LC. Which error message did you get?
    Oct 2020
    10
    Im using this Code from your WIKI as i have my Encoder on 4,5
    using namespace EncoderTool;
    Encoder encoder;
    #include "EncoderTool.h"
    Encoder encoder;
        pinMode(LED_BUILTIN, OUTPUT);
        encoder.begin(4, 5);
    elapsedMillis stopwatch;
        if (stopwatch > 50)
            Serial.println(encoder.getValue() );
            stopwatch = 0;
    And the compiler stops with this:
    Arduino: 1.8.13 (Windows 10), TD: 1.53, Board: "Teensy LC, Keyboard, 48 MHz, Smallest Code, US International"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\danie\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=keyboard,speed=48,opt =osstd,keys=usint -ide-version=10813 -build-path C:\Users\danie\AppData\Local\Temp\arduino_build_73 180 -warnings=none -build-cache C:\Users\danie\AppData\Local\Temp\arduino_cache_97 0610 -verbose C:\Users\danie\Desktop\EncoderToolTest\EncoderTool Test.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\danie\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=keyboard,speed=48,opt =osstd,keys=usint -ide-version=10813 -build-path C:\Users\danie\AppData\Local\Temp\arduino_build_73 180 -warnings=none -build-cache C:\Users\danie\AppData\Local\Temp\arduino_cache_97 0610 -verbose C:\Users\danie\Desktop\EncoderToolTest\EncoderTool Test.ino
    Using board 'teensyLC' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_INTERNATIONAL "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\sketch\\EncoderToolTest.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    Alternatives for EncoderTool.h: [EncoderTool-2.0.0@2.0.0]
    ResolveLibrary(EncoderTool.h)
    -> candidates: [EncoderTool-2.0.0@2.0.0]
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_INTERNATIONAL "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Users\\danie\\Documents\\Arduino\\libraries\\ EncoderTool-2.0.0\\src" "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\sketch\\EncoderToolTest.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    Using cached library dependencies for file: C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.0.0\src\EncPlexBase.cpp
    Using cached library dependencies for file: C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.0.0\src\EncoderBase.cpp
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_INTERNATIONAL "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Users\\danie\\Documents\\Arduino\\libraries\\ EncoderTool-2.0.0\\src" "C:\\Users\\danie\\Documents\\Arduino\\libraries\\ EncoderTool-2.0.0\\src\\Single\\attachInterruptEx.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    Generating function prototypes...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_INTERNATIONAL "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Users\\danie\\Documents\\Arduino\\libraries\\ EncoderTool-2.0.0\\src" "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\sketch\\EncoderToolTest.ino.cpp" -o "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\preproc\\ctags_target_for_gcc_minus_e. cpp" -DARDUINO_LIB_DISCOVERY_PHASE
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\preproc\\ctags_target_for_gcc_minus_e. cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_INTERNATIONAL "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180/pch/Arduino.h" -o "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180/pch/Arduino.h.gch"
    Using previously compiled file: C:\Users\danie\AppData\Local\Temp\arduino_build_73 180\pch\Arduino.h.gch
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_INTERNATIONAL "-IC:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Users\\danie\\Documents\\Arduino\\libraries\\ EncoderTool-2.0.0\\src" "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\sketch\\EncoderToolTest.ino.cpp" -o "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\sketch\\EncoderToolTest.ino.cpp.o"
    Compiling libraries...
    Compiling library "EncoderTool-2.0.0"
    Using previously compiled file: C:\Users\danie\AppData\Local\Temp\arduino_build_73 180\libraries\EncoderTool-2.0.0\EncPlexBase.cpp.o
    Using previously compiled file: C:\Users\danie\AppData\Local\Temp\arduino_build_73 180\libraries\EncoderTool-2.0.0\EncoderBase.cpp.o
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_INTERNATIONAL "-IC:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Users\\danie\\Documents\\Arduino\\libraries\\ EncoderTool-2.0.0\\src" "C:\\Users\\danie\\Documents\\Arduino\\libraries\\ EncoderTool-2.0.0\\src\\Single\\attachInterruptEx.cpp" -o "C:\\Users\\danie\\AppData\\Local\\Temp\\arduino_b uild_73180\\libraries\\EncoderTool-2.0.0\\Single\\attachInterruptEx.cpp.o"
    C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.0.0\src\Single\attachInterruptEx.cpp:41:5: error: too many initializers for 'void (* const [24])()'
    Using library EncoderTool-2.0.0 at version 2.0.0 in folder: C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.0.0
    Error compiling for board Teensy LC.
    Hope this helps as i have no clue what it means....
    Germany
    1,136
    Ok, I see what's wrong and it is probably already fixed in the current code. If you used the current release (v2.0) can you please replace it by the current version from master and give that a try?
    Germany
    1,136
    I just saw that I already prepared a new release a couple of weeks ago...just released it. You can try if v2.1.0 fixes the issue
    Oct 2020
    10
    luni, thanks for the superfast response. Ill give it a try tomorrow an come back to you asap. Many thanks!!
    Germany
    1,136
    @fdaniels: Can you give v2.2.1 a try? https://github.com/luni64/EncoderTool/releases
    New features:
    • Compatibility to T-LC
    • Reduced memory footprint
    Bugfixes:
    • Selecting plain vanilla void(*)(...) callbacks works now and is recommended for memory challenged boards.
    In case your T-LC project is memory limited you can save a few bytes by configuring the library to use plain vanilla void(*)(...) callbacks instead of the default std::function<> type callbacks (see comment in config.h).
    Oct 2020
    10
    Dear luni,
    I removed the old library and tried the new one, sadly with no success. Trying to compile the Code above i now get:
    In file included from C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.2.1\src/EncoderBase.h:2:0,
    from C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.2.1\src/Multiplexed/EncPlexBase.h:4,
    from C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.2.1\src/Multiplexed/EncPlex74165.h:5,
    from C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.2.1\src/EncoderTool.h:3,
    from C:\Users\danie\Desktop\sketch_oct06a\sketch_oct06a .ino:1:
    C:\Users\danie\Documents\Arduino\libraries\Encoder Tool-2.2.1\src/EncoderButton.h:19:14: error: 'bool EncoderTool::EncoderButton::readCurrentState()' marked 'override', but does not override
    bool readCurrentState() override { return curState; }
    As you are in Germany (at least according to your Profile) id like to offer sending you a LC, if you have none at hand. Just let me know.
    EDIT: i changed the Pins to 14,15 as these are the ones used in my Project.
    Germany
    1,136
    The error you now get is due to an old version of Bounce2 which is required to debounce the pushbutton. Unfortunately the one which comes with Teensyduino is a bit outdated.
    Since you are not the first stumbling about it, I added a corresponding comment the documentation. I try to remove the dependency in a later version.
    Fixing the issue is simple: just replace Bounce2 with a current version from here: https://github.com/thomasfredericks/Bounce2.
    Oct 2020
    10
    luni, thanks for your help and superfast response!
    I replaced Bounce2 with the newest Version and now it compiles flawless.
    Sadly, it skips Clicks, im using this Code:
        Encoder encoder;                     // single, directly connected encoder
        int encValue=0;
        int encOldValue=0;
       //pinMode(14, INPUT_PULLUP);
       //   pinMode(16, INPUT_PULLUP);
        encoder.begin(14,16);              // A=0, B=1
    elapsedMillis stopwatch = 0;
        encValue = encoder.getValue(); // get current value
        if (encValue != encOldValue){
          Serial.println(encValue);
          encOldValue = encValue;
    Turning the Encoder slowly it takes 1 - 6 Clicks in either direction to change the Value, i tried 2 different Encoders (of this Type: https://www.reichelt.de/drehimpulseg...ct=pos_2&nbc=1), tried using external 100K Pullups, tried CountMode::half, CountMode::quarter, CountMode::quarterInv.
    Any Ideas?
    Germany
    1,136
    Can you post a picture / sketch which shows how you connected the encoders?
    Oct 2020
    10
    I tried changing the Pins to 14,15 and now it works flawless. I hate things like these....
    Germany
    1,136
    Just had a look at the pinout. Pin 16 doesn't have interrupt capability on the LC. 14, 15 have. So, this makes sense.
    Oct 2020
    10
    Mea Culpa, i missed this.... many thanks again for your help!
    Germany
    1,136
    No problem at all. Let me know if you stumble over anything else or miss some functionality.
