Results 1 to 7 of 7
Thread: Teensy 4.1 using Ethernet Kit - conflict with LEDs (FastLED)
    Sep 2020
    9
    I have a Teensy 4.1 and Ethernet Kit that I purchased from pjrc.com. I am using the nativeEthernet.h library. I have a complex program that I am running with multiple LED Stips and Sensors. Everything works great until I uncomment ethernetSetup();. I get an IP address and the main loop begins as it should but the LEDs won't turn "ON" on any of the strips. I have used Serial.print statements to debug and everything is working correctly. Is there something that I should know about this? My code is 500+ lines and would be too much to include here. I'm hoping that someone has an easy fix. Also, are there any pins that are used by the Ethernet Kit that should not be used in my program?
    Sep 2020
    9
    I have tried moving the code around and trying previous versions of the libraries with no success. I changed the code that turns on the LEDs in hope that it was the fill_solid function, but there was no effect. I am also using pubSubClient.h to communicate with a MQTT Server, which is commented out right now also. My project is about finished except for this huge problem.
    Sep 2020
    9
    In my attempt to troubleshoot, I changed to the Ethernet.h library. The leds work as they should, but the IP address, gateway, etc won't apply. I get 0.0.0.0. for all of them. I'm using Static addresses.
    22,762
    Quote Originally Posted by alskyline View Post
    Which ethernet hardware are you using? Ethernet.h is for the Wiznet-based boards. For the ethernet hardware on Teensy 4.1 you need NativeEthernet.h.
    Sep 2020
    9
    I'm using your Ethernet Kit from pjrc.com. I am using the NativeEthernet.h.
    Sep 2020
    9
    I have attached the code here. There are two tabs:
    /* New Pillar Sketch to work with Teensy 4.1
    #include <FastLED.h>
    #include <NativeEthernet.h>
    #include <PubSubClient.h>
    #define PILLAR                    3
    // Teensy 4.0 Stuff ================
    #define LEDS_PER_SIDE             72
    #define LEDS_IN_BOWL              32
    #define NUMBER_OF_SIDES           4
    #define NUMBER_OF_SETS_PER_SIDE   3
    #define COLOR_ORDER               GRB
    #define CHIPSET                   WS2811
    #define FRAMES_PER_SECOND         60
    #define BRIGHTNESS                255
    CRGB bowl_leds[LEDS_IN_BOWL];
    CRGB leds[NUMBER_OF_SIDES][LEDS_PER_SIDE];
    //struct CRGB * ledarray[NUMBER_OF_SIDES][NUMBER_OF_SETS_PER_SIDE] = {{ledsHigh,ledsMid,ledsLow},{ledsHigh,ledsMid,ledsLow},{ledsHigh,ledsMid,ledsLow},{ledsHigh,ledsMid,ledsLow}};
    #define NUMBER_OF_PANELS          3
    #define LEDS_PER_PANEL            20
    #define NUMBER_OF_BURNS           4
    #define BOWL_HEIGHT               0
    #define BURN_OFFSET               3   // Add this to make fire sim look better when burning at the bottom
    #define GLOW_FADE_IN_RATE         2
    #define GLOW_FADE_OUT_RATE        5
    #define LOW_PANEL_HEIGHT          0
    #define MID_PANEL_HEIGHT          26
    #define HIGH_PANEL_HEIGHT         52
    #define LED_STRIP_SIDE_A_PIN      19  // Data for side A LED strip
    #define LED_STRIP_SIDE_B_PIN      18  // Data for side B LED strip
    #define LED_STRIP_SIDE_C_PIN      14  // Data for side C LED strip
    #define LED_STRIP_SIDE_D_PIN      15  // Data for side D LED strip
    #define LED_STRIP_BOWL_PIN        17 // Data for bowl LED strip
    //Soundboard Pins
    #define SOUND_RESET_PIN           6  // Assert reset on Adafruit SFX board
    #define SOUND_RX_PIN              7  // Rx for Serial2 from Adafruit SFX board
    #define SOUND_TX_PIN              8  // Tx for Serial2 to Adafruit SFX board
    #define SOUND_ACT_PIN             9  // Check for sound activation on Adafruit SFX board
    //Sensor Pins
    #define SENSOR_A1_PIN             10 // Sensor for panel 1 (top) on side A
    #define SENSOR_A2_PIN             11 // Sensor for panel 2 (middle) on side A
    #define SENSOR_A3_PIN             12 // Sensor for panel 3 (bottom) on side A
    #define SENSOR_B1_PIN             4 // Sensor for panel 1 (top) on side B
    #define SENSOR_B2_PIN             5 // Sensor for panel 2 (middle) on side B
    #define SENSOR_B3_PIN             16 // Sensor for panel 3 (bottom) on side B
    #define SENSOR_C1_PIN             23 // Sensor for panel 1 (top) on side C
    #define SENSOR_C2_PIN             3 // Sensor for panel 2 (middle) on side C
    #define SENSOR_C3_PIN             2 // Sensor for panel 3 (bottom) on side C
    #define SENSOR_D1_PIN             20 // Sensor for panel 1 (top) on side D
    #define SENSOR_D2_PIN             21 // Sensor for panel 2 (middle) on side D
    #define SENSOR_D3_PIN             22 // Sensor for panel 3 (bottom) on side D
    typedef uint8_t puzzleState_t;
    int handsBrightness = 0;
    enum
      IGNITE_LOW_A_SOUND_INDEX,
      IGNITE_LOW_B_SOUND_INDEX,
      IGNITE_LOW_C_SOUND_INDEX,
      IGNITE_LOW_D_SOUND_INDEX,
      IGNITE_MID_A_SOUND_INDEX,
      IGNITE_MID_B_SOUND_INDEX,
      IGNITE_MID_C_SOUND_INDEX,
      IGNITE_MID_D_SOUND_INDEX,
      IGNITE_HIGH_A_SOUND_INDEX,
      IGNITE_HIGH_B_SOUND_INDEX,
      IGNITE_HIGH_C_SOUND_INDEX,
      IGNITE_HIGH_D_SOUND_INDEX,
      IGNITE_BOWL_SOUND_INDEX,
      IGNITE_ALL_SOUND_INDEX,
      NUMBER_OF_IGNITE_SOUNDS,
      BURNING_SOUND_INDEX = NUMBER_OF_IGNITE_SOUNDS,
      EASTER_EGG_SOUND_INDEX,
      NUMBER_OF_SOUNDS,
    #define MIN_SOUND_MILLIS 500UL
    enum
      HANDPRINTS_ENABLED_STATE,
      BOWL_IGNITED_STATE,
      PILLAR_ENABLED_STATE,
      PILLAR_SOLVED_STATE,
      EASTER_EGG_STATE
    // Pillars numbers in room with sides shown:
    // ______    _______
    // |  3        4   |
    // |           C   |
    // |  2      B 1 D |
    // |           A   |
    // Handprints (pillar, side, height*): 1B3, 2B3, 3A1
    // Pillars (pillar, side, height*): 1D1, 1C2, 1C1, 1B1, 2A1, 2A2, 2B2, 2C1, 3D1, 3D3, 3C2, 3B3, 4B2, 4B3, 4A2, 4D3
    // *Height: 1 = High, 2 = Mid, 3 = Low
    // Map from sensor pins to positions
    const struct
      boolean handprint_solution;
      boolean pillar_solution;
      uint8_t pin;
      uint16_t panel_height;
      uint8_t ignite_sound_index;
      uint8_t side_index;
      uint8_t height_index;
    } sensor_info[] =
      #if PILLAR == 1
      { false, false, SENSOR_A1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_A_SOUND_INDEX, 0, 2 },
      { false, false, SENSOR_A2_PIN, MID_PANEL_HEIGHT,  IGNITE_MID_A_SOUND_INDEX,  0, 1 },
      { false, false, SENSOR_A3_PIN, LOW_PANEL_HEIGHT,  IGNITE_LOW_A_SOUND_INDEX,  0, 0 },
      { false, true,  SENSOR_B1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_B_SOUND_INDEX, 1, 2 },
      { false, false, SENSOR_B2_PIN, MID_PANEL_HEIGHT,  IGNITE_MID_B_SOUND_INDEX,  1, 1 },
      { true,  false, SENSOR_B3_PIN, LOW_PANEL_HEIGHT,  IGNITE_LOW_B_SOUND_INDEX,  1, 0 },
      { false, true,  SENSOR_C1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_C_SOUND_INDEX, 2, 2 },
      { false, true,  SENSOR_C2_PIN, MID_PANEL_HEIGHT,  IGNITE_MID_C_SOUND_INDEX,  2, 1 },
      { false, false, SENSOR_C3_PIN, LOW_PANEL_HEIGHT,  IGNITE_LOW_C_SOUND_INDEX,  2, 0 },
      { false, true,  SENSOR_D1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_D_SOUND_INDEX, 3, 2 },
      { false, false, SENSOR_D2_PIN, MID_PANEL_HEIGHT,  IGNITE_MID_D_SOUND_INDEX,  3, 1 },
      { false, false, SENSOR_D3_PIN, LOW_PANEL_HEIGHT,  IGNITE_LOW_D_SOUND_INDEX,  3, 0 }
      #elif PILLAR == 2
      { false, true,  SENSOR_A1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_A_SOUND_INDEX, 0, 2 },
      { false, true,  SENSOR_A2_PIN, MID_PANEL_HEIGHT,  IGNITE_MID_A_SOUND_INDEX,  0, 1 },
      { false, false, SENSOR_C2_PIN, MID_PANEL_HEIGHT,  IGNITE_MID_C_SOUND_INDEX,  2, 1 },
      { false, false, SENSOR_D1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_D_SOUND_INDEX, 3, 2 },
      #elif PILLAR == 3
      { true,  false, SENSOR_A1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_A_SOUND_INDEX, 0, 2 },
      { true, false, SENSOR_B1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_B_SOUND_INDEX, 1, 2 },
      { false, true,  SENSOR_B3_PIN, LOW_PANEL_HEIGHT,  IGNITE_LOW_B_SOUND_INDEX,  1, 0 },
      { true, false, SENSOR_C1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_C_SOUND_INDEX, 2, 2 },
      { true, true,  SENSOR_D1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_D_SOUND_INDEX, 3, 2 },
      { false, true,  SENSOR_D3_PIN, LOW_PANEL_HEIGHT,  IGNITE_LOW_D_SOUND_INDEX,  3, 0 }
      #elif PILLAR == 4
      { false, false, SENSOR_B1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_B_SOUND_INDEX, 1, 2 },
      { false, true,  SENSOR_B2_PIN, MID_PANEL_HEIGHT,  IGNITE_MID_B_SOUND_INDEX,  1, 1 },
      { false, false, SENSOR_C1_PIN, HIGH_PANEL_HEIGHT, IGNITE_HIGH_C_SOUND_INDEX, 2, 2 },
    #define NUMBER_OF_SENSORS (sizeof(sensor_info) / sizeof(sensor_info[0]))
    #define IR_ACTIVATED              0
    #define IR_NOT_ACTIVATED          1
    //LED Strips must use the following pins and sequence 19,18,14,15,17
    static boolean sensors[NUMBER_OF_SENSORS];
    static puzzleState_t puzzle_state;
    puzzleState_t prev_puzzle_state;
    //uint32_t current_millis = millis();
      ethernetSetup();
      //mqttSetup();
      //LED Strip Setup
      FastLED.addLeds<NUMBER_OF_SIDES, CHIPSET, LED_STRIP_SIDE_A_PIN, COLOR_ORDER>(leds[0], LEDS_PER_SIDE);
      FastLED.addLeds<NUMBER_OF_SIDES, CHIPSET, LED_STRIP_SIDE_B_PIN, COLOR_ORDER>(leds[1], LEDS_PER_SIDE);
      FastLED.addLeds<NUMBER_OF_SIDES, CHIPSET, LED_STRIP_SIDE_C_PIN, COLOR_ORDER>(leds[2], LEDS_PER_SIDE);
      FastLED.addLeds<NUMBER_OF_SIDES, CHIPSET, LED_STRIP_SIDE_D_PIN, COLOR_ORDER>(leds[3], LEDS_PER_SIDE);
      FastLED.addLeds<NUMBER_OF_SIDES, CHIPSET, LED_STRIP_BOWL_PIN, COLOR_ORDER>(bowl_leds, LEDS_IN_BOWL);
      FastLED.setBrightness(BRIGHTNESS);
      FastLED.setMaxRefreshRate(FRAMES_PER_SECOND);
      // Set up general I/O
      pinMode(SOUND_ACT_PIN, INPUT_PULLUP);
      pinMode(SENSOR_C1_PIN, INPUT_PULLUP);
      pinMode(SENSOR_A1_PIN, INPUT_PULLUP);
      pinMode(SENSOR_A2_PIN, INPUT_PULLUP);
      pinMode(SENSOR_A3_PIN, INPUT_PULLUP);
      pinMode(SENSOR_B1_PIN, INPUT_PULLUP);
      pinMode(SENSOR_B2_PIN, INPUT_PULLUP);
      pinMode(SENSOR_B3_PIN, INPUT_PULLUP);
      pinMode(SENSOR_C2_PIN, INPUT_PULLUP);
      pinMode(SENSOR_C3_PIN, INPUT_PULLUP);
      pinMode(SENSOR_D1_PIN, INPUT_PULLUP);
      pinMode(SENSOR_D2_PIN, INPUT_PULLUP);
      pinMode(SENSOR_D3_PIN, INPUT_PULLUP);
      // Set up debug serial and sound card serial
     Serial.println("Testing Mode - Pillars4.1");
      uint16_t i;
      uint16_t j;
      uint8_t side;
      // Read the sensors and publish to GameMaster Software
      for( i = 0; i < NUMBER_OF_SENSORS; i++ )
        sensors[i] = digitalRead(sensor_info[i].pin);
        Serial.print(sensors[i]); //Sensor Data to Print or Publish
        Serial.print(" ");
      // Update the puzzle state
      prev_puzzle_state = puzzle_state;
      //updatePuzzleState(&puzzle_state, current_millis);
      // Lighting and Sound for Hands
      if(puzzle_state == HANDPRINTS_ENABLED_STATE)
        for( i = 0; i< NUMBER_OF_SENSORS; i++)
              if(sensor_info[i].handprint_solution)
                if(sensors[i] == IR_ACTIVATED)
                    Serial.println("ON");
                     fill_solid(leds[sensor_info[i].side_index] + sensor_info[i].panel_height,LEDS_PER_PANEL, CRGB::Green);
                else {
                    Serial.println("OFF");
                     fill_solid(leds[sensor_info[i].side_index] + sensor_info[i].panel_height,LEDS_PER_PANEL, CRGB::Black);
                     FastLED.show();
       FastLED.show();
      } //End of Handprints
      //Send & Recieve Messages
      //mqttLoop();
      FastLED.show();
    Second Tab:
    //Arduino Ethernet MQTT
    int resetStatus = 0;
    int overrideStatus = 0;
    int solvedStatus = 0;
    // Device Addresses
    // MAC address of this device (Use MAC Address Generator app)
    byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x4C};
    // Unique IP address assigned to device
    const IPAddress ip(192, 168, 0, 205);
    // Gateway Address
    const IPAddress gateway(192, 168, 0, 1);
    //Subnet Mask
    const IPAddress subnet(255, 255, 255, 0);
    //DNS Server Address
    const IPAddress dnServer(192, 168, 0, 1);
    // IP address of the machine running the MQTT server
    const IPAddress mqttServerIP(192, 168, 0, 200);
    // Unique name of this device, used as client ID and Topic Name on MQTT
    const char* deviceID = "PillarThree";
    // Global Variables
    // Create an instance of the Ethernet client
    EthernetClient ethernetClient;
    // Create an instance of the MQTT client based on the ethernet client
    PubSubClient MQTTclient(ethernetClient);
    // The time (from millis()) at which last message was published
    long lastMsgTime = 0;
    // A buffer to hold messages to be sent/have been received
    char msg[64];
    // The topic in which to publish a message
    char topic[32];
    // Counter for number of heartbeat pulses sent
    int pulseCount = 0;
    // Callback function each time a message is published in any of
    // the topics to which this client is subscribed
    void mqttCallback(char* topic, byte* payload, unsigned int length) {
      // The message "payload" passed to this function is a byte*
      // Let's first copy its contents to the msg char[] array
      memcpy(msg, payload, length);
      // Add a NULL terminator to the message to make it a correct string
      msg[length] = '\0';
      // Debug
      Serial.print("Message received in topic [");
      Serial.print(topic);
      Serial.print("] ");
      Serial.println(msg);
      // Act upon the message received
      if(strcmp(msg, "solveOne") == 0) {
        solvedStatus = 1; //Phrase was said correctly
      else if(strcmp(msg, "resetOne") == 0) {
        resetStatus = 1; //HANDPRINTS_ENABLED_STATE
      else if(strcmp(msg, "overrideOne") == 0) {
        overrideStatus = 1; //Hands Override
        Serial.println("OverrideOne message recieved");
      else if(strcmp(msg, "overrideTwo") == 0) {
        overrideStatus = 2; //Pillars Override
      else if(strcmp(msg, "ResetTwo") == 0) {
        resetStatus = 2; //Reset to Pillar Enabled State
    void ethernetSetup() {
      // start the Ethernet connection:
      Serial.println("Initialize Ethernet:");
      Ethernet.begin(mac, ip);
      delay(1500);
      // print your local IP address:
      Serial.print("My IP address: ");
      Serial.println(Ethernet.localIP());
    void mqttSetup() {
      // Define some settings for the MQTT client
      MQTTclient.setServer(mqttServerIP, 1883);
      MQTTclient.setCallback(mqttCallback);
    void mqttLoop() {
      // Ensure there's a connection to the MQTT server
      while (!MQTTclient.connected()) {
        // Debug info
        Serial.print("Attempting to connect to MQTT broker at ");
        Serial.println(mqttServerIP);
        // Attempt to connect
        if (MQTTclient.connect(deviceID)) {
          // Debug info
          Serial.println("Connected to MQTT broker");
          // Once connected, publish an announcement to the ToHost/#deviceID# topic
          snprintf(topic, 32, "ToHost/Pillars/Three", deviceID);
          snprintf(msg, 64, "CONNECTED", deviceID);
          MQTTclient.publish(topic, msg);
          // Subscribe to topics meant for this device
          snprintf(topic, 32, "ToDevice/Pillars/Three", deviceID);
          MQTTclient.subscribe(topic);
          // Subscribe to topics meant for all devices
          MQTTclient.subscribe("ToDevice/All");
        else {
          // Debug info why connection could not be made
          Serial.print("Connection to MQTT server failed, rc=");
          Serial.print(MQTTclient.state());
          Serial.println(" trying again in 5 seconds");
          Serial.println(Ethernet.hardwareStatus());
          // Wait 5 seconds before retrying
          delay(5000);
      // Call the main loop to check for and publish messages
      MQTTclient.loop();
    void publish(char* message){
      MQTTclient.publish(topic, message);
    Sep 2020
    9
    I figured out that only the first LEDs are lighting up on my 72 LED strip. I was trying to light the end of the strip and I got no result. As I moved with in the first 32 LEDs it works. bamos is having the same problem. His comments are at the very end of the following thread.
    https://forum.pjrc.com/threads/60857...-Library/page5
