Results 1 to 3 of 3
Thread: CANBUS send and receinve
    Oct 2019
    5
    is it possible to send and reveive messages Canbus on a same can (teensy 3.2).
    I must send on id: 0x80 a data 0x5 on bit 2 for to wake up an ecu so that it sends these data that I want to read.
    Dec 2016
    Montreal, Canada
    3,449
    yes, you just need to use FlexCAN_T4, it has basic examples to get you up and running. Just make sure since you are on the ECU bus that the PTS or KEY is in IGN_ON mode, irregardless if engine is running or not, just to see if you see data flowing on the teensy example. If that works you can then play write your own frames.
    Also make sure you are using a transceiver on your Teensy 3.2, without one you can't do CAN.
    Oct 2019
    5
    Thankyou tonton81
