Page 2 of 2 FirstFirst 1 2
Results 26 to 41 of 41
Thread: Working with New Audio Objects
  1. #26
    block->data[0] to block->data[3] is 8 bytes. Each audio sample is an int16_t not 32-bits.
    Pete
    Audio blocks are represented with this data type, which is a C struct. The only member intended for use in update() is "data", an array of 16 bit integers representing the audio. If "myblock" is a pointer to an audio_block_t, use myblock->data[0] to access the first audio sample, myblock->data[1] to access the second, and so on. The data[] array is always 32 bit aligned in memory, so you can fetch pairs of samples by type casting the address as a pointer to 32 bit data.
    https://www.pjrc.com/teensy/td_libs_...ewObjects.html
    Also when take a single sample using code
    void AudioEncoder::update(void)
      audio_block_t *in =NULL;
      in = receiveWritable();
      if (!in) return;
      Serial.println(in->data[100], HEX);
    I get output 32 bits and not 16 bits
    FFFFF862
    FFFFECA2
    FFFFF089
    FFFFEB1D
    FFFFDF4A
  2. #27
    Jul 2020
    472
    Quote Originally Posted by Nishant View Post
      if (!in) return;
    FFFFF862
    FFFFECA2
    FFFFF089
    FFFFEB1D
    FFFFDF4A
    You aren't getting 32 bits, its just that println only has a method for int, not int16_t, so the value is implicitly converted from
    16 bit to 32 bit (the natural size of int) by the compiler so it can use the int method on println. If you want to only see
    16 bits in the output you can truncate:
      Serial.println(in->data[100] & 0xFFFF, HEX);
  3. #28
    I am trying this code but somewhere data is getting corrupted
    #include <Arduino.h>
    #include "effect_encoder.h"
    #include <Crypto.h>
    #include <AES.h>
    #include <string.h>
    AESSmall256 aes256;
    uint8_t key[32] ={0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
                        0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F,
                        0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17,
                        0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F};
    uint8_t ciphertext[256];
      uint8_t  buffer[16];
      uint8_t * bptr = (uint8_t*) (in->data);
      if (!in) return;
     // Serial.println(in->data[100] & 0xFFFF, HEX);
      for (int i=0; i < AUDIO_BLOCK_SAMPLES/8; i++)
        uint8_t aes_block [16];
        for (int j = 0 ; j < 16 ; j++)
        aes_block [j] = *bptr++ ;
        aes256.setKey(key, aes256.keySize());
        aes256.encryptBlock(buffer, aes_block);
        memcpy(ciphertext + (i*16), buffer,16);
      memcpy(in->data, ciphertext,256);
      transmit(in);
      release(in);
    output is same where else should be changing
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
    FFFFF0AC
  4. #29
    The code below is working perfectly and I don't need to use the modified println too
    #include <Crypto.h>
    #include <AES.h>
    #include <string.h>
    AESSmall256 aes256;
    uint16_t plaintext[128] = {0xc126,
    0x29f7,
    0x5999,
    0x825e,
    0xcc56,
    0x9ca1,
    0xf0e9,
    0x1a12,
    0xf1e7,
    0x52b6,
    0xa8e6,
    0x7233,
    0x7235,
    0x0f94,
    0x690f,
    0x507a,
    0x7cb3,
    0xe651,
    0xd0a7,
    0x6130,
    0x6e8a,
    0xd554,
    0x7ce2,
    0x8ece,
    0x62de,
    0x5e91,
    0xb845,
    0xfcc5,
    0x62d6,
    0xa366,
    0xcb00,
    0x0ea6,
    0x1600,
    0x52b4,
    0x72f9,
    0xece0,
    0xf444,
    0x5c18,
    0x0df5,
    0x0261,
    0xe604,
    0x69dc,
    0x7b9f,
    0xdcf3,
    0x292a,
    0x6305,
    0x21e0,
    0x7c1b,
    0x0dc6,
    0x0fd4,
    0x75f9,
    0xe663,
    0xa6d4,
    0x2957,
    0x07f7,
    0xf706,
    0x9e2a,
    0x8c1b,
    0x190e,
    0x0e23,
    0x3391,
    0xcc30,
    0xc724,
    0xd415,
    0x3d28,
    0x9997,
    0xf8c0,
    0xe66d,
    0x6326,
    0x57cb,
    0x7e2b,
    0x29d4,
    0x2681,
    0xb9d6,
    0xda2f,
    0x4829,
    0x8442,
    0xd043,
    0xeb78,
    0xf121,
    0x0d99,
    0x1a59,
    0x0bc9,
    0xafa7,
    0x5e73,
    0xe362,
    0x5dfc,
    0x0aaa,
    0x4320,
    0x8928,
    0x3a85,
    0xa25a,
    0x5d07,
    0x73f4,
    0xcee6,
    0x8f86,
    0xcf45,
    0x5635,
    0x87dd,
    0xfe41,
    0x52cb,
    0x5418,
    0xf7e7,
    0x8ff6,
    0xd67e,
    0x7692,
    0xfe41,
    0xccd8,
    0x0c29,
    0xbc57,
    0x0910,
    0x00d2,
    0x0c39,
    0xfc2e,
    0xd0ef,
    0x0a52,
    0x09a4,
    0xd577,
    0x05a6,
    0x0199,
    0xd918,
    0x0a79,
    0x0bf9,
    0x04a1,
    0x06fe,
    0x007e,
    0x0516,
    0x01e8};
    uint16_t plaintext2[128];
    uint16_t ciphertext2[128];
    uint8_t  buffer[16];
    uint8_t  buffer1[16];
    uint8_t plaintext1[256];
    int count =0 ;
    uint8_t * bptr = (uint8_t*) (plaintext);
    uint8_t * bptr1 = (uint8_t*) (ciphertext2);
        Serial.print("plaintext:");
        Serial.println(plaintext[10], HEX);
        for (int i = 0 ; i < 16 ; i++)
          uint8_t aes_block [16] ;
         memcpy(ciphertext2, ciphertext,256);
         Serial.print("ciphertext:");
         Serial.println(ciphertext2[10], HEX);
          uint8_t clear_block [16] ;
          clear_block [j] = *bptr1++ ;
          aes256.decryptBlock(buffer1, clear_block);
          memcpy(plaintext1 + (i*16), buffer1,16);
         memcpy(plaintext2, plaintext1,256);
         Serial.println(plaintext2[10], HEX);
    output is
    plaintext:A8E6
    ciphertext:CB54
    plaintext:A8E6
  5. #30
    Jul 2020
    472
    I suspect there's a uint16_t method for println. Note that int16_t and int32_t will not implicitly cast
    to unsigned types as negative values cannot be represented.
  6. #31
    audio_block_t data[] is uint16_t so it does not have negative values
  7. #32
    1,488
    The audio_block_t data structure is defined in Audiostream.h
    typedef struct audio_block_struct {
    	uint8_t  ref_count;
    	uint8_t  reserved1;
    	uint16_t memory_pool_index;
    	int16_t  data[AUDIO_BLOCK_SAMPLES];
    } audio_block_t;
    The data[] array is int16_t.
    Pete
  8. #33
    Jul 2020
    472
    You clearly haven't checked this in the source code - I'd recommend getting upto speed with the Audio lib internals
    to gain a deeper understanding of what goes on, AudioStream.h & AudioStream.cpp can be perused here:
    https://github.com/PaulStoffregen/co...master/teensy4
  9. #34
    I am able to copy audio block data for processing , the same works out if I use a pre filled array of similar size
  10. #35
    Sorry typo error. There seems to be error while typecasting and working with audio_block->data. But when I try my code with static array similar to audio_block->data size my code works
  11. #36
    	uint8_t  ref_count;
    	uint8_t  reserved1;
    } audio_block_t;
    Pete
     // if (!in) return;
      Serial.print("Audio_block:");
      Serial.println(in->data[0],HEX);
    I am getting varying values some are 32bits and some are 16bits
    Audio_block---:0
    Audio_block---:0
    Audio_block---:0
    Audio_block---:0
    Audio_block---:1
    Audio_block---:6
    Audio_block---:FFFFDDA9
    Audio_block---:FFFFBBC4
    Audio_block---:294C
    Audio_block---:11B8
    Audio_block---:FFFFF48B
    Audio_block---:D2
    Audio_block---:24A
    Audio_block---:1778
    Audio_block---:FFFFC256
    Audio_block---:19A6
    Audio_block---:DF1
    Audio_block---:FFFFEC84
    Audio_block---:F66
    Audio_block---:3CB
    Audio_block---:4BAC
    Audio_block---:FFFFD8DD
    Audio_block---:13D1
    Audio_block---:17FD
    Audio_block---:A8C
    Audio_block---:20F8
    Audio_block---:FFFFFDC0
    Audio_block---:567F
    Audio_block---:FFFFEC0C
    Audio_block---:FFFFE5EB
    Audio_block---:1D8E
    Audio_block---:2
    Audio_block---:81C
    Audio_block---:FFFFFF27
    Audio_block---:620C
    Audio_block---:13BF
    Audio_block---:FFFFE7B2
    Audio_block---:330E
    Audio_block---:6DE
    Audio_block---:FFFFFFA1
    Audio_block---:8D
    Audio_block---:E51
    Audio_block---:3742
    Audio_block---:FFFFE126
    Audio_block---:2DFC
    Audio_block---:5A2
    Audio_block---:FFFFFDF3
    Audio_block---:FFFFFF9B
    Audio_block---:FFFFBD5D
    Audio_block---:466F
    Audio_block---:FFFFD5F8
    Audio_block---:1E42
    Audio_block---:144A
    Audio_block---:20F7
    Audio_block---:1EF2
    Audio_block---:FFFF9E1F
    Audio_block---:5EE2
    Audio_block---:FFFFC007
    Audio_block---:B69
    Audio_block---:FFFFE3FC
    Audio_block---:FFFFDB17
    Audio_block---:71B
    Audio_block---:FFFF9654
    Audio_block---:4CD4
    Audio_block---:FFFFD27D
    Audio_block---:207
    Audio_block---:1557
    Audio_block---:FFFFFBF5
    Audio_block---:FFFFF96F
    Audio_block---:FFFFE7C2
    Audio_block---:3FEE
    Audio_block---:FFFFD427
    Audio_block---:FFFFE99E
    Audio_block---:11B3
    Audio_block---:C20
    Audio_block---:59
    Audio_block---:FFFFF2EC
    Audio_block---:325F
    Audio_block---:FFFFEC27
    Audio_block---:FFFFE20F
    Audio_block---:FFFFFFD5
    Audio_block---:B52
    Audio_block---:D04
    Audio_block---:492D
    Audio_block---:429
    Audio_block---:FFFFEEA9
    Audio_block---:FFFFDBC7
    Audio_block---:E89
    Audio_block---:1E8
    Audio_block---:5E
    Audio_block---:4B6B
    Audio_block---:FFFFEBCE
    Audio_block---:46B
    Audio_block---:FFFFC8E4
    Audio_block---:FFFFFF00
    Audio_block---:FFFFFDB5
    Audio_block---:FFFFF98B
    Audio_block---:4781
    Audio_block---:FFFFC6D4
    Audio_block---:3916
    Audio_block---:FFFFBD11
    Audio_block---:3CF
    Audio_block---:10B6
    Audio_block---:D2B
    Audio_block---:FFFFFFFD
    Audio_block---:FFFFC669
    Audio_block---:27A8
    Audio_block---:FFFFD75A
    Audio_block---:FFFFFADD
    Audio_block---:FFFFE3AB
    Audio_block---:CA3
  12. #37
    1,488
    No they aren't. They are all 32-bits. The difference is that all the numbers that begin with FFFF were negative and FFFF is the sign extension which occurs when a negative 16-bit number is converted to a 32-bit number.
    As @MarkT has explained, if you pass a 16-bit signed integer to Serial.print, it is converted to a signed 32-bit integer because that is what Serial.print handles.
    If you want to always get just the low order 4 HEX digits, cast the sample as (uint16_t) which will make the compiler treat the number as if it was an unsigned 16-bit number. This will still be converted to a 32-bit number but the sign extension won't be done because it is now considered to be unsigned.
    For example, in this snippet:
      int16_t i16 = -1;
      Serial.println(i16,HEX);
      Serial.println((uint16_t)i16,HEX);
    The first println prints FFFFFFFF because that is the 32-bit representation of the 16-bit negative number -1 (FFFF).
    The second println prints FFFF because the cast (uint16_t) forces the number to be treated as if it were unsigned and so the sign extension is not done and the 32-bit result is 0000FFFF, but println doesn't print leading zeroes so the output is FFFF.
    Pete
  13. #38
      int16_t i16 = -1;
    Pete
    Thanks a lot , that made it very clear. I have running the code given below and instead of taking a audio_block , I am testing with a fixes array of [128] and my code works but it fails when a take live audio data
    #include <Crypto.h>
    #include <AES.h>
    #include <string.h>
    AESSmall256 aes256;
    int16_t plaintext[128] = {0xFFFF,
    0x29f7,
    0x5999,
    0x825e,
    0xcc56,
    0x9ca1,
    0xf0e9,
    0x1a12,
    0xf1e7,
    0x52b6,
    0xa8e6,
    0x7233,
    0x7235,
    0x0f94,
    0x690f,
    0x507a,
    0x7cb3,
    0xe651,
    0xd0a7,
    0x6130,
    0x6e8a,
    0xd554,
    0x7ce2,
    0x8ece,
    0x62de,
    0x5e91,
    0xb845,
    0xfcc5,
    0x62d6,
    0xa366,
    0xcb00,
    0x0ea6,
    0x1600,
    0x52b4,
    0x72f9,
    0xece0,
    0xf444,
    0x5c18,
    0x0df5,
    0x0261,
    0xe604,
    0x69dc,
    0x7b9f,
    0xdcf3,
    0x292a,
    0x6305,
    0x21e0,
    0x7c1b,
    0x0dc6,
    0x0fd4,
    0x75f9,
    0xe663,
    0xa6d4,
    0x2957,
    0x07f7,
    0xf706,
    0x9e2a,
    0x8c1b,
    0x190e,
    0x0e23,
    0x3391,
    0xcc30,
    0xc724,
    0xd415,
    0x3d28,
    0x9997,
    0xf8c0,
    0xe66d,
    0x6326,
    0x57cb,
    0x7e2b,
    0x29d4,
    0x2681,
    0xb9d6,
    0xda2f,
    0x4829,
    0x8442,
    0xd043,
    0xeb78,
    0xf121,
    0x0d99,
    0x1a59,
    0x0bc9,
    0xafa7,
    0x5e73,
    0xe362,
    0x5dfc,
    0x0aaa,
    0x4320,
    0x8928,
    0x3a85,
    0xa25a,
    0x5d07,
    0x73f4,
    0xcee6,
    0x8f86,
    0xcf45,
    0x5635,
    0x87dd,
    0xfe41,
    0x52cb,
    0x5418,
    0xf7e7,
    0x8ff6,
    0xd67e,
    0x7692,
    0xfe41,
    0xccd8,
    0x0c29,
    0xbc57,
    0x0910,
    0x00d2,
    0x0c39,
    0xfc2e,
    0xd0ef,
    0x0a52,
    0x09a4,
    0xd577,
    0x05a6,
    0x0199,
    0xd918,
    0x0a79,
    0x0bf9,
    0x04a1,
    0x06fe,
    0x007e,
    0x0516,
    0x01e8};
    int8_t  buffer[16];
    int8_t  buffer1[16];
    int count =0 ;
    int8_t * bptr = (int8_t*) (plaintext);
    int8_t * bptr1 = (int8_t*) (ciphertext2);
        Serial.println(plaintext[0], HEX);
         Serial.println(ciphertext2[0], HEX);
         Serial.println(plaintext2[0], HEX);
    output
    plaintext:FFFFFFFF
    ciphertext:5801
    plaintext:FFFFFFFF
  14. #39
    1,488
    When you print (or println) int16_t data, you must always cast it as (uint16_t) to stop the implicit sign extension. E.g.
        Serial.println((uint16_t)plaintext[0], HEX);
    Then it will print this as FFFF
    Pete
  15. #40
    Finally I have been able to make some code. In the code below I am doing the encryption and decryption to together and it works but with some noise.
    encryption + decryption
    #include <Crypto.h>
    #include <AES.h>
    #include <string.h>
    AudioInputUSB            usbin;          //xy=91.33332824707031,214
    AudioRecordQueue         queuein;        //xy=280.33331298828125,336
    AudioPlayQueue           queueout;       //xy=401.33331298828125,223
    AudioOutputI2S           i2s1;           //xy=578.3333129882812,328
    AudioOutputUSB           usbout;         //xy=593.3333282470703,210
    AudioConnection          patchCord1(usbin, 1, queuein, 0);
    AudioConnection          patchCord2(queueout, 0, usbout, 1);
    AudioConnection          patchCord3(queueout, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=298.3333282470703,135
    AES256 aes256;
    byte key[32] ={0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
    short array1[AUDIO_BLOCK_SAMPLES];
    short array2[AUDIO_BLOCK_SAMPLES];
    int ret=0;
    int j=0;
    byte buffer [16];
    byte buffer2 [16];
    byte cleartext[256];
    byte ciphertext[256];
    byte cleartext2[256];
      while (!Serial) ;
      AudioMemory(64);
      sgtl5000_1.enable();
      sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
      sgtl5000_1.volume(0.5);
      queuein.begin();
      ret=queuein.available();
      if(ret>=1)
        memcpy(array1, queuein.readBuffer(), 2*AUDIO_BLOCK_SAMPLES);
        queuein.freeBuffer();
    //    Serial.print("Audio_block:");
    //    Serial.println(array1[0],HEX);
        int i = 0;
        while(i< AUDIO_BLOCK_SAMPLES)
          cleartext[i] = (array1[i] & 0xFF);
          cleartext[i+1] = (array1[i] >> 8) & 0xFF;
          i++;
          i++;
        byte aes_block [16];
        memcpy(aes_block, cleartext+(j*16),16);
        memcpy(ciphertext + (j*16), buffer,16);
    //    Serial.print("cipher:");
     //   Serial.print(ciphertext[0],HEX);
    //    Serial.println(ciphertext[1],HEX);
        for (int l = 0 ; l < 16 ; l++)
        byte aes_block2 [16];
        memcpy(aes_block2, ciphertext+(l*16),16);
        aes256.decryptBlock(buffer2, aes_block2);
        memcpy(cleartext2 + (l*16), buffer2,16);
     //   Serial.print("clear:");
     //   Serial.print(cleartext2[0],HEX);
      //  Serial.println(cleartext2[1],HEX);
      //  byte low = (array1[0] & 0xFF);
      //  byte high = (array1[0] >> 8) & 0xFF;
        memcpy(array2, cleartext2,256);
     //   Serial.print("clear_Audio_block---:");
     //   Serial.println(array2[0],HEX);
        memcpy(queueout.getBuffer(), array2, 2*AUDIO_BLOCK_SAMPLES);
        queueout.playBuffer();
    However when I try to make encryption and decryption code separately and first run encryption and then decryption, I don't get the the original audio back. I am not able to zero on the error. please help
    Encryption Code:-
    #include <Crypto.h>
    #include <AES.h>
    #include <string.h>
    AESSmall256 aes256;
    int ret=0;
    int j=0;
    byte buffer [16];
    byte buffer2 [16];
      while (!Serial) ;
      AudioMemory(64);
      queuein.begin();
      if(ret>=1)
        int i = 0;
          i++;
          i++;
        memcpy(array2, ciphertext,256);
        Serial.print("cipher_Audio_block---:");
    Decryption code :
    #include <Crypto.h>
    #include <AES.h>
    #include <string.h>
    AESSmall256 aes256;
    int ret=0;
    int j=0;
    byte buffer [16];
    byte buffer2 [16];
      while (!Serial) ;
      AudioMemory(64);
      queuein.begin();
      if(ret>=1)
        int i = 0;
          i++;
          i++;
        aes256.decryptBlock(buffer, aes_block);
  16. #41
    Jul 2020
    472
    Well for starters the key needs to be set once only, but I don't think that's your problem - with encryption
    code you have to make zero errors in the code otherwise the result is inpenetrable garbage - I'd start from
    a known working example from the crypt library perhaps?
    Your code is using ECB mode which isn't secure and would never be used in the real world as it can
    leak information readily - CBC would be much more sensible, but then you have to synchronize streams
    exactly. So get ECB mode working first is a good plan.
    Perhaps rig the plaintext to a known value in the encryption part and check the correct ciphertext makes it
    out, then feed that to the decryption and check the rigged plaintext reappears. Standard ciphers have
    published test vectors you can use to verify the behaviour.
    better
