Working with New Audio Objects
block->data[0] to block->data[3] is 8 bytes. Each audio sample is an int16_t not 32-bits.
Pete
Audio blocks are represented with this data type, which is a C struct. The only member intended for use in update() is "data", an array of 16 bit integers representing the audio. If "myblock" is a pointer to an audio_block_t, use myblock->data[0] to access the first audio sample, myblock->data[1] to access the second, and so on. The data[] array is always 32 bit aligned in memory, so you can fetch pairs of samples by type casting the address as a pointer to 32 bit data.
https://www.pjrc.com/teensy/td_libs_AudioNewObjects.html
Also when take a single sample using code
void AudioEncoder::update(void)
  audio_block_t *in =NULL;
  in = receiveWritable();
  if (!in) return;
  [B]Serial.println(in->data[100], HEX)[/B];
I get output 32 bits and not 16 bits
FFFFF862
FFFFECA2
FFFFF089
FFFFEB1D
FFFFDF4A
  if (!in) return;
FFFFF862
FFFFECA2
FFFFF089
FFFFEB1D
FFFFDF4A
You aren't getting 32 bits, its just that println only has a method for int, not int16_t, so the value is implicitly converted from
16 bit to 32 bit (the natural size of int) by the compiler so it can use the int method on println. If you want to only see
16 bits in the output you can truncate:
  Serial.println(in->data[100] & 0xFFFF, HEX);
I am trying this code but somewhere data is getting corrupted
#include <Arduino.h>
#include "effect_encoder.h"
#include <Crypto.h>
#include <AES.h>
#include <string.h>
AESSmall256 aes256;
uint8_t key[32] ={0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
                    0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F,
                    0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17,
                    0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F};
uint8_t ciphertext[256];
  uint8_t  buffer[16];
  uint8_t * bptr = (uint8_t*) (in->data);
  if (!in) return;
 // Serial.println(in->data[100] & 0xFFFF, HEX);
  for (int i=0; i < AUDIO_BLOCK_SAMPLES/8; i++)
    uint8_t aes_block [16];
    for (int j = 0 ; j < 16 ; j++)
    aes_block [j] = *bptr++ ;
    aes256.setKey(key, aes256.keySize());
    aes256.encryptBlock(buffer, aes_block);
    memcpy(ciphertext + (i*16), buffer,16);
  memcpy(in->data, ciphertext,256);
  [B]Serial.println(in->data[100], HEX);[/B]
  transmit(in);
  release(in);
output is same where else should be changing
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
FFFFF0AC
The code below is working perfectly and I don't need to use the modified println too
#include <Crypto.h>
#include <AES.h>
#include <string.h>
AESSmall256 aes256;
uint16_t plaintext[128] = {0xc126,
0x29f7,
0x5999,
0x825e,
0xcc56,
0x9ca1,
0xf0e9,
0x1a12,
0xf1e7,
0x52b6,
0xa8e6,
0x7233,
0x7235,
0x0f94,
0x690f,
0x507a,
0x7cb3,
0xe651,
0xd0a7,
0x6130,
0x6e8a,
0xd554,
0x7ce2,
0x8ece,
0x62de,
0x5e91,
0xb845,
0xfcc5,
0x62d6,
0xa366,
0xcb00,
0x0ea6,
0x1600,
0x52b4,
0x72f9,
0xece0,
0xf444,
0x5c18,
0x0df5,
0x0261,
0xe604,
0x69dc,
0x7b9f,
0xdcf3,
0x292a,
0x6305,
0x21e0,
0x7c1b,
0x0dc6,
0x0fd4,
0x75f9,
0xe663,
0xa6d4,
0x2957,
0x07f7,
0xf706,
0x9e2a,
0x8c1b,
0x190e,
0x0e23,
0x3391,
0xcc30,
0xc724,
0xd415,
0x3d28,
0x9997,
0xf8c0,
0xe66d,
0x6326,
0x57cb,
0x7e2b,
0x29d4,
0x2681,
0xb9d6,
0xda2f,
0x4829,
0x8442,
0xd043,
0xeb78,
0xf121,
0x0d99,
0x1a59,
0x0bc9,
0xafa7,
0x5e73,
0xe362,
0x5dfc,
0x0aaa,
0x4320,
0x8928,
0x3a85,
0xa25a,
0x5d07,
0x73f4,
0xcee6,
0x8f86,
0xcf45,
0x5635,
0x87dd,
0xfe41,
0x52cb,
0x5418,
0xf7e7,
0x8ff6,
0xd67e,
0x7692,
0xfe41,
0xccd8,
0x0c29,
0xbc57,
0x0910,
0x00d2,
0x0c39,
0xfc2e,
0xd0ef,
0x0a52,
0x09a4,
0xd577,
0x05a6,
0x0199,
0xd918,
0x0a79,
0x0bf9,
0x04a1,
0x06fe,
0x007e,
0x0516,
0x01e8};
uint16_t plaintext2[128];
uint16_t ciphertext2[128];
uint8_t  buffer[16];
uint8_t  buffer1[16];
uint8_t plaintext1[256];
int count =0 ;
uint8_t * bptr = (uint8_t*) (plaintext);
uint8_t * bptr1 = (uint8_t*) (ciphertext2);
    Serial.print("plaintext:");
    [B]Serial.println(plaintext[10], HEX);[/B]
    for (int i = 0 ; i < 16 ; i++)
      uint8_t aes_block [16] ;
     memcpy(ciphertext2, ciphertext,256);
     Serial.print("ciphertext:");
     [B]Serial.println(ciphertext2[10], HEX);[/B]
      uint8_t clear_block [16] ;
      clear_block [j] = *bptr1++ ;
      aes256.decryptBlock(buffer1, clear_block);
      memcpy(plaintext1 + (i*16), buffer1,16);
     memcpy(plaintext2, plaintext1,256);
     [B]Serial.println(plaintext2[10], HEX);[/B]
output is
plaintext:A8E6
ciphertext:CB54
plaintext:A8E6
I suspect there's a uint16_t method for println. Note that int16_t and int32_t will not implicitly cast
to unsigned types as negative values cannot be represented.
audio_block_t data[] is uint16_t so it does not have negative values
The audio_block_t data structure is defined in Audiostream.h
typedef struct audio_block_struct {
	uint8_t  ref_count;
	uint8_t  reserved1;
	uint16_t memory_pool_index;
	int16_t  data[AUDIO_BLOCK_SAMPLES];
} audio_block_t;
The data[] array is int16_t.
Pete
I am able to copy audio block data for processing , the same works out if I use a pre filled array of similar size
Sorry typo error. There seems to be error while typecasting and working with audio_block->data. But when I try my code with static array similar to audio_block->data size my code works
	uint8_t  ref_count;
	uint8_t  reserved1;
} audio_block_t;
Pete
 // if (!in) return;
  Serial.print("Audio_block:");
  Serial.println(in->data[0],HEX);
I am getting varying values some are 32bits and some are 16bits
Audio_block---:0
Audio_block---:0
Audio_block---:0
Audio_block---:0
Audio_block---:1
Audio_block---:6
Audio_block---:FFFFDDA9
Audio_block---:FFFFBBC4
Audio_block---:294C
Audio_block---:11B8
Audio_block---:FFFFF48B
Audio_block---:D2
Audio_block---:24A
Audio_block---:1778
Audio_block---:FFFFC256
Audio_block---:19A6
Audio_block---:DF1
Audio_block---:FFFFEC84
Audio_block---:F66
Audio_block---:3CB
Audio_block---:4BAC
Audio_block---:FFFFD8DD
Audio_block---:13D1
Audio_block---:17FD
Audio_block---:A8C
Audio_block---:20F8
Audio_block---:FFFFFDC0
Audio_block---:567F
Audio_block---:FFFFEC0C
Audio_block---:FFFFE5EB
Audio_block---:1D8E
Audio_block---:2
Audio_block---:81C
Audio_block---:FFFFFF27
Audio_block---:620C
Audio_block---:13BF
Audio_block---:FFFFE7B2
Audio_block---:330E
Audio_block---:6DE
Audio_block---:FFFFFFA1
Audio_block---:8D
Audio_block---:E51
Audio_block---:3742
Audio_block---:FFFFE126
Audio_block---:2DFC
Audio_block---:5A2
Audio_block---:FFFFFDF3
Audio_block---:FFFFFF9B
Audio_block---:FFFFBD5D
Audio_block---:466F
Audio_block---:FFFFD5F8
Audio_block---:1E42
Audio_block---:144A
Audio_block---:20F7
Audio_block---:1EF2
Audio_block---:FFFF9E1F
Audio_block---:5EE2
Audio_block---:FFFFC007
Audio_block---:B69
Audio_block---:FFFFE3FC
Audio_block---:FFFFDB17
Audio_block---:71B
Audio_block---:FFFF9654
Audio_block---:4CD4
Audio_block---:FFFFD27D
Audio_block---:207
Audio_block---:1557
Audio_block---:FFFFFBF5
Audio_block---:FFFFF96F
Audio_block---:FFFFE7C2
Audio_block---:3FEE
Audio_block---:FFFFD427
Audio_block---:FFFFE99E
Audio_block---:11B3
Audio_block---:C20
Audio_block---:59
Audio_block---:FFFFF2EC
Audio_block---:325F
Audio_block---:FFFFEC27
Audio_block---:FFFFE20F
Audio_block---:FFFFFFD5
Audio_block---:B52
Audio_block---:D04
Audio_block---:492D
Audio_block---:429
Audio_block---:FFFFEEA9
Audio_block---:FFFFDBC7
Audio_block---:E89
Audio_block---:1E8
Audio_block---:5E
Audio_block---:4B6B
Audio_block---:FFFFEBCE
Audio_block---:46B
Audio_block---:FFFFC8E4
Audio_block---:FFFFFF00
Audio_block---:FFFFFDB5
Audio_block---:FFFFF98B
Audio_block---:4781
Audio_block---:FFFFC6D4
Audio_block---:3916
Audio_block---:FFFFBD11
Audio_block---:3CF
Audio_block---:10B6
Audio_block---:D2B
Audio_block---:FFFFFFFD
Audio_block---:FFFFC669
Audio_block---:27A8
Audio_block---:FFFFD75A
Audio_block---:FFFFFADD
Audio_block---:FFFFE3AB
Audio_block---:CA3
No they aren't. They are all 32-bits. The difference is that all the numbers that begin with FFFF were negative and FFFF is the sign extension which occurs when a negative 16-bit number is converted to a 32-bit number.
As @MarkT has explained, if you pass a 16-bit signed integer to Serial.print, it is converted to a signed 32-bit integer because that is what Serial.print handles.
If you want to always get just the low order 4 HEX digits, cast the sample as (uint16_t) which will make the compiler treat the number as if it was an unsigned 16-bit number. This will still be converted to a 32-bit number but the sign extension won't be done because it is now considered to be unsigned.
For example, in this snippet:
  int16_t i16 = -1;
  Serial.println(i16,HEX);
  Serial.println((uint16_t)i16,HEX);
The first println prints FFFFFFFF because that is the 32-bit representation of the 16-bit negative number -1 (FFFF).
The second println prints FFFF because the cast (uint16_t) forces the number to be treated as if it were unsigned and so the sign extension is not done and the 32-bit result is 0000FFFF, but println doesn't print leading zeroes so the output is FFFF.
Pete
  int16_t i16 = -1;
Pete
Thanks a lot , that made it very clear. I have running the code given below and instead of taking a audio_block , I am testing with a fixes array of [128] and my code works but it fails when a take live audio data
#include <Crypto.h>
#include <AES.h>
#include <string.h>
AESSmall256 aes256;
int16_t plaintext[128] = {0xFFFF,
0x29f7,
0x5999,
0x825e,
0xcc56,
0x9ca1,
0xf0e9,
0x1a12,
0xf1e7,
0x52b6,
0xa8e6,
0x7233,
0x7235,
0x0f94,
0x690f,
0x507a,
0x7cb3,
0xe651,
0xd0a7,
0x6130,
0x6e8a,
0xd554,
0x7ce2,
0x8ece,
0x62de,
0x5e91,
0xb845,
0xfcc5,
0x62d6,
0xa366,
0xcb00,
0x0ea6,
0x1600,
0x52b4,
0x72f9,
0xece0,
0xf444,
0x5c18,
0x0df5,
0x0261,
0xe604,
0x69dc,
0x7b9f,
0xdcf3,
0x292a,
0x6305,
0x21e0,
0x7c1b,
0x0dc6,
0x0fd4,
0x75f9,
0xe663,
0xa6d4,
0x2957,
0x07f7,
0xf706,
0x9e2a,
0x8c1b,
0x190e,
0x0e23,
0x3391,
0xcc30,
0xc724,
0xd415,
0x3d28,
0x9997,
0xf8c0,
0xe66d,
0x6326,
0x57cb,
0x7e2b,
0x29d4,
0x2681,
0xb9d6,
0xda2f,
0x4829,
0x8442,
0xd043,
0xeb78,
0xf121,
0x0d99,
0x1a59,
0x0bc9,
0xafa7,
0x5e73,
0xe362,
0x5dfc,
0x0aaa,
0x4320,
0x8928,
0x3a85,
0xa25a,
0x5d07,
0x73f4,
0xcee6,
0x8f86,
0xcf45,
0x5635,
0x87dd,
0xfe41,
0x52cb,
0x5418,
0xf7e7,
0x8ff6,
0xd67e,
0x7692,
0xfe41,
0xccd8,
0x0c29,
0xbc57,
0x0910,
0x00d2,
0x0c39,
0xfc2e,
0xd0ef,
0x0a52,
0x09a4,
0xd577,
0x05a6,
0x0199,
0xd918,
0x0a79,
0x0bf9,
0x04a1,
0x06fe,
0x007e,
0x0516,
0x01e8};
int8_t  buffer[16];
int8_t  buffer1[16];
int count =0 ;
int8_t * bptr = (int8_t*) (plaintext);
int8_t * bptr1 = (int8_t*) (ciphertext2);
    Serial.println(plaintext[0], HEX);
     Serial.println(ciphertext2[0], HEX);
     Serial.println(plaintext2[0], HEX);
output
plaintext:FFFFFFFF
ciphertext:5801
plaintext:FFFFFFFF
When you print (or println) int16_t data, you must always cast it as (uint16_t) to stop the implicit sign extension. E.g.
    Serial.println((uint16_t)plaintext[0], HEX);
Then it will print this as FFFF
Pete
Finally I have been able to make some code. In the code below I am doing the encryption and decryption to together and it works but with some noise.
encryption + decryption
#include <SerialFlash.h>
#include <Crypto.h>
#include <AES.h>
#include <string.h>
AudioInputUSB            usbin;          //xy=91.33332824707031,214
AudioRecordQueue         queuein;        //xy=280.33331298828125,336
AudioPlayQueue           queueout;       //xy=401.33331298828125,223
AudioOutputI2S           i2s1;           //xy=578.3333129882812,328
AudioOutputUSB           usbout;         //xy=593.3333282470703,210
AudioConnection          patchCord1(usbin, 1, queuein, 0);
AudioConnection          patchCord2(queueout, 0, usbout, 1);
AudioConnection          patchCord3(queueout, 0, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=298.3333282470703,135
AES256 aes256;
byte key[32] ={0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
short array1[AUDIO_BLOCK_SAMPLES];
short array2[AUDIO_BLOCK_SAMPLES];
int ret=0;
int j=0;
byte buffer [16];
byte buffer2 [16];
byte cleartext[256];
byte ciphertext[256];
byte cleartext2[256];
  while (!Serial) ;
  AudioMemory(64);
  sgtl5000_1.enable();
  sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
  sgtl5000_1.volume(0.5);
  queuein.begin();
  ret=queuein.available();
  if(ret>=1)
    memcpy(array1, queuein.readBuffer(), 2*AUDIO_BLOCK_SAMPLES);
    queuein.freeBuffer();
//    Serial.print("Audio_block:");
//    Serial.println(array1[0],HEX);
    int i = 0;
    while(i< AUDIO_BLOCK_SAMPLES)
      cleartext[i] = (array1[i] & 0xFF);
      cleartext[i+1] = (array1[i] >> 8) & 0xFF;
      i++;
      i++;
    byte aes_block [16];
    memcpy(aes_block, cleartext+(j*16),16);
    memcpy(ciphertext + (j*16), buffer,16);
//    Serial.print("cipher:");
 //   Serial.print(ciphertext[0],HEX);
//    Serial.println(ciphertext[1],HEX);
    for (int l = 0 ; l < 16 ; l++)
    byte aes_block2 [16];
    memcpy(aes_block2, ciphertext+(l*16),16);
    aes256.decryptBlock(buffer2, aes_block2);
    memcpy(cleartext2 + (l*16), buffer2,16);
 //   Serial.print("clear:");
 //   Serial.print(cleartext2[0],HEX);
  //  Serial.println(cleartext2[1],HEX);
  //  byte low = (array1[0] & 0xFF);
  //  byte high = (array1[0] >> 8) & 0xFF;
    memcpy(array2, cleartext2,256);
 //   Serial.print("clear_Audio_block---:");
 //   Serial.println(array2[0],HEX);
    memcpy(queueout.getBuffer(), array2, 2*AUDIO_BLOCK_SAMPLES);
    queueout.playBuffer();
However when I try to make encryption and decryption code separately and first run encryption and then decryption, I don't get the the original audio back. I am not able to zero on the error. please help
Encryption Code:-
#include <Crypto.h>
#include <AES.h>
#include <string.h>
AESSmall256 aes256;
int ret=0;
int j=0;
byte buffer [16];
byte buffer2 [16];
  while (!Serial) ;
  AudioMemory(64);
  queuein.begin();
  if(ret>=1)
    int i = 0;
      i++;
      i++;
    memcpy(array2, ciphertext,256);
    Serial.print("cipher_Audio_block---:");
Decryption code :
#include <Crypto.h>
#include <AES.h>
#include <string.h>
AESSmall256 aes256;
int ret=0;
int j=0;
byte buffer [16];
byte buffer2 [16];
  while (!Serial) ;
  AudioMemory(64);
  queuein.begin();
  if(ret>=1)
    int i = 0;
      i++;
      i++;
    aes256.decryptBlock(buffer, aes_block);
Well for starters the key needs to be set once only, but I don't think that's your problem - with encryption
code you have to make zero errors in the code otherwise the result is inpenetrable garbage - I'd start from
a known working example from the crypt library perhaps?
Your code is using ECB mode which isn't secure and would never be used in the real world as it can
leak information readily - CBC would be much more sensible, but then you have to synchronize streams
exactly. So get ECB mode working first is a good plan.
Perhaps rig the plaintext to a known value in the encryption part and check the correct ciphertext makes it
out, then feed that to the decryption and check the rigged plaintext reappears. Standard ciphers have
published test vectors you can use to verify the behaviour.
better
