Results 1 to 21 of 21
Thread: ra8875/GSL1680 .teensy 4.0 ..touch panel functional but an issue
    Apr 2020
    Guelph Ontario Canada
    116
    Okay I have the GSL1680 up and running from the github example ..there were array bounds issues which I corrected in clear_Reg(0 and reset() ..and the code compiles fine
    The touch function works but y axis is not functioning correctly .. my display is 800 x 480 and the x axis is fine but the y axis position and screen function is way out ...and only 1/4 of the screen is touch functional so only about 1/4 of the screen is working with touch ..
    has anybody else experienced this behaviour ..?
    getting frustrated could use a few pointers other then "buy another screen" but darn I think I may have to do that ..
    I've tried at least 3 library variants .. all have the same bounds array issue ...
    open to thoughts ...
    8,984
    Which display do you have? Which library are you using, which example?
    Apr 2020
    116
    I'm using the ra8875 5" display from buydisplay ..with i2c ..on a teensy 4.0.. I have tried the libraries from Wolfman, the Scallwar release and the ESTBLC release ...all of them have the same boundry array limitation issue in the cpp file the clear_reg() and reset() ...I pulled all of these off guthub ..and used them one at a time to avoid conflicts ..the touch is working , the display is 800 x 480 ..but it identifies the "y" position 2/3rds of the way down the screen ..the touch works from that position to the bottom of the screen ..Touch does not function in the top 2/3 of tge screen ..Im running the stock GSL1680 sketch ..
    Has me really puzzled ..I received a second display identical to the first one and its shows the same behaviour ..I could see anything in the sketch that would cause this behaviour ..and the corrections I made in the cpp file should not effect it I would think ...Open to suggestions .Thanks for getting back to me KurtE appreciate your time ...
    8,984
    I probably have one of these although it came with a small ribbon cable and small adapter part which I never tried and probably lost... I have a 5" with their resistive.
    I also have a couple of their 4.3" capacitive touch display, but it uses a different touch controller chip and support for that other chip is built into our RA8875 library which is an update of the Sumotoy version.
    Not sure what to suggest. I installed the Arduino library for you controller, But it looks like a bunch of gunk where it maybe reprograms the whole controller? Not sure why or what are the configuration information associated with it.
    Is it only seeing the touch, that it translates into only 1/4 of the display or does the touching in the other areas still generate the touch response, but is mapped wrong?
    Again probably can not help much here, but maybe one of the other owners of these displays has more experience with this controller.
    Good Luck
    Apr 2020
    116
    Well ..what has happened is there are 2 versions of the touch controller gsl1680E and fsl 1680F ..."E" has been discontinued .."F" is the current which means that there is new firmware ..which is available in an .h file ..anyhow trying to sort it out..
    Nov 2015
    Cold hollow VT
    187
    @Keith I too have been having problems with this display, ER-TFTM050A2-3 from BuyDisplay.com.
    I find that in the Wolfman (based on Skallwar) release that the Reset and clear reg routines are written incorrectly giving error 3 or 4 in the I2C stuff. Change them to this:
        for (i = 0; i < 2; ++i) {
            Wire.write(REG[i]);
            Wire.write(DATA[i]);
            r = Wire.endTransmission();             // move to inside the loop before the delay(x)
            delay(TIMER[i]);
    There is some other stuff in there that needs attention too.
    Now I still have yet to get this to work as intended, but, I have been able to take the arduino download package from the BuyDisplay website and change things in the DUE code to use the SumoToy release of the RA8875 driver that comes with TeensyDuino. So at least I can see I have not fried my display. NOTE the different settings for SPI & I2C stuff.
    ER-TFTM050A2-3-Teensy.ino
    Nov 2015
    Cold hollow VT
    187
    Oh, there is one more thing, the data sheet for this (may still) shows conflicting information to the interfacing sheet.
    https://www.buydisplay.com/download/...nterfacing.pdf
    Note the I2C pins WAKE is actually on display pin #32 and INT is on pin #33. When I first started with this display I noticed there was no WAKE pin and RESET was on pin #36. This error seems to have been fixed recently though.
    Apr 2020
    116
    Thanks for posting that up ...I got as far as getting the display up and running fine with the exception I could only get 1/3 of the touchscreen to work ..Initially thought the display was faulty but had a secind brand new display , same model and type and it exhibited the same issues ..The best zi can figure is the firmware that initially gets loaded is different from the model revision from the rev "E" to the rev "F"..have you managed to push up the firmware load from buydisplay up to the card ?
    Apr 2020
    116
    ive not had much time to , get back to it yet ...I was hoping the there would be a patch available or a library update on github ..regrettably , Ive not had "time" to really work through it ...
    Nov 2015
    Cold hollow VT
    187
    Quote Originally Posted by Keith_M View Post
    As stated in #6 above I have modified the BuyDisplay code example given fro the Arduino DUE. My mod uses the SumoToy RA8875 driver contained in Teensyduino along with different pin assignments. I attached it to post #6. Change the pin defines at the top to reflect the pins that you use for SPI and I2C (to connect the display) and in >void setup< for the I2C and SPI startup definitions. This worked for me and I now get at least 5 finger touch points across the whole screen. I'm doing this on a Teensy 3.5
    This is not currently a driver as we know it, but it does give me a starting point to figure out how to fix up the wolfmanjm or skallwar driver packages. I've had my display about 1-year and it does work with this demo code I posted here.
    Apr 2020
    116
    Quote Originally Posted by grease_lighting View Post
    I'll run up your sketch this weekend and see how it goes..will post back ..
    Thank-you for all the hard work and sleuthing to get it going ...!!
    cheers
    Apr 2020
    116
    A big thank-you to Greased Lightning ..Ive been struggling with the gsl1680 touch code , and he managed to get me up and running...Ive been on another project and only found today to give it a good go ! Again thankyou very much !
    I do find it bizarre that you need to load all those lines of code to support the firmware to use the touch ..but its running.? So my 2 5" screens will no longer be collecting dust ..
    May 2017
    Netherlands
    139
    The RA8875 5" with GSL1680 controller is quite simple, build many projects with this RA8875 display.
    Best regards,
    Johan
    #include <RA8875.h>
    #include <GSL1680.h>
    #define TC_INT   8
    // install : ILI9341_fonts-master
    #include "font_LiberationMono.h"
    #include "font_DroidSansMono.h"
    #include "font_AwesomeF000.h"
    #include "font_AwesomeF200.h"
    #include "font_AwesomeF180.h"
    #include "font_AwesomeF100.h"
    #include "font_AwesomeF080.h"
    uint16_t buttons_time =100;
    #define WAKE 255
    GSL1680 TS = GSL1680();
    uint16_t TouchY;
    uint16_t TouchX;
    bool     TouchZ = false;
    #define RA8875_RESET 255    //Not used
    #define RA8875_CS 10
    RA8875 tft = RA8875(RA8875_CS, RA8875_RESET, 11, 13, 12);   // 11=MOSI   13=SCLK   12=MISO  10=CS
      tft.begin(RA8875_800x480);
      tft.setRotation(0);
      tft.setCursor(200,350);
      tft.setFont(DroidSansMono_16);
      tft.print("Touch test wait for I2C bus");
      delay(3500); // time for I2C bus
      TS.begin(-1, TC_INT);
      tft.clearScreen();
        tft.setCursor(200,250);
        tft.print(TouchX);
        tft.print(TouchY);
     if (digitalRead(TC_INT) == HIGH) {
        int NBFinger = TS.dataread();
        for (int i = 0; i < NBFinger; i++) {
          TouchX  = (TS.readFingerX(i));
          TouchY  = (TS.readFingerY(i));
      TouchZ = TS.dataread();
    Apr 2020
    116
    Quote Originally Posted by pd0lew View Post
    Best regards,
    Johan
    #include <RA8875.h>
    #define TC_INT   8
    #define WAKE 255
    uint16_t TouchY;
    uint16_t TouchX;
      tft.setRotation(0);
      tft.clearScreen();
        tft.print(TouchX);
        tft.print(TouchY);
    I did manage to get the touch panel to work .. but the problem being only 800 X 200 pixels of the panel were supporting touch .. half of the screen would not respond . I could get the panel to work ..and the touch working but I could not get the touch to work over the full 800 X 480 pixel display .. Only half of it
    May 2017
    Netherlands
    139
    Hi Keith, do you have a 800x480 display? please look at the backside if it shows E257834 than you are good!
    Best,
    Johan
    Apr 2020
    116
    I'm going to take another shot at the gsl1680 ... and try the code you have posted ... I was able to get touch to work but only half the screen was responding.. Thankyou for posting up ..
    Where did you get the font libraries in your code?
    Nov 2015
    Cold hollow VT
    187
    @Keith_M Would you please clarify the <half of screen. . . . > Is that like top/bottom half or every other one, (even/odd lines only)? I'm doing a Teensy 3.5 project and will look at that.
    May 2017
    Netherlands
    139
    Keith, please confirm if you have a E257834 display, because there are also 480x272 displays from Buydisplay.
    The font library is ILI9341_fonts-master and have the font Awesome.
    Best,
    Johan
    May 2017
    Netherlands
    139
    Two screens, a 5" with GSL1680 controller and a 7" with FT5206 controller both displays are awesome.
    JohanClick image for larger version.
Name:	it's achoice .jpg
    Nov 2015
    Cold hollow VT
    187
    Things I notice using the GSL1680 touch screen.
    The GSL1680 touch chip is only a touch sensor. It does not encode pressure information .
    When detecting more than 1 finger information, position matters. Say I'm touching the screen with two fingers. Place one in the middle, don't move it, and the other is sweeping along the wide axis of the display. The X and Y values will swap depending on where the second finger is in relation to the first one. Could this explain what @Keith_M is observing?
    The GSL chip is not programmed to detect gestures.
    I'm not looking for these fancy functions in my application, so this display suits my needs.
    @Keith_M Skallwar = ESTBLC (https://github.com/Skallwar/GSL1680)
    @grease_lighting Are you referring to this line? If yes there should be a problem because on the second iteration of the loop, the transition will have already been terminated.
    It is the other way around
    The library used to work for my final year project but there was some I2C API change if I remember correctly
    I remember that getting the GSL1680 chip to work was a nightmare so please, if the library is not working, open an issue and you have a fix for it, open a pull request. I will happily create a new release with the fix. If one of you guys want to become a maintainer, please PM me
