Page 2 of 2 FirstFirst 1 2
Results 26 to 30 of 30
Thread: Teensy 4.1 How to start using DMA?
  1. #26
    Oct 2019
    177
    Just a quick update..
    After a few hours of going through documentation and experimenting, I finally found how to switch the timer output to pin #33
    I started by setting pin 33 to FlexPWM_PWM2_B00 output
    IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_07 = 1;
    Set PWM2_B00 lower value
    FLEXPWM2_SM0VAL5   = 6;
    Then enabled PWM2_B00
    FLEXPWM2_OUTEN		|= FLEXPWM_OUTEN_PWMB_EN( 1 );
    Next step is to implement the 16 bit color transfer to the DMA kickoff function and callback.
    Hopefully I can come back with some "good news" in the next few days when I find time to mess around with this a little more.
  2. #27
    Oct 2019
    177
    I want to stop the PWM in some cases to write simple 16 bit commands to the display, so I set the registers to stop the PWM and to set pin #33 back to a GPIO pin:
    FLEXPWM2_MCTRL    |= FLEXPWM_MCTRL_RUN( 0 ); // Turn off FLEXPWM
    FLEXPWM2_OUTEN    |= FLEXPWM_OUTEN_PWMB_EN( 0 ); //Disable FlexPWM2_B00 output
    IOMUXC_SW_MUX_CTL_PAD_GPIO_EMC_07 = 5; // set pin 33 back to GPIO4_IO07
    I then tried to toggle the pin high and low using digitalWrite/digitalWriteFast to toggle the WR line manually for a single write strobe but It's not doing anything.
    Also, I noticed that setting FLEXPWM_MCTRL_RUN( 0 ) an/or FLEXPWM_OUTEN_PWMB_EN( 0 ) does not stop the PWM, only changing the pin assignment in the MUX does - which is only doing half of what I want/need it to do.
    Can someone make sense of this for me?
  3. #28
    Quote Originally Posted by miciwan View Post
    the problem is that the manual is riddled with a lot of domain-specific lingo, and (at least for me, coming to uControllers for a different field) it required some time to actually connect some dots and understand what the authors meant by certain things. Also the sources are well documented and are a great reference
    I believe that it might be useful as an introduction to actually reading the reference manual - going over a particular use case and extracting the information needed for that from the docs.
    Miciwan, thank you for this. You provided a great contextual framework. Some one should promote you from "junior member" to "super helpful member".
  4. #29
    ...This puts your buffer into the RAM1 section of memory (TCM - Tightly Coupled Memory) which is not cached...
    Kurt, if you're working with something that uses DMA with repeated/ongoing transfers, and you want to minimize address/data bus contention (due to most of the 16 DMA channels actively doing similar ongoing transfers), would using the (TCM - Tightly Coupled Memory) be more efficient (than DMAMEM )?
  5. #30
    Mar 2021
    West London, UK
    9
    Working on a CCD line-array application, with external SPI ADCs.
    I am trying to adapt this DMA code to initiate an SPI transmit with a variable for a 16bit SPI transaction.
    The SPI receive is being delt with elsewhere (probably a second Teensy 4) so I don't need to wait for the returned data.
    Using flexPWM2, etc. as per miciwan's example.
    Changed the setup to:
    volatile uint32_t scan_count = 0;
    // configure DMA channels
    dmachannel.begin();
    dmachannel.source( scan_count );
    dmachannel.destination( LPSPI4_TDR );
    I then want to start and stop the DMA/SPI at certian points in an indexed loop, state-machine caled by flexPWM2 interrupt at 500kHz
    Start new loop
    Count a number of loop cycles to get to starting point
    dmachannel.enable();
    For a given number of further counts, transmit data at each PWM trigger
    SPI transmit
    At end of active counts, stop DMA
    dmachannel.disable();
    Incriment position
    scan_count++;
    Loop until external trigger resets state-machine.
    I know I am missing something obvious here, any pointers would be appreciated.
    Many thanks.
