Results 1 to 2 of 2
Thread: No PC speaker audio from Teensy 3.2
    I have my Teensy 3.2 programmed with a simple sine generator (Audio Library) connected to the Usb output. On my Windows 10 computer, I have a program called "Soundcard Scope". I have all the Input setup options set to "Digital Audio Interface Teensy" and all the Output setup options set to my PC sound speaker output. I can receive input audio from the Teensy and see it on the Soundcard Scope but I don't get any output on the PC speakers. All other PC sound functions work. If I set up the PC Soundcard Scope's internal signal generator to output a tone, I do hear it. I've tried deleting and reinstalling drivers and moving to a different port.
    Suggestions?
    Joe
    Jun 2018
    126
    Did you try enabling "listen to this devive" (or similar) on the teensy soundcard settings? It sounds like that's what you are looking for.
    Control panel>sound>recording>teensy>listen to this device checkbox. (Guessing without looking).
    This will add latency.
