Results 1 to 3 of 3
Thread: Nintendo 64 Controller Emulator with USB Host with Teensy4.1
    Sep 2020
    8
    I made a project that emulates the controllers for the Nintendo 64 and allows you to use USB controllers in their place
    If you're familiar with the Nintendo64 console, it can also emulate all the official peripherals that would go into the controller. (Memory pack, Transfer Pak, Rumble Pak)
    It uses the Teensy4.1 and takes advantage of the USB Host driver, 2 x PSRAM chips with a fully memory allocator and SD Card with FATFS driver.
    Alot of the RAM is actively used to simulate the Nintendo peripherals.
    The project is on my repo https://github.com/Ryzee119/usb64
    Sep 2020
    Port Reeding
    1
    Great job, will check it out!
    May 2018
    196
    This is a great idea! What about a Dreamcast version with vmu on a little lcd ?
