Nintendo 64 Controller Emulator with USB Host with Teensy4.1
I made a project that emulates the controllers for the Nintendo 64 and allows you to use USB controllers in their place
If you're familiar with the Nintendo64 console, it can also emulate all the official peripherals that would go into the controller. (Memory pack, Transfer Pak, Rumble Pak)
It uses the Teensy4.1 and takes advantage of the USB Host driver, 2 x PSRAM chips with a fully memory allocator and SD Card with FATFS driver.
Alot of the RAM is actively used to simulate the Nintendo peripherals.
The project is on my repo https://github.com/Ryzee119/usb64
Great job, will check it out!
This is a great idea! What about a Dreamcast version with vmu on a little lcd ?
- You may not post replies
- You may not edit your posts
Forum Rules
