Results 1 to 12 of 12
Thread: Teensy Integration with the Arduino Pro IDE
    PaulStoffregen can you comment?
    23,001
    I can only confirm I can currently *not* working on Arduino Pro IDE support.
    Ok thanks for the info. Is there an IDE that supports debugging on a teensy?
    12,668
    There is a GDB thread for TeensyDebug
    Not sure what you mean, what is a GDB thread?
    23,001
    In this case, "thread" means a topic of conversation on this forum. Utterly unrelated to anything like multi-threaded programming.
    12,668
    Indeed :: pjrc.com/threads/61373-Using-GDB-with-Teensy-without-hardware-debugger-first-Beta
    Just a forum search for "GDB" - finds that 'thread'
    ok is this for Visual Micro? So do I need to search this forum for GDB for TeensyDebug?
    12,668
    Crossposted ... forum search on either would get there as linked above
    Ok I added the vMicro extension to VS. How do i get the teensy 3.2 board installed as an option board?
    12,668
    Visual Micro can be used - @KurtE did it posted somewhere - but the library in that thread works with just the IDE as well. Using Visual Micro is an extra step - adds more features not tried here
