Results 1 to 9 of 9
Thread: Draw filter curves on the display
    I am bad at arithmetic. That's why I need some support to draw filter curves on the display. I found an example and changed something. The curve looks like a low pass with a strong response. I need the waveform for some filters such as LowPass, BandPass and HighPass.
    My example of drawing a LowPass
    // draw_filter_curves
    void draw_filter_curves (void)
    	/* Original calculation
    	 uint8_t x = 80;
    	 uint8_t y = 50;
    	 uint8_t cx = 80;
    	 uint8_t cy = 80;
    	 int rx	= 10;
    	 int ry = 10;
    	 for (float i = 0; i < 1 * pi; i += .05) {
    		 x = cx + sin(i) * rx;
    		 y = cy + cos(i) * ry;
    		 disp.drawPixel(x, y, ST7735_WHITE);
    	// my calculation for an LowPass with strong resonance
    	uint8_t x = 80;
    	uint8_t y = 50;
    	uint8_t cx = 80;
    	uint8_t cy = 80;
    	int rx	= -10;
    	int ry = -15;
    		y = cx + sin(i) * ry;
    		x = cy + log(i) * rx;
    		disp.drawPixel(160 - x, y, ST7735_WHITE);
    Draw on Display
    Thanks for help
    Jul 2020
    466
    Filter responses are calculated from the poles and zeroes of the filter. Are we talking about
    analog filters or digital?
    They are digital filters. The filter curve is only symbolic and is controlled by the parameters Cutoff and Resonance.
    Jul 2020
    466
    Then you need to have your frequency variable i, and cos and sin to convert that into position on the unit circle,
    all that remains is to evaluate that z value for all the poles and zeroes, multiply by the overall gain factor to get the
    response for an arbitrary filter. This is direct application of the filter's equation (a rational in z).
    Thanks for your information. It's complicated.
    Jul 2020
    466
    Actually its complex (maths joke...)
    Feb 2020
    Dublin, Ireland
    46
    You'll find code to calculate biquad filter response here:
    https://forum.juce.com/t/draw-freque...nction/20669/2
    Hi Alan
    I wrote my own code. The basis is a special sine table for drawing the filter curve.
    // draw_filter_curves to LCD
    	// clear old curve
    	disp.fillRect(20,48,112,38,ST7735_BLACK);
    	// draw filter lowpass curve ------------------------------------------
    		const uint8_t x_plot = 68;
    		const uint8_t y_plot = 85;
    		uint8_t x = 40;
    		uint16_t r = 0;
    		uint8_t y = 0;
    		uint8_t y_ = 0;
    		uint8_t i = 0;
    		uint8_t i_ = 0;
    		uint8_t q_typ = 12;			// Filter Q
    		uint16_t resonance = 0;
    		// pot_1 cutoff value
    		// pot_2 resonancy
    		for (i = 0; i < 48; i++)
    			resonance = (Filter_curve[(i * 8)]);
    			resonance = (((resonance >> 2) * pot_2) >> 7);
    			r = (x + r - y) + resonance;
    			y = r / q_typ;
    			disp.drawLine((pot_1 / 2) + x_plot - i_,(y_plot - y_ / 2), (pot_1 / 2) + x_plot - i, (y_plot - y / 2),ST7735_RED);
    			i_ = i;
    			y_ = y;
    		disp.drawLine(20, (y_plot - y_ / 2), 20 + (pot_1 / 2), (y_plot - y_ / 2), ST7735_RED);
    // Sine filter curv ----------------------------
    const byte Filter_curve[385] PROGMEM = {
    	1,      2,      2,      3,      2,      3,      3,      4,
    	5,      4,      7,      5,      9,      7,     10,     11,
    	11,     13,     13,     17,     16,     18,     21,     21,
    	23,     25,     27,     28,     32,     31,     36,     36,
    	39,     41,     43,     46,     48,     51,     53,     55,
    	57,     62,     63,     65,     70,     70,     75,     76,
    	81,     82,     85,     89,     92,     94,     97,    100,
    	104,    107,    109,    112,    116,    119,    122,    124,
    	129,    130,    135,    137,    140,    144,    147,    148,
    	154,    155,    158,    163,    163,    169,    169,    174,
    	177,    178,    182,    185,    187,    191,    192,    195,
    	199,    200,    203,    205,    209,    210,    212,    216,
    	216,    220,    221,    223,    226,    227,    230,    230,
    	233,    235,    235,    239,    238,    241,    242,    243,
    	245,    245,    246,    249,    247,    251,    249,    252,
    	251,    252,    253,    253,    253,    254,    254,    254,
    	253,    255,    254,    253,    253,    254,    252,    253,
    	251,    251,    250,    250,    248,    248,    246,    246,
    	245,    242,    243,    240,    239,    238,    236,    234,
    	233,    231,    230,    226,    226,    224,    221,    219,
    	217,    215,    212,    211,    208,    206,    202,    201,
    	198,    196,    192,    190,    188,    184,    182,    179,
    	177,    173,    170,    168,    164,    162,    158,    156,
    	153,    149,    147,    143,    141,    136,    135,    131,
    	128,    125,    122,    118,    116,    113,    109,    106,
    	104,    101,     96,     95,     92,     88,     85,     83,
    	80,     77,     74,     71,     69,     66,     63,     61,
    	57,     56,     53,     50,     49,     45,     43,     42,
    	38,     37,     35,     32,     31,     29,     26,     26,
    	22,     22,     20,     19,     16,     16,     13,     14,
    	11,     10,     10,      8,      8,      6,      6,      5,
    	4,      5,      2,      3,      2,      2,      2,      3,
    	0,		0,		0,		0,		0,		0,		0,		0,
    	0,
    A little video of my synth project: https://youtu.be/ffCMaR70G6g
    Sound from my Handy (not so nice).
    Greetings Rolf
    Thanks for the link. Its very intresting
