I am in the process of transferring my project on my arduino due to the Teensy 4.1.
One of the main reasons for this is the memory usage of my sketch.
If I compare the memory usage of the sketch between the Due and the Teensy, the Teensy uses only 6% against 64% on the Due.
That is the good news, however, the compiler indicates that global variables use 78% of the dynamic memory.
Unfortunately, the compiler does not indicate this consumption for the Due, but I expected that I would have much more memory left with the Teensy. Or am I missing something ? And can extra psram mean anything ?
