chunkman20
Hi all,
I recently purchased a Teensy 4.1 to use as a data logger for a research project. I'd like to read 4-5 analog pins at 4000 Hz or greater and store the data to an SD card.
I have the latest version of SdFat-beta. I ran the TeensySdioDemo on the Teensy w/FIFO SDIO. Here are the results.
Everything seems fast, but I can't get the ExFatLogger sketch to work. When I try and use ExFatLogger, it says "Type any character to begin" and then hangs when I type a character. I changed the sd.begin(SD_CONFIG) statement to sd.begin(SdioConfig(FIFO_SDIO)) which I found in the TeensySdioDemo.
If I comment out the line printUnusedStack(), the logger runs but I can't reduce the sampling interval below 2000 us without it stopping.
I can get the program working at 1000 Hz sampling rate, but from what I've heard on the forums a Teensy 4.1 should definitely be capable of much higher sampling rates.
I'm using a Sandisk 32gb Ultra Plus micro SD card.
Please let me know if you need any more information - here's the code that I modified.
// Example to demonstrate write latency for preallocated exFAT files.
// I suggest you write a PC program to convert very large bin files.
// If an exFAT SD is required, the ExFatFormatter example will format
// smaller cards with an exFAT file system.
// The maximum data rate will depend on the quality of your SD,
// the size of the FIFO, and using dedicated SPI.
#include "SdFat.h"
#include "FreeStack.h"
#include "ExFatLogger.h"
// This example was designed for exFAT but will support FAT16/FAT32.
// Note: Uno will not support SD_FAT_TYPE = 3.
// SD_FAT_TYPE = 0 for SdFat/File as defined in SdFatConfig.h,
// 1 for FAT16/FAT32, 2 for exFAT, 3 for FAT16/FAT32 and exFAT.
#define SD_FAT_TYPE 2
// Interval between data records in microseconds.
// Try 250 with Teensy 3.6, Due, or STM32.
// Try 2000 with AVR boards.
// Try 4000 with SAMD Zero boards.
const uint32_t LOG_INTERVAL_USEC = 2000;
// Set USE_RTC nonzero for file timestamps.
// RAM use will be marginal on Uno with RTClib.
#define USE_RTC 0
#if USE_RTC
#include "RTClib.h"
#endif // USE_RTC
// LED to light if overruns occur.
#define ERROR_LED_PIN -1
Change the value of SD_CS_PIN if you are using SPI and
your hardware does not use the default value, SS.
Common values are:
Arduino Ethernet shield: pin 4
Sparkfun SD shield: pin 8
Adafruit SD shields and modules: pin 10
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = SS;
#else // SDCARD_SS_PIN
// Assume built-in SD is used.
const uint8_t SD_CS_PIN = SDCARD_SS_PIN;
#endif // SDCARD_SS_PIN
// FIFO SIZE - 512 byte sectors. Modify for your board.
#ifdef __AVR_ATmega328P__
// Use 512 bytes for 328 boards.
#define FIFO_SIZE_SECTORS 1
#elif defined(__AVR__)
// Use 2 KiB for other AVR boards.
#define FIFO_SIZE_SECTORS 4
#else // __AVR_ATmega328P__
// Use 8 KiB for non-AVR boards.
#define FIFO_SIZE_SECTORS 16
#endif // __AVR_ATmega328P__
// Preallocate 1GiB file.
const uint32_t PREALLOCATE_SIZE_MiB = 1024UL;
// Select the fastest interface. Assumes no other SPI devices.
#if ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI)
#else // ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI)
#endif // ENABLE_DEDICATED_SPI
// Save SRAM if 328.
#include "MinimumSerial.h"
MinimumSerial MinSerial;
#define Serial MinSerial
// Replace logRecord(), printRecord(), and ExFatLogger.h for your sensors.
void logRecord(data_t* data, uint16_t overrun) {
if (overrun) {
// Add one since this record has no adc data. Could add overrun field.
overrun++;
data->adc[0] = 0X8000 | overrun;
for (size_t i = 0; i < ADC_COUNT; i++) {
data->adc[i] = analogRead(i);
void printRecord(Print* pr, data_t* data) {
static uint32_t nr = 0;
if (!data) {
pr->print(F("LOG_INTERVAL_USEC,"));
pr->println(LOG_INTERVAL_USEC);
pr->print(F("rec#"));
pr->print(F(",adc"));
pr->print(i);
pr->println();
nr = 0;
return;
if (data->adc[0] & 0X8000) {
uint16_t n = data->adc[0] & 0X7FFF;
nr += n;
pr->print(F("-1,"));
pr->print(n);
pr->println(F(",overuns"));
pr->print(nr++);
pr->write(',');
pr->print(data->adc[i]);
pr->println();
const uint64_t PREALLOCATE_SIZE = (uint64_t)PREALLOCATE_SIZE_MiB << 20;
// Max length of file name including zero byte.
#define FILE_NAME_DIM 40
// Max number of records to buffer while SD is busy.
const size_t FIFO_DIM = 512*FIFO_SIZE_SECTORS/sizeof(data_t);
#if SD_FAT_TYPE == 0
typedef SdFat sd_t;
typedef File file_t;
#elif SD_FAT_TYPE == 1
typedef SdFat32 sd_t;
typedef File32 file_t;
#elif SD_FAT_TYPE == 2
typedef SdExFat sd_t;
typedef ExFile file_t;
#elif SD_FAT_TYPE == 3
typedef SdFs sd_t;
typedef FsFile file_t;
#else // SD_FAT_TYPE
#error Invalid SD_FAT_TYPE
#endif // SD_FAT_TYPE
sd_t sd;
file_t binFile;
file_t csvFile;
// You may modify the filename. Digits before the dot are file versions.
char binName[] = "ExFatLogger00.bin";
#if USE_RTC
RTC_DS1307 rtc;
// Call back for file timestamps. Only called for file create and sync().
void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
DateTime now = rtc.now();
// Return date using FS_DATE macro to format fields.
*date = FS_DATE(now.year(), now.month(), now.day());
// Return time using FS_TIME macro to format fields.
*time = FS_TIME(now.hour(), now.minute(), now.second());
// Return low time bits in units of 10 ms.
*ms10 = now.second() & 1 ? 100 : 0;
#endif // USE_RTC
#define error(s) sd.errorHalt(&Serial, F(s))
#define dbgAssert(e) ((e) ? (void)0 : error("assert " #e))
// Convert binary file to csv file.
void binaryToCsv() {
uint8_t lastPct = 0;
uint32_t t0 = millis();
data_t binData[FIFO_DIM];
if (!binFile.seekSet(512)) {
error("binFile.seek faile");
uint32_t tPct = millis();
printRecord(&csvFile, nullptr);
while (!Serial.available() && binFile.available()) {
int nb = binFile.read(binData, sizeof(binData));
if (nb <= 0 ) {
error("read binFile failed");
size_t nr = nb/sizeof(data_t);
for (size_t i = 0; i < nr; i++) {
printRecord(&csvFile, &binData[i]);
if ((millis() - tPct) > 1000) {
uint8_t pct = binFile.curPosition()/(binFile.fileSize()/100);
if (pct != lastPct) {
tPct = millis();
lastPct = pct;
Serial.print(pct, DEC);
Serial.println('%');
csvFile.sync();
if (Serial.available()) {
csvFile.close();
Serial.print(F("Done: "));
Serial.print(0.001*(millis() - t0));
Serial.println(F(" Seconds"));
void createBinFile() {
binFile.close();
while (sd.exists(binName)) {
char* p = strchr(binName, '.');
if (!p) {
error("no dot in filename");
while (true) {
p--;
if (p < binName || *p < '0' || *p > '9') {
error("Can't create file name");
if (p[0] != '9') {
p[0]++;
p[0] = '0';
if (!binFile.open(binName, O_RDWR | O_CREAT)) {
error("open binName failed");
Serial.println(binName);
if (!binFile.preAllocate(PREALLOCATE_SIZE)) {
error("preAllocate failed");
Serial.print(F("preAllocated: "));
Serial.print(PREALLOCATE_SIZE_MiB);
Serial.println(F(" MiB"));
bool createCsvFile() {
char csvName[FILE_NAME_DIM];
if (!binFile.isOpen()) {
Serial.println(F("No current binary file"));
return false;
// Create a new csvFile.
binFile.getName(csvName, sizeof(csvName));
char* dot = strchr(csvName, '.');
if (!dot) {
strcpy(dot + 1, "csv");
if (!csvFile.open(csvName, O_WRONLY | O_CREAT | O_TRUNC)) {
error("open csvFile failed");
serialClearInput();
Serial.print(F("Writing: "));
Serial.print(csvName);
Serial.println(F(" - type any character to stop"));
return true;
void logData() {
int32_t delta; // Jitter in log time.
int32_t maxDelta = 0;
uint32_t maxLogMicros = 0;
uint32_t maxWriteMicros = 0;
size_t maxFifoUse = 0;
size_t fifoCount = 0;
size_t fifoHead = 0;
size_t fifoTail = 0;
uint16_t overrun = 0;
uint16_t maxOverrun = 0;
uint32_t totalOverrun = 0;
uint32_t fifoBuf[128*FIFO_SIZE_SECTORS];
data_t* fifoData = (data_t*)fifoBuf;
// Write dummy sector to start multi-block write.
dbgAssert(sizeof(fifoBuf) >= 512);
memset(fifoBuf, 0, sizeof(fifoBuf));
if (binFile.write(fifoBuf, 512) != 512) {
error("write first sector failed");
serialClearInput();
Serial.println(F("Type any character to stop"));
// Wait until SD is not busy.
while (sd.card()->isBusy()) {}
// Start time for log file.
uint32_t m = millis();
// Time to log next record.
uint32_t logTime = micros();
while (true) {
// Time for next data record.
logTime += LOG_INTERVAL_USEC;
// Wait until time to log data.
delta = micros() - logTime;
if (delta > 0) {
Serial.print(F("delta: "));
Serial.println(delta);
error("Rate too fast");
while (delta < 0) {
if (fifoCount < FIFO_DIM) {
uint32_t m = micros();
logRecord(fifoData + fifoHead, overrun);
m = micros() - m;
if (m > maxLogMicros) {
maxLogMicros = m;
fifoHead = fifoHead < (FIFO_DIM - 1) ? fifoHead + 1 : 0;
fifoCount++;
if (overrun) {
if (overrun > maxOverrun) {
maxOverrun = overrun;
overrun = 0;
totalOverrun++;
overrun++;
if (overrun > 0XFFF) {
error("too many overruns");
if (ERROR_LED_PIN >= 0) {
digitalWrite(ERROR_LED_PIN, HIGH);
// Save max jitter.
if (delta > maxDelta) {
maxDelta = delta;
// Write data if SD is not busy.
if (!sd.card()->isBusy()) {
size_t nw = fifoHead > fifoTail ? fifoCount : FIFO_DIM - fifoTail;
// Limit write time by not writing more than 512 bytes.
const size_t MAX_WRITE = 512/sizeof(data_t);
if (nw > MAX_WRITE) nw = MAX_WRITE;
size_t nb = nw*sizeof(data_t);
uint32_t usec = micros();
if (nb != binFile.write(fifoData + fifoTail, nb)) {
error("write binFile failed");
usec = micros() - usec;
if (usec > maxWriteMicros) {
maxWriteMicros = usec;
fifoTail = (fifoTail + nw) < FIFO_DIM ? fifoTail + nw : 0;
if (fifoCount > maxFifoUse) {
maxFifoUse = fifoCount;
fifoCount -= nw;
Serial.print(F("\nLog time: "));
Serial.print(0.001*(millis() - m));
binFile.truncate();
binFile.sync();
Serial.print(("File size: "));
// Warning cast used for print since fileSize is uint64_t.
Serial.print((uint32_t)binFile.fileSize());
Serial.println(F(" bytes"));
Serial.print(F("totalOverrun: "));
Serial.println(totalOverrun);
Serial.print(F("FIFO_DIM: "));
Serial.println(FIFO_DIM);
Serial.print(F("maxFifoUse: "));
Serial.println(maxFifoUse);
Serial.print(F("maxLogMicros: "));
Serial.println(maxLogMicros);
Serial.print(F("maxWriteMicros: "));
Serial.println(maxWriteMicros);
Serial.print(F("Log interval: "));
Serial.print(LOG_INTERVAL_USEC);
Serial.print(F(" micros\nmaxDelta: "));
Serial.print(maxDelta);
Serial.println(F(" micros"));
void openBinFile() {
char name[FILE_NAME_DIM];
serialClearInput();
Serial.println(F("Enter file name"));
if (!serialReadLine(name, sizeof(name))) {
return;
if (!sd.exists(name)) {
Serial.println(name);
Serial.println(F("File does not exist"));
return;
binFile.close();
if (!binFile.open(name, O_RDONLY)) {
Serial.println(F("open failed"));
return;
Serial.println(F("File opened"));
void printData() {
return;
// Skip first dummy sector.
error("seek failed");
serialClearInput();
Serial.println(F("type any character to stop\n"));
printRecord(&Serial, nullptr);
while (binFile.available() && !Serial.available()) {
data_t record;
if (binFile.read(&record, sizeof(data_t)) != sizeof(data_t)) {
printRecord(&Serial, &record);
void printUnusedStack() {
#if HAS_UNUSED_STACK
Serial.print(F("\nUnused stack: "));
Serial.println(UnusedStack());
#endif // HAS_UNUSED_STACK
void serialClearInput() {
do {
delay(10);
} while (Serial.read() >= 0);
bool serialReadLine(char* str, size_t size) {
size_t n = 0;
while(!Serial.available()) {
yield();
while (true) {
int c = Serial.read();
if (c < ' ') break;
str[n++] = c;
if (n >= size) {
Serial.println(F("input too long"));
return false;
while (!Serial.available() && (millis() - m) < 100){}
if (!Serial.available()) break;
str[n] = 0;
return true;
void testSensor() {
const uint32_t interval = 200000;
int32_t diff;
data_t data;
serialClearInput();
Serial.println(F("\nTesting - type any character to stop\n"));
while (!Serial.available()) {
m += interval;
do {
diff = m - micros();
} while (diff > 0);
logRecord(&data, 0);
printRecord(&Serial, &data);
pinMode(ERROR_LED_PIN, OUTPUT);
// Wait for USB Serial
while (!Serial) {
SysCall::yield();
Serial.println(F("Type any character to begin"));
yield();
FillStack();
#if !ENABLE_DEDICATED_SPI
Serial.println(F(
"\nFor best performance edit SdFatConfig.h\n"
"and set ENABLE_DEDICATED_SPI nonzero"));
#endif // !ENABLE_DEDICATED_SPI
Serial.print(FIFO_DIM);
Serial.println(F(" FIFO entries will be used."));
/* Initialize SD.
if (!sd.begin(SD_CONFIG)) {
sd.initErrorHalt(&Serial);
//Changed to SdioConfig(FIFO_SDIO)
if (!sd.begin(SdioConfig(FIFO_SDIO))) {
#if USE_RTC
if (!rtc.begin()) {
error("rtc.begin failed");
if (!rtc.isrunning()) {
// Set RTC to sketch compile date & time.
// rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
error("RTC is NOT running!");
// Set callback
FsDateTime::setCallback(dateTime);
#endif // USE_RTC
//printUnusedStack(); Commented out, program seems to hang here
// Read any Serial data.
serialClearInput();
digitalWrite(ERROR_LED_PIN, LOW);
Serial.println(F("type: "));
Serial.println(F("b - open existing bin file"));
Serial.println(F("c - convert file to csv"));
Serial.println(F("l - list files"));
Serial.println(F("p - print data to Serial"));
Serial.println(F("r - record data"));
Serial.println(F("t - test without logging"));
SysCall::yield();
char c = tolower(Serial.read());
if (c == 'b') {
openBinFile();
} else if (c == 'c') {
if (createCsvFile()) {
binaryToCsv();
} else if (c == 'l') {
Serial.println(F("ls:"));
sd.ls(&Serial, LS_DATE | LS_SIZE);
} else if (c == 'p') {
printData();
} else if (c == 'r') {
createBinFile();
logData();
} else if (c == 't') {
testSensor();
Serial.println(F("Invalid entry"));
