Eagle Schematic/library for the Teensy 3.2
I find those eagle libraries containing the components of the teensy 3.2 are hard to find, I've been using the library below, but it isn't that helpful, if anybody has any eagle files about the Teensy 3.2, please share it
Maybe you could make use of the libraries for Teensy 3.1? It's pretty much identical to Teensy 3.2 as far as those libraries are concerned, which is probably why nobody has bothered to make one called 3.2.
I will, but I haven't found an identical library that contains all the components of the 3.2/3.1 with the same footprints
