Results 1 to 6 of 6
Thread: Teensyduino 1.53 Compile error on Win7
    Oct 2020
    3
    I am using the Arduino IDE with Teensyduino 1.53 installed on Windows 7 machine and have selected as the board "Teensy 3.2/3.1". I declare some global short x1, y1, x2, y2; and assign y1 a value.
    I get the following error(s):
    C:\Users\don\Documents\Projects\Instructable Projects\Chess_Robot\Test_Programs\IDETest_Teensy3 .1\IDETest_Teensy3.1.ino:1:11: error: 'short int y1' redeclared as different kind of symbol
    In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/WProgram.h:36:0,
    from C:\Users\don\AppData\Local\Temp\arduino_build_5167 62\pch\Arduino.h:6:
    c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\math.h:539:15: note: previous declaration 'double y1(double)'
    extern double y1 _PARAMS((double));
    C:\Users\don\Documents\Projects\Instructable Projects\Chess_Robot\Test_Programs\IDETest_Teensy3 .1\IDETest_Teensy3.1.ino: In function 'void setup()':
    C:\Users\don\Documents\Projects\Instructable Projects\Chess_Robot\Test_Programs\IDETest_Teensy3 .1\IDETest_Teensy3.1.ino:5:8: error: assignment of function 'double y1(double)'
    y1 = 5;
    C:\Users\don\Documents\Projects\Instructable Projects\Chess_Robot\Test_Programs\IDETest_Teensy3 .1\IDETest_Teensy3.1.ino:5:8: error: cannot convert 'int' to 'double(double)' in assignment
    Error compiling for board Teensy 3.2 / 3.1.
    The following is the code:
        y1 = 5;
        while(1);
    Is this something I can fix or is there something in a library that is not properly scoped?
    Thanks, don
    1,429
    y1 is already defined by the math library (y1 is the name for a Bessel function). Therefore you can not declare a global variable with this name. It is the same as you would like to declare a global variable named sin, or cos, or exp...
    13,746
    Use a different name for "y1". That name is already spoken for and declared with a different type.
    With verbose compile it shows here as:
    T:\tCode\FORUM\VarConflict\VarConflict.ino:1:11: error: 'short int y1' redeclared as different kind of symbol
    In file included from T:\arduino-1.8.13\hardware\teensy\avr\cores\teensy4/WProgram.h:36:0,
                     from T:\TEMP\arduino_build_VarConflict.ino\pch\Arduino.h:6:
    t:\arduino-1.8.13\hardware\tools\arm\arm-none-eabi\include\math.h:539:15: note: previous declaration 'double y1(double)'
    T:\tCode\FORUM\VarConflict\VarConflict.ino: In function 'void setup()':
    T:\tCode\FORUM\VarConflict\VarConflict.ino:10:8: error: assignment of function 'double y1(double)'
         y1 = 5;
    T:\tCode\FORUM\VarConflict\VarConflict.ino:10:8: error: cannot convert 'int' to 'double(double)' in assignment
    Oct 2020
    3
    Thanks for the quick response. I was confused as this is the first time that I have used a Teensy with the Arduino IDE and when I compile the same program for an Arduino Mega, it compiles cleanly. I might have expected to have to include a math library to get that conflict. Well Thanks for the help and explanation of the error.
    1,429
    The Arduino IDE automatically includes Arduino.h. The error message defragster posted, shows that Arduino.h includes WProgram.h which includes math.h...
    Oct 2020
    3
    Ok, great, thanks for the detailed explanation. I'll just rename my variables.
