Page 5 of 5 FirstFirst ... 3 4 5
Results 101 to 108 of 108
Thread: malloc/free for EXTMEM and DTCM
  1. #101
    8,987
    Hi Frank,
    For me it is hard to say, I would probably go with a) as you have the white space.
    It is hard to know at times what information is needed or wanted an in what form.
    Example suppose you copy 20 bitmaps to a Flash memory chip that has LittleFS on it, and maybe the flash is getting full?
    Do you want to know how big each file is? many times yes. As if I copy a bitmap from one media to another, you want to know how many bytes there are. Likewise when you open the file you may want to verify the bitmap by knowing the size of file versus header information.
    But other times, like why I am I running out of space. Maybe you want/need to know how much disk space does that file consume.
  2. #102
    Germany
    8,280
    Hi Kurt, I think FS are out of the scope of this tool.
    If the files are added as PROGMEM Const, they are included.
    And it can only know what is fixed at compiletime.
    I've added a stack warning if 99% of RAM1 is used (see code)
    Windows-exe is updated, but I didn't bother updating the Linux-versions..
  3. #103
    13,907
    Version a) looks good - if that isn't clear at least it makes it easy to refer to if a problem is posted.
  4. #104
    8,987
    Sorry I did not want to imply that the File system information should be included here as again this tool would not know anything.
    I was trying to mention it as an analogy of the code:
    You see that the code takes: 5.89 kB
    of Memory, but it actually consumes 32KB of RAM1...
    The majority of the time a user may not care. BUT: if they are running low on RAM1, and their code is 32KB + 10 bytes, They can gain 32KB of data space if the probably mark one function as FLASHMEM. Again not overly intuitive.
    Also somehow here and/or T4.x product page or memory details page, may want to again a section, on transitioning a T3.x program to a T4. Why do I have less memory...
    Again likewise on T3.x when you mark a large array as const, the data does not consume the RAM. To do this on T4.x you need to mark that data as PROGMEM...
    Again outside scope of the tool.
  5. #105
    Germany
    8,280
    Kurt, maybe a runtime memInfo() would be good to have in the core.
    (As this was not the first time I pressed the wrong button without realizing it, I think about removing the "+" from my account... we have no spam anymore...)
    Edit: Linux- 32Bit and 64Bit variants on Github updated, as well as Windows. More details in Post #85
  6. #106
    13,907
    LFSintegrity show this - pretty near an EDGE case 64KB to 96 KB ITCM:
    RAM1:  22.79% of 512 kB used.
       Code (ITCM, 32 kB Blocks):   65.71 kB
       Variables (DTCM):            20.69 kB
       Available for Variables:    395.31 kB
    RAM2:   2.36% of 512 kB used.
       Variables (DMAMEM):          12.09 kB
       Available for Heap:         499.91 kB
    EXTMEM: not used.
    FLASH:   1.11% of 7936 kB used.
       Code and Constants:          88.13 kB
    So having to do MATH (and assume the last digit) I see I broke into block @3 of ITCM for 1752 bytes of code.
    And marking :: FLASHMEM void setup() {
    Code (ITCM, 32 kB Blocks): 65.48 kB
    Another small func down a few bytes - Still 96KB : FLASHMEM void makeRootDirs() {
    Code (ITCM, 32 kB Blocks): 65.43 kB
    And another small func down a few bytes - Still 96KB : FLASHMEM void printDirectory() {
    Code (ITCM, 32 kB Blocks): 64.93 kB
    Moving three printf strings as F() actually adds code. Is the F() code larger than a simple string?
    Code (ITCM, 32 kB Blocks): 64.99 kB
    Took the F() strings out of the added @mjs513 speedBench() code and it did not change:.
    Opps - So the math works out - knowing how to do it ... which I was WRONG on as the kB's are really 1024 sets of bytes. thought I was aiming to get below 65536 Bytes, not
    NOTE this agrees with the LINKER/build output:
    Memory region         Used Size  Region Size  %age Used
                ITCM:         96 KB       512 KB     18.75%
                DTCM:       21184 B       512 KB      4.04%
                 RAM:       12384 B       512 KB      2.36%
               FLASH:       90436 B      7936 KB      1.11%
                ERAM:          0 GB        16 MB      0.00%
    Okay putting the speedBench() to FLASHMEM:
    RAM1:  16.54% of 512 kB used.
       Code (ITCM, 32 kB Blocks):   62.57 kB
       Available for Variables:    427.31 kB
    EXTMEM: not used.
    Then undoing the other func()'s from FLASHMEM:
       Code (ITCM, 32 kB Blocks):   63.35 kB
    EXTMEM: not used.
       Code and Constants:          88.27 kB
  7. #107
    Germany
    8,280
    I've added exidx to the calculation, it was missing.
    However you might see no difference, due to the rounding to kB.
  8. #108
    24,075
    Quick followup to this old thread, 1.47-beta7 adds more detailed printing of memory usage. It does most but not all of the things discussed here.
    This is the source code:
    https://github.com/PaulStoffregen/teensy_size
